  4. Linux/Debian - Grafana-Repo muss aktualisiert werden
151 Beiträge 23 Kommentatoren 48.5k Aufrufe 22 Beobachtet
  • M Marty56
    Danke an alle.
    Warum muss Linux immer so eine fürchterlichere Frickelei sein?!
    Ich verstehe das nicht.
    Ich habe die Befehle vom ersten Post eingetippt.
    Und bekomme jetzt folgenden Output.
    Hit:1 http://security.debian.org bullseye-security InRelease
    Hit:2 http://ftp.debian.org/debian bullseye InRelease
    Hit:3 http://ftp.debian.org/debian bullseye-updates InRelease
    Get:4 https://packages.grafana.com/oss/deb stable InRelease [5984 B]
    Get:5 https://repos.influxdata.com/debian bullseye InRelease [7022 B]
    Get:6 https://apt.grafana.com stable InRelease [5984 B]
    Hit:7 https://deb.nodesource.com/node_16.x bullseye InRelease
    Ign:8 https://apt.tvheadend.org/unstable bullseye InRelease
    Hit:9 https://apt.tvheadend.org/unstable bullseye Release
    Err:4 https://packages.grafana.com/oss/deb stable InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    Err:5 https://repos.influxdata.com/debian bullseye InRelease
      The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    Get:11 https://apt.grafana.com stable/main amd64 Packages [105 kB]
    Fetched 118 kB in 1s (80.5 kB/s)
    Reading package lists... Done
    4 packages can be upgraded. Run 'apt list --upgradable' to see them.
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://packages.grafana.com/oss/deb stable InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: https://repos.influxdata.com/debian bullseye InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    N: Skipping acquire of configured file 'main/binary-amd64/Packages' as repository 'https://apt.tvheadend.org/unstable bullseye InRelease' doesn't support architecture 'amd64'
    W: Failed to fetch https://packages.grafana.com/oss/deb/dists/stable/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 9E439B102CF3C0C6
    W: Failed to fetch https://repos.influxdata.com/debian/dists/bullseye/InRelease  The following signatures couldn't be verified because the public key is not available: NO_PUBKEY D8FF8E1F7DF8B07E
    W: Some index files failed to download. They have been ignored, or old ones used instead.
    apt-key list | grep -i grafana | wc -l
    Warning: apt-key is deprecated. Manage keyring files in trusted.gpg.d instead (see apt-key(8)).
    @marty56 sagte in Linux/Debian - Grafana-Repo muss aktualisiert werden:
    Moin,
    Zu 1: Das hat nichts mit Linux zu tun, sondern mit der Distribution und den 3rd. Party Software Hersteller, die versuchen zu verhinder, das schlechte Menschen, verseuchte Pakete auf Deinen PC installieren können. Jede Distribution kocht da leider ihr eigenes Süppchen.
    Zu 2. Dann musst Du dir mal ein gutes Buch zu Linux kaufen und lesen, dann wird vieles klar :)
    Zu 3. immer nur Befehle, die ein anderer hier eintippt blindlings zu kopieren und sich dann zu wundern wieso geht das bei mir nicht, ist auch nicht so klug.
    Hatte ich ja schon weiter oben geschrieben, Lesen (Bildet) dann nachdenken, dann handeln.
    Wenn Du auf die Seite von Grafana gehst, steht genau beschrieben was zu tun ist, um die neuen Signaturen in sein System zu bekommen.
    Bernd
      Moin,
      Bernd
      Marty56
      schrieb am zuletzt editiert von Marty56
      @dp20eic Sehr hilfreich. Leider habe ich überhaupt keinen Bock, Bücher über Linux zu lesen und Frickelkönig zu werden.
      HW:NUC (16 GB Ram)
      OS: Debian Bullseye, Promox V7, node v16.x npm 8.19.3
      ? Thomas BraunT ChaotC 3 Antworten Letzte Antwort
      -4
      • M Marty56
        Moin,
        ist doch eine Aussage, kann ich mit leben, ob Du damit leben kannst und ob Du mit dieser Einstellung Hilfe bekommst, kann ich Dir nur wünschen. Ich bin dann mal weg.
        Bernd
        • M Marty56
          Dann lass es bleiben und nerv andere nicht mit deinem Unwillen dich damit zu beschäftigen.
          Ich z.B. habe überhaupt keinen Bock so triviales Zeug Leuten zu erklären die es nicht wissen wollen. Setz besser ein Windows ein.
          Das Repo ist nach der obigen Anleitung und mit ein wenig Nachdenken in Nullkommanix richtig umgestellt. Hat gestern bei mir keine 10 Sekunden gedauert. Da war nix 'zu frickeln'.
          • M Marty56
            ChaotC Offline
            ChaotC Offline
            Chaot
            @marty56 Ich verstehe dein Problem nicht.
            Ich musste mich beim Übergang von win 3.1 auf Win 95 komplett neu damit befassen. Dann kam Win2000 was auch viele Eigenheiten hatte und dann die Umstellung auf Win7. Auch hier musste einiges komplett neu erlernt werden.
            Warum ist das bei Windows ok, aber bei Linux plötzlich böse?
            Wenn ich eine Software nutze muss ich mich halt damit beschäftigen damit ich sie richtig einsetzen kann. Das war schon bei PC-DOS so und wird auch bei Win 25 irgendwann so bleiben.
            Und Frickelkönig? Dann hast du noch nie einen Windows Server bearbeitet.
            • ? Offline
              Moin,
              lasst doch gut sein, es geht hier nur darum Grafana und zwischendurch auch mal influxDB nach der Singnaturänderung wieder ans Laufen zu bringen, alles andere ist vergebene Liebesmüh und bring hier gar nichts :)
              Bernd
                Moin,
                Bernd
                Marty56
                @dp20eic ganz meiner Meinung. Sorry, dass ich vom Thema abgewichen bin.
                HW:NUC (16 GB Ram)
                  @lessthanmore
                  Key löschen. Geht wie oben:
                  sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
                  Die /etc/apt/sources.list.d/influxdata.list löschen.
                  Aktuelles Setup für influxdb:
                  wget -q -O - https://repos.influxdata.com/influxdb.key | sudo gpg --dearmor -o /usr/share/keyrings/influxdb.gpg
                  export DISTRIB_ID=$(lsb_release -si); export DISTRIB_CODENAME=$(lsb_release -sc)
                  echo "deb [signed-by=/usr/share/keyrings/influxdb.gpg] https://repos.influxdata.com/${DISTRIB_ID,,} ${DISTRIB_CODENAME} stable" | sudo tee /etc/apt/sources.list.d/influxdb.list > /dev/null
                  shellyrulestheworld
                  Vielen Dank für deine Beiträge. Hab auch versucht influxdb umzustellen, wie von dir beschrieben.
                  Err:7 https://repos.influxdata.com/debian bullseye InRelease
                  Fetched 7,022 B in 3s (2,530 B/s)
                  All packages are up to date.
                  klappt aber leider nicht. Hab ich was vergessen?
                  mein vorgehen war folgendes:
                  apt-key list | grep -i influxdb | wc -l
                  sudo rm influxdb.list
                  • S shellyrulestheworld
                    @shellyrulestheworld
                    ls -lA /etc/apt/sources.list.d/
                    sudo apt update
                    sagt? Vollständig posten, nix weg lassen. Auch nicht das login prompt.
                      sudo apt update
                      shellyrulestheworld
                      @thomas-braun said in Linux/Debian - Grafana-Repo muss aktualisiert werden:
                      pi@raspberrypi:~ $ ls -lA /etc/apt/sources.list.d/
                      total 24
                      -rw-r--r-- 1 root root  60 Dec 23 10:10 deconz.list
                      -rw-r--r-- 1 root root  84 Jan 30 14:21 grafana.list
                      -rw-r--r-- 1 root root 101 Jan 30 15:05 influxdb.list
                      -rw-r--r-- 1 root root 208 Dec 23 09:34 nodesource.list
                      -rw-r--r-- 1 root root 398 Jan 11 16:11 ookla_speedtest-cli.list
                      -rw-r--r-- 1 root root 191 Sep 22 04:50 raspi.list
                      pi@raspberrypi:~ $ sudo apt update
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Hit:6 https://phoscon.de/apt/deconz bullseye InRelease
                      Hit:7 https://apt.grafana.com stable InRelease
                      Get:8 https://repos.influxdata.com/debian bullseye InRelease [7,022 B]
                      Hit:9 https://packagecloud.io/ookla/speedtest-cli/debian bullseye InRelease
                      Err:8 https://repos.influxdata.com/debian bullseye InRelease
                      Fetched 7,022 B in 2s (3,282 B/s)
                      pi@raspberrypi:~ $
                        total 24
                        pi@raspberrypi:~ $
                        sudo rm /etc/apt/sources.list.d/influxdb.list
                        wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                        echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                        echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                        sudo apt update
                        sudo apt full-upgrade
                        S hotspot_2H 2 Antworten Letzte Antwort
                          sudo apt update
                          shellyrulestheworld
                          ein großes Dankeschön, läuft perfekt durch :-)
                          Ist wirklich ein klasse Support von dir
                          • darkbluD Offline
                            darkbluD Offline
                            darkblu
                            und wieder eine Anfänger Frage, muss ich hier auch die beiden Schlüssel von influx löschen ?
                            pi@raspberrypi:~ $ apt-key list
                            pub   rsa2048 2012-04-01 [SC]
                                  A0DA 38D0 D76E 8B5D 6388  7281 9165 938D 90FD DD2E
                            uid        [ unbekannt ] Mike Thompson (Raspberry Pi Debian armhf ARMv6+VFP) <mpthompson@gmail.com>
                            sub   rsa2048 2012-04-01 [E]
                            pub   rsa2048 2012-06-17 [SC]
                                  CF8A 1AF5 02A2 AA2D 763B  AE7E 82B1 2992 7FA3 303E
                            uid        [ unbekannt ] Raspberry Pi Archive Signing Key
                            sub   rsa2048 2012-06-17 [E]
                            pub   rsa4096 2015-09-28 [SC]
                                  05CE 1508 5FC0 9D18 E99E  FB22 684A 14CF 2582 E0C5
                            uid        [ unbekannt ] InfluxDB Packaging Service <support@influxdb.com>
                            sub   rsa4096 2015-09-28 [E]
                            pub   rsa4096 2023-01-18 [SC] [verfällt: 2026-01-17]
                                  9D53 9D90 D332 8DC7 D6C8  D3B9 D8FF 8E1F 7DF8 B07E
                            uid        [ unbekannt ] InfluxData Package Signing Key <support@influxdata.com>
                            pi@raspberrypi:~ $
                            und dann
                            sudo apt update
                            ausführen ?
                            Raspi 4, 4GB für Influxdb 1.8 und Grafana
                            Raspi 5, 8 GB für ioBroker
                            Threadnetzwerk per Apple
                            • darkbluD darkblu
                              pi@raspberrypi:~ $
                              und dann
                              sudo apt update
                              ausführen ?
                              @darkblu
                              Ja, die Schlüssel sollten aus apt-key raus.
                              Ob du dann das Repo anlegen musst hängt vom jetzigen Setup ab.
                              darkbluD 1 Antwort Letzte Antwort
                                @darkblu
                                darkbluD Offline
                                darkbluD Offline
                                darkblu
                                Wie finde ich denn raus, ob ich das Repo anlegen muss, bzw. welches Setup ich habe ?
                                Sorry für meine Unwissenheit.
                                • darkbluD darkblu
                                  wendy2702W Offline
                                  wendy2702W Offline
                                  @darkblu Guckst du hier: https://forum.iobroker.net/post/937984
                                  • darkbluD Offline
                                    darkbluD Offline
                                    darkblu
                                    sodele,
                                    sudo apt update
                                    sagt:
                                    pi@raspberrypi:~ $ sudo apt-key del 05CE15085FC09D18E99EFB22684A14CF2582E0C5
                                    OK
                                    pi@raspberrypi:~ $ sudo apt-key del 9D539D90D3328DC7D6C8D3B9D8FF8E1F7DF8B07E
                                    OK
                                    insgesamt 12
                                    -rw-r--r-- 1 root root  84 30. Jan 18:31 grafana.list
                                    -rw-r--r-- 1 root root 208 26. Aug 15:09 nodesource.list
                                    -rw-r--r-- 1 root root 191 30. Okt 2021  raspi.list
                                    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                                    OK:2 https://deb.nodesource.com/node_16.x bullseye InRelease
                                    OK:3 https://apt.grafana.com stable InRelease
                                    OK:4 http://archive.raspberrypi.org/debian bullseye InRelease
                                    Alle Pakete sind aktuell.
                                    wenn ich es richtig verstanden habe, bin ich dann endlich am Ziel und muss nix mehr machen 😧 ?
                                    also das hier (nicht machen):
                                    sudo apt update
                                    • darkbluD darkblu
                                      sodele,
                                      sudo apt update
                                      sagt:
                                      OK
                                      OK
                                      insgesamt 12
                                      sudo apt update
                                      @darkblu
                                      Da ist kein Repo für influxdb angelegt.
                                      Also wirst du das tun müssen, wenn influxdb verwendet werden soll.
                                        @darkblu
                                        darkbluD Offline
                                        darkbluD Offline
                                        darkblu
                                        ey ey Sir
                                        hier die Ausgabe:
                                        pi@raspberrypi:~ $ iob stop
                                        pi@raspberrypi:~ $ sudo rm /etc/apt/sources.list.d/influxdb.list
                                        rm: das Entfernen von '/etc/apt/sources.list.d/influxdb.list' ist nicht möglich: Datei oder Verzeichnis nicht gefunden
                                        pi@raspberrypi:~ $ wget -q https://repos.influxdata.com/influxdata-archive_compat.key
                                        pi@raspberrypi:~ $ echo '393e8779c89ac8d958f81f942f9ad7fb82a25e133faddaf92e15b16e6ac9ce4c influxdata-archive_compat.key' | sha256sum -c && cat influxdata-archive_compat.key | gpg --dearmor | sudo tee /etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg > /dev/null
                                        influxdata-archive_compat.key: OK
                                        pi@raspberrypi:~ $ echo 'deb [signed-by=/etc/apt/trusted.gpg.d/influxdata-archive_compat.gpg] https://repos.influxdata.com/debian stable main' | sudo tee /etc/apt/sources.list.d/influxdata.list
                                        Holen:2 https://repos.influxdata.com/debian stable InRelease [6.874 B]
                                        OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        OK:5 http://archive.raspberrypi.org/debian bullseye InRelease
                                        Holen:6 https://repos.influxdata.com/debian stable/main armhf Packages [1.669 B]
                                        Es wurden 8.543 B in 1 s geholt (6.376 B/s).
                                        pi@raspberrypi:~ $ sudo apt full-upgrade
                                        Paketaktualisierung (Upgrade) wird berechnet… Fertig
                                        0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                                        pi@raspberrypi:~ $
                                        jetzt bin ich aber durch ?
                                        • darkbluD darkblu
                                          ey ey Sir
                                          hier die Ausgabe:
                                          pi@raspberrypi:~ $
                                          @darkblu
                                          apt policy influxdb*
                                          sagt?
