  4. Wasserzähler - Version 2 - all-in-device
wasserzählerversion 2ai on the edgecnnwater meterwater gaugeesp32ov2640neuronale netzehausautomatisierung
3.4k Beiträge 240 Kommentatoren 2.4m Aufrufe 231 Beobachtet
  • C C4nc3r 0
    Das sind LOGs nach dem flashen
    Werde es gleich nochmal mit Flash Tool mal testen.
    ets Jul 29 2019 12:21:46
    rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0xee
    clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
    mode:DIO, clock div:2
    load:0x3fff0030,len:7664
    load:0x40078000,len:15360
    load:0x40080400,len:3744
    entry 0x4008067c
    I (27) boot: ESP-IDF 4.3.2 2nd stage bootloader
    I (27) boot: compile time 20:02:47
    I (27) boot: chip revision: 3
    I (30) boot_comm: chip revision: 3, min. bootloader chip revision: 0
    I (37) boot.esp32: SPI Speed      : 40MHz
    I (42) boot.esp32: SPI Mode       : DIO
    I (46) boot.esp32: SPI Flash Size : 4MB
    I (51) boot: Enabling RNG early entropy source...
    I (56) boot: Partition Table:
    I (60) boot: ## Label            Usage          Type ST Offset   Length
    I (67) boot:  0 nvs              WiFi data        01 02 00009000 00004000
    I (75) boot:  1 otadata          OTA data         01 00 0000d000 00002000
    I (82) boot:  2 phy_init         RF data          01 01 0000f000 00001000
    I (89) boot:  3 ota_0            OTA app          00 10 00010000 001db000
    I (97) boot:  4 ota_1            OTA app          00 11 001f0000 001db000
    I (104) boot: End of partition table
    I (109) boot: No factory image, trying OTA 0
    I (114) boot_comm: chip revision: 3, min. application chip revision: 0
    I (121) esp_image: segment 0: paddr=00010020 vaddr=3f400020 size=4bda0h (310688) map
    I (248) esp_image: segment 1: paddr=0005bdc8 vaddr=3ffb0000 size=04250h ( 16976) load
    I (256) esp_image: segment 2: paddr=00060020 vaddr=400d0020 size=166f00h (1470208) map
    I (818) esp_image: segment 3: paddr=001c6f28 vaddr=3ffb4250 size=00038h (    56) load
    I (819) esp_image: segment 4: paddr=001c6f68 vaddr=40080000 size=1b6a0h (112288) load
    I (872) esp_image: segment 5: paddr=001e2610 vaddr=50000000 size=00010h (    16) load
    I (886) boot: Loaded app from partition at offset 0x10000
    I (914) boot: Set actual ota_seq=1 in otadata[0]
    I (914) boot: Disabling RNG early entropy source...
    I (925) psram: This chip is ESP32-D0WD
    E (926) psram: PSRAM ID read error: 0xffffffff
    E (926) spiram: SPI RAM enabled but initialization failed. Bailing out.
    I (933) cpu_start: Failed to init external RAM; continuing without it.
    I (940) cpu_start: Pro cpu up.
    I (944) cpu_start: Starting app cpu, entry point is 0x40083b44
    I (0) cpu_start: App cpu up.
    I (966) cpu_start: Pro cpu start user code
    I (966) cpu_start: cpu freq: 160000000
    I (966) cpu_start: Application information:
    I (970) cpu_start: Project name:     esp32cam-server-only
    I (976) cpu_start: App version:      v13.0.8
    I (981) cpu_start: Compile time:     Dec 19 2022 20:41:40
    I (987) cpu_start: ELF file SHA256:  2279775554dcdb30...
    I (993) cpu_start: ESP-IDF:          4.4.2
    I (999) heap_init: Initializing. RAM available for dynamic allocation:
    I (1005) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
    I (1012) heap_init: At 3FFC06F0 len 0001F910 (126 KiB): DRAM
    I (1018) heap_init: At 3FFE0440 len 00003AE0 (14 KiB): D/IRAM
    I (1024) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
    I (1031) heap_init: At 4009B6A0 len 00004960 (18 KiB): IRAM
    I (1038) spi_flash: detected chip: generic
    I (1042) spi_flash: flash io: dio
    I (1052) cpu_start: Starting scheduler on PRO CPU.
    I (0) cpu_start: Starting scheduler on APP CPU.
    I (1057) MAIN:
    I (1057) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
    I (3067) gpio: GPIO[25]| InputEn: 1| OutputEn: 0| OpenDrain: 0| Pullup: 1| Pulldown: 0| Intr:2
    I (3067) cam_hal: cam init ok
    I (3067) sccb: pin_sda 26 pin_scl 27
    I (3067) sccb: sccb_i2c_port=1
    I (3077) gpio: GPIO[32]| InputEn: 0| OutputEn: 1| OpenDrain: 0| Pullup: 0| Pulldown: 0| Intr:0
    I (3107) camera: Detected camera at address=0x30
    I (3107) camera: Detected OV2640 camera
    I (3107) camera: Camera PID=0x26 VER=0x42 MIDL=0x7f MIDH=0xa2
    I (3187) cam_hal: buffer_size: 32768, half_buffer_size: 4096, node_buffer_size: 2048, node_cnt: 16, total_cnt: 15
    I (3187) cam_hal: Allocating 61440 Byte frame buffer in PSRAM
    E (3197) cam_hal: cam_dma_config(306): frame buffer malloc failed
    E (3207) cam_hal: cam_config(390): cam_dma_config failed
    E (3207) camera: Camera config failed with error 0xffffffff
    E (3217) CAM: Camera Init Failed
    I (5217) MAIN: Using SDMMC peripheral
    E (5247) sdmmc_common: sdmmc_init_ocr: send_op_cond (1) returned 0x107
    E (5247) vfs_fat_sdmmc: sdmmc_card_init failed (0x107).
    E (5247) MAIN: Failed to initialize the card (ESP_ERR_TIMEOUT). Make sure SD card lines have pull-up resistors in place.
    ESP8266E Offline
    ESP8266E Offline
    ESP8266
    schrieb am zuletzt editiert von ESP8266
    #2643
    @c4nc3r-0 , da steht schon Chip Revision 3....das sagt nicht kompatibel. Brauchts nichts weiter versuchen. Entweder zurück schicken, oder Tonne. https://jomjol.github.io/AI-on-the-edge-device-docs/Hardware-Compatibility/
    • ESP8266E ESP8266
      David G.D Online
      David G.D Online
      David G.
      #2644
      @esp8266
      Da hat @C4nc3r-0 aber echt Pech.
      Hab mir genau seinen (den Amazonartikel, außer er hat nicht genau seinen verlinkt) vor ca 2 Monaten und vor ca 1 Woche bestellt. Die laufen alle.....
      ESP8266E C 2 Antworten Letzte Antwort
      • David G.D David G.
        @esp8266
        ESP8266E Offline
        ESP8266E Offline
        ESP8266
        #2645
        @david-g , das scheint eh nur noch Glücksache sein. Hat wahrscheinlich auch mit dem wieder Anfahren der Chip Produktion zu tun.
        • ESP8266E ESP8266
          David G.D Online
          David G.D Online
          David G.
          #2646
          @esp8266
          Muss man sich eigentlich welche bunkern, bevor es die "alte" Revision nicht mehr gibt.....
          Doof, dass es (wie ich glaube) nicht am Gerät selber drauf steht.
          ESP8266E 1 Antwort Letzte Antwort
            @esp8266
            ESP8266E Offline
            ESP8266E Offline
            ESP8266
            #2647
            @david-g , ich habe noch 2 Stück. 2 sind verbaut. Reicht.
            Eine Lupe sagt viel aus....
            David G.D 2 Antworten Letzte Antwort
            • ESP8266E ESP8266
              David G.D Online
              David G.D Online
              David G.
              #2648
              @esp8266
              2 Verbaut und einen auf Lager.
              Ja? Dann muss ich am Montag auf der Arbeit mal schauen, da hab ich meinen anderen noch liegen.
                @esp8266
                C4nc3r 0
                #2649
                @david-g
                Ich hatte meine am 29.12.2022 bestellt.
                Echt unglaublich, dass man sich 6 Stück bestellt hat und kein einziger funktioniert.
                Hoffentlich funktioniert dieser 😕
                Habe mir nun diesen bestellt.
                Link
                • ESP8266E Offline
                  ESP8266E Offline
                  ESP8266
                  #2650
                  @c4nc3r-0 , Reichelt ist zwar eine renomierte Firma, aber auch nicht gegen Fakes etc geschützt. Genauso das große "C". Die können nicht alles überprüfen....
                  • C Offline
                    C4nc3r 0
                    #2651
                    @ESP8266 Wie soll man dann jemals einen funktionieren bekommen?
                    Zum Glück habe ich bei Amazon 30 Tage Rückgaberecht. Werde nun alle zurück schicken !!
                    • C C4nc3r 0
                      David G.D Online
                      David G.D Online
                      David G.
                      #2652
                      @c4nc3r-0
                      Der Verkäufer weist in der Beschreibung ja sogar drauf hin, dass man sich bei Problemen mit dem Speicher an sich wenden soll.
                      Lieber Kunde,
                      Wenn Sie auf Probleme stoßen, auf die PSRAM bei der Verwendung des ESP32 -Entwicklungsausschusses nicht erkannt werden kann, kontaktieren Sie uns bitte, um einen Austausch zu beantragen.
                      Es tut uns sehr leid, Ihnen Unannehmlichkeiten zu verursachen.
                      Da meckert Dein Log ja auch.
                      C 1 Antwort Letzte Antwort
                        @c4nc3r-0
                        Lieber Kunde,
                        C4nc3r 0
                        #2653
                        @david-g
                        @ESP8266
                        Danke für den Hinweis.
                        Werde ich sofort machen.
                        • C C4nc3r 0
                          @david-g
                          @ESP8266
                          ESP8266E Offline
                          ESP8266E Offline
                          ESP8266
                          #2654
                          OTon
                          Gehört hier zwar nicht hin, aber ich habe mir innerhalb von 8 Monaten 2 SSD`s´von Intenso zerschossen. Wurden immer langsamer, bis IOB nicht mehr startete. Jetzt habe ich eine Sandisk dran. Mal sehen wie lange. Im PC werkelt schon eine seit 4 Jahren. Da steckt man nicht drin aber die Qualität wird immer schlimmer. Da hätte ich auch eine HDD nehmen können, die würde wohl noch laufen.
                          OToff
                          • ESP8266E ESP8266
                            OTon
                            OToff
                            BananaJoeB Offline
                            BananaJoeB Offline
                            BananaJoe
                            #2655
                            @esp8266 sagte in Wasserzähler - Version 2 - all-in-device:
                            Intenso stellt auch keine SSDs (oder Festplatten) her oder lässt diese herstellen. Die kaufen im großen Stil Rückläufer und Ausschussware auf, testen ob die Funktionieren, ziehen die Aufkleber ab und patschen die eigenen drauf und verkaufen die wieder.
                            Da ist es immer Glücksache was du bekommst.
                            • HasontH Offline
                              HasontH Offline
                              Hasont
                              schrieb am zuletzt editiert von Hasont
                              #2656
                              Hallo zusammen, hab vor 3 Wochen von 12.1 auf die Version 13.08 upgedated und alle meine 3 Zähler (Gas,Wasser und Strom) laufen damit ohne Probleme. Allerdings ist es bei zwei so, dass der Browser fast gar nicht mehr geht. Es dauert ewig bis er ein Bild aufbaut und bringt auch falsche Meldungen wie z.B. die html Version wäre falsch oder er findet lt. log keine Referenzbilder. Das ist aber definitiv nicht richtig. Ich hab auch schon x mal neu geflasht. Mit den alten Versionen war das nie. Es kommt mir so vor als wäre die WLAN Verbindung seit der 13.8 extrem schlecht. Am Tisch geht alles und im Keller 15m neben der Fritzbox und durch eine Wand sagt er -70dBm. Hat hier jemand sowas ähnliches? Ich hab die Zähler nun das schon das dritte Jahr. Wenn ich nix mit dem Browser mache erreiche ich weit über 2000 Runden ohne Probleme. Leider will man ja doch immer mal wieder mal über den Browser zugreifen. Der Stromzähler ist 5m näher und bat das Bild in sekunden auf. Er hat grad -63dBm und 6623 Runden. Eigentlich war der immer mein Sorgenkind;-)
                              Bin mal auf eure Antwort gespannt. Der ESP hat lt. log bei den zwei die nicht gut funktionieren 8MB PSRAM.
                              SD Karte hab ich auch schon x-mal getausch. Am Arbeitsplatz (Router steht 2m entfernt scheint alles zu gehen, zumindest die ersten paar mal bis ich es wieder im Keller verbaue. Einer davon zeigt auch immer um die 70 Grad was aber schon immer so ist. Da ich bisher noch nichts in der Art im Forum gelesen habe will ich das auch nicht als Fehler melden.
                              LG aus Franken, Horst
                              J David G.D HasontH 3 Antworten Letzte Antwort
                              • HasontH Hasont
                                JoergH
                                schrieb am zuletzt editiert von JoergH
                                #2657
                                @hasont
                                Hallo Horst,
                                ich hatte ähnliche Probleme bereits mit älteren Versionen. Zum einen habe ich die Erfahrung gemacht, dass eine ausreichende Stromversorgung extrem wichtig ist, zum anderen, dass microSD Karten größer 4 GB zu Instabilität geführt haben. Seitdem ich diese beiden Fehlerquellen eliminiert habe, hatte ich keine Probleme mehr.
                                HasontH 1 Antwort Letzte Antwort
                                • HasontH Hasont
                                  David G.D Online
                                  David G.D Online
                                  David G.
                                  #2658
                                  @hasont
                                  Ganz selten habe ich das auch.
                                  Nach einem refresh kommt die Seite dann aber zügig.
                                  Gaaanz manchmal erst nach 20 sek oder so.
                                  Hab ich mir aber nie was bei gedacht.
                                  Bin auch auf 13 unterwegs. Dke 12er hatte ich nur ein paar Tage am laufen.
                                  Empfang -74 und -67.
                                  Wenn alles gut läuft, muss man ja auch nie drauf schauen. Zudem hab ich auch alle Infos samt Bild in meiner Visu.
                                  Das mit der Temperatur habe ich auch. Einer ist immer bei so bei 44 Grad, der andere zwischen 80 und 82 Grad. Aber solange es läuft.....
                                  Anfühlen tut er sich nicht so warm.
                                  EDIT
                                  Bezug auf die Antwort von @Joerg-H
                                  Habe eine 16 und eine 32 GB Karte im Einsatz.
                                  • J JoergH
                                    @hasont
                                    Hallo Horst,
                                    HasontH Offline
                                    HasontH Offline
                                    Hasont
                                    #2659
                                    @joergh
                                    Hallo Joerg,
                                    das Thema mit den SD Karten kenne ich, bin ja Kind der ersten Stunde;-)
                                    Leider bekommt man ja keine 4GB Karten mehr oder hast du da einen Tip für mich.
                                    Alle Zähler laufen auf 4GB Sundisk oder Trancent Karten. Beim neu aufsetzen rennt das Ding auch sofort ohne Fehler im Log los und im Keller gehts dann nichts mehr. Stromversorgung ist ein 2A NG mit 1000uF. Das hat aber den großen Nachteil, dass bei Stromausfall schon passiert ist, dass durch den großen Elko die Spannung nicht schnell genug abfällt und der ESP in einen Zustand kommt wo nur noch neu flashen hilft. Alles schon durch;-)
                                    LG Horst
                                      @hasont
                                      EDIT
                                      JoergH
                                      #2660
                                      @david-g
                                      16 und 32 GB hatte ich auch eine Zeitlang, aber eben auch immer wieder sporadisch Probleme, bis ich die getauscht habe. Anscheinend verbrauchen die zu viel Strom und es kommt zu Lese- und Schreibfehlern, nicht immer, aber immer wieder...
                                      • HasontH Hasont
                                        @joergh
                                        Hallo Joerg,
                                        LG Horst
                                        JoergH
                                        #2661
                                        @hasont
                                        Ich habe keine Kondensatoren im Einsatz, sondern ein sehr starkes Netzteil genommen, an das ich alle gehängt habe. Pro ESP 1A bei 5V
                                        • J JoergH
                                          @hasont
                                          ESP8266E Offline
                                          ESP8266E Offline
                                          ESP8266
                                          #2662
                                          @joergh , und das ist falsch durch den Kabelverlust. Das ist zwar nur im Millivoltbereich aber trotzdem in der Hinsicht nicht Stabil. Ein Elko gehört direkt an den 5V Anschluß des ESP´s um wirklich alle Fehler auszuschließen. Oder hast du zwischen Netzteil und ESP ein 4 oder 5 mm² Kabel liegen. Die meisten Netzteilkabel haben nur 0,75 mm² und das soll der Elko ausgleichen.
                                          Je mehr Geräte an dem Netzteil angeschlossen und je länger die Kabel sind, um so größer macht sich das an den Ausgängen bemerkbar. Es sollten dann alle einen direkten Elko bekommen.
                                          @Hasont , SD Karten im MB Bereich habe ich noch nie gesehen. Die Kleinste die ich habe, ist eine 2 GB Karte und gerade die macht Probleme. Mit der 8GB habe ich keine, auch eine 16 GB funzt bei mir die ich aber nicht im Betrieb habe.
                                          J HasontH 2 Antworten Letzte Antwort
