  4. [SourceAnalytix 0.4.8-Final] Released !
2.3k Beiträge 184 Kommentatoren 1.5m Aufrufe 153 Beobachtet
  • J Joshude
    Nein, die liefen alle weiter
    crunchipC Offline
    crunchipC Offline
    #1379
    @joshude und was hat dieser shelly für einen Zählerstand aktuell?
    laut deinem Auszug
    cumulativeValue":8564.140800000001
    aber ein Reset erkannt
    valueAtDeviceReset : (6457.1286)
    zeig mal das Raw vom original DP
      laut deinem Auszug
      Joshude
      #1380
      @crunchip
      Der Raw-Value beträgt 2134364.8
        "type": "state",
        "common": {
          "name": "Total consumed energy",
          "type": "number",
          "role": "value.totalconsumed",
          "read": true,
          "write": false,
          "def": 0,
          "unit": "Wh",
          "custom": {
            "influxdb.0": {
              "enabled": true,
              "storageType": "",
              "aliasId": "",
              "changesOnly": true,
              "debounce": 1000,
              "changesRelogInterval": 0,
              "changesMinDelta": 0,
              "retention": 31536000,
              "debounceTime": 0,
              "blockTime": 1000,
              "ignoreBelowNumber": "",
              "disableSkippedValueLogging": false,
              "enableDebugLogs": false
            "sourceanalytix.0": {
              "enabled": true,
              "selectedUnit": "Detect automatically",
              "start_day": 8564.140800000001,
              "start_week": 8564.140800000001,
              "start_month": 8425.0793,
              "start_quarter": 6455.4933,
              "start_year": 250,
              "selectedPrice": "ElectricityDay",
              "costs": true,
              "consumption": true,
              "meter_values": true,
              "valueAtDeviceReset": 6457.1286,
              "valueAtDeviceInit": null,
              "cumulativeValue": 8564.140800000001
        "native": {},
        "_id": "shelly.0.SHEM-3#C45BBE798A48#1.Total.ConsumedPower",
        "acl": {
          "owner": "system.user.admin",
          "object": 1636,
          "state": 1636
        "from": "system.adapter.shelly.0",
        "user": "system.user.admin",
        "ts": 1671659753935
      Die Werte in den Settings des DP:
      • J Joshude
        @crunchip
          "type": "state",
          "common": {
            "type": "number",
            "read": true,
            "write": false,
            "def": 0,
            "unit": "Wh",
            "custom": {
              "influxdb.0": {
                "enabled": true,
                "storageType": "",
                "aliasId": "",
                "debounce": 1000,
                "debounceTime": 0,
                "blockTime": 1000,
                "enabled": true,
                "start_year": 250,
                "costs": true,
          "native": {},
          "acl": {
            "object": 1636,
            "state": 1636
          "ts": 1671659753935
        crunchipC Offline
        crunchipC Offline
        #1381
        @joshude sagte in [SourceAnalytix 0.4.8-Final] Released !:
        2134364.8
        das ist der Wert deines shelly Zähler? oder vllt ein anderer?
        das stimmt doch hinten und vorne nicht.
        "start_day": 8564.140800000001, "start_week": 8564.140800000001,
        des weiteren sind hier beide Werte gleich, heute ist bereits Mittwoch, ist der Zähler nicht gelaufen?
        wie alt war denn das backup?
        • J Offline
          Joshude
          schrieb am zuletzt editiert von Joshude
          #1382
          Das Backup war vom 19.12., 2 Uhr morgens. Im Laufe des 19. habe ich mir die Kiste dann zerschossen.
          Wobei, jetzt wo ich tippe... Irgendwann, ich glaube im August und September hat sich jeweils der Wert im Sourceanalytix auf magische Weise ohne mein Zutun verdoppelt. Also von ca 2000kwh auf 4000 und dann noch mal verdoppelt auf 8000. Das heißt die 8500kwh sind eh nicht richtig, da fehlen mir jetzt aber die genauen historischen Daten. So stand der dann aber zuletzt immer im Sourceanalytix und ich habe erstmal damit gelebt.
          €: Für z.B. den genannten Shelly sind auch alle Datenpunkte in Sourceanalytix leer. Sprich die ganzen historischen Daten was die monatlichen Verbräuche und so angeht. Das wäre schon schade, wenn das alles weg ist
          €2:
          Wenn ich mir die Daten im EChart-Adapter angucke sind die noch alle da. Also das ist jetzt der historische Datenbestand aus InfluxDB für den jetzt hier exemplarisch genannten DP. da sieht man auch an 4 Stellen die Ausbrüche nach unten, da waren es jeweils -3kwh, warum auch immer. An den letzten beiden hat sich jeweils der Wert bei Sourceanalytix verdoppelt.
          • J Joshude
            €2:
            crunchipC Offline
            crunchipC Offline
            #1383
            @joshude
            das heisst, du hattest da jeweils ein device reset
            dann sind die Wert eh für die Tonne
            also wird aktuell gar nix geschrieben
            ist das der original Datenpunkt?
            shelly sind bekannt dafür, das bei Strom weg, der Zähler bei 0 beginnt, weil nicht in den flash Speicher geschrieben wird, bei vereinzelten shelly passiert es auch bei einem firmware update(hatte ich z.b. mit einem shelly 1pm+)
            • F Offline
              Frank579
              #1384
              Hallo und frohe Weihnachten zusammen, habe ein Problem beim device Reset, er wird zwar laut Log erkannt aber er wäre deaktiviert/unter Stellenwert.
              Hatte beim Schwellenwert 1 drin stehen habe aber auch schon mit 0 versucht immer die selbe Meldung im Log.
              Habe schon was mit den Einstellungen rum Experimentiert aber es bleibt dabei 😔
              Sourceanalytix läuft die aktuelle Beta ...
              2022-12-26 11:14:12.712 - info: sourceanalytix.0 (34718) Device reset detected for alias.0.Geräte.PV_Anlage.CONSUMPTION, feature disabled (or below threshold) processing normally)
              Jemand einen wink in die richtige Richtung 😀
              etvE 1 Antwort Letzte Antwort
              • F Frank579
                etvE Offline
                etvE Offline
                etv
                #1385
                Hallo in die Runde!
                Auch ich hab ein "device reset" Problem und finde keine Lösung....
                Ich hab unter anderem auch Verbrauchsgruppen in denen ich die Verbräuche mehrerer Geräte summiere. Wenn nun eines der Geräte einen Device Reset macht, dann erkennt der SourceAnalytix den Reset bei diesem Gerät - so weit so gut.
                ABER - in der Verbrauchsgruppe springt der Verbrauch dann ja nur um den Wert dieses einen Geräts "runter". D.h. von z.B. 115 kWh auf 97 kWh.
                SourceAnalytix erkennt das als Reset, nimmt aber "0" als neuen Startwert und somit stimmt die Verbrauchssumme nicht mehr.
                Wie kann ich das mit dem Reset so einstellen, dass er dann den jetzt neuen Wert (z.B. eben 97) als "0" nimmt und nicht von wirklich "0" wieder hochzählt?
                Liebe Grüße
                tom
                …ist schon sehr lange begeisterter ioBroker Nutzer! 1x zu Hause und 1x auf der Alm. ioBroker ist das 'Hirn' des Smarthome und steuert HomeMatic und Shellys, loggt was so passiert, zeigt es auf Tabletts schön an und ermöglicht mir via Cloud Adapter den Fernzugriff...
                • crunchipC Offline
                  crunchipC Offline
                  #1386
                  @all
                  denkt dran, heute Nacht nach 0:00Uhr die Instanz einmal neu zu starten, damit die Ordner angelegt werden
                  ChaotC M 2 Antworten Letzte Antwort
                    @all
                    ChaotC Offline
                    ChaotC Offline
                    Chaot
                    #1387
                    @crunchip Habe ich damals bei der Installation schon eingerichtet:
                    a200A O 2 Antworten Letzte Antwort
                    • ChaotC Chaot
                      a200A Offline
                      a200A Offline
                      a200
                      #1388
                      @chaot habe einen neuen strompreis angelegt. reicht das, wenn ich morgen nachmittags den neuen preis den verschiedenen geräten in SA zuweise?
                      IoBroker auf QNAP TS-451, Raspi und NUC
                      • a200A a200
                        ChaotC Offline
                        ChaotC Offline
                        Chaot
                        schrieb am zuletzt editiert von Chaot
                        #1389
                        @a200 Was meinst du mit "angelegt"? Wenn du In SA den Strompreis änderst wird er ab der Änderung so für den Tag übernommen.
                          @all
                          ManfredHi
                          schrieb am zuletzt editiert von ManfredHi
                          #1390
                          @crunchip sagte in [SourceAnalytix 0.4.8-Final] Released !:
                          Danke für den Hinweis. Hatte ich noch nicht eingerichtet, dass der Adapter am 1. Jänner kurz nach Mitternacht neu gestartet werden soll.
                          Guten Rutsch & Prosit Neujahr 2023 !
                          • ChaotC Chaot
                            O Online
                            O Online
                            Oli
                            #1391
                            @chaot
                            Sorry für die blöde Frage, aber wo stelle ich das ein?
                            Einen guten Rutsch ins neue Jahr wünschen ich.
                            Oliver
                            • O Oli
                              @chaot
                              ManfredHi
                              #1392
                              @oli sagte in [SourceAnalytix 0.4.8-Final] Released !:
                              Expertenmodus einschalten und dann bei der Instanz das "Automatisch neu starten" konfigurieren:
                              O 1 Antwort Letzte Antwort
                              • M ManfredHi
                                O Online
                                O Online
                                Oli
                                #1393
                                @manfredh-1
                                Super, danke und guten Rutsch
                                Oliver
                                • O Oli
                                  @manfredh-1
                                  babl
                                  #1394
                                  @Dutchman moin
                                  Zuerst mal an alle ein gutes neues Jahr, meine Frage, kann man die letzten Jahre vom Adapter irgendwie ein bisschen optimieren, habe bei Sourceanalytix alleine an die fast 10000 states. Kann ich z.B. von 2020 die Monats, Wochen und Tagesdaten löschen ohne daß hier dann irgendwas krumm läuft?
                                  tugsiT 1 Antwort Letzte Antwort
                                  • B babl
                                    @Dutchman moin
                                    tugsiT Offline
                                    tugsiT Offline
                                    tugsi
                                    #1395
                                    @babl sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                    Ja, Du kannst den Datenpunkt 2020 löschen und somit die Unterstruktur Monat, Wochen, Quartal gleich mit.
                                    Darauf wird nicht mehr zugegriffen, ist halt dann "nur" noch als Historie drin.
                                    Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
                                    • tugsiT Offline
                                      tugsiT Offline
                                      tugsi
                                      #1396
                                      Ab wann wird Zählerstand zu Jahresbeginn umgestellt?
                                      Ich habe da noch den Stand von 2022 drin, auch nach einem Neustart des Adapters.
                                      • tugsiT tugsi
                                        crunchipC Offline
                                        crunchipC Offline
                                        #1397
                                        @tugsi sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                        welchen Zählerstand meinst du?
                                        • W Offline
                                          W Offline
                                          Willi-Wunder
                                          #1398
                                          euch erstmal mal ein gesundes neues Jahr und vielen Dank für den tollen Adapter :-)
                                          Habe meinen Adpater nun neugestartet damit er das Jahr 2023 anlegt. Mir ist aufgefallen, dass beim Datenpunkt 2023 - consumed - weeks bei Woche 52 bereits Werte drin stehen. Hat hiefür jemand eine Erklärung? Messe 2x Shellys + 1x Mqqt, bei allen dreien das gleiche.....
