  4. Admin startet nicht mehr
    5.6k
111 Beiträge 9 Kommentatoren 19.0k Aufrufe 8 Beobachtet
    @phoenixcr
    iobroker stop
    iobroker fix
    iobroker start
    iobroker diag
    PhoenixCR
    schrieb am zuletzt editiert von PhoenixCR
    Hallo Thomas, danke, es hat funktioniert.
    Anbei das Ergebnis.
    			v.2022-12-13
    Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
    Installation: 		Native
    Timezone: 		Europe/Berlin
    User-ID: 		1000
    X-Server: 		true
    Pending OS-Updates: 	74
    Nodejs-Installation: 	/usr/bin/nodejs 	v16.17.1
    			/usr/bin/node 		v16.17.1
    			/usr/bin/npm 		8.19.2
    ioBroker Core: 		js-controller 		4.0.23
    			admin 			6.3.5
    ioBroker Status: 	iobroker is running on this host.
    Objects type: jsonl
    States  type: jsonl
    Pending iob updates: 	0
    Objects: 		6537
    States: 		5071
    Size of iob-Database:
    8.8M	/opt/iobroker/iobroker-data/objects.jsonl
    6.7M	/opt/iobroker/iobroker-data/objects.json.migrated
    6.7M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
    2.2M	/opt/iobroker/iobroker-data/states.jsonl
    816K	/opt/iobroker/iobroker-data/states.json.migrated
    816K	/opt/iobroker/iobroker-data/states.json.bak.migrated
    0	/opt/iobroker/iobroker-data/states.json.broken
    ====================== END OF SUMMARY ==================
    P Thomas BraunT 2 Antworten Letzte Antwort
    • P PhoenixCR
      Anbei das Ergebnis.
      			v.2022-12-13
      User-ID: 		1000
      X-Server: 		true
      			/usr/bin/npm 		8.19.2
      			admin 			6.3.5
      Objects type: jsonl
      States  type: jsonl
      Objects: 		6537
      States: 		5071
      PhoenixCR
      @phoenixcr
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      Skript v.2022-12-13
      *** BASE SYSTEM ***
      Model		: Raspberry Pi 4 Model B Rev 1.4
      Architecture: 	armv7l
      Docker: 	false
      Virtualization: none
      Distributor ID:	Raspbian
      Description:	Raspbian GNU/Linux 10 (buster)
      Release:	10
      Codename:	buster
      PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="10"
      VERSION="10 (buster)"
      VERSION_CODENAME=buster
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       10:39:03 up  2:24,  2 users,  load average: 2.11, 2.56, 2.59
      CPU threads: 4
      *** Time and Time Zones ***
      Tue Dec 27 09:39:03 UTC 2022
      Tue Dec 27 10:39:03 CET 2022
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      pi
      /home/pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server: 	true
      Desktop: 	LXDE-pi
      Terminal: 	x11
      *** MEMORY ***
      Mem:           7.9G        1.7G        4.6G        125M        1.7G        6.3G
      Swap:           99M          0B         99M
      Total:         8.0G        1.7G        4.7G
               7897 M total memory
               1677 M used memory
                526 M active memory
               2540 M inactive memory
               4551 M free memory
                240 M buffer memory
               1427 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4      118G   13G  101G  11% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G  1.7M  3.9G   1% /dev/shm
      tmpfs          tmpfs     3.9G   74M  3.8G   2% /run
      tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
      /dev/sda1      vfat      253M   49M  204M  20% /boot
      tmpfs          tmpfs     790M   12K  790M   1% /run/user/1000
      TARGET                SOURCE     FSTYPE          OPTIONS
      /                     /dev/sda2  ext4            rw,noatime
      |-/sys/fs/bpf         none       bpf             rw,nosuid,nodev,noexec,relatime,mode=700
      |-/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
      `-/boot               /dev/sda1  vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
      /var:
      2.6G	/var/
      1.1G	/var/cache/apt/archives
      1.1G	/var/cache/apt
      1.1G	/var/cache
      1002M	/var/log
      /opt/iobroker/backups:
      1.8G	/opt/iobroker/backups/
      /opt/iobroker/iobroker-data:
      786M	/opt/iobroker/iobroker-data/
      509M	/opt/iobroker/iobroker-data/files
      92M	/opt/iobroker/iobroker-data/node-red
      91M	/opt/iobroker/iobroker-data/node-red/node_modules
      86M	/opt/iobroker/iobroker-data/backup-objects
      33M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
      15M	/opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
      9.7M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
      9.1M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
      8.9M	/opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
      *** NodeJS-Installation ***
      /usr/bin/npm 		8.19.2
      nodejs:
        Installed: 16.17.1-deb-1nodesource1
        Candidate: 16.19.0-deb-1nodesource1
        Version table:
           16.19.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
       *** 16.17.1-deb-1nodesource1 100
           10.24.0~dfsg-1~deb10u2 500
      *** ioBroker-Installation ***
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      Core adapters versions
      js-controller: 	4.0.23
      admin: 		6.3.5
      Adapters from github: 	3
      + system.adapter.admin.0                  : admin                 : HomeAutomation                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.influxdb.0               : influxdb              : HomeAutomation                           -  enabled, port: 8086
      + system.adapter.mqtt.0                   : mqtt                  : HomeAutomation                           -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : HomeAutomation                           -  enabled, port: 1880, bind: 0.0.0.0
      + system.adapter.sayit.0                  : sayit                 : HomeAutomation                           -  enabled, port: 0
      + system.adapter.sonoff.0                 : sonoff                : HomeAutomation                           -  enabled, port: 1883, bind: 0.0.0.0
      + system.adapter.telegram.0               : telegram              : HomeAutomation                           -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.web.0                    : web                   : HomeAutomation                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      ioBroker-Repositories
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      ioBroker-Instances
      Adapter    "backitup"     : 2.5.9    , installed 2.5.9
      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
      Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "email"        : 1.1.4    , installed 1.1.4
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "heatingcontrol": 2.9.3   , installed 2.9.3
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "i2c"          : 1.2.1    , installed 1.2.1
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.9   , installed 1.11.9
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "paw"          : 0.3.2    , installed 0.3.2
      Adapter    "places"       : 1.1.2    , installed 1.1.2
      Adapter    "psa"          : 0.0.11   , installed 0.0.11
      Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
      Adapter    "samsung"      : 0.5.11   , installed 0.5.11
      Adapter    "sayit"        : 1.12.3   , installed 1.12.3
      Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
      Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "tankerkoenig" : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "text2command" : 2.3.0    , installed 2.3.0
      Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
      Adapter    "tuya"         : 3.11.1   , installed 3.11.1
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
      Objects and States
      Objects: 	6537
      States: 	5070
      E: Repository 'https://packages.grafana.com/oss/deb stable InRelease' changed its 'Origin' value from 'grafana stable' to '. stable'
      E: Repository 'https://packages.grafana.com/oss/deb stable InRelease' changed its 'Label' value from 'grafana stable' to '. stable'
      Pending Updates: 74
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1527171    25234/io.jarvis.0
      tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          14319      577/dnsmasq
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17752      552/sshd
      tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15673      372/cupsd
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       1518166    21372/node-red
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14331      499/influxd
      tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1518129    22389/io.sonoff.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       1514484    22107/io.mqtt.0
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       1514485    22107/io.mqtt.0
      tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          17800      514/anydesk
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1507075    19141/iobroker.js-c
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1507068    19141/iobroker.js-c
      tcp        0      0 0.0.0.0:35789           0.0.0.0:*               LISTEN      0          35725      514/anydesk
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1509661    19484/io.admin.0
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1532606    26604/io.web.0
      tcp6       0      0 :::46163                :::*                    LISTEN      1001       1516423    21372/node-red
      tcp6       0      0 :::53                   :::*                    LISTEN      0          14321      577/dnsmasq
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        19382      499/influxd
      tcp6       0      0 :::22                   :::*                    LISTEN      0          17754      552/sshd
      tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15672      372/cupsd
      tcp6       0      0 :::3000                 :::*                    LISTEN      117        20679      488/grafana-server
      tcp6       0      0 :::45665                :::*                    LISTEN      1001       1518656    21372/node-red
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1518873    22710/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1518874    22710/io.tuya.0
      udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          14318      577/dnsmasq
      udp     2624      0 0.0.0.0:68              0.0.0.0:*                           0          20843      416/dhcpcd
      udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18488      508/cups-browsed
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1521559    24181/io.chromecast
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1516452    21372/node-red
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1516449    21372/node-red
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15678      410/avahi-daemon: r
      udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          22414      514/anydesk
      udp        0      0 0.0.0.0:58711           0.0.0.0:*                           108        15680      410/avahi-daemon: r
      udp6       0      0 :::58809                :::*                                108        15681      410/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          21468      416/dhcpcd
      udp6       0      0 :::53                   :::*                                0          14320      577/dnsmasq
      udp6       0      0 :::5353                 :::*                                108        15679      410/avahi-daemon: r
                         Mark until here for C&P
      iob diag has finished.
      • P PhoenixCR
        Anbei das Ergebnis.
        			v.2022-12-13
        User-ID: 		1000
        X-Server: 		true
        			/usr/bin/npm 		8.19.2
        			admin 			6.3.5
        Objects type: jsonl
        States  type: jsonl
        Objects: 		6537
        States: 		5071
        @phoenixcr sagte in Admin startet nicht mehr:
        buster
        Buster hat sein End Of Life erreicht. Installier da das 'Bullseye'-Release.
        Und zwar dann OHNE Desktop.
        P 1 Antwort Letzte Antwort
          buster
          PhoenixCR
          ich brauche aber das Desktop, zwecks Fernzugriff.
          Glaubst du, das ist das Problem der abstürzte?
          Danke!
          • P PhoenixCR
            Danke!
            Macht man per SSH und Kommandozeile. OHNE DESKTOP!!
            J P 2 Antworten Letzte Antwort
              jhg
              Ich hänge mich hier mal mit einer Frage dran, da es nicht lohnt dafür einen neuen Thread zu öffnen.
              Nachdem ich meinen ioBroker auf neue Hardware umgezogen habe, hat der Admin adapter nun die Nummer 2.
              Also admin.2 und nicht admin.0.
              Kann das irgendwann mal Probleme machen? Sollte ich das ändern?
                PhoenixCR
                erledigt, ohne Desktop.
                Selber Verhältnis.
                In log, steht nichts Besonderes
                fehlt sogar der Export Knopf
                • P PhoenixCR
                  Selber Verhältnis.
                  @phoenixcr
                  Und
                  iobroker diag
                  sagt nun?
                    @phoenixcr
                    Und
                    iobroker diag
                    sagt nun?
                    PhoenixCR
                    @thomas-braun sagte in Admin startet nicht mehr:
                    iobroker diag
                    Skript v.2022-12-13
                    *** BASE SYSTEM ***
                    Docker:         false
                    Description:    Raspbian GNU/Linux 11 (bullseye)
                    Release:        11
                    Codename:       bullseye
                    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
                    VERSION_ID="11"
                    VERSION="11 (bullseye)"
                    VERSION_CODENAME=bullseye
                    ID=raspbian
                    ID_LIKE=debian
                     19:57:59 up  4:13,  1 user,  load average: 1.41, 1.63, 2.53
                    CPU threads: 4
                    Tue Dec 27 19:57:59 UTC 2022
                    Tue Dec 27 19:57:59 GMT 2022
                    GMT +0000
                    Europe/London
                    chris
                    /home/chris
                    chris adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                    X-Server:       false
                    Desktop:
                    Terminal:       tty
                    *** MEMORY ***
                    Mem:            7.9G        1.5G        4.4G        0.0K        2.0G        6.4G
                    Swap:            99M        1.0M         98M
                    Total:          8.0G        1.5G        4.5G
                             7897 M total memory
                             1490 M used memory
                              701 M active memory
                             2533 M inactive memory
                             4388 M free memory
                              151 M buffer memory
                             1867 M swap cache
                               99 M total swap
                                1 M used swap
                               98 M free swap
                    *** FILESYSTEM ***
                    /dev/root      ext4      118G  5.0G  108G   5% /
                    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                    /dev/sda1      vfat      255M   50M  206M  20% /boot
                    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                    /var:
                    542M    /var/
                    282M    /var/cache
                    276M    /var/cache/apt
                    212M    /var/cache/apt/archives
                    98M     /var/lib
                    240M    /opt/iobroker/backups/
                    118M    /opt/iobroker/backups/Influxdb
                    529M    /opt/iobroker/iobroker-data/
                    428M    /opt/iobroker/iobroker-data/files
                    79M     /opt/iobroker/iobroker-data/node-red/node_modules
                    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                    17M     /opt/iobroker/iobroker-data/objects.jsonl
                    /usr/bin/nodejs         v16.19.0
                    /usr/bin/node           v16.19.0
                    /usr/bin/npm            8.19.3
                    nodejs:
                      Installed: 16.19.0-deb-1nodesource1
                      Version table:
                     *** 16.19.0-deb-1nodesource1 500
                            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                         12.22.12~dfsg-1~deb11u1 500
                    ioBroker Status
                    Objects type: jsonl
                    States  type: jsonl
                    admin:          6.3.5
                    Adapters from github:   2
                    + system.adapter.admin.0                  : admin                 : homeautomationcretu                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.mqtt.0                   : mqtt                  : homeautomationcretu                      -  enabled, port: 1885, bind: 0.0.0.0
                    + system.adapter.sayit.0                  : sayit                 : homeautomationcretu                      -  enabled, port: 0
                    + system.adapter.telegram.0               : telegram              : homeautomationcretu                      -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.web.0                    : web                   : homeautomationcretu                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                    ioBroker-Instances
                    Objects and States
                    Objects:        6463
                    States:         5008
                    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                    Hit:3 https://repos.influxdata.com/debian bullseye InRelease
                    Hit:4 https://apt.grafana.com stable InRelease
                    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                    Reading package lists...
                    Pending Updates: 0
                    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       45447      10525/io.jarvis.0
                    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11762      541/sshd: /usr/sbin
                    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        140894     26161/influxd
                    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       44880      11581/io.mqtt.0
                    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       44881      11581/io.mqtt.0
                    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16053      1795/iobroker.js-co
                    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16046      1795/iobroker.js-co
                    tcp6       0      0 :::22                   :::*                    LISTEN      0          11764      541/sshd: /usr/sbin
                    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16122      1823/io.admin.0
                    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30720      7826/io.web.0
                    tcp6       0      0 :::8086                 :::*                    LISTEN      999        141933     26161/influxd
                    tcp6       0      0 :::3000                 :::*                    LISTEN      110        77925      17659/grafana-serve
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33946      7993/io.chromecast.
                    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11593      403/avahi-daemon: r
                    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32188      7852/io.tuya.0
                    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32189      7852/io.tuya.0
                    udp        0      0 0.0.0.0:43026           0.0.0.0:*                           108        11595      403/avahi-daemon: r
                    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14566      783/dhcpcd
                    udp6       0      0 :::5353                 :::*                                108        11594      403/avahi-daemon: r
                    udp6       0      0 :::56192                :::*                                108        11596      403/avahi-daemon: r
                    udp6       0      0 :::546                  :::*                                0          14628      783/dhcpcd
                    Press any key for a summary
                    • P PhoenixCR
                      iobroker diag
                      Skript v.2022-12-13
                      *** BASE SYSTEM ***
                      Docker:         false
                      Release:        11
                      Codename:       bullseye
                      VERSION_ID="11"
                      ID=raspbian
                      ID_LIKE=debian
                      CPU threads: 4
                      GMT +0000
                      Europe/London
                      chris
                      /home/chris
                      X-Server:       false
                      Desktop:
                      Terminal:       tty
                      *** MEMORY ***
                      Swap:            99M        1.0M         98M
                               7897 M total memory
                               1490 M used memory
                                701 M active memory
                               4388 M free memory
                                151 M buffer memory
                               1867 M swap cache
                                 99 M total swap
                                  1 M used swap
                                 98 M free swap
                      *** FILESYSTEM ***
                      /var:
                      542M    /var/
                      282M    /var/cache
                      276M    /var/cache/apt
                      98M     /var/lib
                      /usr/bin/npm            8.19.3
                      nodejs:
                        Version table:
                      ioBroker Status
                      Objects type: jsonl
                      States  type: jsonl
                      admin:          6.3.5
                      ioBroker-Instances
                      Objects and States
                      Objects:        6463
                      States:         5008
                      Pending Updates: 0
                      @phoenixcr
                      Setz die Zeitzone richtig.
                      Problem behoben?
                      • P PhoenixCR
                        @djmarc75 sagte in Admin startet nicht mehr:
                        iobroker start admin
                        Hallo an alle, bei mir stürzt nämlich auch der Admin ab und zu ab.
                        Der Instanz ist nicht immer in die liste an. Wenn ich es Manuel starte, läuft es eine weile.
                        Der iobroker diag Befehl, gibt bei mir nur die help liste aus, komisch.
                        pi@HomeAutomation:~ $ iobroker list instances
                        + system.adapter.backitup.0               : backitup              : HomeAutomation                           -  enabled
                        + system.adapter.chromecast.0             : chromecast            : HomeAutomation                           -  enabled
                          system.adapter.daswetter.0              : daswetter             : HomeAutomation                           - disabled
                        + system.adapter.device-reminder.0        : device-reminder       : HomeAutomation                           -  enabled
                          system.adapter.devices.0                : devices               : HomeAutomation                           -  enabled
                        + system.adapter.discovery.0              : discovery             : HomeAutomation                           -  enabled
                        + system.adapter.ds18b20.0                : ds18b20               : HomeAutomation                           -  enabled
                          system.adapter.echarts.0                : echarts               : HomeAutomation                           - disabled
                        + system.adapter.email.0                  : email                 : HomeAutomation                           -  enabled
                          system.adapter.feiertage.0              : feiertage             : HomeAutomation                           - disabled
                          system.adapter.flot.0                   : flot                  : HomeAutomation                           -  enabled
                          system.adapter.fully-tablet-control.0   : fully-tablet-control  : HomeAutomation                           - disabled
                        + system.adapter.ham.0                    : ham                   : HomeAutomation                           -  enabled
                          system.adapter.heatingcontrol.0         : heatingcontrol        : HomeAutomation                           - disabled
                          system.adapter.history.0                : history               : HomeAutomation                           -  enabled
                          system.adapter.i2c.0                    : i2c                   : HomeAutomation                           - disabled
                          system.adapter.ical.0                   : ical                  : HomeAutomation                           -  enabled
                          system.adapter.icons-icons8.0           : icons-icons8          : HomeAutomation                           -  enabled
                          system.adapter.icons-material-png.0     : icons-material-png    : HomeAutomation                           -  enabled
                          system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeAutomation                           -  enabled
                          system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : HomeAutomation                           -  enabled
                          system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: HomeAutomation                           -  enabled
                        + system.adapter.info.0                   : info                  : HomeAutomation                           -  enabled
                        + system.adapter.iot.0                    : iot                   : HomeAutomation                           -  enabled
                        + system.adapter.jarvis.0                 : jarvis                : HomeAutomation                           -  enabled
                        + system.adapter.javascript.0             : javascript            : HomeAutomation                           -  enabled
                          system.adapter.lgtv.0                   : lgtv                  : HomeAutomation                           - disabled
                        + system.adapter.modbus.0                 : modbus                : HomeAutomation                           -  enabled
                          system.adapter.modbus.1                 : modbus                : HomeAutomation                           - disabled
                        + system.adapter.modbus.2                 : modbus                : HomeAutomation                           -  enabled
                        + system.adapter.net-tools.0              : net-tools             : HomeAutomation                           -  enabled
                          system.adapter.paw.0                    : paw                   : HomeAutomation                           - disabled, port: 2323
                          system.adapter.ping.0                   : ping                  : HomeAutomation                           - disabled
                          system.adapter.pushsafer.0              : pushsafer             : HomeAutomation                           - disabled
                        + system.adapter.rpi2.0                   : rpi2                  : HomeAutomation                           -  enabled
                          system.adapter.samsung.0                : samsung               : HomeAutomation                           - disabled
                          system.adapter.samsung_tizen.0          : samsung_tizen         : HomeAutomation                           - disabled, port: 8002
                          system.adapter.schoolfree.0             : schoolfree            : HomeAutomation                           -  enabled
                          system.adapter.shuttercontrol.0         : shuttercontrol        : HomeAutomation                           - disabled
                          system.adapter.speedport.0              : speedport             : HomeAutomation                           - disabled
                        + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeAutomation                           -  enabled
                        + system.adapter.text2command.0           : text2command          : HomeAutomation                           -  enabled
                          system.adapter.trashschedule.0          : trashschedule         : HomeAutomation                           - disabled
                        + system.adapter.tuya.0                   : tuya                  : HomeAutomation                           -  enabled
                        + system.adapter.virtualpowermeter.0      : virtualpowermeter     : HomeAutomation                           -  enabled
                          system.adapter.vis-bars.0               : vis-bars              : HomeAutomation                           -  enabled
                          system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : HomeAutomation                           -  enabled
                          system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeAutomation                           -  enabled
                          system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : HomeAutomation                           -  enabled
                          system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeAutomation                           -  enabled
                          system.adapter.vis-history.0            : vis-history           : HomeAutomation                           -  enabled
                          system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeAutomation                           -  enabled
                          system.adapter.vis-icontwo.0            : vis-icontwo           : HomeAutomation                           -  enabled
                        + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeAutomation                           -  enabled
                          system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeAutomation                           -  enabled
                          system.adapter.vis-justgage.0           : vis-justgage          : HomeAutomation                           -  enabled
                          system.adapter.vis-keyboard.0           : vis-keyboard          : HomeAutomation                           -  enabled
                          system.adapter.vis-lcars.0              : vis-lcars             : HomeAutomation                           -  enabled
                          system.adapter.vis-map.0                : vis-map               : HomeAutomation                           -  enabled
                          system.adapter.vis-material-advanced.0  : vis-material-advanced : HomeAutomation                           -  enabled
                          system.adapter.vis-metro.0              : vis-metro             : HomeAutomation                           -  enabled
                          system.adapter.vis-players.0            : vis-players           : HomeAutomation                           -  enabled
                          system.adapter.vis-plumb.0              : vis-plumb             : HomeAutomation                           -  enabled
                          system.adapter.vis-rgraph.0             : vis-rgraph            : HomeAutomation                           -  enabled
                          system.adapter.vis.0                    : vis                   : HomeAutomation                           -  enabled
                          system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeAutomation                           - disabled
                          system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : HomeAutomation                           - disabled
                          system.adapter.wifilight.0              : wifilight             : HomeAutomation                           - disabled
                        + system.adapter.yahka.0                  : yahka                 : HomeAutomation                           -  enabled
                          system.adapter.yahka.1                  : yahka                 : HomeAutomation                           - disabled
                        + instance is alive
                        pi@HomeAutomation:~ $ iobroker diag
                        iobroker [command]
                        Commands:
                          iobroker setup                                               Setup ioBroker
                          iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                          iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                          iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                          iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                          iobroker info                                                Shows the host info
                          iobroker logs [<adapter>]                                    Monitor log
                          iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                          iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                          iobroker rebuild [<module>]                                  Rebuild all native modules or path
                          iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                          iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                          iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                          iobroker update [<repositoryUrl>]                            Update repository and list adapters
                          iobroker upgrade                                             Upgrade management
                          iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                          iobroker object                                              Object management  [aliases: o]
                          iobroker state                                               State management  [aliases: s]
                          iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                          iobroker list <type> [<filter>]                              List all entries, like objects
                          iobroker chmod <mode> <file>                                 Change file rights
                          iobroker chown <user> <group> <file>                         Change file ownership
                          iobroker touch <file>                                        Touch file
                          iobroker rm <file>                                           Remove file
                          iobroker file                                                File management
                          iobroker user                                                User commands
                          iobroker group                                               group management
                          iobroker host <hostname>                                     Set host to given hostname
                          iobroker set <adapter>.<instance>                            Change settings of adapter config
                          iobroker license <license.file or license.text>              Update license by given file
                          iobroker cert                                                Certificate management
                          iobroker clean <yes>                                         Clears all objects and states
                          iobroker backup                                              Create backup
                          iobroker restore <backup name or path>                       Restore a specified backup
                          iobroker validate <backup name or path>                      Validate a specified backup
                          iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                          iobroker repo [<name>]                                       Show repo information
                          iobroker uuid                                                Show uuid of the installation  [aliases: id]
                          iobroker unsetup                                             Reset license, installation secret and language
                          iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                          iobroker multihost                                           Multihost management
                          iobroker compact                                             compact group management
                          iobroker plugin                                              Plugin management
                          iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                        Options:
                          --help  Show help  [boolean]
                        ich habe keine ideen mehr was es sein könnte.
                        danke schn mal im voraus für eure Hilfe.
                        ist das alles an Informationen?
                          @phoenixcr
                          Problem behoben?
                          PhoenixCR
                          Zurzeit ja.
                          Vielen Dank.
                            PhoenixCR
                            Siehe oben.
                            Aber im Moment läuft es.
                              @phoenixcr
                              Problem behoben?
                              PhoenixCR
                              geht wieder nicht
                              und der diag bleibt hängen beim repositories
                              /var:
                              864M    /var/
                              358M    /var/lib
                              282M    /var/cache
                              276M    /var/cache/apt
                              263M    /var/lib/influxdb
                              588M    /opt/iobroker/backups/
                              345M    /opt/iobroker/backups/influxdbold
                              302M    /opt/iobroker/backups/influxdbold/data
                              261M    /opt/iobroker/backups/influxdbold/data/iobroker
                              229M    /opt/iobroker/backups/influxdbold/data/iobroker/autogen
                              554M    /opt/iobroker/iobroker-data/
                              84M     /opt/iobroker/iobroker-data/node-red/node_modules
                              22M     /opt/iobroker/iobroker-data/objects.jsonl
                              /usr/bin/npm            8.19.3
                              nodejs:
                                Version table:
                              ioBroker Status
                              No connection to databases possible ...
                              admin:          6.3.5
                              • P PhoenixCR
                                geht wieder nicht
                                /var:
                                864M    /var/
                                358M    /var/lib
                                282M    /var/cache
                                276M    /var/cache/apt
                                /usr/bin/npm            8.19.3
                                nodejs:
                                  Version table:
                                ioBroker Status
                                admin:          6.3.5
                                Das dürfte lediglich länger dauern, wenn der iobroker nicht läuft.
                                  PhoenixCR
                                  Es ist gelaufen, habe nach 10 Minuten abgebrochen, dann ein fix durchgeführt.
                                  Skript v.2022-12-13
                                  *** BASE SYSTEM ***
                                  Docker:         false
                                  Release:        11
                                  Codename:       bullseye
                                  VERSION_ID="11"
                                  ID=raspbian
                                  ID_LIKE=debian
                                   12:56:56 up  2:16,  1 user,  load average: 1.96, 3.35, 3.43
                                  CPU threads: 4
                                  Wed Dec 28 11:56:56 UTC 2022
                                  Wed Dec 28 12:56:56 CET 2022
                                  CET +0100
                                  Europe/Berlin
                                  chris
                                  /home/chris
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Mem:            7.9G        552M        6.3G        1.0M        1.0G        7.1G
                                  Swap:            99M          0B         99M
                                  Total:          8.0G        552M        6.4G
                                           7897 M total memory
                                            552 M used memory
                                            296 M active memory
                                           1107 M inactive memory
                                           6309 M free memory
                                            173 M buffer memory
                                            861 M swap cache
                                             99 M total swap
                                              0 M used swap
                                             99 M free swap
                                  *** FILESYSTEM ***
                                  /dev/root      ext4      118G  5.7G  107G   6% /
                                  /var:
                                  877M    /var/
                                  360M    /var/lib
                                  283M    /var/cache
                                  277M    /var/cache/apt
                                  265M    /var/lib/influxdb
                                  538M    /opt/iobroker/iobroker-data/
                                  /usr/bin/npm            8.19.3
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.5
                                  + system.adapter.influxdb.0               : influxdb              : homeautomationcretu                      -  enabled, port: 8086
                                  + system.adapter.node-red.0               : node-red              : homeautomationcretu                      -  enabled, port: 1880, bind: 0.0.0.0
                                  ioBroker-Instances
                                  Objects and States
                                  Objects:        6464
                                  States:         5015
                                  Pending Updates: 0
                                  tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       172297     17337/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       172296     17337/io.mqtt.0
                                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       169725     17222/node-red
                                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       166723     16960/iobroker.js-c
                                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       168411     16960/iobroker.js-c
                                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14285      518/sshd: /usr/sbin
                                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        8015       725/influxd
                                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       173176     17561/io.jarvis.0
                                  tcp6       0      0 :::3000                 :::*                    LISTEN      110        14541      721/grafana-server
                                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        14563      725/influxd
                                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       179245     17994/io.web.0
                                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       169232     16986/io.admin.0
                                  tcp6       0      0 :::35375                :::*                    LISTEN      1001       171596     17222/node-red
                                  tcp6       0      0 :::22                   :::*                    LISTEN      0          14287      518/sshd: /usr/sbin
                                  tcp6       0      0 :::46611                :::*                    LISTEN      1001       172299     17222/node-red
                                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       172360     17385/io.tuya.0
                                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       172361     17385/io.tuya.0
                                  udp        0      0 0.0.0.0:55339           0.0.0.0:*                           108        14205      398/avahi-daemon: r
                                  udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14311      720/dhcpcd
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       170865     17458/io.chromecast
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       171600     17222/node-red
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       171597     17222/node-red
                                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14203      398/avahi-daemon: r
                                  udp6       0      0 :::52141                :::*                                108        14206      398/avahi-daemon: r
                                  udp6       0      0 :::546                  :::*                                0          12062      720/dhcpcd
                                  udp6       0      0 :::5353                 :::*                                108        14204      398/avahi-daemon: r
                                  • P PhoenixCR
                                    Skript v.2022-12-13
                                    *** BASE SYSTEM ***
                                    Docker:         false
                                    Release:        11
                                    Codename:       bullseye
                                    VERSION_ID="11"
                                    ID=raspbian
                                    ID_LIKE=debian
                                    CPU threads: 4
                                    CET +0100
                                    Europe/Berlin
                                    chris
                                    /home/chris
                                    X-Server:       false
                                    Desktop:
                                    Terminal:       tty
                                    *** MEMORY ***
                                    Swap:            99M          0B         99M
                                             7897 M total memory
                                              552 M used memory
                                              296 M active memory
                                             6309 M free memory
                                              173 M buffer memory
                                              861 M swap cache
                                               99 M total swap
                                                0 M used swap
                                               99 M free swap
                                    *** FILESYSTEM ***
                                    /var:
                                    877M    /var/
                                    360M    /var/lib
                                    283M    /var/cache
                                    277M    /var/cache/apt
                                    /usr/bin/npm            8.19.3
                                    nodejs:
                                      Version table:
                                    ioBroker Status
                                    Objects type: jsonl
                                    States  type: jsonl
                                    admin:          6.3.5
                                    ioBroker-Instances
                                    Objects and States
                                    Objects:        6464
                                    States:         5015
                                    Pending Updates: 0
                                    PhoenixCR
                                    @phoenixcr
                                    Noch jemand Ideen?
                                    Im log steht nichts drin das der abstürz verursachen könnte.
                                    Und ich glaube das der komplette ioBroker stürzt ab.
                                    Auf dem Raspi läuft nur der ioBroker.
                                    • P PhoenixCR
                                      @phoenixcr
                                      Noch jemand Ideen?
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      was machen dann die repo's influx und grafana? und woher kommen die backups?
                                        PhoenixCR
                                        @crunchip sagte in Admin startet nicht mehr:
                                        Ja stimmt. IoBroker, Influx, Grafana und node red.
                                        Die Backup sind mit backitup gemacht worden
                                        • P PhoenixCR
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          und da gibts keine Probleme? oder ist da auch hin und wieder etwas nicht erreichbar?
