  4. [SourceAnalytix 0.4.8-Final] Released !
2.3k Beiträge 184 Kommentatoren 1.5m Aufrufe 153 Beobachtet
  • J Offline
    Joshude
    #1376
    Ich finde leider über die Suche nichts:
    Ich musste meinen iobroker neu aufsetzen und habe alles ausm Backup wiederhergestellt. Inkl. InfluxDB, die Daten sehen mir auch valide aus.
    Leider spuckt Sourceanalytix nun keine plausiblen Werte mehr aus.
    Log liest sich auch, als wäre ein alter Wert erkannt worden, aber dennoch gibts hier Probleme.
    sourceanalytix.0 2022-12-21 19:15:52.619	error	Initialization of shelly.0.SHEM-3#C45BBE798A48#1.Total.ConsumedPower failed, check warn messages !
    sourceanalytix.0 2022-12-21 19:15:52.618	error	Cannot handle calculations for shelly.0.SHEM-3#C45BBE798A48#1.Total.ConsumedPower, check log messages and adjust settings!
    sourceanalytix.0 2022-12-21 19:15:52.618	error	Troubleshoot Data shelly.0.SHEM-3#C45BBE798A48#1.Total.ConsumedPower custom Data : {"type":"state","common":{"name":"Total consumed energy","type":"number","role":"value.totalconsumed","read":true,"write":false,"def":0,"unit":"Wh","custom":{"influxdb.0":{"enabled":true,"storageType":"","aliasId":"","changesOnly":true,"debounce":1000,"changesRelogInterval":0,"changesMinDelta":0,"retention":31536000,"debounceTime":0,"blockTime":1000,"ignoreBelowNumber":"","disableSkippedValueLogging":false,"enableDebugLogs":false},"sourceanalytix.0":{"enabled":true,"selectedUnit":"Detect automatically","start_day":8564.140800000001,"start_week":8564.140800000001,"start_month":8425.0793,"start_quarter":6455.4933,"start_year":250,"selectedPrice":"ElectricityDay","costs":true,"consumption":true,"meter_values":false,"valueAtDeviceReset":6457.1286,"valueAtDeviceInit":null,"cumulativeValue":8564.140800000001}}},"native":{},"_id":"shelly.0.SHEM-3#C45BBE798A48#1.Total.ConsumedPower","acl":{"owner":"system.user.admin","ownerGroup":"system.group.administrator","object":1636,"state":1636},"from":"system.adapter.shelly.0","user":"system.user.admin","ts":1671646529552}
    sourceanalytix.0 2022-12-21 19:15:52.617	error	Check settings for shelly.0.SHEM-3#C45BBE798A48#1.Total.ConsumedPower ! Known valueAtDeviceReset : (6457.1286) > known cumulative value (0) cannot proceed
    sourceanalytix.0 2022-12-21 19:15:52.611	info	Initialising (4 of 6) "shelly.0.SHEM-3#C45BBE798A48#1.Total.ConsumedPower"
    • J Joshude
      crunchipC Offline
      crunchipC Offline
      #1377
      @joshude sagte in [SourceAnalytix 0.4.8-Final] Released !:
      war der shelly Stromlos?
      • J Offline
        Joshude
        #1378
        Nein, die liefen alle weiter
        • J Joshude
          crunchipC Offline
          crunchipC Offline
          #1379
          @joshude und was hat dieser shelly für einen Zählerstand aktuell?
          laut deinem Auszug
          aber ein Reset erkannt
          zeig mal das Raw vom original DP
            laut deinem Auszug
            Joshude
            #1380
            @crunchip
            Der Raw-Value beträgt 2134364.8
              "type": "state",
              "common": {
                "name": "Total consumed energy",
                "type": "number",
                "role": "value.totalconsumed",
                "read": true,
                "write": false,
                "def": 0,
                "unit": "Wh",
                "custom": {
                  "influxdb.0": {
                    "enabled": true,
                    "storageType": "",
                    "aliasId": "",
                    "changesOnly": true,
                    "debounce": 1000,
                    "changesRelogInterval": 0,
                    "changesMinDelta": 0,
                    "retention": 31536000,
                    "debounceTime": 0,
                    "blockTime": 1000,
                    "ignoreBelowNumber": "",
                    "disableSkippedValueLogging": false,
                    "enableDebugLogs": false
                  "sourceanalytix.0": {
                    "enabled": true,
                    "selectedUnit": "Detect automatically",
                    "start_day": 8564.140800000001,
                    "start_week": 8564.140800000001,
                    "start_month": 8425.0793,
                    "start_quarter": 6455.4933,
                    "start_year": 250,
                    "selectedPrice": "ElectricityDay",
                    "costs": true,
                    "consumption": true,
                    "meter_values": true,
                    "valueAtDeviceReset": 6457.1286,
                    "valueAtDeviceInit": null,
                    "cumulativeValue": 8564.140800000001
              "native": {},
              "_id": "shelly.0.SHEM-3#C45BBE798A48#1.Total.ConsumedPower",
              "acl": {
                "owner": "system.user.admin",
                "object": 1636,
                "state": 1636
              "from": "system.adapter.shelly.0",
              "user": "system.user.admin",
              "ts": 1671659753935
            Die Werte in den Settings des DP:
            • J Joshude
              @crunchip
                "type": "state",
                "common": {
                  "type": "number",
                  "read": true,
                  "write": false,
                  "def": 0,
                  "unit": "Wh",
                  "custom": {
                    "influxdb.0": {
                      "enabled": true,
                      "storageType": "",
                      "aliasId": "",
                      "debounce": 1000,
                      "debounceTime": 0,
                      "blockTime": 1000,
                      "enabled": true,
                      "start_year": 250,
                      "costs": true,
                "native": {},
                "acl": {
                  "object": 1636,
                  "state": 1636
                "ts": 1671659753935
              crunchipC Offline
              crunchipC Offline
              #1381
              2134364.8
              das ist der Wert deines shelly Zähler? oder vllt ein anderer?
              das stimmt doch hinten und vorne nicht.
              "start_day": 8564.140800000001, "start_week": 8564.140800000001,
              des weiteren sind hier beide Werte gleich, heute ist bereits Mittwoch, ist der Zähler nicht gelaufen?
              wie alt war denn das backup?
              • J Offline
                Joshude
                schrieb am zuletzt editiert von Joshude
                #1382
                Das Backup war vom 19.12., 2 Uhr morgens. Im Laufe des 19. habe ich mir die Kiste dann zerschossen.
                Wobei, jetzt wo ich tippe... Irgendwann, ich glaube im August und September hat sich jeweils der Wert im Sourceanalytix auf magische Weise ohne mein Zutun verdoppelt. Also von ca 2000kwh auf 4000 und dann noch mal verdoppelt auf 8000. Das heißt die 8500kwh sind eh nicht richtig, da fehlen mir jetzt aber die genauen historischen Daten. So stand der dann aber zuletzt immer im Sourceanalytix und ich habe erstmal damit gelebt.
                €: Für z.B. den genannten Shelly sind auch alle Datenpunkte in Sourceanalytix leer. Sprich die ganzen historischen Daten was die monatlichen Verbräuche und so angeht. Das wäre schon schade, wenn das alles weg ist
                €2:
                Wenn ich mir die Daten im EChart-Adapter angucke sind die noch alle da. Also das ist jetzt der historische Datenbestand aus InfluxDB für den jetzt hier exemplarisch genannten DP. da sieht man auch an 4 Stellen die Ausbrüche nach unten, da waren es jeweils -3kwh, warum auch immer. An den letzten beiden hat sich jeweils der Wert bei Sourceanalytix verdoppelt.
                • J Joshude
                  €2:
                  crunchipC Offline
                  crunchipC Offline
                  #1383
                  @joshude
                  das heisst, du hattest da jeweils ein device reset
                  dann sind die Wert eh für die Tonne
                  also wird aktuell gar nix geschrieben
                  ist das der original Datenpunkt?
                  shelly sind bekannt dafür, das bei Strom weg, der Zähler bei 0 beginnt, weil nicht in den flash Speicher geschrieben wird, bei vereinzelten shelly passiert es auch bei einem firmware update(hatte ich z.b. mit einem shelly 1pm+)
                  • F Offline
                    Frank579
                    #1384
                    Hallo und frohe Weihnachten zusammen, habe ein Problem beim device Reset, er wird zwar laut Log erkannt aber er wäre deaktiviert/unter Stellenwert.
                    Hatte beim Schwellenwert 1 drin stehen habe aber auch schon mit 0 versucht immer die selbe Meldung im Log.
                    Habe schon was mit den Einstellungen rum Experimentiert aber es bleibt dabei 😔
                    Sourceanalytix läuft die aktuelle Beta ...
                    2022-12-26 11:14:12.712 - info: sourceanalytix.0 (34718) Device reset detected for alias.0.Geräte.PV_Anlage.CONSUMPTION, feature disabled (or below threshold) processing normally)
                    Jemand einen wink in die richtige Richtung 😀
                    etvE 1 Antwort Letzte Antwort
                    • F Frank579
                      etvE Offline
                      etvE Offline
                      etv
                      #1385
                      Hallo in die Runde!
                      Auch ich hab ein "device reset" Problem und finde keine Lösung....
                      Ich hab unter anderem auch Verbrauchsgruppen in denen ich die Verbräuche mehrerer Geräte summiere. Wenn nun eines der Geräte einen Device Reset macht, dann erkennt der SourceAnalytix den Reset bei diesem Gerät - so weit so gut.
                      ABER - in der Verbrauchsgruppe springt der Verbrauch dann ja nur um den Wert dieses einen Geräts "runter". D.h. von z.B. 115 kWh auf 97 kWh.
                      SourceAnalytix erkennt das als Reset, nimmt aber "0" als neuen Startwert und somit stimmt die Verbrauchssumme nicht mehr.
                      Wie kann ich das mit dem Reset so einstellen, dass er dann den jetzt neuen Wert (z.B. eben 97) als "0" nimmt und nicht von wirklich "0" wieder hochzählt?
                      Liebe Grüße
                      tom
                      …ist schon sehr lange begeisterter ioBroker Nutzer! 1x zu Hause und 1x auf der Alm. ioBroker ist das 'Hirn' des Smarthome und steuert HomeMatic und Shellys, loggt was so passiert, zeigt es auf Tabletts schön an und ermöglicht mir via Cloud Adapter den Fernzugriff...
                      • crunchipC Offline
                        crunchipC Offline
                        #1386
                        @all
                        denkt dran, heute Nacht nach 0:00Uhr die Instanz einmal neu zu starten, damit die Ordner angelegt werden
                        ChaotC M 2 Antworten Letzte Antwort
                          @all
                          ChaotC Offline
                          ChaotC Offline
                          Chaot
                          #1387
                          @crunchip Habe ich damals bei der Installation schon eingerichtet:
                          a200A O 2 Antworten Letzte Antwort
                          • ChaotC Chaot
                            a200A Offline
                            a200A Offline
                            a200
                            #1388
                            @chaot habe einen neuen strompreis angelegt. reicht das, wenn ich morgen nachmittags den neuen preis den verschiedenen geräten in SA zuweise?
                            IoBroker auf QNAP TS-451, Raspi und NUC
                            • a200A a200
                              ChaotC Offline
                              ChaotC Offline
                              Chaot
                              schrieb am zuletzt editiert von Chaot
                              #1389
                              @a200 Was meinst du mit "angelegt"? Wenn du In SA den Strompreis änderst wird er ab der Änderung so für den Tag übernommen.
                                @all
                                ManfredHi
                                schrieb am zuletzt editiert von ManfredHi
                                #1390
                                @crunchip sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                Danke für den Hinweis. Hatte ich noch nicht eingerichtet, dass der Adapter am 1. Jänner kurz nach Mitternacht neu gestartet werden soll.
                                Guten Rutsch & Prosit Neujahr 2023 !
                                • ChaotC Chaot
                                  O Offline
                                  O Offline
                                  Oli
                                  #1391
                                  @chaot
                                  Sorry für die blöde Frage, aber wo stelle ich das ein?
                                  Einen guten Rutsch ins neue Jahr wünschen ich.
                                  Oliver
                                  • O Oli
                                    @chaot
                                    ManfredHi
                                    #1392
                                    @oli sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                    Expertenmodus einschalten und dann bei der Instanz das "Automatisch neu starten" konfigurieren:
                                    O 1 Antwort Letzte Antwort
                                    • M ManfredHi
                                      O Offline
                                      O Offline
                                      Oli
                                      #1393
                                      @manfredh-1
                                      Super, danke und guten Rutsch
                                      Oliver
                                      • O Oli
                                        @manfredh-1
                                        babl
                                        #1394
                                        @Dutchman moin
                                        Zuerst mal an alle ein gutes neues Jahr, meine Frage, kann man die letzten Jahre vom Adapter irgendwie ein bisschen optimieren, habe bei Sourceanalytix alleine an die fast 10000 states. Kann ich z.B. von 2020 die Monats, Wochen und Tagesdaten löschen ohne daß hier dann irgendwas krumm läuft?
                                        tugsiT 1 Antwort Letzte Antwort
                                        • B babl
                                          @Dutchman moin
                                          tugsiT Offline
                                          tugsiT Offline
                                          tugsi
                                          #1395
                                          @babl sagte in [SourceAnalytix 0.4.8-Final] Released !:
                                          Ja, Du kannst den Datenpunkt 2020 löschen und somit die Unterstruktur Monat, Wochen, Quartal gleich mit.
                                          Darauf wird nicht mehr zugegriffen, ist halt dann "nur" noch als Historie drin.
                                          Master ioBroker in Proxmox als LXC auf 1. Tiny-Lenovo, Proxmox-VM als Slave auf 2. Tinyi-Lenovo mit Zigbee und Monitor zur Visualisierung, Hauptautomatisierung über S7 auf Beckhoff CX, dazu noch Shelly, Homematic...
