  3. Off Topic
  4. Proxmox
  5. Proxmox VM mit IOBroker OWServer
    2.7k
    4.8k
    4.0k
Geplant Angeheftet Gesperrt Verschoben Proxmox
150 Beiträge 5 Kommentatoren 21.3k Aufrufe 4 Beobachtet
    @laser sagte in Proxmox VM mit IOBroker OWServer:
    Das war ein Mißverständnis aber trotz Allem:
    was gibt den journalctl aus? Am besten zweite Konsole aufmachen, wenn Du owserver.service startest
    # $ sudo journalctl -f
    Oder gibt es noch weitere Log-Files, Syslog oder Logs vom owserver?
    Bernd
    Laser
    schrieb am zuletzt editiert von Laser
    @dp20eic
    Beim Start von OWSERVER:
    Jan 02 14:22:09 debian11 sudo[586]: pam_unix(sudo:session): session opened for user root(uid=0) by otto(uid=1000)
    Jan 02 14:22:12 debian11 qemu-ga[352]: info: guest-ping called
    Jan 02 14:22:23 debian11 qemu-ga[352]: info: guest-ping called
    Jan 02 14:22:29 debian11 sudo[589]:     otto : TTY=pts/0 ; PWD=/home/otto ; USER=root ; COMMAND=/usr/bin/systemctl restart owserver
    Jan 02 14:22:29 debian11 sudo[589]: pam_unix(sudo:session): session opened for user root(uid=0) by otto(uid=1000)
    Jan 02 14:22:29 debian11 systemd[1]: Starting Backend server for 1-wire control...
    Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Failed with result 'protocol'.
    Jan 02 14:22:29 debian11 systemd[1]: Failed to start Backend server for 1-wire control.
    Jan 02 14:22:29 debian11 sudo[589]: pam_unix(sudo:session): session closed for user root
    Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 1.
    Jan 02 14:22:29 debian11 systemd[1]: Stopped Backend server for 1-wire control.
    Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 2.
    Jan 02 14:22:29 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 3.
    Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 4.
    Jan 02 14:22:30 debian11 systemd[1]: Stopped Backend server for 1-wire control.
    Jan 02 14:22:30 debian11 systemd[1]: Starting Backend server for 1-wire control...
    Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Failed with result 'protocol'.
    Jan 02 14:22:30 debian11 systemd[1]: Failed to start Backend server for 1-wire control.
    Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Scheduled restart job, restart counter is at 5.
    Jan 02 14:22:30 debian11 systemd[1]: owserver.service: Start request repeated too quickly.
    Jan 02 14:22:34 debian11 qemu-ga[352]: info: guest-ping called
    Ich konnte nichts Auschlußreiches finden. Habe auch schon einen neuen USB- Busmaster besorgt, der den OWServer mit Daten versorgt.
    Wenn ich beim Durchreichen des USB statt der Hersteller ID direkt den Anschluß wähle, wo der USB Busmaster dranhängt, erscheint immer "ausgesteckt"
    • L Laser
      Heute wieder das gleiche Problem gehabt. IOBroker auf VM installiert. Danach OW Sever installiert. Ging nicht. Alles gelöscht, dann zuerst den OWserver installiert, dann IOBroker. Funktionierte.
      crunchipC Offline
      crunchipC Offline
      was war denn da das Problem? vllt kommt man so dahinter warum beides zusammen nicht funktioniert
      server: port = 192.168.2.103:4304
      server: server = 192.168.10.1:3131
      was sind das für IP's
      hast du die Ports mal abgefragt ob sich da etwas behindert?
      L 1 Antwort Letzte Antwort
        Laser
        #66
        @crunchip
        Dadurch, daß ich ständig neue VM's erzeugt habe, ändert sich auch die ID + IP-Adresse. Ich habe natürlich (so der Plan) immer die richtige IP- Adresse verwendet.
        Thomas BraunT ? 2 Antworten Letzte Antwort
        • L Laser
          @crunchip
          #67
          @laser
          Mit welchen Versionen bist du da unterwegs?
          Könnte es sein, dass du noch in diesen Fehler rennst?
          https://bugs.debian.org/cgi-bin/bugreport.cgi?bug=971513
            @laser
            Laser
            #68
            otto@debian11:~$ /usr/bin/owhttpd -V
            /usr/bin/owhttpd version:
                    3.2p4
            libow version:
                    3.2p4
            otto@debian11:~$
            • L Laser
                      3.2p4
              libow version:
                      3.2p4
              otto@debian11:~$
              Laser
              #69
              Die gleiche Debian- und OWServer Version auf einem Mini-PC ohne Virtualisierung funktioniert aber!
              Mein Produktivsystem möchte ich nicht mit allen möglichen Experimenten "versauen". Deshalb Proxmox auf einem NUC I3.
              • L Laser
                Wo hättest Du das Thema gerne? Im Nirvana? IOBroker ohne Zusätze bringt keinen Nutzen.
                So wie es früher hieß "Windows ohne Software funktioniert einwandfrei"
                #70
                @laser das beantwortet meine Frage nicht.
                @homoran sagte in Proxmox VM mit IOBroker OWServer:
                funktioniert der OWServer nicht mehr.
                und der gehört zu ioBroker?
                da ich Onewire nicht nutze weiss ich nicht, ob der OWServer Teil von ioBroker ist.
                ist das hier ein ioBroker Thema??
                oder offtopic?
                Hab es jetzt mal dahin geschoben.
                gar keine Frage.
                Aber Reparaturanleitungen für einen Tesla sind auch kein ioBroker Thema, nur weil es für den Tesla einen Adapter gibt.
                Das gilt ebenso für Grafana, Influx DB usw.
                  oder offtopic?
                  gar keine Frage.
                  Laser
                  #71
                  OK. Offtopic. Das löst aber mein Problem nicht.
                  Hat denn niemand auf einer VM mit IOBroker die allgegenwärtigen 1wire- Temperaturfühler DS18B20 im Einsatz? Kann ich mir nicht vorstellen.
                  • L Laser
                    Laser
                    #72
                    Wenn "onewire" nicht Teil des IOBroker wäre, hätte ich ja dieses Problem nicht.
                    Es gibt ja den Adapter dafür!
                    Nicht der fehlerhafte Adapter ist das Problem, sondern dass bei Installation von IOBroker der OWServer nicht mehr funktioniert. Wenn das kein IOBroker problem ist?
                    Unter den Tisch kehren ist natürlich auch eine Lösung!
                    • L Laser
                      #73
                      was schrob ich?
                        was schrob ich?
                        Laser
                        #74
                        und was schrieb ich?
                        "Nicht der fehlerhafte Adapter ist das Problem, sondern dass bei Installation von IOBroker der OWServer nicht mehr funktioniert. Wenn das kein IOBroker problem ist?"
                        • L Laser
                          @crunchip
                          #75
                          @laser
                          Ok, das hilft Dir nicht, aber ich habe gerade mal auf meinem Produktiven iobroker die Pakete installiert, nach der Installation, lief der owserver.service und auch nach einem reboot habe ich keine Probleme den Service zu starten/stoppen usw.
                          Unterschied ist, ich habe keinen Stick oder andere Hardware 1-wire und bei mir läuft ein LXC Container unter Proxmox.
                          dp20eic@iobroker:~$ sudo systemctl status owserver.service
                          * owserver.service - Backend server for 1-wire control
                               Loaded: loaded (/lib/systemd/system/owserver.service; enabled; vendor preset: enabled)
                               Active: active (running) since Mon 2023-01-02 14:43:56 CET; 40min ago
                          TriggeredBy: * owserver.socket
                                 Docs: man:owserver(1)
                             Main PID: 120 (owserver)
                                  CPU: 12ms
                               CGroup: /system.slice/owserver.service
                                       `-120 /usr/bin/owserver --foreground -c /etc/owfs.conf
                          Jan 02 14:43:56 iobroker systemd[1]: Starting Backend server for 1-wire control...
                          Jan 02 14:43:56 iobroker owserver[120]: DEFAULT: ow_opt.c:(780) systemd mode -- ignore foreground request
                          Jan 02 14:43:56 iobroker owserver[120]: DEFAULT: ow_opt.c:(670) systemd mode -- ignore 'p' option
                          Jan 02 14:43:56 iobroker owserver[120]: *** WARNING *** The program 'owserver' uses the Apple Bonjour compatibility layer of Avahi.
                          Jan 02 14:43:56 iobroker owserver[120]: *** WARNING *** Please fix your application to use the native API of Avahi!
                          Jan 02 14:43:56 iobroker owserver[120]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
                          Jan 02 14:43:56 iobroker systemd[1]: Started Backend server for 1-wire control.
                          dp20eic@iobroker:~$ sudo systemctl status owhttpd.service
                          * owhttpd.service - Tiny webserver for 1-wire control
                               Loaded: loaded (/lib/systemd/system/owhttpd.service; enabled; vendor preset: enabled)
                               Active: active (running) since Mon 2023-01-02 15:22:29 CET; 2min 22s ago
                                 Docs: man:owhttpd(1)
                             Main PID: 1622 (owhttpd)
                                  CPU: 14ms
                               CGroup: /system.slice/owhttpd.service
                                       `-1622 /usr/bin/owhttpd --foreground -c /etc/owfs.conf
                          Jan 02 15:22:29 iobroker systemd[1]: Starting Tiny webserver for 1-wire control...
                          Jan 02 15:22:29 iobroker systemd[1]: Started Tiny webserver for 1-wire control.
                          Jan 02 15:22:29 iobroker owhttpd[1622]: *** WARNING *** The program 'owhttpd' uses the Apple Bonjour compatibility layer of Avahi.
                          Jan 02 15:22:29 iobroker owhttpd[1622]: *** WARNING *** Please fix your application to use the native API of Avahi!
                          Jan 02 15:22:29 iobroker owhttpd[1622]: *** WARNING *** For more information see <http://0pointer.de/blog/projects/avahi-compat.html>
                          L crunchipC 2 Antworten Letzte Antwort
                          • L Laser
                            #76
                            Natürlich nicht!
                            Deswegen hilft man dir ja auch den Fehler in deiner Installation finden.
                              @laser
                                      CPU: 12ms
                                      CPU: 14ms
                              Laser
                              #77
                              @dp20eic
                              Das ist schon mal was. Allerdings ein Container. Da blicke ich noch nicht mit dem Durchreichen des USB durch. Am USB hängt ja der Stick zum 1wire Temperatursensor.
                              Aber der Service startet ja bei Dir problemlos.
                              Homoran: ganz bestimmt habe ich etwas falsch gemacht. Nur was??
                                @laser
                                        CPU: 12ms
                                        CPU: 14ms
                                crunchipC Offline
                                crunchipC Offline
                                #78
                                @dp20eic sagte in Proxmox VM mit IOBroker OWServer:
                                hätte mich auch gewundert
                                  Laser
                                  #79
                                  @crunchip
                                  Nur was "verbiegt" die IOBroker installation auf dem Debian System, daß der Server nicht mehr startet? Ist doch Irre!
                                  • L Laser
                                    @crunchip
                                    crunchipC Offline
                                    crunchipC Offline
                                    #80
                                    @laser setz doch einfach mal ganz neu auf und ohne die config zu bearbeiten
                                      Laser
                                      #81
                                      @crunchip
                                      OK, den Versuch ist es wert. Allerdings bekomme ich da ja nicht den USB- 1wire- Stick dran.
                                      Aber sehen, ob sich was starten läßt, kann man ja.
                                      • L Laser
                                        @crunchip
                                        crunchipC Offline
                                        crunchipC Offline
                                        #82
                                        eben, geht ja erstmal darum
                                          Laser
                                          #83
                                          @crunchip
                                          So, das ging schnell. Ich sehe zwar keine angeschlossenen Sensoren, aber die Fakes. Vor IObroker install kann ich auf 2121 zugreifen, nach Installation immer noch. Nach Reboot wieder das Gleiche Drama wie zuvor!
