  4. Admin startet nicht mehr
    5.6k
111 Beiträge 9 Kommentatoren 19.0k Aufrufe 8 Beobachtet
  • P PhoenixCR
    @thomas-braun sagte in Admin startet nicht mehr:
    iobroker diag
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and end.
    It helps us to help you!
    Press any key to continue
    Skript v.2022-12-13
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     19:57:59 up  4:13,  1 user,  load average: 1.41, 1.63, 2.53
    CPU threads: 4
    *** Time and Time Zones ***
    Tue Dec 27 19:57:59 UTC 2022
    Tue Dec 27 19:57:59 GMT 2022
    GMT +0000
    Europe/London
    *** User and Groups ***
    chris
    /home/chris
    chris adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            7.9G        1.5G        4.4G        0.0K        2.0G        6.4G
    Swap:            99M        1.0M         98M
    Total:          8.0G        1.5G        4.5G
             7897 M total memory
             1490 M used memory
              701 M active memory
             2533 M inactive memory
             4388 M free memory
              151 M buffer memory
             1867 M swap cache
               99 M total swap
                1 M used swap
               98 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4      118G  5.0G  108G   5% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
    /dev/sda1      vfat      255M   50M  206M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    TARGET  SOURCE    FSTYPE OPTIONS
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    542M    /var/
    282M    /var/cache
    276M    /var/cache/apt
    212M    /var/cache/apt/archives
    98M     /var/lib
    /opt/iobroker/backups:
    240M    /opt/iobroker/backups/
    118M    /opt/iobroker/backups/Influxdb
    /opt/iobroker/iobroker-data:
    529M    /opt/iobroker/iobroker-data/
    428M    /opt/iobroker/iobroker-data/files
    79M     /opt/iobroker/iobroker-data/node-red/node_modules
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    17M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.3.5
    Adapters from github:   2
    + system.adapter.admin.0                  : admin                 : homeautomationcretu                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.mqtt.0                   : mqtt                  : homeautomationcretu                      -  enabled, port: 1885, bind: 0.0.0.0
    + system.adapter.sayit.0                  : sayit                 : homeautomationcretu                      -  enabled, port: 0
    + system.adapter.telegram.0               : telegram              : homeautomationcretu                      -  enabled, port: 8443, bind: 0.0.0.0
    + system.adapter.web.0                    : web                   : homeautomationcretu                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    ioBroker-Repositories
    Stable (default): http://download.iobroker.net/sources-dist.json
    Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
    ioBroker-Instances
    Adapter    "backitup"     : 2.5.9    , installed 2.5.9
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "device-reminder": 1.2.9  , installed 1.2.9
    Adapter    "devices"      : 1.1.2    , installed 1.1.2
    Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
    Adapter    "echarts"      : 1.0.12   , installed 1.0.12
    Adapter    "email"        : 1.1.4    , installed 1.1.4
    Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
    Adapter    "flot"         : 1.11.0   , installed 1.11.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "heatingcontrol": 2.9.3   , installed 2.9.3
    Adapter    "history"      : 2.2.4    , installed 2.2.4
    Adapter    "i2c"          : 1.2.1    , installed 1.2.1
    Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
    Adapter    "info"         : 1.9.19   , installed 1.9.19
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "modbus"       : 5.0.11   , installed 5.0.11
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.0    , installed 4.0.0
    Adapter    "paw"          : 0.3.2    , installed 0.3.2
    Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
    Adapter    "sayit"        : 1.12.3   , installed 1.12.3
    Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
    Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "tankerkoenig" : 3.1.0    , installed 3.1.0
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "text2command" : 2.3.0    , installed 2.3.0
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "tuya"         : 3.11.1   , installed 3.11.1
    Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
    Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
    Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
    Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
    Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
    Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
    Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Objects and States
    Objects:        6463
    States:         5008
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://repos.influxdata.com/debian bullseye InRelease
    Hit:4 https://apt.grafana.com stable InRelease
    Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       45447      10525/io.jarvis.0
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11762      541/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        140894     26161/influxd
    tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       44880      11581/io.mqtt.0
    tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       44881      11581/io.mqtt.0
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16053      1795/iobroker.js-co
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16046      1795/iobroker.js-co
    tcp6       0      0 :::22                   :::*                    LISTEN      0          11764      541/sshd: /usr/sbin
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16122      1823/io.admin.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30720      7826/io.web.0
    tcp6       0      0 :::8086                 :::*                    LISTEN      999        141933     26161/influxd
    tcp6       0      0 :::3000                 :::*                    LISTEN      110        77925      17659/grafana-serve
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33946      7993/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11593      403/avahi-daemon: r
    udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32188      7852/io.tuya.0
    udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32189      7852/io.tuya.0
    udp        0      0 0.0.0.0:43026           0.0.0.0:*                           108        11595      403/avahi-daemon: r
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14566      783/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        11594      403/avahi-daemon: r
    udp6       0      0 :::56192                :::*                                108        11596      403/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          14628      783/dhcpcd
    iob diag has finished.
    Press any key for a summary
    @phoenixcr
    Setz die Zeitzone richtig.
    Problem behoben?
    P 2 Antworten Letzte Antwort
    • P PhoenixCR
      @djmarc75 sagte in Admin startet nicht mehr:
      iobroker start admin
      Hallo an alle, bei mir stürzt nämlich auch der Admin ab und zu ab.
      Der Instanz ist nicht immer in die liste an. Wenn ich es Manuel starte, läuft es eine weile.
      Der iobroker diag Befehl, gibt bei mir nur die help liste aus, komisch.
      pi@HomeAutomation:~ $ iobroker list instances
        system.adapter.admin.0                  : admin                 : HomeAutomation                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.backitup.0               : backitup              : HomeAutomation                           -  enabled
      + system.adapter.chromecast.0             : chromecast            : HomeAutomation                           -  enabled
        system.adapter.daswetter.0              : daswetter             : HomeAutomation                           - disabled
      + system.adapter.device-reminder.0        : device-reminder       : HomeAutomation                           -  enabled
        system.adapter.devices.0                : devices               : HomeAutomation                           -  enabled
      + system.adapter.discovery.0              : discovery             : HomeAutomation                           -  enabled
      + system.adapter.ds18b20.0                : ds18b20               : HomeAutomation                           -  enabled
        system.adapter.echarts.0                : echarts               : HomeAutomation                           - disabled
      + system.adapter.email.0                  : email                 : HomeAutomation                           -  enabled
        system.adapter.feiertage.0              : feiertage             : HomeAutomation                           - disabled
        system.adapter.flot.0                   : flot                  : HomeAutomation                           -  enabled
        system.adapter.fully-tablet-control.0   : fully-tablet-control  : HomeAutomation                           - disabled
      + system.adapter.ham.0                    : ham                   : HomeAutomation                           -  enabled
        system.adapter.heatingcontrol.0         : heatingcontrol        : HomeAutomation                           - disabled
        system.adapter.history.0                : history               : HomeAutomation                           -  enabled
        system.adapter.i2c.0                    : i2c                   : HomeAutomation                           - disabled
        system.adapter.ical.0                   : ical                  : HomeAutomation                           -  enabled
        system.adapter.icons-icons8.0           : icons-icons8          : HomeAutomation                           -  enabled
        system.adapter.icons-material-png.0     : icons-material-png    : HomeAutomation                           -  enabled
        system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeAutomation                           -  enabled
        system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : HomeAutomation                           -  enabled
        system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: HomeAutomation                           -  enabled
      + system.adapter.influxdb.0               : influxdb              : HomeAutomation                           -  enabled, port: 8086
      + system.adapter.info.0                   : info                  : HomeAutomation                           -  enabled
      + system.adapter.iot.0                    : iot                   : HomeAutomation                           -  enabled
      + system.adapter.jarvis.0                 : jarvis                : HomeAutomation                           -  enabled
      + system.adapter.javascript.0             : javascript            : HomeAutomation                           -  enabled
        system.adapter.lgtv.0                   : lgtv                  : HomeAutomation                           - disabled
      + system.adapter.modbus.0                 : modbus                : HomeAutomation                           -  enabled
        system.adapter.modbus.1                 : modbus                : HomeAutomation                           - disabled
      + system.adapter.modbus.2                 : modbus                : HomeAutomation                           -  enabled
      + system.adapter.mqtt.0                   : mqtt                  : HomeAutomation                           -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.net-tools.0              : net-tools             : HomeAutomation                           -  enabled
      + system.adapter.node-red.0               : node-red              : HomeAutomation                           -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.paw.0                    : paw                   : HomeAutomation                           - disabled, port: 2323
        system.adapter.ping.0                   : ping                  : HomeAutomation                           - disabled
        system.adapter.pushsafer.0              : pushsafer             : HomeAutomation                           - disabled
      + system.adapter.rpi2.0                   : rpi2                  : HomeAutomation                           -  enabled
        system.adapter.samsung.0                : samsung               : HomeAutomation                           - disabled
        system.adapter.samsung_tizen.0          : samsung_tizen         : HomeAutomation                           - disabled, port: 8002
      + system.adapter.sayit.0                  : sayit                 : HomeAutomation                           -  enabled, port: 0
        system.adapter.schoolfree.0             : schoolfree            : HomeAutomation                           -  enabled
        system.adapter.shuttercontrol.0         : shuttercontrol        : HomeAutomation                           - disabled
      + system.adapter.sonoff.0                 : sonoff                : HomeAutomation                           -  enabled, port: 1883, bind: 0.0.0.0
        system.adapter.speedport.0              : speedport             : HomeAutomation                           - disabled
      + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeAutomation                           -  enabled
      + system.adapter.telegram.0               : telegram              : HomeAutomation                           -  enabled, port: 8443, bind: 0.0.0.0
      + system.adapter.text2command.0           : text2command          : HomeAutomation                           -  enabled
        system.adapter.trashschedule.0          : trashschedule         : HomeAutomation                           - disabled
      + system.adapter.tuya.0                   : tuya                  : HomeAutomation                           -  enabled
      + system.adapter.virtualpowermeter.0      : virtualpowermeter     : HomeAutomation                           -  enabled
        system.adapter.vis-bars.0               : vis-bars              : HomeAutomation                           -  enabled
        system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : HomeAutomation                           -  enabled
        system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeAutomation                           -  enabled
        system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : HomeAutomation                           -  enabled
        system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeAutomation                           -  enabled
        system.adapter.vis-history.0            : vis-history           : HomeAutomation                           -  enabled
        system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeAutomation                           -  enabled
        system.adapter.vis-icontwo.0            : vis-icontwo           : HomeAutomation                           -  enabled
      + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeAutomation                           -  enabled
        system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeAutomation                           -  enabled
        system.adapter.vis-justgage.0           : vis-justgage          : HomeAutomation                           -  enabled
        system.adapter.vis-keyboard.0           : vis-keyboard          : HomeAutomation                           -  enabled
        system.adapter.vis-lcars.0              : vis-lcars             : HomeAutomation                           -  enabled
        system.adapter.vis-map.0                : vis-map               : HomeAutomation                           -  enabled
        system.adapter.vis-material-advanced.0  : vis-material-advanced : HomeAutomation                           -  enabled
        system.adapter.vis-metro.0              : vis-metro             : HomeAutomation                           -  enabled
        system.adapter.vis-players.0            : vis-players           : HomeAutomation                           -  enabled
        system.adapter.vis-plumb.0              : vis-plumb             : HomeAutomation                           -  enabled
        system.adapter.vis-rgraph.0             : vis-rgraph            : HomeAutomation                           -  enabled
        system.adapter.vis.0                    : vis                   : HomeAutomation                           -  enabled
      + system.adapter.web.0                    : web                   : HomeAutomation                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
        system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeAutomation                           - disabled
        system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : HomeAutomation                           - disabled
        system.adapter.wifilight.0              : wifilight             : HomeAutomation                           - disabled
      + system.adapter.yahka.0                  : yahka                 : HomeAutomation                           -  enabled
        system.adapter.yahka.1                  : yahka                 : HomeAutomation                           - disabled
      + instance is alive
      pi@HomeAutomation:~ $ iobroker diag
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
        iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
        iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      ich habe keine ideen mehr was es sein könnte.
      danke schn mal im voraus für eure Hilfe.
      @phoenixcr sagte in Admin startet nicht mehr:
      ist das alles an Informationen?
      P 1 Antwort Letzte Antwort
        @phoenixcr
        Problem behoben?
        PhoenixCR
        Zurzeit ja.
        Vielen Dank.
          PhoenixCR
          Siehe oben.
          Aber im Moment läuft es.
            @phoenixcr
            Problem behoben?
            PhoenixCR
            geht wieder nicht
            und der diag bleibt hängen beim repositories
            /var:
            864M    /var/
            358M    /var/lib
            282M    /var/cache
            276M    /var/cache/apt
            263M    /var/lib/influxdb
            588M    /opt/iobroker/backups/
            345M    /opt/iobroker/backups/influxdbold
            302M    /opt/iobroker/backups/influxdbold/data
            261M    /opt/iobroker/backups/influxdbold/data/iobroker
            229M    /opt/iobroker/backups/influxdbold/data/iobroker/autogen
            554M    /opt/iobroker/iobroker-data/
            84M     /opt/iobroker/iobroker-data/node-red/node_modules
            22M     /opt/iobroker/iobroker-data/objects.jsonl
            /usr/bin/npm            8.19.3
            nodejs:
              Version table:
            ioBroker Status
            No connection to databases possible ...
            admin:          6.3.5
            • P PhoenixCR
              geht wieder nicht
              /var:
              864M    /var/
              358M    /var/lib
              282M    /var/cache
              276M    /var/cache/apt
              /usr/bin/npm            8.19.3
              nodejs:
                Version table:
              ioBroker Status
              admin:          6.3.5
              Das dürfte lediglich länger dauern, wenn der iobroker nicht läuft.
                PhoenixCR
                Es ist gelaufen, habe nach 10 Minuten abgebrochen, dann ein fix durchgeführt.
                Skript v.2022-12-13
                *** BASE SYSTEM ***
                Docker:         false
                Release:        11
                Codename:       bullseye
                VERSION_ID="11"
                ID=raspbian
                ID_LIKE=debian
                 12:56:56 up  2:16,  1 user,  load average: 1.96, 3.35, 3.43
                CPU threads: 4
                Wed Dec 28 11:56:56 UTC 2022
                Wed Dec 28 12:56:56 CET 2022
                CET +0100
                Europe/Berlin
                chris
                /home/chris
                X-Server:       false
                Desktop:
                Terminal:       tty
                *** MEMORY ***
                Mem:            7.9G        552M        6.3G        1.0M        1.0G        7.1G
                Swap:            99M          0B         99M
                Total:          8.0G        552M        6.4G
                         7897 M total memory
                          552 M used memory
                          296 M active memory
                         1107 M inactive memory
                         6309 M free memory
                          173 M buffer memory
                          861 M swap cache
                           99 M total swap
                            0 M used swap
                           99 M free swap
                *** FILESYSTEM ***
                /dev/root      ext4      118G  5.7G  107G   6% /
                /var:
                877M    /var/
                360M    /var/lib
                283M    /var/cache
                277M    /var/cache/apt
                265M    /var/lib/influxdb
                538M    /opt/iobroker/iobroker-data/
                8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
                /usr/bin/npm            8.19.3
                nodejs:
                  Version table:
                ioBroker Status
                Objects type: jsonl
                States  type: jsonl
                admin:          6.3.5
                + system.adapter.influxdb.0               : influxdb              : homeautomationcretu                      -  enabled, port: 8086
                + system.adapter.node-red.0               : node-red              : homeautomationcretu                      -  enabled, port: 1880, bind: 0.0.0.0
                ioBroker-Instances
                Objects and States
                Objects:        6464
                States:         5015
                Pending Updates: 0
                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       172297     17337/io.mqtt.0
                tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       172296     17337/io.mqtt.0
                tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       169725     17222/node-red
                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       166723     16960/iobroker.js-c
                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       168411     16960/iobroker.js-c
                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14285      518/sshd: /usr/sbin
                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        8015       725/influxd
                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       173176     17561/io.jarvis.0
                tcp6       0      0 :::3000                 :::*                    LISTEN      110        14541      721/grafana-server
                tcp6       0      0 :::8086                 :::*                    LISTEN      999        14563      725/influxd
                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       179245     17994/io.web.0
                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       169232     16986/io.admin.0
                tcp6       0      0 :::35375                :::*                    LISTEN      1001       171596     17222/node-red
                tcp6       0      0 :::22                   :::*                    LISTEN      0          14287      518/sshd: /usr/sbin
                tcp6       0      0 :::46611                :::*                    LISTEN      1001       172299     17222/node-red
                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       172360     17385/io.tuya.0
                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       172361     17385/io.tuya.0
                udp        0      0 0.0.0.0:55339           0.0.0.0:*                           108        14205      398/avahi-daemon: r
                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14311      720/dhcpcd
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       170865     17458/io.chromecast
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       171600     17222/node-red
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       171597     17222/node-red
                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14203      398/avahi-daemon: r
                udp6       0      0 :::52141                :::*                                108        14206      398/avahi-daemon: r
                udp6       0      0 :::546                  :::*                                0          12062      720/dhcpcd
                udp6       0      0 :::5353                 :::*                                108        14204      398/avahi-daemon: r
                • P PhoenixCR
                  Skript v.2022-12-13
                  *** BASE SYSTEM ***
                  Docker:         false
                  Release:        11
                  Codename:       bullseye
                  VERSION_ID="11"
                  ID=raspbian
                  ID_LIKE=debian
                  CPU threads: 4
                  CET +0100
                  Europe/Berlin
                  chris
                  /home/chris
                  X-Server:       false
                  Desktop:
                  Terminal:       tty
                  *** MEMORY ***
                  Swap:            99M          0B         99M
                           7897 M total memory
                            552 M used memory
                            296 M active memory
                           6309 M free memory
                            173 M buffer memory
                            861 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  *** FILESYSTEM ***
                  /var:
                  877M    /var/
                  360M    /var/lib
                  283M    /var/cache
                  277M    /var/cache/apt
                  /usr/bin/npm            8.19.3
                  nodejs:
                    Version table:
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin:          6.3.5
                  ioBroker-Instances
                  Objects and States
                  Objects:        6464
                  States:         5015
                  Pending Updates: 0
                  PhoenixCR
                  schrieb am zuletzt editiert von PhoenixCR
                  @phoenixcr
                  Noch jemand Ideen?
                  Im log steht nichts drin das der abstürz verursachen könnte.
                  Und ich glaube das der komplette ioBroker stürzt ab.
                  Auf dem Raspi läuft nur der ioBroker.
                  • P PhoenixCR
                    @phoenixcr
                    Noch jemand Ideen?
                    crunchipC Abwesend
                    crunchipC Abwesend
                    was machen dann die repo's influx und grafana? und woher kommen die backups?
                      PhoenixCR
                      @crunchip sagte in Admin startet nicht mehr:
                      Ja stimmt. IoBroker, Influx, Grafana und node red.
                      Die Backup sind mit backitup gemacht worden
                      • P PhoenixCR
                        crunchipC Abwesend
                        crunchipC Abwesend
                        und da gibts keine Probleme? oder ist da auch hin und wieder etwas nicht erreichbar?
                          PhoenixCR
                          Die sind aber in den ioBroker integriert. Wenn der ioBroker nicht geht, gehen die auch nicht.
                          Im Moment geht gar nix mehr
                          P crunchipC 2 Antworten Letzte Antwort
                          • P PhoenixCR
                            PhoenixCR
                            sorry, falsch geäußert, node red und grafana geht
                            • P PhoenixCR
                              PhoenixCR
                              @phoenixcr
                              der list instances gibt folgendes zurück
                              chris@homeautomationcretu:~ $ iobroker list instances
                              • P PhoenixCR
                                crunchipC Abwesend
                                crunchipC Abwesend
                                neee, das ist alles eigenständig, du hast im iobroker nur die Adapter/Instanzen dazu und influx, sowie grafana laufen auch ohne iobroker
                                  PhoenixCR
                                  Hab es bemerkt
                                  der iob.js verbraucht aber ziemlich viel. Oder?
                                  16960 iobroker  20   0  399516 285548  31328 R  97.4   3.5 286:14.72 iobroker.js-con
                                  • P Offline
                                    PhoenixCR
                                    Guten Morgen.
                                    Also keine Verbesserung.
                                    Nach stopp fix Start läuft er wieder.
                                    any clues? Niemand?
                                    jetzt habe ich noch sehr häufig in log:
                                    slow connection to states DB. Still waiting ...
                                    und der iobroker Status sagt:
                                     iobroker status
                                     Cannot determine Set feature status: Connection is closed.
                                     Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
                                     Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                                     Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                                    • P PhoenixCR
                                      @phoenixcr
                                      Noch jemand Ideen?
                                      crunchipC Abwesend
                                      crunchipC Abwesend
                                      und was kommen generell für Meldungen?
                                      irgendwelche Warnung oder Error
                                        PhoenixCR
                                        des kam nachts um 0 uhr
                                        FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                                        2022-12-29 00:04:01.504  - warn: ds18b20.0 (7222) Error reading sensor 28-3c01d0758d62: Error: Read error
                                        2022-12-29 00:22:10.928  - warn: modbus.0 (6971) Error: undefined
                                        2022-12-29 06:59:00.474  - error: host.homeautomationcretu instance system.adapter.mqtt.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                                        2022-12-29 06:57:04.781  - error: host.homeautomationcretu Cannot find view "system" for search "instance" : Connection is closed. -kommt öfter
                                        2022-12-29 06:57:04.780  - warn: host.homeautomationcretu get state error: Connection is closed.
                                        2022-12-29 06:57:00.737  - warn: rpi2.0 (1265) get state error: DB closed
                                        über 7500 in den aktuellen log
                                        • P PhoenixCR
                                          crunchipC Abwesend
                                          crunchipC Abwesend
                                          @phoenixcr dann kümmere dich doch erstmal darum, das deine Geräte/Sensoren/Adapter sauber funktionieren
