  4. JavaScript
  5. Roborock Adapter tester gesucht
766 Beiträge 51 Kommentatoren 394.7k Aufrufe 52 Beobachtet
  • wendy2702W wendy2702
    @copystring sagte in Roborock Adapter tester gesucht:
    @wendy2702 Nochmal neu laden. Nicht alle Pfade waren richtig hinterlegt.
    Erledigt.
    Hier mein Home. Daten die Sensibel sein könnten habe ich mal gekürzt.
    {"id":3XXXXX8,"name":"My Home","lon":null,"lat":null,"geoName":null,"products":[{"id":"4oXXXXXLs","name":"Roborock S7","code":"a15","model":"roborock.vacuum.a15","iconUrl":null,"attribute":null,"capability":0,"category":"robot.vacuum.cleaner","schema":[{"id":"101","name":"rpc_request","code":"rpc_request","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"102","name":"rpc_response","code":"rpc_response","mode":"rw","type":"RAW","property":null,"desc":null},{"id":"120","name":"错误代码","code":"error_code","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"121","name":"设备状态","code":"state","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"122","name":"设备电量","code":"battery","mode":"ro","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"123","name":"清扫模式","code":"fan_power","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"124","name":"拖地模式","code":"water_box_mode","mode":"rw","type":"ENUM","property":"{\"range\": []}","desc":null},{"id":"125","name":"主刷寿命","code":"main_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"126","name":"边刷寿命","code":"side_brush_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"127","name":"滤网寿命","code":"filter_life","mode":"rw","type":"VALUE","property":"{\"max\": 100, \"min\": 0, \"step\": 1, \"unit\": null, \"scale\": 1}","desc":null},{"id":"128","name":"额外状态","code":"additional_props","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"130","name":"完成事件","code":"task_complete","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"131","name":"电量不足任务取消","code":"task_cancel_low_power","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"132","name":"运动中任务取消","code":"task_cancel_in_motion","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"133","name":"充电状态","code":"charge_status","mode":"ro","type":"RAW","property":null,"desc":null},{"id":"134","name":"烘干状态","code":"drying_status","mode":"ro","type":"RAW","property":null,"desc":null}]}],"devices":[{"duid":"52XXXXXmr","name":"Roborock S7","attribute":null,"activeTime":1673803344,"localKey":"nZXXXXXO2","runtimeEnv":null,"timeZoneId":"Europe/Berlin","iconUrl":"","productId":"4oXXXXXOLs","lon":null,"lat":null,"share":false,"shareTime":null,"online":true,"fv":"02.16.12","pv":"1.0","roomId":null,"tuyaUuid":null,"tuyaMigrated":false,"extra":"{}","sn":"R1XXXXX81","featureSet":"0","newFeatureSet":"0000000000002000","deviceStatus":{"120":0,"121":8,"122":100,"123":104,"124":203,"125":47,"126":21,"127":95},"silentOtaSwitch":false}],"receivedDevices":[],"rooms":[{"id":10397463,"name":"Küche"},{"id":10397459,"name":"Wohnzimmer"},{"id":10397457,"name":"Arbeitszimmer"},{"id":10397453,"name":"Bad"},{"id":10397450,"name":"Schlafzimmer"},{"id":10397445,"name":"Flur"}]}
    S7+
    D
    D
    DonToben
    #142
    @wendy2702 said in Roborock Adapter tester gesucht:
    Erledigt.
    S7+
    ... das wäre jetzt gerade meine Frage gewesen. Welche Infos soll man schwärzen?
    @copystring
    Würde dir die Daten dann per PN schicken.
    • D DonToben
      Erledigt.
      S7+
      @copystring
      wendy2702W
      wendy2702W
      #143
      @dontoben Soviel steht nicht drin und ob man damit was anfangen kann weiß ich auch nicht. Ich habe alles mit ID, Token, Serial Nummer mal gekürzt.
      • copystringC
        copystringC
        copystring
        #144
        Da steht nicht so viel spannendes drin. Aber gerne via pn.
        Unterstütze meine Arbeit gerne mit einer Spende über PayPal:
        https://paypal.me/copystring
        W 1 Antwort Letzte Antwort
        • copystringC copystring
          W
          W
          worxweis
          #145
          @copystring Also meiner ist lt. App ein roborock.vacuum.s6
          • copystringC
            copystringC
            copystring
            #146
            Hat jemand einen Roborock S7 MaxV (Ultra) roborock_vacuum_a27 und kann den adapter via https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes testen? Wenn das läuft dann kann ich die anderen Klassen entsprechend für die anderen Roboter genau so anpassen. Dann hätte ich ziemlich übersichtlichen Code für Klassen der einzelnen Roboter.
            O M-A HuebM 2 Antworten Letzte Antwort
              O
              O
              oxident
              schrieb am zuletzt editiert von oxident
              #147
              @copystring Ich kann gerade nur sagen, dass ich einen S7 MaxV Ultra (vielleicht A28) habe und der erste schnelle Test mit dem Branch in Fehlern beim Adapterstart geführt hat. Leider habe ich vergessen, die Logs zu speichern und bin schnell wieder zum Master zurück.
              Hole ich aber nach!
                M-A HuebM
                M-A HuebM
                M-A Hueb
                #148
                @copystring Hallo,
                ich habe einen MaxV. Allerdings startet der Adapeter nicht mehr:
                roborock.0
                	2023-01-26 08:19:05.034	warn	Terminated (UNCAUGHT_EXCEPTION): Without reason
                roborock.0
                	2023-01-26 08:19:05.034	info	terminating
                roborock.0
                	2023-01-26 08:19:05.033	error	this.extended_robot_class is not a constructor
                roborock.0
                	2023-01-26 08:19:05.033	error	TypeError: this.extended_robot_class is not a constructor at new vacuum (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\lib\vacuum.js:41:25) at Roborock.onReady (C:\Program Files\iobroker\SmartHome\node_modules\iobroker.roborock\main.js:173:20)
                roborock.0
                	2023-01-26 08:19:05.032	error	unhandled promise rejection: this.extended_robot_class is not a constructor
                roborock.0
                	2023-01-26 08:19:05.032	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                roborock.0
                	2023-01-26 08:19:05.030	debug	Robot key: roborock.vacuum.a27
                roborock.0
                	2023-01-26 08:19:05.007	info	MQTT initialized
                roborock.0
                	2023-01-26 08:19:04.990	debug	RoomIDs debug: {"7993732":"Schlafzimmer","7993746":"Flur","7993754":"Arbeitszimmer","7993760":"Gästezimmer","7993766":"Küche","7993774":"Badezimmer","7993881":"Toilette","7993886":"Wohnzimmer","7993887":"Esszimmer","7997563":"Standard"}
                roborock.0
                	2023-01-26 08:19:04.871	info	starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in C:/Program Files/iobroker/SmartHome/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                iobroker unter Win11. NPM 10.9.3 Node.js v22.18.0 js-controller 7.0.7
                copystringC O 2 Antworten Letzte Antwort
                • M-A HuebM M-A Hueb
                  @copystring Hallo,
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  copystringC
                  copystringC
                  copystring
                  #149
                  @m-a-hueb said in Roborock Adapter tester gesucht:
                  @copystring Hallo,
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  roborock.0
                  OK. Wann hast du das installiert? Ich hab gestern spät abends den Code angepasst.
                  • M-A HuebM
                    M-A HuebM
                    M-A Hueb
                    #150
                    @copystring Heute morgen
                      @copystring Hallo,
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      O
                      O
                      oxident
                      #151
                      @copystring Hallo,
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      roborock.0
                      Exakt das war auch mein Problem, jedoch mit dem Code vom Stand gestern Nachmittag. Selber Robotertyp...
                      • copystringC
                        copystringC
                        copystring
                        #152
                        War schon spät gestern. Habe bei fast allen Robotern etwas vergessen anzupassen. Sollte jetzt aber laufen. Bitte nochmal mit der aktuellen Version testen. https://github.com/copystring/ioBroker.roborock/tree/split_robots_into_classes
                          wendy2702W
                          wendy2702W
                          #153
                          Wie bzw. woran erkennt man einen Unterschied?
                          • copystringC
                            copystringC
                            copystring
                            #154
                            Ähm. Der Adapter sollte jetzt auch für andere Roboter aus S7 starten. Das ging bisher in dieser branch nicht.
                              wendy2702W
                              wendy2702W
                              #155
                              @copystring OK.
                              Dann sehe ich bei mir keinen Unterschied 😁
                              copystringC 1 Antwort Letzte Antwort
                                @copystring OK.
                                copystringC
                                copystringC
                                copystring
                                #156
                                @wendy2702 :( welcher Fehler kommt?
                                  wendy2702W
                                  wendy2702W
                                  #157
                                  @copystring nein nein...
                                  kein Fehler.
                                  Habe S7+, Adapter startet.
                                  Lediglich einige Objekte nach wie vor leer.
                                    kein Fehler.
                                    copystringC
                                    copystringC
                                    copystring
                                    #158
                                    @wendy2702 Ach so. Ja das kann sein. Dazu komme ich dann wenn der Adapter aus branch split_robots_into_classes überhaupt wieder startet.
                                    Durch diese branch kann jeder seine eigene Konfiguration erhalten und nicht die gleiche für alle :)
                                    Was ist denn leer? Dann würde ich das direkt für deinen Roboter anpassen.
                                      wendy2702W
                                      wendy2702W
                                      #159
                                      @copystring
                                      Hier steht immer nur "0h", keine Ahnung ob das so sein soll:
                                      Und dann hier einige von denen welche von Interesse sein könnten, wie z.B Akku
                                      Dann z.B. hier
                                        @copystring
                                        Dann z.B. hier
                                        copystringC
                                        copystringC
                                        copystring
                                        #160
                                        @wendy2702 hm ja es scheint so, als ob der S7 und seine variationen dust_collection_work_times und filter_element_work_time gar nicht unterstützen. Daher kommt da auch kein Wert.
                                        Warum bei dir Bettery etc aber (null) ist verstehe ich nicht. Schick mal bitte ein debug log nach dem Start des Adapters.
                                        Bei deviceInfo gucke ich nochmal rein. Da werden anscheinend nicht alle Parameter sauber abgefragt.
                                        • Black ThunderB
                                          Black ThunderB
                                          Black Thunder
                                          schrieb am zuletzt editiert von Black Thunder
                                          #161
                                          @copystring Erstmal vielen Dank, dass du dich um einen dedizierten Roborock-Adapter kümmerst. 👍
                                          Hab gerade mal meinen Roborock S7 von der Xiaomi Home App in die Roborock-App umgezogen und die aktuelle Version deines Adapters aus dem "split_robots_into_classes"-Branch installiert. Grundsätzlich klappt die Verbindung auf jeden Fall schon mal und es werden auch einige Daten vom Roboter abgerufen. Allerdings ebenso mit den bereits hier berichteten teils fehlenden/falschen Zuordnungen zu den korrekten States (speziell unter "roborock.0.Devices.XXX.deviceStatus").
                                          Zusätzlich habe ich aber noch das Problem, dass der Adapter abstürzt, sobald ein beliebiges Kommando unter "roborock.0.Devices.XXX.commands" gesetzt wird. Im Log sieht das dann z.B. für "commands.load_multi_map" so aus:
                                          2023-01-26 22:31:46.562 - info: host.raspberrypi-gang "system.adapter.roborock.0" enabled
                                          2023-01-26 22:31:47.186 - info: host.raspberrypi-gang instance system.adapter.roborock.0 started with pid 7107
                                          2023-01-26 22:31:48.988 - debug: roborock.0 (7107) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2023-01-26 22:31:49.067 - debug: roborock.0 (7107) Objects client ready ... initialize now
                                          2023-01-26 22:31:49.070 - debug: roborock.0 (7107) Objects create System PubSub Client
                                          2023-01-26 22:31:49.071 - debug: roborock.0 (7107) Objects create User PubSub Client
                                          2023-01-26 22:31:49.214 - debug: roborock.0 (7107) Objects client initialize lua scripts
                                          2023-01-26 22:31:49.222 - debug: roborock.0 (7107) Objects connected to redis: 127.0.0.1:9001
                                          2023-01-26 22:31:49.226 - silly: roborock.0 (7107) redis psubscribe cfg.o.system.user.*
                                          2023-01-26 22:31:49.285 - silly: roborock.0 (7107) redis psubscribe cfg.o.enum.*
                                          2023-01-26 22:31:49.292 - silly: roborock.0 (7107) objectDB connected
                                          2023-01-26 22:31:49.296 - debug: roborock.0 (7107) Redis States: Use Redis connection: 127.0.0.1:6379
                                          2023-01-26 22:31:49.305 - debug: roborock.0 (7107) States create System PubSub Client
                                          2023-01-26 22:31:49.307 - debug: roborock.0 (7107) States create User PubSub Client
                                          2023-01-26 22:31:49.320 - debug: roborock.0 (7107) States connected to redis: 127.0.0.1:6379
                                          2023-01-26 22:31:49.322 - silly: roborock.0 (7107) statesDB connected
                                          2023-01-26 22:31:49.599 - info: roborock.0 (7107) starting. Version 0.0.1 (non-npm: copystring/ioBroker.roborock#split_robots_into_classes) in /opt/iobroker/node_modules/iobroker.roborock, node: v16.19.0, js-controller: 4.0.24
                                          2023-01-26 22:31:49.741 - silly: roborock.0 (7107) States system redis pmessage io.system.adapter.roborock.0.logLevel/io.system.adapter.roborock.0.logLevel:{"val":"silly","ack":true,"ts":1674768709647,"q":0,"from":"system.adapter.roborock.0","lc":1674260525427}
                                          2023-01-26 22:31:49.853 - debug: roborock.0 (7107) RoomIDs debug: {"10467471":"Wohnzimmer","10467473":"Zimmer Domi","10467476":"Küche","10467477":"Schlafzimmer","10467479":"Bad","10467481":"Balkon","10467484":"Gang"}
                                          2023-01-26 22:31:49.931 - info: roborock.0 (7107) MQTT initialized
                                          2023-01-26 22:31:49.979 - debug: roborock.0 (7107) Robot key: roborock.vacuum.a15
                                          2023-01-26 22:31:50.437 - debug: roborock.0 (7107) Latest data requested
                                          2023-01-26 22:31:50.441 - debug: roborock.0 (7107) getParameter: get_mop_mode
                                          2023-01-26 22:31:50.446 - debug: roborock.0 (7107) getParameter: get_water_box_custom_mode
                                          2023-01-26 22:31:50.449 - debug: roborock.0 (7107) getParameter: get_status
                                          2023-01-26 22:31:50.450 - debug: roborock.0 (7107) getParameter: get_consumable
                                          2023-01-26 22:31:50.452 - debug: roborock.0 (7107) getParameter: get_network_info
                                          2023-01-26 22:31:50.454 - debug: roborock.0 (7107) getParameter: get_carpet_mode
                                          2023-01-26 22:31:50.456 - debug: roborock.0 (7107) getParameter: get_carpet_cleaning_mode
                                          2023-01-26 22:31:50.458 - debug: roborock.0 (7107) getParameter: get_fw_features
                                          2023-01-26 22:31:50.458 - debug: roborock.0 (7107) Firmware features request
                                          2023-01-26 22:31:50.459 - debug: roborock.0 (7107) getParameter: get_multi_maps_list
                                          2023-01-26 22:31:50.461 - debug: roborock.0 (7107) getParameter: get_room_mapping
                                          2023-01-26 22:31:50.461 - debug: roborock.0 (7107) get_room_mapping
                                          2023-01-26 22:31:50.545 - debug: roborock.0 (7107) dps debug: {"id":3,"result":[203]}
                                          2023-01-26 22:31:50.550 - debug: roborock.0 (7107) dps debug: {"id":4,"result":[{"msg_ver":2,"msg_seq":1521,"state":8,"battery":100,"clean_time":5104,"clean_area":46190000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                          2023-01-26 22:31:50.559 - debug: roborock.0 (7107) dps debug: {"id":1,"result":[300]}
                                          2023-01-26 22:31:50.563 - debug: roborock.0 (7107) dps debug: {"id":7,"result":{"clean_time":863797,"clean_area":13435762500,"clean_count":336,"dust_collection_count":0,"records":[1674725138,1674725117,1674725026,1674643201,1674470400,1674211201,1674038400,1673865601,1673606401,1673433600,1673260802,1673001600,1672828801,1672656000,1672396799,1672224000,1672051200,1671791332,1671619200,1671446400]}}
                                          2023-01-26 22:31:50.584 - debug: roborock.0 (7107) dps debug: {"id":9,"result":"unknown_method"}
                                          2023-01-26 22:31:50.586 - debug: roborock.0 (7107) Unknown parameter: "unknown_method"
                                          2023-01-26 22:31:50.588 - debug: roborock.0 (7107) dps debug: {"id":2,"result":[{"msg_ver":2,"msg_seq":1522,"state":8,"battery":100,"clean_time":5104,"clean_area":46190000,"error_code":0,"map_present":1,"in_cleaning":0,"in_returning":0,"in_fresh_state":1,"lab_status":1,"water_box_status":1,"fan_power":102,"dnd_enabled":1,"map_status":3,"is_locating":0,"lock_status":0,"water_box_mode":203,"water_box_carriage_status":0,"mop_forbidden_enable":0,"adbumper_status":[0,0,0],"water_shortage_status":0,"dock_type":0,"dust_collection_status":0,"auto_dust_collection":1,"mop_mode":300,"debug_mode":0,"dock_error_status":0,"unsave_map_reason":0,"unsave_map_flag":0}]}
                                          2023-01-26 22:31:50.591 - debug: roborock.0 (7107) dps debug: {"id":8,"result":[{"enable":1,"current_integral":450,"current_high":500,"current_low":400,"stall_time":10}]}
                                          2023-01-26 22:31:50.615 - debug: roborock.0 (7107) dps debug: {"id":10,"result":[111,112,113,114,115,116,117,118,119,120,122,123,124,125]}
                                          2023-01-26 22:31:50.619 - debug: roborock.0 (7107) dps debug: {"id":6,"result":{"ssid":"1.FCGlucke","ip":"192.168.2.102","mac":"b0:4a:39:04:69:e9","bssid":"44:4e:6d:69:b7:f1","rssi":-62}}
                                          2023-01-26 22:31:50.623 - debug: roborock.0 (7107) dps debug: {"id":11,"result":[{"max_multi_map":1,"max_bak_map":1,"multi_map_count":1,"map_info":[{"mapFlag":0,"add_time":1674730815,"length":10,"name":"Hauptkarte","bak_maps":[{"mapFlag":4,"add_time":1674646243}]}]}]}
                                          2023-01-26 22:31:50.627 - debug: roborock.0 (7107) dps debug: {"id":5,"result":[{"main_brush_work_time":863894,"side_brush_work_time":0,"filter_work_time":313720,"filter_element_work_time":0,"sensor_dirty_time":58909,"dust_collection_work_times":0}]}
                                          2023-01-26 22:31:50.632 - debug: roborock.0 (7107) dps debug: {"id":12,"result":[[16,"10467476"],[17,"10467479"],[18,"10467477"],[19,"10467481"],[20,"10467473"],[22,"10467471"],[23,"10467484"]]}
                                          2023-01-26 22:31:50.633 - debug: roborock.0 (7107) get_room_mapping: [[16,"10467476"],[17,"10467479"],[18,"10467477"],[19,"10467481"],[20,"10467473"],[22,"10467471"],[23,"10467484"]]
                                          2023-01-26 22:31:50.695 - debug: roborock.0 (7107) dps debug: {"id":13,"result":[{"begin":1674725138,"end":1674730242,"duration":5104,"area":46190000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.698 - debug: roborock.0 (7107) dps debug: {"id":17,"result":[{"begin":1674470400,"end":1674473247,"duration":2847,"area":45627500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.700 - debug: roborock.0 (7107) dps debug: {"id":14,"result":[{"begin":1674725117,"end":1674725124,"duration":2,"area":0,"error":0,"complete":0,"start_type":2,"clean_type":1,"finish_reason":43,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.703 - debug: roborock.0 (7107) dps debug: {"id":18,"result":[{"begin":1674211201,"end":1674214020,"duration":2819,"area":45745000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.705 - debug: roborock.0 (7107) dps debug: {"id":15,"result":[{"begin":1674725026,"end":1674725079,"duration":41,"area":920000,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":43,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.707 - debug: roborock.0 (7107) dps debug: {"id":16,"result":[{"begin":1674643201,"end":1674646187,"duration":2986,"area":45902500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.709 - debug: roborock.0 (7107) dps debug: {"id":19,"result":[{"begin":1674038400,"end":1674041195,"duration":2795,"area":45662500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.712 - debug: roborock.0 (7107) dps debug: {"id":20,"result":[{"begin":1673865601,"end":1673868654,"duration":3053,"area":45852500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.714 - debug: roborock.0 (7107) dps debug: {"id":24,"result":[{"begin":1673001600,"end":1673001754,"duration":147,"area":3327500,"error":0,"complete":0,"start_type":2,"clean_type":3,"finish_reason":60,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.716 - debug: roborock.0 (7107) dps debug: {"id":25,"result":[{"begin":1672828801,"end":1672831852,"duration":3051,"area":45580000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.718 - debug: roborock.0 (7107) dps debug: {"id":27,"result":[{"begin":1672396799,"end":1672399678,"duration":2879,"area":46062500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.720 - debug: roborock.0 (7107) dps debug: {"id":30,"result":[{"begin":1671791332,"end":1671794384,"duration":3051,"area":46140000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.721 - debug: roborock.0 (7107) dps debug: {"id":31,"result":[{"begin":1671619200,"end":1671622099,"duration":2898,"area":45690000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.723 - debug: roborock.0 (7107) dps debug: {"id":28,"result":[{"begin":1672224000,"end":1672226907,"duration":2907,"area":45725000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.725 - debug: roborock.0 (7107) dps debug: {"id":32,"result":[{"begin":1671446400,"end":1671449983,"duration":3583,"area":45985000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.727 - debug: roborock.0 (7107) dps debug: {"id":21,"result":[{"begin":1673606401,"end":1673609286,"duration":2885,"area":45722500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.729 - debug: roborock.0 (7107) dps debug: {"id":29,"result":[{"begin":1672051200,"end":1672054195,"duration":2995,"area":46020000,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.731 - debug: roborock.0 (7107) dps debug: {"id":26,"result":[{"begin":1672656000,"end":1672658889,"duration":2888,"area":45622500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.733 - debug: roborock.0 (7107) dps debug: {"id":23,"result":[{"begin":1673260802,"end":1673263712,"duration":2910,"area":45922500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:50.865 - debug: roborock.0 (7107) dps debug: {"id":22,"result":[{"begin":1673433600,"end":1673436525,"duration":2925,"area":45552500,"error":0,"complete":1,"start_type":2,"clean_type":3,"finish_reason":56,"dust_collection_status":0}]}
                                          2023-01-26 22:31:54.524 - silly: roborock.0 (7107) States user redis pmessage io.roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.commands.*/io.roborock.0.Devices.BzoCkI61lkZZ4dPedPre6.commands.load_multi_map:{"val":0,"ack":false,"ts":1674768714518,"q":0,"from":"system.adapter.admin.0","user":"system.user.admin","lc":1674726972089}
                                          2023-01-26 22:31:54.528 - debug: roborock.0 (7107) onStateChange: load_multi_map with value: 0
                                          2023-01-26 22:31:54.532 - error: roborock.0 (7107) Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
                                          2023-01-26 22:31:54.533 - error: roborock.0 (7107) unhandled promise rejection: Cannot read properties of undefined (reading 'command')
                                          2023-01-26 22:31:54.543 - error: roborock.0 (7107) TypeError: Cannot read properties of undefined (reading 'command')
                                          at Roborock.onStateChange (/opt/iobroker/node_modules/iobroker.roborock/main.js:274:25)
                                          at Roborock.emit (node:events:513:28)
                                          at Immediate. (/opt/iobroker/node_modules/@iobroker/js-controller-adapter/build/lib/adapter/adapter.js:5385:53)
                                          at processImmediate (node:internal/timers:466:21)
                                          2023-01-26 22:31:54.544 - error: roborock.0 (7107) Cannot read properties of undefined (reading 'command')
                                          2023-01-26 22:31:54.558 - info: roborock.0 (7107) terminating
                                          2023-01-26 22:31:54.561 - warn: roborock.0 (7107) Terminated (UNCAUGHT_EXCEPTION): Without reason
                                          2023-01-26 22:31:55.212 - error: host.raspberrypi-gang instance system.adapter.roborock.0 terminated with code 6 (UNCAUGHT_EXCEPTION)
                                          2023-01-26 22:31:55.212 - info: host.raspberrypi-gang Restart adapter system.adapter.roborock.0 because enabled
                                          2023-01-26 22:31:57.948 - info: host.raspberrypi-gang "system.adapter.roborock.0" disabled
                                          2023-01-26 22:32:27.491 - debug: roborock.0 (7494) Redis Objects: Use Redis connection: 127.0.0.1:9001
                                          2023-01-26 22:32:27.577 - debug: roborock.0 (7494) Objects client ready ... initialize now
                                          2023-01-26 22:32:27.579 - debug: roborock.0 (7494) Objects create System PubSub Client
                                          2023-01-26 22:32:27.581 - debug: roborock.0 (7494) Objects create User PubSub Client
                                          2023-01-26 22:32:27.730 - debug: roborock.0 (7494) Objects client initialize lua scripts
                                          2023-01-26 22:32:27.750 - debug: roborock.0 (7494) Objects connected to redis: 127.0.0.1:9001
                                          2023-01-26 22:32:27.754 - silly: roborock.0 (7494) redis psubscribe cfg.o.system.user.*
                                          2023-01-26 22:32:27.819 - silly: roborock.0 (7494) redis psubscribe cfg.o.enum.*
                                          2023-01-26 22:32:27.826 - silly: roborock.0 (7494) objectDB connected
                                          2023-01-26 22:32:27.830 - debug: roborock.0 (7494) Redis States: Use Redis connection: 127.0.0.1:6379
                                          2023-01-26 22:32:27.839 - debug: roborock.0 (7494) States create System PubSub Client
                                          2023-01-26 22:32:27.842 - debug: roborock.0 (7494) States create User PubSub Client
                                          2023-01-26 22:32:27.853 - debug: roborock.0 (7494) States connected to redis: 127.0.0.1:6379
                                          2023-01-26 22:32:27.855 - silly: roborock.0 (7494) statesDB connected
                                          2023-01-26 22:32:27.892 - error: roborock.0 (7494) adapter disabled
                                          2023-01-26 22:32:27.903 - warn: roborock.0 (7494) Terminated (NO_ADAPTER_CONFIG_FOUND): Without reason
                                          2023-01-26 22:32:28.611 - error: host.raspberrypi-gang instance system.adapter.roborock.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                                          Ist das schon bekannt bzw. soll das in diesem Branch noch gar nicht funktionieren?
                                          84.1k
