  4. JavaScript
  5. Roborock Adapter tester gesucht
    6.8k
766 Beiträge 51 Kommentatoren 323.6k Aufrufe 52 Beobachtet
  • D DonToben
    Bei mir S7 Pro Ultra
    M-A HuebM Offline
    M-A HuebM Offline
    M-A Hueb
    schrieb am zuletzt editiert von M-A Hueb
    #129
    roborock.vacuuum.a27 Roborrock Maxv Ultra
    iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
    • copystringC copystring
      @m-a-hueb said in Roborock Adapter tester gesucht:
      @copystring Sorry war zu schnell und hatte den neu installierten Adapter noch auf Info stehen.
      roborock.0
      	2023-01-25 09:09:53.586	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
      roborock.0
      	2023-01-25 09:09:53.586	info	terminating
      roborock.0
      	2023-01-25 09:09:53.584	error	Exception-Code: MODULE_NOT_FOUND: Cannot find module './undefined' Require stack: - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js
      roborock.0
      	2023-01-25 09:09:53.584	error	Error: Cannot find module './undefined' Require stack: - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:995:15) at Function.Module._load (node:internal/modules/cjs/loader:841:27) at Module.require (node:internal/modules/cjs/loader:1067:19) at require (node:internal/modules/cjs/helpers:103:18) at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:19:31) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:172:20)
      roborock.0
      	2023-01-25 09:09:53.584	error	unhandled promise rejection: Cannot find module './undefined' Require stack: - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js - C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js
      roborock.0
      	2023-01-25 09:09:53.583	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
      roborock.0
      	2023-01-25 09:09:53.582	debug	Test vacuum log: undefined
      roborock.0
      	2023-01-25 09:09:53.582	debug	Detected robot name: Wall-E
      roborock.0
      	2023-01-25 09:09:53.581	info	MQTT initialized
      roborock.0
      	2023-01-25 09:09:53.565	debug	RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"}
      roborock.0
      	2023-01-25 09:09:53.418	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
      Wall-E? Okay dann geht das nicht so wie ich mir das vorgestellt habe. Danke.
      Dimi
      #130
      @copystring
      Hallo, tolle Arbeit.
      Also ich habe einen Roborock S6 MaxV und der hat laut App die Modellbezeichnung roborock.vacuum.a10
        DonToben
        #131
        @copystring
        Hi, ich habe ein Problem mit dem Roborock Adapter festgestellt. Er reagiert nicht immer auf steuern app_segment_clean. Räume sind auf true gesetzt. Komplettreinigung über app_start funktioniert immer.
        Nach Adapter Neustart geht dann wieder app_segment_clean für eine bestimmte Zeit.
        • copystringC Offline
          copystringC Offline
          copystring
          #132
          Die meisten Roboter sollten nun laufen.
          Beim S4 scheint es keinen Mop zu geben. Für diesen habe ich das Feature entfernt.
          https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
          Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
          https://paypal.me/copystring
            copystringC Offline
            copystring
            schrieb am zuletzt editiert von copystring
            #133
            Wenn ihr euer homedata zuschicken könntet dann kann ich für jeden Roboter den deviceStatus vollständig erstellen.
              wendy2702W Offline
              wendy2702W Offline
              #134
              @copystring sagte in Roborock Adapter tester gesucht:
              Woran kann man erkennen das der Typ erkannt wurde ?
              EDIT: Vielleicht kannst du die Versionsnummern mal hochzählen damit man sehen kann ob die richtige Version installiert wurde und läuft.
                copystringC Offline
                copystring
                #135
                Wenn keine Fehlermeldung erscheint :)
                  wendy2702W Offline
                  wendy2702W Offline
                  #136
                  @copystring Im Debug log beim Adpater start meinst du?
                    copystringC Offline
                    copystring
                    #137
                    Genau so ist es. Ansonsten meldet der Adapter, dass der Roboter nicht unterstützt ist.
                      wendy2702W Offline
                      wendy2702W Offline
                      #138
                      @copystring Bei mir läuft er nicht mehr:
                      2023-01-25 18:25:30.721  - info: host.iobroker stopInstance system.adapter.roborock.0 (force=false, process=true)
                      2023-01-25 18:25:30.729  - info: roborock.0 (1033377) Got terminate signal TERMINATE_YOURSELF
                      2023-01-25 18:25:30.738  - info: roborock.0 (1033377) terminating
                      2023-01-25 18:25:30.739  - info: roborock.0 (1033377) Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
                      2023-01-25 18:25:30.792  - info: host.iobroker stopInstance system.adapter.roborock.0 send kill signal
                      2023-01-25 18:25:31.353  - info: host.iobroker instance system.adapter.roborock.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
                      2023-01-25 18:25:34.032  - info: host.iobroker instance system.adapter.roborock.0 started with pid 1047380
                      2023-01-25 18:25:34.745  - debug: roborock.0 (1047380) Redis Objects: Use Redis connection: 0.0.0.0:9001
                      2023-01-25 18:25:34.788  - debug: roborock.0 (1047380) Objects client ready ... initialize now
                      2023-01-25 18:25:34.789  - debug: roborock.0 (1047380) Objects create System PubSub Client
                      2023-01-25 18:25:34.790  - debug: roborock.0 (1047380) Objects create User PubSub Client
                      2023-01-25 18:25:34.870  - debug: roborock.0 (1047380) Objects client initialize lua scripts
                      2023-01-25 18:25:34.876  - debug: roborock.0 (1047380) Objects connected to redis: 0.0.0.0:9001
                      2023-01-25 18:25:34.910  - debug: roborock.0 (1047380) Redis States: Use Redis connection: 0.0.0.0:9000
                      2023-01-25 18:25:34.932  - debug: roborock.0 (1047380) States create System PubSub Client
                      2023-01-25 18:25:34.932  - debug: roborock.0 (1047380) States create User PubSub Client
                      2023-01-25 18:25:35.016  - debug: roborock.0 (1047380) States connected to redis: 0.0.0.0:9000
                      2023-01-25 18:25:35.221  - info: roborock.0 (1047380) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                      2023-01-25 18:25:35.432  - debug: roborock.0 (1047380) RoomIDs debug: {"10397445":"Flur","10397450":"Schlafzimmer","10397453":"Bad","10397457":"Arbeitszimmer","10397459":"Wohnzimmer","10397463":"Küche"}
                      2023-01-25 18:25:35.458  - info: roborock.0 (1047380) MQTT initialized
                      2023-01-25 18:25:35.459  - debug: roborock.0 (1047380) Detected robot model: roborock.vacuum.a15
                      2023-01-25 18:25:35.460  - debug: roborock.0 (1047380) Robot key: undefined
                      2023-01-25 18:25:35.462  - error: roborock.0 (1047380) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                      2023-01-25 18:25:35.462  - error: roborock.0 (1047380) unhandled promise rejection: Cannot find module 'ioBroker.roborock/lib/basic_robot'
                      - /opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js
                      - /opt/iobroker/node_modules/iobroker.roborock/lib/vacuum.js
                      - /opt/iobroker/node_modules/iobroker.roborock/main.js
                      2023-01-25 18:25:35.462  - error: roborock.0 (1047380) Error: Cannot find module 'ioBroker.roborock/lib/basic_robot'
                          at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.roborock/lib/roborock.vacuum.a15.js:5:21)
                      2023-01-25 18:25:35.462  - error: roborock.0 (1047380) Exception-Code: MODULE_NOT_FOUND: Cannot find module 'ioBroker.roborock/lib/basic_robot'
                      2023-01-25 18:25:35.463  - info: roborock.0 (1047380) terminating
                      2023-01-25 18:25:35.464  - warn: roborock.0 (1047380) Terminated (UNCAUGHT_EXCEPTION): Without reason
                      2023-01-25 18:25:36.081  - error: host.iobroker instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                      2023-01-25 18:25:36.081  - info: host.iobroker Restart adapter system.adapter.roborock.0 because enabled
                      copystringC 1 Antwort Letzte Antwort
                      • wendy2702W wendy2702
                        copystringC Offline
                        copystringC Offline
                        copystring
                        #139
                        @wendy2702 Nochmal neu laden. Nicht alle Pfade waren richtig hinterlegt.
                          DonToben
                          #140
                          roborock.0
                          	2023-01-25 18:37:11.775	debug	Detected robot model: roborock.vacuum.a62
                          Ich denke, er hat den Rocorock S7 Pro Ultra jetzt richtig erkannt.
                            wendy2702W Offline
                            wendy2702W Offline
                            #141
                            Erledigt.
                            Hier mein Home. Daten die Sensibel sein könnten habe ich mal gekürzt.
                            {"id":3XXXXX8,"name":"My Home","lon":null,"lat":null,"geoName":null,"products":[{"id":"4oXXXXXLs","name":"Roborock S7","code":"a15","model":"roborock.vacuum.a15","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"52XXXXXmr","name":"Roborock S7","attribute":null,"activeTime":1673803344,"localKey":"nZXXXXXO2","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"4oXXXXXOLs","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.16.12","pv":"1.0","roomId":null,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{}","sn":"R1XXXXX81","featureSet":"0","newFeatureSet":"0000000000002000","deviceStatus":{"120":0,"121":8,"122":100,"123":104,"124":203,"125":47,"126":21,"127":95},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10397463,"name":"Küche"},{"id":10397459,"name":"Wohnzimmer"},{"id":10397457,"name":"Arbeitszimmer"},{"id":10397453,"name":"Bad"},{"id":10397450,"name":"Schlafzimmer"},{"id":10397445,"name":"Flur"}]}
                            S7+
                              Erledigt.
                              S7+
                              DonToben
                              #142
                              @wendy2702 said in Roborock Adapter tester gesucht:
                              Erledigt.
                              S7+
                              ... das wäre jetzt gerade meine Frage gewesen. Welche Infos soll man schwärzen?
                              @copystring
                              Würde dir die Daten dann per PN schicken.
                              • D DonToben
                                Erledigt.
                                S7+
                                @copystring
                                wendy2702W Offline
                                wendy2702W Offline
                                #143
                                @dontoben Soviel steht nicht drin und ob man damit was anfangen kann weiß ich auch nicht. Ich habe alles mit ID, Token, Serial Nummer mal gekürzt.
                                  copystringC Offline
                                  copystring
                                  #144
                                  Da steht nicht so viel spannendes drin. Aber gerne via pn.
                                  W 1 Antwort Letzte Antwort
                                    W Offline
                                    W Offline
                                    worxweis
                                    #145
                                    @copystring Also meiner ist lt. App ein roborock.vacuum.s6
                                      copystringC Offline
                                      copystring
                                      #146
                                      Hat jemand einen Roborock S7 MaxV (Ultra) roborock_vacuum_a27 und kann den adapter via https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes testen? Wenn das läuft dann kann ich die anderen Klassen entsprechend für die anderen Roboter genau so anpassen. Dann hätte ich ziemlich übersichtlichen Code für Klassen der einzelnen Roboter.
                                      O M-A HuebM 2 Antworten Letzte Antwort
                                        O Online
                                        O Online
                                        oxident
                                        schrieb am zuletzt editiert von oxident
                                        #147
                                        @copystring Ich kann gerade nur sagen, dass ich einen S7 MaxV Ultra (vielleicht A28) habe und der erste schnelle Test mit dem Branch in Fehlern beim Adapterstart geführt hat. Leider habe ich vergessen, die Logs zu speichern und bin schnell wieder zum Master zurück.
                                        Hole ich aber nach!
                                          M-A HuebM Offline
                                          M-A HuebM Offline
                                          M-A Hueb
                                          #148
                                          @copystring Hallo,
                                          ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:
                                          roborock.0
                                          	2023-01-26 08:19:05.034	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          roborock.0
                                          	2023-01-26 08:19:05.034	info	terminating
                                          roborock.0
                                          	2023-01-26 08:19:05.033	error	this.extended_robot_class is not a constructor
                                          roborock.0
                                          	2023-01-26 08:19:05.033	error	TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20)
                                          roborock.0
                                          	2023-01-26 08:19:05.032	error	unhandled promise rejection: this.extended_robot_class is not a constructor
                                          roborock.0
                                          	2023-01-26 08:19:05.032	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          roborock.0
                                          	2023-01-26 08:19:05.030	debug	Robot key: roborock.vacuum.a27
                                          roborock.0
                                          	2023-01-26 08:19:05.007	info	MQTT initialized
                                          roborock.0
                                          	2023-01-26 08:19:04.990	debug	RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"}
                                          roborock.0
                                          	2023-01-26 08:19:04.871	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                          copystringC O 2 Antworten Letzte Antwort
