  4. Freier Arbeitsspeicher nimmt schnell ab ...
    5.5k
88 Beiträge 7 Kommentatoren 11.0k Aufrufe 5 Beobachtet
    @sms sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
    readlink: missing operand
    Das sind auch schon komische Meldungen da. Normalerweise tauchen die nicht auf.
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    liefert?
    Und
    sudo apt update
    apt policy libcap2-bin
    • SMSS SMS
      @thomas-braun schon mehrfach gemacht
      pi@MotionEye:~ $ iob fix
      library: loaded
      Library version=2022-12-09
          Welcome to the ioBroker installation fixer!
          Script version: 2022-12-22
          You might need to enter your password a couple of times.
          Installing prerequisites (1/4)
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
      Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists... Done
      Installed gcc-c++
      Try 'readlink --help' for more information.
      usage: setcap [-q] [-v] [-n <rootid>] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
       Note <filename> must be a regular (non-symlink) file.
          Checking ioBroker user and directory permissions (2/4)
          Database maintenance (3/4)
      Checking for uncompressed JSONL databases... This might take a while!
      usage: sudo -h | -K | -k | -V
      usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
      usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
                  [command]
      usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                  [-h host] [-p prompt] [-R directory] [-T timeout] [-u user]
                  [VAR=value] [-i|-s] [<command>]
      usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                  [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
      main: line 12: [: -lt: unary operator expected
      sudo: npm: command not found
          Checking autostart (4/4)
      Enabling autostart...
      Autostart enabled!
          Your installation was fixed successfully
          Run iobroker start to start ioBroker again!
      @sms
      sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
        liefert?
        SMSS Offline
        SMSS Offline
        SMS
        @thomas-braun sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
        liefert?
        wie gebe ich das ein?
        • SMSS SMS
          liefert?
          Wie meinst du das?
          Eingeben oder in die Konsole pasten.
          Ich würde es kopieren/pasten...
          SMSS 1 Antwort Letzte Antwort
            Wie meinst du das?
            SMSS Offline
            SMSS Offline
            SMS
            schrieb am zuletzt editiert von SMS
            @thomas-braun so?
            pi@MotionEye:/ $
            aarch64
            pi@MotionEye:/ $
            oder
            pi@MotionEye:/ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
            pi@MotionEye:/ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs                                       aarch64
            pi@MotionEye:/ $
            • SMSS SMS
              @thomas-braun so?
              pi@MotionEye:/ $
              aarch64
              pi@MotionEye:/ $
              oder
              pi@MotionEye:/ $
              @sms
              Ja, allerdings sieht das auf einem gesunden System so aus:
              echad@chet:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
              aarch64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              /usr/bin/npx
              v19.4.0
              v19.4.0
              9.2.0
              9.2.0
              4.0.24
              echad
              echad adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin boinc gpio i2c spi iobroker
              tty
              /home/echad
              Da ist wohl nodejs kaputt.
                @sms
                aarch64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                v19.4.0
                v19.4.0
                9.2.0
                9.2.0
                4.0.24
                echad
                tty
                /home/echad
                SMSS Offline
                SMSS Offline
                SMS
                @thomas-braun und wie bekomme ich das wieder hin?
                • SMSS SMS
                  @sms
                  sudo apt update
                  apt policy nodejs
                  SMSS 2 Antworten Letzte Antwort
                    @sms
                    sudo apt update
                    apt policy nodejs
                    SMSS Offline
                    SMSS Offline
                    SMS
                    @thomas-braun liegt es vielleicht daran, das 14 und 16 drauf sind?
                    pi@MotionEye:/ $ sudo apt update
                    Hit:1 http://deb.debian.org/debian bullseye InRelease
                    Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                    Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                    Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                    All packages are up to date.
                    pi@MotionEye:/ $
                    • SMSS SMS
                      @sms
                      Und warum steht der 'pi' nicht in seinem Home-Verzeichnis?
                      Schubs denn da mal hin:
                      cd ~
                        @sms
                        sudo apt update
                        apt policy nodejs
                        SMSS Offline
                        SMSS Offline
                        SMS
                        pi@MotionEye:/ $ apt policy nodejs
                        nodejs:
                          Installed: (none)
                          Candidate: 16.19.0-deb-1nodesource1
                          Version table:
                             16.19.0-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                             14.21.2-deb-1nodesource1 500
                                500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                             12.22.12~dfsg-1~deb11u1 500
                                500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                             12.22.5~dfsg-2~11u1 500
                                500 http://deb.debian.org/debian bullseye/main arm64 Packages
                        pi@MotionEye:/ $
                        • SMSS SMS
                          nodejs:
                            Installed: (none)
                            Version table:
                          pi@MotionEye:/ $
                          Installed: (none)
                          ? Wie schafft man das?
                          sudo apt install nodejs
                            Installed: (none)
                            SMSS Offline
                            SMSS Offline
                            SMS
                            #66
                            pi@MotionEye:~ $ sudo apt install nodejs
                            The following NEW packages will be installed:
                              nodejs
                            0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                            Need to get 26.6 MB of archives.
                            After this operation, 128 MB of additional disk space will be used.
                            Get:1 https://deb.nodesource.com/node_16.x bullseye/main arm64 nodejs arm64 16.19.0-deb-1nodesource1 [26.6 MB]
                            Fetched 26.6 MB in 1s (19.0 MB/s)
                            Selecting previously unselected package nodejs.
                            (Reading database ... 49321 files and directories currently installed.)
                            Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_arm64.deb ...
                            Unpacking nodejs (16.19.0-deb-1nodesource1) ...
                            Setting up nodejs (16.19.0-deb-1nodesource1) ...
                            Processing triggers for man-db (2.9.4-2) ...
                            Neustart?
                            • SMSS SMS
                                nodejs
                              Neustart?
                              #67
                              @sms
                              sagt nun?
                                @sms
                                sagt nun?
                                SMSS Offline
                                SMSS Offline
                                SMS
                                #68
                                pi@MotionEye:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                                aarch64
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                /usr/bin/npx
                                v16.19.0
                                v16.19.0
                                8.19.3
                                8.19.3
                                4.0.23
                                pi
                                pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                tty
                                /home/pi
                                Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                nodejs:
                                  Installed: 16.19.0-deb-1nodesource1
                                  Version table:
                                 *** 16.19.0-deb-1nodesource1 500
                                pi@MotionEye:~ $
                                • SMSS SMS
                                  aarch64
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  /usr/bin/npx
                                  v16.19.0
                                  v16.19.0
                                  8.19.3
                                  8.19.3
                                  4.0.23
                                  pi
                                  tty
                                  /home/pi
                                  nodejs:
                                    Version table:
                                  pi@MotionEye:~ $
                                  #69
                                  @sms
                                  Ja, so soll das aussehen.
                                  iobroker restart
                                    @sms
                                    iobroker restart
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    #70
                                    iobroker restart
                                    läuft! Jetzt noch ein update
                                    Jetzt muss auf dem Master nur wieder mqtt laufen
                                    mqtt.0
                                    2023-01-14 21:18:48.379	info	Starting MQTT-WebSocket authenticated server on 0.0.0.0:1887
                                    mqtt.0
                                    2023-01-14 21:18:48.377	info	Starting MQTT authenticated server on 0.0.0.0:1886
                                    mqtt.0
                                    2023-01-14 21:18:47.933	info	starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.mqtt, node: v16.19.0, js-controller: 4.0.24
                                    mqtt.0
                                    2023-01-14 21:18:30.746	info	Terminated (NO_ERROR): Without reason
                                    mqtt.0
                                    2023-01-14 21:18:30.744	info	terminating
                                    mqtt.0
                                    2023-01-14 21:18:30.313	info	Got terminate signal TERMINATE_YOURSELF
                                    mqtt.0
                                    2023-01-14 21:18:30.225	info	Adapter is disabled => stop
                                    • SMSS SMS
                                      iobroker restart
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      mqtt.0
                                      #71
                                      das tut er!
                                      hat wahrscheinlich nur keinen Kontakt zu einem Client.
                                      Aber dass du nicht die Standardports verwendest weisst du?
                                        das tut er!
                                        SMSS Offline
                                        SMSS Offline
                                        SMS
                                        #72
                                        @homoran hm, aber welcher
                                        HomoranH crunchipC 2 Antworten Letzte Antwort
                                        • SMSS SMS
                                          #73
                                          was?
