  4. JavaScript
  5. Roborock Adapter tester gesucht
766 Beiträge 51 Kommentatoren 394.7k Aufrufe 52 Beobachtet
  • D
    D
    DonToben
    #140
    roborock.0
    	2023-01-25 18:37:11.775	debug	Detected robot model: roborock.vacuum.a62
    Ich denke, er hat den Rocorock S7 Pro Ultra jetzt richtig erkannt.
    • copystringC copystring
      @wendy2702 Nochmal neu laden. Nicht alle Pfade waren richtig hinterlegt.
      wendy2702W
      wendy2702W
      #141
      @copystring sagte in Roborock Adapter tester gesucht:
      Erledigt.
      Hier mein Home. Daten die Sensibel sein könnten habe ich mal gekürzt.
      {"id":3XXXXX8,"name":"My Home","lon":null,"lat":null,"geoName":null,"products":[{"id":"4oXXXXXLs","name":"Roborock S7","code":"a15","model":"roborock.vacuum.a15","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"52XXXXXmr","name":"Roborock S7","attribute":null,"activeTime":1673803344,"localKey":"nZXXXXXO2","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"4oXXXXXOLs","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.16.12","pv":"1.0","roomId":null,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{}","sn":"R1XXXXX81","featureSet":"0","newFeatureSet":"0000000000002000","deviceStatus":{"120":0,"121":8,"122":100,"123":104,"124":203,"125":47,"126":21,"127":95},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10397463,"name":"Küche"},{"id":10397459,"name":"Wohnzimmer"},{"id":10397457,"name":"Arbeitszimmer"},{"id":10397453,"name":"Bad"},{"id":10397450,"name":"Schlafzimmer"},{"id":10397445,"name":"Flur"}]}
      S7+
      • wendy2702W wendy2702
        Erledigt.
        S7+
        D
        D
        DonToben
        #142
        @wendy2702 said in Roborock Adapter tester gesucht:
        Erledigt.
        S7+
        ... das wäre jetzt gerade meine Frage gewesen. Welche Infos soll man schwärzen?
        @copystring
        Würde dir die Daten dann per PN schicken.
        • D DonToben
          Erledigt.
          S7+
          @copystring
          wendy2702W
          wendy2702W
          #143
          @dontoben Soviel steht nicht drin und ob man damit was anfangen kann weiß ich auch nicht. Ich habe alles mit ID, Token, Serial Nummer mal gekürzt.
          • copystringC
            copystringC
            copystring
            #144
            Da steht nicht so viel spannendes drin. Aber gerne via pn.
            Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
            https://paypal.me/copystring
            W 1 Antwort Letzte Antwort
              W
              W
              worxweis
              #145
              @copystring Also meiner ist lt. App ein roborock.vacuum.s6
              • copystringC
                copystringC
                copystring
                #146
                Hat jemand einen Roborock S7 MaxV (Ultra) roborock_vacuum_a27 und kann den adapter via https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes testen? Wenn das läuft dann kann ich die anderen Klassen entsprechend für die anderen Roboter genau so anpassen. Dann hätte ich ziemlich übersichtlichen Code für Klassen der einzelnen Roboter.
                O M-A HuebM 2 Antworten Letzte Antwort
                  O
                  O
                  oxident
                  schrieb am zuletzt editiert von oxident
                  #147
                  @copystring Ich kann gerade nur sagen, dass ich einen S7 MaxV Ultra (vielleicht A28) habe und der erste schnelle Test mit dem Branch in Fehlern beim Adapterstart geführt hat. Leider habe ich vergessen, die Logs zu speichern und bin schnell wieder zum Master zurück.
                  Hole ich aber nach!
                    M-A HuebM
                    M-A HuebM
                    M-A Hueb
                    #148
                    @copystring Hallo,
                    ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:
                    roborock.0
                    	2023-01-26 08:19:05.034	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                    roborock.0
                    	2023-01-26 08:19:05.034	info	terminating
                    roborock.0
                    	2023-01-26 08:19:05.033	error	this.extended_robot_class is not a constructor
                    roborock.0
                    	2023-01-26 08:19:05.033	error	TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20)
                    roborock.0
                    	2023-01-26 08:19:05.032	error	unhandled promise rejection: this.extended_robot_class is not a constructor
                    roborock.0
                    	2023-01-26 08:19:05.032	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                    roborock.0
                    	2023-01-26 08:19:05.030	debug	Robot key: roborock.vacuum.a27
                    roborock.0
                    	2023-01-26 08:19:05.007	info	MQTT initialized
                    roborock.0
                    	2023-01-26 08:19:04.990	debug	RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"}
                    roborock.0
                    	2023-01-26 08:19:04.871	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                    iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                    copystringC O 2 Antworten Letzte Antwort
                    • M-A HuebM M-A Hueb
                      @copystring Hallo,
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      copystringC
                      copystringC
                      copystring
                      #149
                      @m-a-hueb said in Roborock Adapter tester gesucht:
                      @copystring Hallo,
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      OK. Wann hast du das installiert? Ich hab gestern spät abends den Code angepasst.
                      • M-A HuebM
                        M-A HuebM
                        M-A Hueb
                        #150
                        @copystring Heute morgen
                          @copystring Hallo,
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          O
                          O
                          oxident
                          #151
                          @copystring Hallo,
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          roborock.0
                          Exakt das war auch mein Problem, jedoch mit dem Code vom Stand gestern Nachmittag. Selber Robotertyp...
                          • copystringC
                            copystringC
                            copystring
                            #152
                            War schon spät gestern. Habe bei fast allen Robotern etwas vergessen anzupassen. Sollte jetzt aber laufen. Bitte nochmal mit der aktuellen Version testen. https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
                              wendy2702W
                              wendy2702W
                              #153
                              Wie bzw. woran erkennt man einen Unterschied?
                              • copystringC
                                copystringC
                                copystring
                                #154
                                Ähm. Der Adapter sollte jetzt auch für andere Roboter aus S7 starten. Das ging bisher in dieser branch nicht.
                                  wendy2702W
                                  wendy2702W
                                  #155
                                  @copystring OK.
                                  Dann sehe ich bei mir keinen Unterschied 😁
                                  copystringC 1 Antwort Letzte Antwort
                                    @copystring OK.
                                    copystringC
                                    copystringC
                                    copystring
                                    #156
                                    @wendy2702 :( welcher Fehler kommt?
                                      wendy2702W
                                      wendy2702W
                                      #157
                                      @copystring nein nein...
                                      kein Fehler.
                                      Habe S7+, Adapter startet.
                                      Lediglich einige Objekte nach wie vor leer.
                                        kein Fehler.
                                        copystringC
                                        copystringC
                                        copystring
                                        #158
                                        @wendy2702 Ach so. Ja das kann sein. Dazu komme ich dann wenn der Adapter aus branch split_robots_into_classes überhaupt wieder startet.
                                        Durch diese branch kann jeder seine eigene Konfiguration erhalten und nicht die gleiche für alle :)
                                        Was ist denn leer? Dann würde ich das direkt für deinen Roboter anpassen.
                                          wendy2702W
                                          wendy2702W
                                          #159
                                          @copystring
                                          Hier steht immer nur "0h", keine Ahnung ob das so sein soll:
                                          Und dann hier einige von denen welche von Interesse sein könnten, wie z.B Akku
                                          Dann z.B. hier
                                          84.1k
