  4. Freier Arbeitsspeicher nimmt schnell ab ...
    5.5k
88 Beiträge 7 Kommentatoren 11.0k Aufrufe 5 Beobachtet
    @sms
    sudo whoami
    sagt z. B.
    SMSS Offline
    SMSS Offline
    SMS
    @thomas-braun sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
    sudo whoami
    pi@MotionEye:~ $ sudo whoami
    root
    pi@MotionEye:~ $
    • SMSS SMS
      sudo whoami
      root
      pi@MotionEye:~ $
      @sms
      Jag den fixer mal über das System.
      SMSS 1 Antwort Letzte Antwort
        @sms
        SMSS Offline
        SMSS Offline
        SMS
        @thomas-braun schon mehrfach gemacht
        pi@MotionEye:~ $ iob fix
        library: loaded
        Library version=2022-12-09
            Welcome to the ioBroker installation fixer!
            Script version: 2022-12-22
            You might need to enter your password a couple of times.
            Installing prerequisites (1/4)
        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
        Hit:2 http://deb.debian.org/debian bullseye InRelease
        Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
        Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
        Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
        Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
        Reading package lists... Done
        Installed gcc-c++
        readlink: missing operand
        Try 'readlink --help' for more information.
        usage: setcap [-q] [-v] [-n <rootid>] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
         Note <filename> must be a regular (non-symlink) file.
            Checking ioBroker user and directory permissions (2/4)
            Database maintenance (3/4)
        Checking for uncompressed JSONL databases... This might take a while!
        usage: sudo -h | -K | -k | -V
        usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
        usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
                    [command]
        usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                    [-h host] [-p prompt] [-R directory] [-T timeout] [-u user]
                    [VAR=value] [-i|-s] [<command>]
        usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                    [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
        main: line 12: [: -lt: unary operator expected
        sudo: npm: command not found
            Checking autostart (4/4)
        Enabling autostart...
        Autostart enabled!
            Your installation was fixed successfully
            Run iobroker start to start ioBroker again!
        • SMSS SMS
          library: loaded
          Installed gcc-c++
                      [command]
          Autostart enabled!
          @sms sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
          Das sind auch schon komische Meldungen da. Normalerweise tauchen die nicht auf.
          sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
          uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
          liefert?
          Thomas BraunT SMSS 2 Antworten Letzte Antwort
            liefert?
            Und
            sudo apt update
            apt policy libcap2-bin
            • SMSS SMS
              library: loaded
              Installed gcc-c++
                          [command]
              Autostart enabled!
              @sms
              sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                liefert?
                SMSS Offline
                SMSS Offline
                SMS
                liefert?
                wie gebe ich das ein?
                • SMSS SMS
                  liefert?
                  Wie meinst du das?
                  Eingeben oder in die Konsole pasten.
                  Ich würde es kopieren/pasten...
                    Wie meinst du das?
                    SMSS Offline
                    SMSS Offline
                    SMS
                    schrieb am zuletzt editiert von SMS
                    @thomas-braun so?
                    pi@MotionEye:/ $
                    aarch64
                    pi@MotionEye:/ $
                    oder
                    pi@MotionEye:/ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                    pi@MotionEye:/ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs                                       aarch64
                    pi@MotionEye:/ $
                    • SMSS SMS
                      @thomas-braun so?
                      pi@MotionEye:/ $
                      aarch64
                      pi@MotionEye:/ $
                      oder
                      pi@MotionEye:/ $
                      @sms
                      Ja, allerdings sieht das auf einem gesunden System so aus:
                      echad@chet:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                      aarch64
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      /usr/bin/npx
                      v19.4.0
                      v19.4.0
                      9.2.0
                      9.2.0
                      4.0.24
                      echad
                      echad adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin boinc gpio i2c spi iobroker
                      tty
                      /home/echad
                      Da ist wohl nodejs kaputt.
                        @sms
                        aarch64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        /usr/bin/npx
                        v19.4.0
                        v19.4.0
                        9.2.0
                        9.2.0
                        4.0.24
                        echad
                        tty
                        /home/echad
                        SMSS Offline
                        SMSS Offline
                        SMS
                        @thomas-braun und wie bekomme ich das wieder hin?
                        • SMSS SMS
                          @sms
                          sudo apt update
                          apt policy nodejs
                            @sms
                            sudo apt update
                            apt policy nodejs
                            SMSS Offline
                            SMSS Offline
                            SMS
                            @thomas-braun liegt es vielleicht daran, das 14 und 16 drauf sind?
                            pi@MotionEye:/ $ sudo apt update
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                            All packages are up to date.
                            pi@MotionEye:/ $
                            • SMSS SMS
                              @sms
                              Und warum steht der 'pi' nicht in seinem Home-Verzeichnis?
                              Schubs denn da mal hin:
                              cd ~
                                @sms
                                sudo apt update
                                apt policy nodejs
                                SMSS Offline
                                SMSS Offline
                                SMS
                                pi@MotionEye:/ $ apt policy nodejs
                                nodejs:
                                  Installed: (none)
                                  Candidate: 16.19.0-deb-1nodesource1
                                  Version table:
                                     16.19.0-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                     14.21.2-deb-1nodesource1 500
                                        500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                                     12.22.12~dfsg-1~deb11u1 500
                                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                     12.22.5~dfsg-2~11u1 500
                                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                pi@MotionEye:/ $
                                • SMSS SMS
                                  nodejs:
                                    Installed: (none)
                                    Version table:
                                  pi@MotionEye:/ $
                                  Installed: (none)
                                  ? Wie schafft man das?
                                  sudo apt install nodejs
                                    Installed: (none)
                                    SMSS Offline
                                    SMSS Offline
                                    SMS
                                    #66
                                    pi@MotionEye:~ $ sudo apt install nodejs
                                    The following NEW packages will be installed:
                                      nodejs
                                    0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                    Need to get 26.6 MB of archives.
                                    After this operation, 128 MB of additional disk space will be used.
                                    Get:1 https://deb.nodesource.com/node_16.x bullseye/main arm64 nodejs arm64 16.19.0-deb-1nodesource1 [26.6 MB]
                                    Fetched 26.6 MB in 1s (19.0 MB/s)
                                    Selecting previously unselected package nodejs.
                                    (Reading database ... 49321 files and directories currently installed.)
                                    Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_arm64.deb ...
                                    Unpacking nodejs (16.19.0-deb-1nodesource1) ...
                                    Setting up nodejs (16.19.0-deb-1nodesource1) ...
                                    Processing triggers for man-db (2.9.4-2) ...
                                    Neustart?
                                    • SMSS SMS
                                        nodejs
                                      Neustart?
                                      #67
                                      @sms
                                      sagt nun?
                                        @sms
                                        sagt nun?
                                        SMSS Offline
                                        SMSS Offline
                                        SMS
                                        #68
                                        pi@MotionEye:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                                        aarch64
                                        /usr/bin/nodejs
                                        /usr/bin/node
                                        /usr/bin/npm
                                        /usr/bin/npx
                                        v16.19.0
                                        v16.19.0
                                        8.19.3
                                        8.19.3
                                        4.0.23
                                        pi
                                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        tty
                                        /home/pi
                                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                        nodejs:
                                          Installed: 16.19.0-deb-1nodesource1
                                          Version table:
                                         *** 16.19.0-deb-1nodesource1 500
                                        pi@MotionEye:~ $
                                        • SMSS SMS
                                          aarch64
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          /usr/bin/npx
                                          v16.19.0
                                          v16.19.0
                                          8.19.3
                                          8.19.3
                                          4.0.23
                                          pi
                                          tty
                                          /home/pi
                                          nodejs:
                                            Version table:
                                          pi@MotionEye:~ $
                                          #69
                                          @sms
                                          Ja, so soll das aussehen.
                                          iobroker restart
