  4. Freier Arbeitsspeicher nimmt schnell ab ...
    5.5k
88 Beiträge 7 Kommentatoren 11.0k Aufrufe 5 Beobachtet
  • SMSS SMS
    @thomas-braun schon mehrfach gemacht
    pi@MotionEye:~ $ iob fix
    library: loaded
    Library version=2022-12-09
        Welcome to the ioBroker installation fixer!
        Script version: 2022-12-22
        You might need to enter your password a couple of times.
        Installing prerequisites (1/4)
    Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
    Hit:2 http://deb.debian.org/debian bullseye InRelease
    Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
    Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
    Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists... Done
    Installed gcc-c++
    readlink: missing operand
    Try 'readlink --help' for more information.
    usage: setcap [-q] [-v] [-n <rootid>] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
     Note <filename> must be a regular (non-symlink) file.
        Checking ioBroker user and directory permissions (2/4)
        Database maintenance (3/4)
    Checking for uncompressed JSONL databases... This might take a while!
    usage: sudo -h | -K | -k | -V
    usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
    usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
                [command]
    usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                [-h host] [-p prompt] [-R directory] [-T timeout] [-u user]
                [VAR=value] [-i|-s] [<command>]
    usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
    main: line 12: [: -lt: unary operator expected
    sudo: npm: command not found
        Checking autostart (4/4)
    Enabling autostart...
    Autostart enabled!
        Your installation was fixed successfully
        Run iobroker start to start ioBroker again!
    @sms sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
    Das sind auch schon komische Meldungen da. Normalerweise tauchen die nicht auf.
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
    liefert?
    Thomas BraunT SMSS 2 Antworten Letzte Antwort
      liefert?
      Und
      sudo apt update
      apt policy libcap2-bin
      • SMSS SMS
        library: loaded
        Installed gcc-c++
                    [command]
        Autostart enabled!
        @sms
        sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
          liefert?
          SMSS Offline
          SMSS Offline
          SMS
          @thomas-braun sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
          liefert?
          wie gebe ich das ein?
          • SMSS SMS
            liefert?
            Wie meinst du das?
            Eingeben oder in die Konsole pasten.
            Ich würde es kopieren/pasten...
            SMSS 1 Antwort Letzte Antwort
              Wie meinst du das?
              SMSS Offline
              SMSS Offline
              SMS
              schrieb am zuletzt editiert von SMS
              @thomas-braun so?
              pi@MotionEye:/ $
              aarch64
              pi@MotionEye:/ $
              oder
              pi@MotionEye:/ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
              pi@MotionEye:/ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs                                       aarch64
              pi@MotionEye:/ $
              • SMSS SMS
                @thomas-braun so?
                pi@MotionEye:/ $
                aarch64
                pi@MotionEye:/ $
                oder
                pi@MotionEye:/ $
                @sms
                Ja, allerdings sieht das auf einem gesunden System so aus:
                echad@chet:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                aarch64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                /usr/bin/npx
                v19.4.0
                v19.4.0
                9.2.0
                9.2.0
                4.0.24
                echad
                echad adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin boinc gpio i2c spi iobroker
                tty
                /home/echad
                Da ist wohl nodejs kaputt.
                  @sms
                  aarch64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  /usr/bin/npx
                  v19.4.0
                  v19.4.0
                  9.2.0
                  9.2.0
                  4.0.24
                  echad
                  tty
                  /home/echad
                  SMSS Offline
                  SMSS Offline
                  SMS
                  @thomas-braun und wie bekomme ich das wieder hin?
                  • SMSS SMS
                    @sms
                    sudo apt update
                    apt policy nodejs
                      @sms
                      sudo apt update
                      apt policy nodejs
                      SMSS Offline
                      SMSS Offline
                      SMS
                      @thomas-braun liegt es vielleicht daran, das 14 und 16 drauf sind?
                      pi@MotionEye:/ $ sudo apt update
                      Hit:1 http://deb.debian.org/debian bullseye InRelease
                      Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                      All packages are up to date.
                      pi@MotionEye:/ $
                      • SMSS SMS
                        @sms
                        Und warum steht der 'pi' nicht in seinem Home-Verzeichnis?
                        Schubs denn da mal hin:
                        cd ~
                          @sms
                          sudo apt update
                          apt policy nodejs
                          SMSS Offline
                          SMSS Offline
                          SMS
                          pi@MotionEye:/ $ apt policy nodejs
                          nodejs:
                            Installed: (none)
                            Candidate: 16.19.0-deb-1nodesource1
                            Version table:
                               16.19.0-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                               14.21.2-deb-1nodesource1 500
                                  500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                               12.22.12~dfsg-1~deb11u1 500
                                  500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                               12.22.5~dfsg-2~11u1 500
                                  500 http://deb.debian.org/debian bullseye/main arm64 Packages
                          pi@MotionEye:/ $
                          • SMSS SMS
                            nodejs:
                              Installed: (none)
                              Version table:
                            pi@MotionEye:/ $
                            Installed: (none)
                            ? Wie schafft man das?
                            sudo apt install nodejs
                              Installed: (none)
                              SMSS Offline
                              SMSS Offline
                              SMS
                              #66
                              pi@MotionEye:~ $ sudo apt install nodejs
                              The following NEW packages will be installed:
                                nodejs
                              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                              Need to get 26.6 MB of archives.
                              After this operation, 128 MB of additional disk space will be used.
                              Get:1 https://deb.nodesource.com/node_16.x bullseye/main arm64 nodejs arm64 16.19.0-deb-1nodesource1 [26.6 MB]
                              Fetched 26.6 MB in 1s (19.0 MB/s)
                              Selecting previously unselected package nodejs.
                              (Reading database ... 49321 files and directories currently installed.)
                              Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_arm64.deb ...
                              Unpacking nodejs (16.19.0-deb-1nodesource1) ...
                              Setting up nodejs (16.19.0-deb-1nodesource1) ...
                              Processing triggers for man-db (2.9.4-2) ...
                              Neustart?
                              • SMSS SMS
                                  nodejs
                                Neustart?
                                #67
                                @sms
                                sagt nun?
                                  @sms
                                  sagt nun?
                                  SMSS Offline
                                  SMSS Offline
                                  SMS
                                  #68
                                  pi@MotionEye:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                                  aarch64
                                  /usr/bin/nodejs
                                  /usr/bin/node
                                  /usr/bin/npm
                                  /usr/bin/npx
                                  v16.19.0
                                  v16.19.0
                                  8.19.3
                                  8.19.3
                                  4.0.23
                                  pi
                                  pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                  tty
                                  /home/pi
                                  Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                  nodejs:
                                    Installed: 16.19.0-deb-1nodesource1
                                    Version table:
                                   *** 16.19.0-deb-1nodesource1 500
                                  pi@MotionEye:~ $
                                  • SMSS SMS
                                    aarch64
                                    /usr/bin/nodejs
                                    /usr/bin/node
                                    /usr/bin/npm
                                    /usr/bin/npx
                                    v16.19.0
                                    v16.19.0
                                    8.19.3
                                    8.19.3
                                    4.0.23
                                    pi
                                    tty
                                    /home/pi
                                    nodejs:
                                      Version table:
                                    pi@MotionEye:~ $
                                    #69
                                    @sms
                                    Ja, so soll das aussehen.
                                    iobroker restart
                                      @sms
                                      iobroker restart
                                      SMSS Offline
                                      SMSS Offline
                                      SMS
                                      #70
                                      iobroker restart
                                      läuft! Jetzt noch ein update
                                      Jetzt muss auf dem Master nur wieder mqtt laufen
                                      mqtt.0
                                      2023-01-14 21:18:48.379	info	Starting MQTT-WebSocket authenticated server on 0.0.0.0:1887
                                      mqtt.0
                                      2023-01-14 21:18:48.377	info	Starting MQTT authenticated server on 0.0.0.0:1886
                                      mqtt.0
                                      2023-01-14 21:18:47.933	info	starting. Version 4.0.7 in /opt/iobroker/node_modules/iobroker.mqtt, node: v16.19.0, js-controller: 4.0.24
                                      mqtt.0
                                      2023-01-14 21:18:30.746	info	Terminated (NO_ERROR): Without reason
                                      mqtt.0
                                      2023-01-14 21:18:30.744	info	terminating
                                      mqtt.0
                                      2023-01-14 21:18:30.313	info	Got terminate signal TERMINATE_YOURSELF
                                      mqtt.0
                                      2023-01-14 21:18:30.225	info	Adapter is disabled => stop
                                      • SMSS SMS
                                        iobroker restart
                                        mqtt.0
                                        mqtt.0
                                        mqtt.0
                                        mqtt.0
                                        mqtt.0
                                        mqtt.0
                                        mqtt.0
                                        #71
                                        das tut er!
                                        hat wahrscheinlich nur keinen Kontakt zu einem Client.
                                        Aber dass du nicht die Standardports verwendest weisst du?
                                          das tut er!
                                          SMSS Offline
                                          SMSS Offline
                                          SMS
                                          #72
                                          @homoran hm, aber welcher
                                          HomoranH crunchipC 2 Antworten Letzte Antwort
