  4. Admin startet nicht mehr
    5.6k
111 Beiträge 9 Kommentatoren 19.0k Aufrufe 8 Beobachtet
  • P PhoenixCR
    geht wieder nicht
    und der diag bleibt hängen beim repositories
    /       /dev/sda2 ext4   rw,noatime
    `-/boot /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    864M    /var/
    358M    /var/lib
    282M    /var/cache
    276M    /var/cache/apt
    263M    /var/lib/influxdb
    /opt/iobroker/backups:
    588M    /opt/iobroker/backups/
    345M    /opt/iobroker/backups/influxdbold
    302M    /opt/iobroker/backups/influxdbold/data
    261M    /opt/iobroker/backups/influxdbold/data/iobroker
    229M    /opt/iobroker/backups/influxdbold/data/iobroker/autogen
    /opt/iobroker/iobroker-data:
    554M    /opt/iobroker/iobroker-data/
    428M    /opt/iobroker/iobroker-data/files
    84M     /opt/iobroker/iobroker-data/node-red/node_modules
    78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
    33M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
    22M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    9.7M    /opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
    9.1M    /opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
    *** ioBroker-Installation ***
    ioBroker Status
    No connection to databases possible ...
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.3.5
    Adapters from github:   2
    ioBroker-Repositories
    @phoenixcr sagte in Admin startet nicht mehr:
    Das dürfte lediglich länger dauern, wenn der iobroker nicht läuft.
    P 1 Antwort Letzte Antwort
      PhoenixCR
      @thomas-braun sagte in Admin startet nicht mehr:
      Es ist gelaufen, habe nach 10 Minuten abgebrochen, dann ein fix durchgeführt.
      *** ioBroker Diagnosis ***
      Please stretch the window of your terminal programm (puTTY) as wide as possible or switch to full screen
      The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
      https://forum.iobroker.net
      Just copy and paste the Summary Page, including the ``` characters at start and end.
      It helps us to help you!
      Press any key to continue
      Skript v.2022-12-13
      *** BASE SYSTEM ***
      Model           : Raspberry Pi 4 Model B Rev 1.4
      Architecture:   armv7l
      Docker:         false
      Virtualization: none
      Distributor ID: Raspbian
      Description:    Raspbian GNU/Linux 11 (bullseye)
      Release:        11
      Codename:       bullseye
      PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
      NAME="Raspbian GNU/Linux"
      VERSION_ID="11"
      VERSION="11 (bullseye)"
      VERSION_CODENAME=bullseye
      ID=raspbian
      ID_LIKE=debian
      HOME_URL="http://www.raspbian.org/"
      SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
      BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
      Systemuptime and Load:
       12:56:56 up  2:16,  1 user,  load average: 1.96, 3.35, 3.43
      CPU threads: 4
      *** Time and Time Zones ***
      Wed Dec 28 11:56:56 UTC 2022
      Wed Dec 28 12:56:56 CET 2022
      CET +0100
      Europe/Berlin
      *** User and Groups ***
      chris
      /home/chris
      chris adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
      *** X-Server-Setup ***
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Mem:            7.9G        552M        6.3G        1.0M        1.0G        7.1G
      Swap:            99M          0B         99M
      Total:          8.0G        552M        6.4G
               7897 M total memory
                552 M used memory
                296 M active memory
               1107 M inactive memory
               6309 M free memory
                173 M buffer memory
                861 M swap cache
                 99 M total swap
                  0 M used swap
                 99 M free swap
      *** FILESYSTEM ***
      /dev/root      ext4      118G  5.7G  107G   6% /
      devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
      tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
      tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
      /dev/sda1      vfat      255M   50M  206M  20% /boot
      tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
      TARGET  SOURCE    FSTYPE OPTIONS
      /var:
      877M    /var/
      360M    /var/lib
      283M    /var/cache
      277M    /var/cache/apt
      265M    /var/lib/influxdb
      538M    /opt/iobroker/iobroker-data/
      8.9M    /opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
      /usr/bin/npm            8.19.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      + system.adapter.admin.0                  : admin                 : homeautomationcretu                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
      + system.adapter.influxdb.0               : influxdb              : homeautomationcretu                      -  enabled, port: 8086
      + system.adapter.mqtt.0                   : mqtt                  : homeautomationcretu                      -  enabled, port: 1885, bind: 0.0.0.0
      + system.adapter.node-red.0               : node-red              : homeautomationcretu                      -  enabled, port: 1880, bind: 0.0.0.0
        system.adapter.sayit.0                  : sayit                 : homeautomationcretu                      -  enabled, port: 0
      + system.adapter.telegram.0               : telegram              : homeautomationcretu                      -  enabled, port: 8443, bind: 0.0.0.0
        system.adapter.web.0                    : web                   : homeautomationcretu                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
      Stable (default): http://download.iobroker.net/sources-dist.json
      Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
      ioBroker-Instances
      Adapter    "backitup"     : 2.5.9    , installed 2.5.9
      Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
      Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
      Adapter    "device-reminder": 1.2.9  , installed 1.2.9
      Adapter    "devices"      : 1.1.2    , installed 1.1.2
      Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
      Adapter    "echarts"      : 1.0.12   , installed 1.0.12
      Adapter    "email"        : 1.1.4    , installed 1.1.4
      Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
      Adapter    "flot"         : 1.11.0   , installed 1.11.0
      Adapter    "ham"          : 5.3.1    , installed 5.3.1
      Adapter    "heatingcontrol": 2.9.3   , installed 2.9.3
      Adapter    "history"      : 2.2.4    , installed 2.2.4
      Adapter    "i2c"          : 1.2.1    , installed 1.2.1
      Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
      Adapter    "info"         : 1.9.19   , installed 1.9.19
      Adapter    "iot"          : 1.11.9   , installed 1.11.9
      Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
      Adapter    "javascript"   : 6.1.4    , installed 6.1.4
      Controller "js-controller": 4.0.23   , installed 4.0.23
      Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
      Adapter    "modbus"       : 5.0.11   , installed 5.0.11
      Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
      Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
      Adapter    "node-red"     : 4.0.0    , installed 4.0.0
      Adapter    "paw"          : 0.3.2    , installed 0.3.2
      Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
      Adapter    "sayit"        : 1.12.3   , installed 1.12.3
      Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
      Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
      Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
      Adapter    "tankerkoenig" : 3.1.0    , installed 3.1.0
      Adapter    "telegram"     : 1.15.2   , installed 1.15.2
      Adapter    "text2command" : 2.3.0    , installed 2.3.0
      Adapter    "trashschedule": 2.0.3    , installed 2.0.3
      Adapter    "tuya"         : 3.11.1   , installed 3.11.1
      Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
      Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
      Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
      Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
      Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
      Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
      Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
      Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
      Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
      Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
      Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
      Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
      Adapter    "yahka"        : 0.13.1   , installed 0.13.1
      Objects and States
      Objects:        6464
      States:         5015
      Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:3 https://repos.influxdata.com/debian bullseye InRelease
      Hit:4 https://apt.grafana.com stable InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Reading package lists...
      Pending Updates: 0
      *** Listening Ports ***
      tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       172297     17337/io.mqtt.0
      tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       172296     17337/io.mqtt.0
      tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       169725     17222/node-red
      tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       166723     16960/iobroker.js-c
      tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       168411     16960/iobroker.js-c
      tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14285      518/sshd: /usr/sbin
      tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        8015       725/influxd
      tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       173176     17561/io.jarvis.0
      tcp6       0      0 :::3000                 :::*                    LISTEN      110        14541      721/grafana-server
      tcp6       0      0 :::8086                 :::*                    LISTEN      999        14563      725/influxd
      tcp6       0      0 :::8082                 :::*                    LISTEN      1001       179245     17994/io.web.0
      tcp6       0      0 :::8081                 :::*                    LISTEN      1001       169232     16986/io.admin.0
      tcp6       0      0 :::35375                :::*                    LISTEN      1001       171596     17222/node-red
      tcp6       0      0 :::22                   :::*                    LISTEN      0          14287      518/sshd: /usr/sbin
      tcp6       0      0 :::46611                :::*                    LISTEN      1001       172299     17222/node-red
      udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       172360     17385/io.tuya.0
      udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       172361     17385/io.tuya.0
      udp        0      0 0.0.0.0:55339           0.0.0.0:*                           108        14205      398/avahi-daemon: r
      udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14311      720/dhcpcd
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       170865     17458/io.chromecast
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       171600     17222/node-red
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       171597     17222/node-red
      udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        14203      398/avahi-daemon: r
      udp6       0      0 :::52141                :::*                                108        14206      398/avahi-daemon: r
      udp6       0      0 :::546                  :::*                                0          12062      720/dhcpcd
      udp6       0      0 :::5353                 :::*                                108        14204      398/avahi-daemon: r
      iob diag has finished.
      Press any key for a summary
      • P PhoenixCR
        Skript v.2022-12-13
        *** BASE SYSTEM ***
        Docker:         false
        Release:        11
        Codename:       bullseye
        VERSION_ID="11"
        ID=raspbian
        ID_LIKE=debian
        CPU threads: 4
        CET +0100
        Europe/Berlin
        chris
        /home/chris
        X-Server:       false
        Desktop:
        Terminal:       tty
        *** MEMORY ***
        Swap:            99M          0B         99M
                 7897 M total memory
                  552 M used memory
                  296 M active memory
                 6309 M free memory
                  173 M buffer memory
                  861 M swap cache
                   99 M total swap
                    0 M used swap
                   99 M free swap
        *** FILESYSTEM ***
        /var:
        877M    /var/
        360M    /var/lib
        283M    /var/cache
        277M    /var/cache/apt
        /usr/bin/npm            8.19.3
        nodejs:
          Version table:
        ioBroker Status
        Objects type: jsonl
        States  type: jsonl
        admin:          6.3.5
        ioBroker-Instances
        Objects and States
        Objects:        6464
        States:         5015
        Pending Updates: 0
        PhoenixCR
        schrieb am zuletzt editiert von PhoenixCR
        @phoenixcr
        Noch jemand Ideen?
        Im log steht nichts drin das der abstürz verursachen könnte.
        Und ich glaube das der komplette ioBroker stürzt ab.
        Auf dem Raspi läuft nur der ioBroker.
        • P PhoenixCR
          @phoenixcr
          Noch jemand Ideen?
          crunchipC Abwesend
          crunchipC Abwesend
          was machen dann die repo's influx und grafana? und woher kommen die backups?
            PhoenixCR
            @crunchip sagte in Admin startet nicht mehr:
            Ja stimmt. IoBroker, Influx, Grafana und node red.
            Die Backup sind mit backitup gemacht worden
            • P PhoenixCR
              crunchipC Abwesend
              crunchipC Abwesend
              und da gibts keine Probleme? oder ist da auch hin und wieder etwas nicht erreichbar?
                PhoenixCR
                Die sind aber in den ioBroker integriert. Wenn der ioBroker nicht geht, gehen die auch nicht.
                Im Moment geht gar nix mehr
                P crunchipC 2 Antworten Letzte Antwort
                • P PhoenixCR
                  PhoenixCR
                  sorry, falsch geäußert, node red und grafana geht
                  • P PhoenixCR
                    PhoenixCR
                    @phoenixcr
                    der list instances gibt folgendes zurück
                    chris@homeautomationcretu:~ $ iobroker list instances
                    • P PhoenixCR
                      crunchipC Abwesend
                      crunchipC Abwesend
                      neee, das ist alles eigenständig, du hast im iobroker nur die Adapter/Instanzen dazu und influx, sowie grafana laufen auch ohne iobroker
                        PhoenixCR
                        Hab es bemerkt
                        der iob.js verbraucht aber ziemlich viel. Oder?
                        16960 iobroker  20   0  399516 285548  31328 R  97.4   3.5 286:14.72 iobroker.js-con
                        • P Offline
                          PhoenixCR
                          Guten Morgen.
                          Also keine Verbesserung.
                          Nach stopp fix Start läuft er wieder.
                          any clues? Niemand?
                          jetzt habe ich noch sehr häufig in log:
                          slow connection to states DB. Still waiting ...
                          und der iobroker Status sagt:
                           iobroker status
                           Cannot determine Set feature status: Connection is closed.
                           Unable to subscribe to expiry Keyspace events from Redis Server: Connection is closed.
                           Unable to subscribe to evicted Keyspace events from Redis Server: Connection is closed.
                           Unable to subscribe to meta namespace "meta." changes: Connection is closed.
                          • P PhoenixCR
                            @phoenixcr
                            Noch jemand Ideen?
                            crunchipC Abwesend
                            crunchipC Abwesend
                            und was kommen generell für Meldungen?
                            irgendwelche Warnung oder Error
                              PhoenixCR
                              des kam nachts um 0 uhr
                              FATAL ERROR: Ineffective mark-compacts near heap limit Allocation failed - JavaScript heap out of memory
                              2022-12-29 00:04:01.504  - warn: ds18b20.0 (7222) Error reading sensor 28-3c01d0758d62: Error: Read error
                              2022-12-29 00:22:10.928  - warn: modbus.0 (6971) Error: undefined
                              2022-12-29 06:59:00.474  - error: host.homeautomationcretu instance system.adapter.mqtt.0 terminated with code 3 (NO_ADAPTER_CONFIG_FOUND)
                              2022-12-29 06:57:04.781  - error: host.homeautomationcretu Cannot find view "system" for search "instance" : Connection is closed. -kommt öfter
                              2022-12-29 06:57:04.780  - warn: host.homeautomationcretu get state error: Connection is closed.
                              2022-12-29 06:57:00.737  - warn: rpi2.0 (1265) get state error: DB closed
                              über 7500 in den aktuellen log
                              • P PhoenixCR
                                crunchipC Abwesend
                                crunchipC Abwesend
                                @phoenixcr dann kümmere dich doch erstmal darum, das deine Geräte/Sensoren/Adapter sauber funktionieren
                                  PhoenixCR
                                  Wie meinst du das?
                                  Der ds18b20 Fehler ist sporadisch.
                                  Ist das die Ursache?
                                  Es ist aber über 1 Jahr ohne Problemen so gelaufen.
                                  Sagt dir der Meldung etwas?
                                  Uncaught Rejection: Error: States DB is not allowed to start in the current Multihost environment
                                      at Redis.<anonymous> (/opt/iobroker/node_modules/@iobroker/db-states-redis/lib/states/statesInRedisClient.js:579:23)
                                      at processTicksAndRejections (node:internal/process/task_queues:96:5)
                                  • P PhoenixCR
                                    Wie meinst du das?
                                    crunchipC Abwesend
                                    crunchipC Abwesend
                                    #66
                                    @phoenixcr hab das hier nicht genau verfolgt, jedoch lese ich gerade Multihost?
                                      PhoenixCR
                                      #67
                                      Das verstehe ich auch nicht.
                                      Was bedeutet das?
                                      • P PhoenixCR
                                        crunchipC Abwesend
                                        crunchipC Abwesend
                                        #68
                                        https://stackoverflow.com/questions/53230823/fatal-error-ineffective-mark-compacts-near-heap-limit-allocation-failed-javas
                                        bzw
                                        https://sebhastian.com/javascript-heap-out-of-memory/
                                        Was bedeutet das?
                                        hast du ein Multihost system?
                                          bzw
                                          Was bedeutet das?
                                          PhoenixCR
                                          #69
                                          @crunchip
                                          Nein. 1 einziges raspi mit IoBroker usw.
