  4. Freier Arbeitsspeicher nimmt schnell ab ...
    5.5k
88 Beiträge 7 Kommentatoren 11.0k Aufrufe 5 Beobachtet
    @sms
    Jag den fixer mal über das System.
    SMSS Offline
    SMSS Offline
    SMS
    @thomas-braun schon mehrfach gemacht
    pi@MotionEye:~ $ iob fix
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2022-12-22
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    Installed gcc-c++
    readlink: missing operand
    Try 'readlink --help' for more information.
    usage: setcap [-q] [-v] [-n <rootid>] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
     Note <filename> must be a regular (non-symlink) file.
        Checking ioBroker user and directory permissions (2/4)
        Database maintenance (3/4)
    Checking for uncompressed JSONL databases... This might take a while!
    usage: sudo -h | -K | -k | -V
    usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
    usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
                [command]
    usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                [-h host] [-p prompt] [-R directory] [-T timeout] [-u user]
                [VAR=value] [-i|-s] [<command>]
    usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
    main: line 12: [: -lt: unary operator expected
    sudo: npm: command not found
        Checking autostart (4/4)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    • SMSS SMS
      library: loaded
      Installed gcc-c++
                  [command]
      Autostart enabled!
      @sms sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
      Das sind auch schon komische Meldungen da. Normalerweise tauchen die nicht auf.
      sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
      liefert?
      Thomas BraunT SMSS 2 Antworten Letzte Antwort
        liefert?
        Und
        sudo apt update
        apt policy libcap2-bin
        • SMSS SMS
          library: loaded
          Installed gcc-c++
                      [command]
          Autostart enabled!
          @sms
          sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
            liefert?
            SMSS Offline
            SMSS Offline
            SMS
            @thomas-braun sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
            liefert?
            wie gebe ich das ein?
            • SMSS SMS
              liefert?
              Wie meinst du das?
              Eingeben oder in die Konsole pasten.
              Ich würde es kopieren/pasten...
              SMSS 1 Antwort Letzte Antwort
                Wie meinst du das?
                SMSS Offline
                SMSS Offline
                SMS
                schrieb am zuletzt editiert von SMS
                @thomas-braun so?
                pi@MotionEye:/ $
                aarch64
                pi@MotionEye:/ $
                oder
                pi@MotionEye:/ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                pi@MotionEye:/ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs                                       aarch64
                pi@MotionEye:/ $
                • SMSS SMS
                  @thomas-braun so?
                  pi@MotionEye:/ $
                  aarch64
                  pi@MotionEye:/ $
                  oder
                  pi@MotionEye:/ $
                  @sms
                  Ja, allerdings sieht das auf einem gesunden System so aus:
                  echad@chet:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                  aarch64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v19.4.0
                  v19.4.0
                  9.2.0
                  9.2.0
                  4.0.24
                  echad
                  echad adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin boinc gpio i2c spi iobroker
                  tty
                  /home/echad
                  Da ist wohl nodejs kaputt.
                    @sms
                    aarch64
                    /usr/bin/nodejs
                    /usr/bin/node
                    /usr/bin/npm
                    /usr/bin/npx
                    v19.4.0
                    v19.4.0
                    9.2.0
                    9.2.0
                    4.0.24
                    echad
                    tty
                    /home/echad
                    SMSS Offline
                    SMSS Offline
                    SMS
                    @thomas-braun und wie bekomme ich das wieder hin?
                    • SMSS SMS
                      @sms
                      sudo apt update
                      apt policy nodejs
                        @sms
                        sudo apt update
                        apt policy nodejs
                        SMSS Offline
                        SMSS Offline
                        SMS
                        @thomas-braun liegt es vielleicht daran, das 14 und 16 drauf sind?
                        pi@MotionEye:/ $ sudo apt update
                        Hit:1 http://deb.debian.org/debian bullseye InRelease
                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                        All packages are up to date.
                        pi@MotionEye:/ $
                        • SMSS SMS
                          @sms
                          Und warum steht der 'pi' nicht in seinem Home-Verzeichnis?
                          Schubs denn da mal hin:
                          cd ~
                            @sms
                            sudo apt update
                            apt policy nodejs
                            SMSS Offline
                            SMSS Offline
                            SMS
                            pi@MotionEye:/ $ apt policy nodejs
                            nodejs:
                              Installed: (none)
                              Candidate: 16.19.0-deb-1nodesource1
                              Version table:
                                 16.19.0-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                 14.21.2-deb-1nodesource1 500
                                    500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                                 12.22.12~dfsg-1~deb11u1 500
                                    500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                 12.22.5~dfsg-2~11u1 500
                                    500 http://deb.debian.org/debian bullseye/main arm64 Packages
                            pi@MotionEye:/ $
                            • SMSS SMS
                              nodejs:
                                Installed: (none)
                                Version table:
                              pi@MotionEye:/ $
                              Installed: (none)
                              ? Wie schafft man das?
                              sudo apt install nodejs
                                Installed: (none)
                                SMSS Offline
                                SMSS Offline
                                SMS
                                #66
                                pi@MotionEye:~ $ sudo apt install nodejs
                                The following NEW packages will be installed:
                                  nodejs
                                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                Need to get 26.6 MB of archives.
                                After this operation, 128 MB of additional disk space will be used.
                                Get:1 https://deb.nodesource.com/node_16.x bullseye/main arm64 nodejs arm64 16.19.0-deb-1nodesource1 [26.6 MB]
                                Fetched 26.6 MB in 1s (19.0 MB/s)
                                Selecting previously unselected package nodejs.
                                (Reading database ... 49321 files and directories currently installed.)
                                Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_arm64.deb ...
                                Unpacking nodejs (16.19.0-deb-1nodesource1) ...
                                Setting up nodejs (16.19.0-deb-1nodesource1) ...
                                Processing triggers for man-db (2.9.4-2) ...
                                Neustart?
                                • SMSS SMS
                                    nodejs
                                  Neustart?
                                  #67
                                  @sms
                                  sagt nun?
                                    @sms
                                    sagt nun?
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    #68
                                    pi@MotionEye:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                                    aarch64
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/bin/npx
                                    v16.19.0
                                    v16.19.0
                                    8.19.3
                                    8.19.3
                                    4.0.23
                                    pi
                                    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                    tty
                                    /home/pi
                                    Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                    nodejs:
                                      Installed: 16.19.0-deb-1nodesource1
                                      Version table:
                                     *** 16.19.0-deb-1nodesource1 500
                                    pi@MotionEye:~ $
                                    • SMSS SMS
                                      aarch64
                                      /usr/bin/nodejs
                                      /usr/bin/node
                                      /usr/bin/npm
                                      /usr/bin/npx
                                      v16.19.0
                                      v16.19.0
                                      8.19.3
                                      8.19.3
                                      4.0.23
                                      pi
                                      tty
                                      /home/pi
                                      nodejs:
                                        Version table:
                                      pi@MotionEye:~ $
                                      #69
                                      @sms
                                      Ja, so soll das aussehen.
                                      iobroker restart
                                        @sms
                                        iobroker restart
                                        SMSS Offline
                                        SMSS Offline
                                        SMS
                                        #70
                                        iobroker restart
                                        läuft! Jetzt noch ein update
                                        Jetzt muss auf dem Master nur wieder mqtt laufen
                                        mqtt.0
                                        2023-01-14 21:18:48.379	info	Starting MQTT-WebSocket authenticated server on 0.0.0.0:1887
                                        mqtt.0
                                        2023-01-14 21:18:48.377	info	Starting MQTT authenticated server on 0.0.0.0:1886
                                        mqtt.0
                                        2023-01-14 21:18:47.933	info	starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.mqtt, node: v16.19.0, js-controller: 4.0.24
                                        mqtt.0
                                        2023-01-14 21:18:30.746	info	Terminated (NO_ERROR): Without reason
                                        mqtt.0
                                        2023-01-14 21:18:30.744	info	terminating
                                        mqtt.0
                                        2023-01-14 21:18:30.313	info	Got terminate signal TERMINATE_YOURSELF
                                        mqtt.0
                                        2023-01-14 21:18:30.225	info	Adapter is disabled => stop
                                        • SMSS SMS
                                          iobroker restart
                                          mqtt.0
                                          mqtt.0
                                          mqtt.0
                                          mqtt.0
                                          mqtt.0
                                          mqtt.0
                                          mqtt.0
                                          #71
                                          das tut er!
                                          hat wahrscheinlich nur keinen Kontakt zu einem Client.
                                          Aber dass du nicht die Standardports verwendest weisst du?
