  4. Test Adapter zigbee2mqtt
    6.3k
zigbeezigbee 3.0zigbee2mqtt
526 Beiträge 52 Kommentatoren 203.6k Aufrufe 45 Beobachtet
  • B biker1602
    @asgothian
    [Unit]
    Description=zigbee2mqtt
    After=network.target
    [Service]
    Environment=NODE_ENV=production
    ExecStart=/usr/bin/npm start
    WorkingDirectory=/opt/zigbee2mqtt
    StandardOutput=inherit
    # Or use StandardOutput=null if you don't want Zigbee2MQTT messages filling syslog, for more options see systemd.exec(5)
    StandardError=inherit
    Restart=always
    RestartSec=10s
    User=pi
    [Install]
    WantedBy=multi-user.target
    So habe den Pfad geändert
    pi@raspberrypi:/opt/zigbee2mqtt $ npm start
    > zigbee2mqtt@1.28.0 start
    > node index.js
    Zigbee2MQTT:info  2022-12-20 13:13:06: Logging to console and directory: '/opt/zigbee2mqtt/data/log/2022-12-20.13-13-06' filename: log.txt
    Zigbee2MQTT:info  2022-12-20 13:13:06: Starting Zigbee2MQTT version 1.28.0 (commit #03ba647)
    Zigbee2MQTT:info  2022-12-20 13:13:06: Starting zigbee-herdsman (0.14.62)
    Zigbee2MQTT:info  2022-12-20 13:13:07: zigbee-herdsman started (resumed)
    Zigbee2MQTT:info  2022-12-20 13:13:07: Coordinator firmware version: '{"meta":{"maintrel":3,"majorrel":2,"minorrel":6,"product":0,"revision":20190608,"transportrev":2},"type":"zStack12"}'
    Zigbee2MQTT:info  2022-12-20 13:13:07: Currently 1 devices are joined:
    Zigbee2MQTT:info  2022-12-20 13:13:07: IKEA Smart Home Button (0x84fd27fffe1f7496): E1524/E1810 - IKEA TRADFRI remote control (EndDevice)
    Zigbee2MQTT:info  2022-12-20 13:13:07: Zigbee: disabling joining new devices.
    Zigbee2MQTT:info  2022-12-20 13:13:07: Connecting to MQTT server at mqtt://localhost
    Zigbee2MQTT:info  2022-12-20 13:13:07: Connected to MQTT server
    Zigbee2MQTT:info  2022-12-20 13:13:07: MQTT publish: topic 'zigbee2mqtt/bridge/state', payload '{"state":"online"}'
    Zigbee2MQTT:info  2022-12-20 13:13:07: MQTT publish: topic 'zigbee2mqtt/IKEA Smart Home Button/availability', payload '{"state":"offline"}'
    Zigbee2MQTT:info  2022-12-20 13:13:07: Started frontend on port 0.0.0.0:8080
    Gestartet Adapter ist Grün und sobald ich die Konsole schließe ist er wieder Gelb
    AsgothianA Offline
    AsgothianA Offline
    Asgothian
    #253
    @biker1602 solange du das Programm immer direkt per npm startet bleibt es so
    Du musst schon den Dienst starten. Nachdem du die Datei angepasst hast solltest du nochmal das versuchen was @ciddi89 weiter oben geschrieben hat:
    @ciddi89 sagte in Test Adapter zigbee2mqtt:
    @biker1602
    Mach mal
    systemctl daemon-reload
    Und dann noch mal
    sudo systemctl start zigbee2mqtt
    Und Ergebnis von
    systemctl status zigbee2mqtt.service
      @asgothian sagte in Test Adapter zigbee2mqtt:
      auch wenn @thomas-braun Meinung ist das nur ein System auf dem aktuellen Stand lebensfähig ist.
      Zumindest macht es das Leben leichter mit noch unterstützen Systemen herumzuhantieren.
      AsgothianA Offline
      AsgothianA Offline
      Asgothian
      #254
      @thomas-braun sagte in Test Adapter zigbee2mqtt:
      Grundsatzdiskussion - will ich hier nicht führen. Wir haben da unterschiedliche Ansichten.
      • B biker1602
        @asgothian
        [Unit]
        [Service]
        Restart=always
        RestartSec=10s
        User=pi
        [Install]
        > node index.js
        crunchipC Offline
        crunchipC Offline
        #255
        @biker1602 sagte in Test Adapter zigbee2mqtt:
        Verify that the configuration works:
        Start Zigbee2MQTT
        Show status
        Now that everything works, we want systemctl to start Zigbee2MQTT automatically on boot, this can be done by executing:
        sudo systemctl enable zigbee2mqtt.service
        ansonsten mach mal ein reboot
        • AsgothianA Asgothian
          #256
          @asgothian
          Da gibt es ja auch nix zu diskutieren, grundsätzlich ist es natürlich schwieriger ein System nach dem EOL am laufen zu halten als ein aktuell vom Hersteller noch unterstütztes.
            biker1602
            #257
            @asgothian said in Test Adapter zigbee2mqtt:
            @biker1602
            Mach mal
            Und dann noch mal
            Und Ergebnis von
            Das war es jetzt bleibt er grün. 👌 Jetzt ist zwar der IKEA Button Offline aber vielleicht erholt er sich ja noch. Oder muss der neiu angelernt werden?
              @asgothian
              AsgothianA Offline
              AsgothianA Offline
              Asgothian
              #258
              @asgothian
              Da gibt es viel zu diskutieren. Der OP hat kein problem damit sein System am laufen zu halten - es läuft. Er hat ein problem damit aus einer nicht auf sein System zugeschnittenen Anleitung zusätzliche Software zum laufen zu kriegen. Das wäre bei dem neu aufgesetzten System genau so geblieben, da sich an dem eigentlichen Fehler absolut NICHTS durch das neue System ändert.
              Die Frage ist also nicht ob ein neues System einfacher zu warten ist, sondern ob das neu installieren das Problem des OP's löst. Tut es nicht.
              A.
                @asgothian
                A.
                #259
                @asgothian
                Richtig, die Service-Datei ist hüben wie drüben falsch.
                Trotzdem wird ein abgekündigtes System künstlich am Leben gehalten, die Aufgabe das Release zu wechseln stellt sich früher oder später ohnehin.
                Je länger das herausgezögert wird desto komplexer wird das aber erfahrungsgemäß. Deswegen beizeiten wechseln und nicht das EOL eintreten lassen. Dafür gibt es ja den Übergangszeitraum von über einem Jahr bei Debian von Release zu Release. Kommt ja nicht aus heiterem Himmel.
                Die 'große' Operation ist jetzt mit einem Pflästerchen etwas herausgezögert worden. Aber wie viele Pflaster willste da noch draufpappen?
                  @asgothian
                  arteckA Offline
                  arteckA Offline
                  arteck
                  #260
                  aber im andern thread... und nicht HIER
                  • IdleBitI IdleBit
                    Aktuelle Test Version NPM version
                    Veröffentlichungsdatum 13.01.2023
                    Github Link https://github.com/o0shojo0o/ioBroker.zigbee2mqtt
                    Stats: Downloads Number of Installations Current version in stable repository
                    Tests: Test and Release CodeQL
                    Changelog
                    --> Ist hier zu finden <--
                    Dieser Adapter ermöglicht es, die Datenpunkte der Geräte einer Zigbee2MQTT-Instanz in ioBroker einzubinden.
                    Es wird erstmal die Konfigurationsvariante Websocket empfohlen.
                    Der @nox309 hat auch schon eine Dokumentation begonnen die HIER zu finden ist.
                    Die folgenden Zigbee2MQTT Konfiguration Parameter sind zwingen erforderlich damit der Adapter die Daten verarbeiten kann.
                    advanced:
                         legacy_api: false
                         legacy_availability_payload: false
                         output: json
                    device_options:
                         legacy: false
                    availability: true
                    toralt
                    #261
                    @idlebit mal eine generelle Frage:
                    Ich habe zigbee2mqtt auf die neueste Version upgedatet (28.5) und bekomme anschließen jede Minute einen disconnect des Adapters wegen websocket error. Adapter ist aktuell bei 2.5.0.
                    Ich habe nun meine Backup VM gestartet und bin somit wieder auf Version 28.4 bei zigbee2mqtt. Nun funktioniert wieder alles wie vorher. Muss ich nach dem Update von zigbee2mqtt wieder irgendwas in der config anpassen bevor der Adapter wieder funktioniert? In der Dokumentation von @nox309 konnte ich hierzu nichts finden.
                    << ioBroker im Docker auf Synology DS1821+, 10GBit, 32GB RAM>>
                    ? arteckA 2 Antworten Letzte Antwort
                    • T toralt
                      #262
                      @toralt ne eigentlich nicht. Habe auch das Update gemacht und danach lief alles wieder wie vorher.
                      • T toralt
                        arteckA Offline
                        arteckA Offline
                        arteck
                        #263
                        @toralt 29.0 ist das neuste.. und JA du solltest dir das update howto bei zigbee2mqtt durchlesen..
                        • IdleBitI IdleBit
                          Changelog
                          advanced:
                               legacy_api: false
                               output: json
                          device_options:
                               legacy: false
                          availability: true
                          Jan.S100
                          #264
                          @idlebit sagte in Test Adapter zigbee2mqtt:
                          Veröffentlichungsdatum wartet noch auf die Freigabe für das Beta-Repo
                          Hallo, mal eine kleine Frage. Wann kommt der Adapter ins Beta-Repo?
                          Bei anderen Adaptern ging das meiner Meinung nach schneller.
                          Ihr macht hier eine tolle Arbeit. 👍
                          Ich vergesse immer nachzuschauen ob ein neues Update bei Github gibt. 😱
                          Allen ein gesundes neues Jahr.
                          Jan
                          • J Jan.S100
                            Jan
                            arteckA Offline
                            arteckA Offline
                            arteck
                            #265
                            @jan-s100 wenn @apollon77 zeit gefunden hat für ein Code Review.
                            bis dahin musst du es von GIT installieren
                            • arteckA arteck
                              toralt
                              #266
                              @arteck Stimmt, Sorry, 1.29.0
                              Genau nach der offiziellen Anleitung habe ich das update gemacht. zigbee2mqtt läuft danach ja auch bestens. Nur der Adapter halt nicht mehr.
                              • T toralt
                                arteckA Offline
                                arteckA Offline
                                arteck
                                #267
                                @toralt das dauert so 5 sec bis der sich wieder neu verbindet.
                                • arteckA arteck
                                  toralt
                                  #268
                                  @arteck ja, das klappt auch, dann ist er ne minute grün, dann kommt ein websocket error und er wird gelb, dann wird er gleich wieder grün, nach ca 1 minute wieder websocket error. Das geht dann immer so weiter.
                                  • T toralt
                                    #269
                                    @toralt zeig doch mal ein Log
                                    T 2 Antworten Letzte Antwort
                                    • apollon77A apollon77
                                      toralt
                                      schrieb am zuletzt editiert von toralt
                                      #270
                                      @apollon77 Wenn sich über das lange WE Zeit findet, dann werde ich da nochmal einen Versuch starten. Dann kann ich das Log posten. Nachdem ich die VM mit 1.29.0 wieder gelöscht habe muss ich das update erst nochmal machen.
                                      • ? Offline
                                        #271
                                        Hallo zusammen und danke @IdleBit und weiteren Beteiligten für diesen Adapter.
                                        Adapter Version:
                                        v2.5.0
                                        Zigbee2MQTT Version
                                        1.29.0 commit: dddce57
                                        Coordinator-Typ
                                        zStack3x0
                                        Coordinator-Version
                                        20210708
                                        Coordinator IEEE Adresse
                                        0x00124b0021b7802b
                                        Frontend Version
                                        0.6.121
                                        Nun meine Erfahrungen:
                                        Ich habe 96 Geräte. Der Großteil läuft bis jetzt einwandfrei.
                                        Probleme habe ich beim Schalter E1743 von Ikea. Dieser schaltet bei Betätigung die Datenpunkte im Iobroker nicht von true auf false. Obwohl auf dem Zigbee2mqtt Server im Frontend einwandfrei geschaltet und angezeigt wird. Hat da jemand eine Idee?
                                        Lg
                                          Adapter Version:
                                          v2.5.0
                                          Zigbee2MQTT Version
                                          Coordinator-Typ
                                          zStack3x0
                                          Coordinator-Version
                                          20210708
                                          0x00124b0021b7802b
                                          Frontend Version
                                          0.6.121
                                          Lg
                                          AsgothianA Offline
                                          AsgothianA Offline
                                          Asgothian
                                          #272
                                          @david83 sagte in Test Adapter zigbee2mqtt:
                                          bist du sicher das er sie nicht schaltet ? Da diese unter Umständen nur kurz auf Wahr gehen zeigt das Frontend die Änderungen ggf. nicht an.
                                          Setz mal einen Trigger drauf und schau mal.
                                          A.
