  4. Freier Arbeitsspeicher nimmt schnell ab ...
    5.5k
88 Beiträge 7 Kommentatoren 11.0k Aufrufe 5 Beobachtet
  • SMSS SMS
    @thomas-braun sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
    iobroker status
    pi@MotionEye:~ $ iobroker status
    sudo: node: command not found
    pi@MotionEye:~ $
    seltsam!
    @sms
    sudo whoami
    sagt z. B.
    SMSS 1 Antwort Letzte Antwort
      @sms
      sudo whoami
      sagt z. B.
      SMSS Offline
      SMSS Offline
      SMS
      sudo whoami
      pi@MotionEye:~ $ sudo whoami
      root
      pi@MotionEye:~ $
      • SMSS SMS
        sudo whoami
        root
        pi@MotionEye:~ $
        @sms
        Jag den fixer mal über das System.
          @sms
          SMSS Offline
          SMSS Offline
          SMS
          @thomas-braun schon mehrfach gemacht
          pi@MotionEye:~ $ iob fix
          library: loaded
          Library version=2022-12-09
              Welcome to the ioBroker installation fixer!
              Script version: 2022-12-22
              You might need to enter your password a couple of times.
              Installing prerequisites (1/4)
          Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
          Hit:2 http://deb.debian.org/debian bullseye InRelease
          Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
          Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
          Hit:5 https://deb.nodesource.com/node_14.x bullseye InRelease
          Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
          Reading package lists... Done
          Installed gcc-c++
          readlink: missing operand
          Try 'readlink --help' for more information.
          usage: setcap [-q] [-v] [-n <rootid>] (-r|-|<caps>) <filename> [ ... (-r|-|<capsN>) <filenameN> ]
           Note <filename> must be a regular (non-symlink) file.
              Checking ioBroker user and directory permissions (2/4)
              Database maintenance (3/4)
          Checking for uncompressed JSONL databases... This might take a while!
          usage: sudo -h | -K | -k | -V
          usage: sudo -v [-AknS] [-g group] [-h host] [-p prompt] [-u user]
          usage: sudo -l [-AknS] [-g group] [-h host] [-p prompt] [-U user] [-u user]
                      [command]
          usage: sudo [-AbEHknPS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                      [-h host] [-p prompt] [-R directory] [-T timeout] [-u user]
                      [VAR=value] [-i|-s] [<command>]
          usage: sudo -e [-AknS] [-r role] [-t type] [-C num] [-D directory] [-g group]
                      [-h host] [-p prompt] [-R directory] [-T timeout] [-u user] file ...
          main: line 12: [: -lt: unary operator expected
          sudo: npm: command not found
              Checking autostart (4/4)
          Enabling autostart...
          Autostart enabled!
              Your installation was fixed successfully
              Run iobroker start to start ioBroker again!
          • SMSS SMS
            library: loaded
            Installed gcc-c++
                        [command]
            Autostart enabled!
            @sms sagte in Freier Arbeitsspeicher nimmt schnell ab ...:
            Das sind auch schon komische Meldungen da. Normalerweise tauchen die nicht auf.
            sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
            uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
            liefert?
            Thomas BraunT SMSS 2 Antworten Letzte Antwort
              liefert?
              Und
              sudo apt update
              apt policy libcap2-bin
              • SMSS SMS
                library: loaded
                Installed gcc-c++
                            [command]
                Autostart enabled!
                @sms
                sudo setcap cap_net_raw+eip $(eval readlink -f `which node`)
                  liefert?
                  SMSS Offline
                  SMSS Offline
                  SMS
                  liefert?
                  wie gebe ich das ein?
                  • SMSS SMS
                    liefert?
                    Wie meinst du das?
                    Eingeben oder in die Konsole pasten.
                    Ich würde es kopieren/pasten...
                      Wie meinst du das?
                      SMSS Offline
                      SMSS Offline
                      SMS
                      schrieb am zuletzt editiert von SMS
                      @thomas-braun so?
                      pi@MotionEye:/ $
                      aarch64
                      pi@MotionEye:/ $
                      oder
                      pi@MotionEye:/ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                      pi@MotionEye:/ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs                                       aarch64
                      pi@MotionEye:/ $
                      • SMSS SMS
                        @thomas-braun so?
                        pi@MotionEye:/ $
                        aarch64
                        pi@MotionEye:/ $
                        oder
                        pi@MotionEye:/ $
                        @sms
                        Ja, allerdings sieht das auf einem gesunden System so aus:
                        echad@chet:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                        aarch64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        /usr/bin/npx
                        v19.4.0
                        v19.4.0
                        9.2.0
                        9.2.0
                        4.0.24
                        echad
                        echad adm dialout cdrom sudo audio video plugdev games users input render netdev lpadmin boinc gpio i2c spi iobroker
                        tty
                        /home/echad
                        Da ist wohl nodejs kaputt.
                          @sms
                          aarch64
                          /usr/bin/nodejs
                          /usr/bin/node
                          /usr/bin/npm
                          /usr/bin/npx
                          v19.4.0
                          v19.4.0
                          9.2.0
                          9.2.0
                          4.0.24
                          echad
                          tty
                          /home/echad
                          SMSS Offline
                          SMSS Offline
                          SMS
                          @thomas-braun und wie bekomme ich das wieder hin?
                          • SMSS SMS
                            @sms
                            sudo apt update
                            apt policy nodejs
                              @sms
                              sudo apt update
                              apt policy nodejs
                              SMSS Offline
                              SMSS Offline
                              SMS
                              @thomas-braun liegt es vielleicht daran, das 14 und 16 drauf sind?
                              pi@MotionEye:/ $ sudo apt update
                              Hit:1 http://deb.debian.org/debian bullseye InRelease
                              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                              All packages are up to date.
                              pi@MotionEye:/ $
                              • SMSS SMS
                                @sms
                                Und warum steht der 'pi' nicht in seinem Home-Verzeichnis?
                                Schubs denn da mal hin:
                                cd ~
                                  @sms
                                  sudo apt update
                                  apt policy nodejs
                                  SMSS Offline
                                  SMSS Offline
                                  SMS
                                  pi@MotionEye:/ $ apt policy nodejs
                                  nodejs:
                                    Installed: (none)
                                    Candidate: 16.19.0-deb-1nodesource1
                                    Version table:
                                       16.19.0-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                                       14.21.2-deb-1nodesource1 500
                                          500 https://deb.nodesource.com/node_14.x bullseye/main arm64 Packages
                                       12.22.12~dfsg-1~deb11u1 500
                                          500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                                       12.22.5~dfsg-2~11u1 500
                                          500 http://deb.debian.org/debian bullseye/main arm64 Packages
                                  pi@MotionEye:/ $
                                  • SMSS SMS
                                    nodejs:
                                      Installed: (none)
                                      Version table:
                                    pi@MotionEye:/ $
                                    Installed: (none)
                                    ? Wie schafft man das?
                                    sudo apt install nodejs
                                      Installed: (none)
                                      SMSS Offline
                                      SMSS Offline
                                      SMS
                                      #66
                                      pi@MotionEye:~ $ sudo apt install nodejs
                                      The following NEW packages will be installed:
                                        nodejs
                                      0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                      Need to get 26.6 MB of archives.
                                      After this operation, 128 MB of additional disk space will be used.
                                      Get:1 https://deb.nodesource.com/node_16.x bullseye/main arm64 nodejs arm64 16.19.0-deb-1nodesource1 [26.6 MB]
                                      Fetched 26.6 MB in 1s (19.0 MB/s)
                                      Selecting previously unselected package nodejs.
                                      (Reading database ... 49321 files and directories currently installed.)
                                      Preparing to unpack .../nodejs_16.19.0-deb-1nodesource1_arm64.deb ...
                                      Unpacking nodejs (16.19.0-deb-1nodesource1) ...
                                      Setting up nodejs (16.19.0-deb-1nodesource1) ...
                                      Processing triggers for man-db (2.9.4-2) ...
                                      Neustart?
                                      • SMSS SMS
                                          nodejs
                                        Neustart?
                                        #67
                                        @sms
                                        sagt nun?
                                          @sms
                                          sagt nun?
                                          SMSS Offline
                                          SMSS Offline
                                          SMS
                                          #68
                                          pi@MotionEye:~ $ uname -m && type -P nodejs node npm npx && nodejs -v && node -v && npm -v && npx -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                                          aarch64
                                          /usr/bin/nodejs
                                          /usr/bin/node
                                          /usr/bin/npm
                                          /usr/bin/npx
                                          v16.19.0
                                          v16.19.0
                                          8.19.3
                                          8.19.3
                                          4.0.23
                                          pi
                                          pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                          tty
                                          /home/pi
                                          Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                                          nodejs:
                                            Installed: 16.19.0-deb-1nodesource1
                                            Version table:
                                           *** 16.19.0-deb-1nodesource1 500
                                          pi@MotionEye:~ $
