Roborock Adapter tester gesucht
Genau so ist es. Ansonsten meldet der Adapter, dass der Roboter nicht unterstützt ist.
@copystring Bei mir läuft er nicht mehr:
2023-01-25 18:25:30.721 - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true) 2023-01-25 18:25:30.729 - info: roborock.0 (1033377) Got terminate signal TERMINATE_YOURSELF 2023-01-25 18:25:30.738 - info: roborock.0 (1033377) terminating 2023-01-25 18:25:30.739 - info: roborock.0 (1033377) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-01-25 18:25:30.792 - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal 2023-01-25 18:25:31.353 - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-01-25 18:25:34.032 - info: host.iobroker instance system.adapter.roborock.0 started with pid 1047380 2023-01-25 18:25:34.745 - debug: roborock.0 (1047380) Redis Objects: Use Redis connection: 0.0.0.0:9001 2023-01-25 18:25:34.788 - debug: roborock.0 (1047380) Objects client ready ... initialize now 2023-01-25 18:25:34.789 - debug: roborock.0 (1047380) Objects create System PubSub Client 2023-01-25 18:25:34.790 - debug: roborock.0 (1047380) Objects create User PubSub Client 2023-01-25 18:25:34.870 - debug: roborock.0 (1047380) Objects client initialize lua scripts 2023-01-25 18:25:34.876 - debug: roborock.0 (1047380) Objects connected to redis: 0.0.0.0:9001 2023-01-25 18:25:34.910 - debug: roborock.0 (1047380) Redis States: Use Redis connection: 0.0.0.0:9000 2023-01-25 18:25:34.932 - debug: roborock.0 (1047380) States create System PubSub Client 2023-01-25 18:25:34.932 - debug: roborock.0 (1047380) States create User PubSub Client 2023-01-25 18:25:35.016 - debug: roborock.0 (1047380) States connected to redis: 0.0.0.0:9000 2023-01-25 18:25:35.221 - info: roborock.0 (1047380) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24 2023-01-25 18:25:35.432 - debug: roborock.0 (1047380) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"} 2023-01-25 18:25:35.458 - info: roborock.0 (1047380) MQTT initialized 2023-01-25 18:25:35.459 - debug: roborock.0 (1047380) Detected robot model: roborock.vacuum.a15 2023-01-25 18:25:35.460 - debug: roborock.0 (1047380) Robot key: undefined 2023-01-25 18:25:35.462 - error: roborock.0 (1047380) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-01-25 18:25:35.462 - error: roborock.0 (1047380) unhandled promise rejection: Cannot find module 'ioBroker.roborock/lib/basic_robot' - /opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js - /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js - /opt/iobroker/node_modules/iobroker.roborock/main.js 2023-01-25 18:25:35.462 - error: roborock.0 (1047380) Error: Cannot find module 'ioBroker.roborock/lib/basic_robot' - /opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js - /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js - /opt/iobroker/node_modules/iobroker.roborock/main.js at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js:5:21) 2023-01-25 18:25:35.462 - error: roborock.0 (1047380) Exception-Code: MODULE_NOT_FOUND: Cannot find module 'ioBroker.roborock/lib/basic_robot' - /opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js - /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js - /opt/iobroker/node_modules/iobroker.roborock/main.js 2023-01-25 18:25:35.463 - info: roborock.0 (1047380) terminating 2023-01-25 18:25:35.464 - warn: roborock.0 (1047380) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-01-25 18:25:36.081 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-01-25 18:25:36.081 - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled -
2023-01-25 18:25:30.721 - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true) 2023-01-25 18:25:30.729 - info: roborock.0 (1033377) Got terminate signal TERMINATE_YOURSELF 2023-01-25 18:25:30.738 - info: roborock.0 (1033377) terminating 2023-01-25 18:25:30.739 - info: roborock.0 (1033377) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason 2023-01-25 18:25:30.792 - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal 2023-01-25 18:25:31.353 - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION) 2023-01-25 18:25:34.032 - info: host.iobroker instance system.adapter.roborock.0 started with pid 1047380 2023-01-25 18:25:34.745 - debug: roborock.0 (1047380) Redis Objects: Use Redis connection: 0.0.0.0:9001 2023-01-25 18:25:34.788 - debug: roborock.0 (1047380) Objects client ready ... initialize now 2023-01-25 18:25:34.789 - debug: roborock.0 (1047380) Objects create System PubSub Client 2023-01-25 18:25:34.790 - debug: roborock.0 (1047380) Objects create User PubSub Client 2023-01-25 18:25:34.870 - debug: roborock.0 (1047380) Objects client initialize lua scripts 2023-01-25 18:25:34.876 - debug: roborock.0 (1047380) Objects connected to redis: 0.0.0.0:9001 2023-01-25 18:25:34.910 - debug: roborock.0 (1047380) Redis States: Use Redis connection: 0.0.0.0:9000 2023-01-25 18:25:34.932 - debug: roborock.0 (1047380) States create System PubSub Client 2023-01-25 18:25:34.932 - debug: roborock.0 (1047380) States create User PubSub Client 2023-01-25 18:25:35.016 - debug: roborock.0 (1047380) States connected to redis: 0.0.0.0:9000 2023-01-25 18:25:35.221 - info: roborock.0 (1047380) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24 2023-01-25 18:25:35.432 - debug: roborock.0 (1047380) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"} 2023-01-25 18:25:35.458 - info: roborock.0 (1047380) MQTT initialized 2023-01-25 18:25:35.459 - debug: roborock.0 (1047380) Detected robot model: roborock.vacuum.a15 2023-01-25 18:25:35.460 - debug: roborock.0 (1047380) Robot key: undefined 2023-01-25 18:25:35.462 - error: roborock.0 (1047380) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). 2023-01-25 18:25:35.462 - error: roborock.0 (1047380) unhandled promise rejection: Cannot find module 'ioBroker.roborock/lib/basic_robot' - /opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js - /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js - /opt/iobroker/node_modules/iobroker.roborock/main.js 2023-01-25 18:25:35.462 - error: roborock.0 (1047380) Error: Cannot find module 'ioBroker.roborock/lib/basic_robot' - /opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js - /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js - /opt/iobroker/node_modules/iobroker.roborock/main.js at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js:5:21) 2023-01-25 18:25:35.462 - error: roborock.0 (1047380) Exception-Code: MODULE_NOT_FOUND: Cannot find module 'ioBroker.roborock/lib/basic_robot' - /opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js - /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js - /opt/iobroker/node_modules/iobroker.roborock/main.js 2023-01-25 18:25:35.463 - info: roborock.0 (1047380) terminating 2023-01-25 18:25:35.464 - warn: roborock.0 (1047380) Terminated (UNCAUGHT_EXCEPTION): Without reason 2023-01-25 18:25:36.081 - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION) 2023-01-25 18:25:36.081 - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled@wendy2702 Nochmal neu laden. Nicht alle Pfade waren richtig hinterlegt.
@copystring sagte in Roborock Adapter tester gesucht:
Erledigt.
Hier mein Home. Daten die Sensibel sein könnten habe ich mal gekürzt.{"id":3XXXXX8,"name":"My Home","lon":null,"lat":null,"geoName":null,"products":[{"id":"4oXXXXXLs","name":"Roborock S7","code":"a15","model":"roborock.vacuum.a15","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"52XXXXXmr","name":"Roborock S7","attribute":null,"activeTime":1673803344,"localKey":"nZXXXXXO2","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"4oXXXXXOLs","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.16.12","pv":"1.0","roomId":null,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{}","sn":"R1XXXXX81","featureSet":"0","newFeatureSet":"0000000000002000","deviceStatus":{"120":0,"121":8,"122":100,"123":104,"124":203,"125":47,"126":21,"127":95},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10397463,"name":"Küche"},{"id":10397459,"name":"Wohnzimmer"},{"id":10397457,"name":"Arbeitszimmer"},{"id":10397453,"name":"Bad"},{"id":10397450,"name":"Schlafzimmer"},{"id":10397445,"name":"Flur"}]}S7+
Erledigt.
@wendy2702 said in Roborock Adapter tester gesucht:
Erledigt.
... das wäre jetzt gerade meine Frage gewesen. Welche Infos soll man schwärzen?
@copystring
Würde dir die Daten dann per PN schicken. -
Erledigt.
@copystring
Da steht nicht so viel spannendes drin. Aber gerne via pn.
@copystring Also meiner ist lt. App ein roborock.vacuum.s6
Hat jemand einen Roborock S7 MaxV (Ultra) roborock_vacuum_a27 und kann den adapter via https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes testen? Wenn das läuft dann kann ich die anderen Klassen entsprechend für die anderen Roboter genau so anpassen. Dann hätte ich ziemlich übersichtlichen Code für Klassen der einzelnen Roboter.
@copystring Ich kann gerade nur sagen, dass ich einen S7 MaxV Ultra (vielleicht A28) habe und der erste schnelle Test mit dem Branch in Fehlern beim Adapterstart geführt hat. Leider habe ich vergessen, die Logs zu speichern und bin schnell wieder zum Master zurück.
Hole ich aber nach!
@copystring Hallo,
ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:roborock.0 2023-01-26 08:19:05.034 warn Terminated (UNCAUGHT_EXCEPTION): Without reason roborock.0 2023-01-26 08:19:05.034 info terminating roborock.0 2023-01-26 08:19:05.033 error this.extended_robot_class is not a constructor roborock.0 2023-01-26 08:19:05.033 error TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20) roborock.0 2023-01-26 08:19:05.032 error unhandled promise rejection: this.extended_robot_class is not a constructor roborock.0 2023-01-26 08:19:05.032 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). roborock.0 2023-01-26 08:19:05.030 debug Robot key: roborock.vacuum.a27 roborock.0 2023-01-26 08:19:05.007 info MQTT initialized roborock.0 2023-01-26 08:19:04.990 debug RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"} roborock.0 2023-01-26 08:19:04.871 info starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24 -
@copystring Hallo,
ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:roborock.0 2023-01-26 08:19:05.034 warn Terminated (UNCAUGHT_EXCEPTION): Without reason roborock.0 2023-01-26 08:19:05.034 info terminating roborock.0 2023-01-26 08:19:05.033 error this.extended_robot_class is not a constructor roborock.0 2023-01-26 08:19:05.033 error TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20) roborock.0 2023-01-26 08:19:05.032 error unhandled promise rejection: this.extended_robot_class is not a constructor roborock.0 2023-01-26 08:19:05.032 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). roborock.0 2023-01-26 08:19:05.030 debug Robot key: roborock.vacuum.a27 roborock.0 2023-01-26 08:19:05.007 info MQTT initialized roborock.0 2023-01-26 08:19:04.990 debug RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"} roborock.0 2023-01-26 08:19:04.871 info starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24@m-a-hueb said in Roborock Adapter tester gesucht:
@copystring Hallo,
ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:roborock.0 2023-01-26 08:19:05.034 warn Terminated (UNCAUGHT_EXCEPTION): Without reason roborock.0 2023-01-26 08:19:05.034 info terminating roborock.0 2023-01-26 08:19:05.033 error this.extended_robot_class is not a constructor roborock.0 2023-01-26 08:19:05.033 error TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20) roborock.0 2023-01-26 08:19:05.032 error unhandled promise rejection: this.extended_robot_class is not a constructor roborock.0 2023-01-26 08:19:05.032 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). roborock.0 2023-01-26 08:19:05.030 debug Robot key: roborock.vacuum.a27 roborock.0 2023-01-26 08:19:05.007 info MQTT initialized roborock.0 2023-01-26 08:19:04.990 debug RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"} roborock.0 2023-01-26 08:19:04.871 info starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24OK. Wann hast du das installiert? Ich hab gestern spät abends den Code angepasst.
@copystring Heute morgen
@copystring Hallo,
@copystring Hallo,
ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:roborock.0 2023-01-26 08:19:05.034 warn Terminated (UNCAUGHT_EXCEPTION): Without reason roborock.0 2023-01-26 08:19:05.034 info terminating roborock.0 2023-01-26 08:19:05.033 error this.extended_robot_class is not a constructor roborock.0 2023-01-26 08:19:05.033 error TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20) roborock.0 2023-01-26 08:19:05.032 error unhandled promise rejection: this.extended_robot_class is not a constructor roborock.0 2023-01-26 08:19:05.032 error Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch(). roborock.0 2023-01-26 08:19:05.030 debug Robot key: roborock.vacuum.a27 roborock.0 2023-01-26 08:19:05.007 info MQTT initialized roborock.0 2023-01-26 08:19:04.990 debug RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"} roborock.0 2023-01-26 08:19:04.871 info starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24Exakt das war auch mein Problem, jedoch mit dem Code vom Stand gestern Nachmittag. Selber Robotertyp...
War schon spät gestern. Habe bei fast allen Robotern etwas vergessen anzupassen. Sollte jetzt aber laufen. Bitte nochmal mit der aktuellen Version testen. https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
Wie bzw. woran erkennt man einen Unterschied?
Ähm. Der Adapter sollte jetzt auch für andere Roboter aus S7 starten. Das ging bisher in dieser branch nicht.
@copystring OK.
Dann sehe ich bei mir keinen Unterschied
@copystring OK.
@wendy2702 :( welcher Fehler kommt?
