  4. Admin startet nicht mehr
    5.6k
111 Beiträge 9 Kommentatoren 19.0k Aufrufe 8 Beobachtet
    @iced112
    Dann zeig jetzt nochmal die Ausgabe von
    iobroker diag
    I Offline
    I Offline
    IceD112
    schrieb am zuletzt editiert von IceD112
    *** ioBroker Diagnosis ***
    Please stretch the window of your terminal programm (puTTY) as wide as possible        or switch to full screen
    The following checks may give hints to potential malconfigurations or errors, pl        ease post them in our forum:
    https://forum.iobroker.net
    Just copy and paste the Summary Page, including the ``` characters at start and        end.
    It helps us to help you!
    Press any key to continue
    Skript v.2022-12-13
    *** BASE SYSTEM ***
    Model           : Raspberry Pi 4 Model B Rev 1.4
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 11 (bullseye)
    Release:        11
    Codename:       bullseye
    PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="11"
    VERSION="11 (bullseye)"
    VERSION_CODENAME=bullseye
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     22:15:29 up  1:38,  2 users,  load average: 0.93, 0.51, 0.50
    CPU threads: 4
    *** Time and Time Zones ***
    Sun Dec 25 21:15:29 UTC 2022
    Sun Dec 25 22:15:29 CET 2022
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:            1.9G        1.5G        179M        0.0K        212M        418M
    Swap:            99M         99M        0.0K
    Total:          2.0G        1.6G        180M
             1872 M total memory
             1480 M used memory
              190 M active memory
             1391 M inactive memory
              179 M free memory
               35 M buffer memory
              176 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    *** FILESYSTEM ***
    Filesystem                                Type      Size  Used Avail Use% Mounted on
    /dev/root                                 ext4       29G  6.2G   22G  23% /
    devtmpfs                                  devtmpfs  776M     0  776M   0% /dev
    tmpfs                                     tmpfs     937M     0  937M   0% /dev/shm
    tmpfs                                     tmpfs     375M  812K  374M   1% /run
    tmpfs                                     tmpfs     5.0M  4.0K  5.0M   1% /run/lock
    /dev/mmcblk0p1                            vfat      253M   50M  203M  20% /boot
    tmpfs                                     tmpfs     188M     0  188M   0% /run/user/1000
    //192.168.178.1/IceDBox/IOBROKER/ioBroker cifs      4.1G  176M  4.0G   5% /opt/iobroker/backups
    TARGET                  SOURCE                                    FSTYPE OPTIONS
    /                       /dev/mmcblk0p2                            ext4   rw,noatime
    |-/boot                 /dev/mmcblk0p1                            vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
    `-/opt/iobroker/backups //192.168.178.1/IceDBox/IOBROKER/ioBroker cifs   rw,relatime,vers=3.1.1,cache=strict,username=ioB_Backup,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
    /var:
    2.6G    /var/
    2.2G    /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968
    2.2G    /var/log
    138M    /var/cache
    /opt/iobroker/backups:
    148M    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    751M    /opt/iobroker/iobroker-data/
    344M    /opt/iobroker/iobroker-data/files
    249M    /opt/iobroker/iobroker-data/backup-objects
    74M     /opt/iobroker/iobroker-data/files/vis.0
    72M     /opt/iobroker/iobroker-data/files/telegram.admin
    139M    /opt/iobroker/iobroker-data/states.jsonl
    20M     /opt/iobroker/iobroker-data/objects.jsonl
    15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
    8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
    8.0M    /opt/iobroker/iobroker-data/backup-objects/2022-12-24_18-41_states.jsonl.gz
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.19.0
    /usr/bin/node           v16.19.0
    /usr/bin/npm            8.19.3
    nodejs:
      Installed: 16.19.0-deb-1nodesource1
      Candidate: 16.19.0-deb-1nodesource1
      Version table:
     *** 16.19.0-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
         12.22.12~dfsg-1~deb11u1 500
    *** ioBroker-Installation ***
    ioBroker Status
    Objects type: jsonl
    States  type: jsonl
    Core adapters versions
    js-controller:  4.0.23
    admin:          6.3.5
    Adapters from github:   0
    + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
    + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
    + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
    + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
    + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
    ioBroker-Repositories
    Active repo(s): stable
    ioBroker-Instances
    Used repository: stable
    Adapter    "accuweather"  : 1.2.1    , installed 1.2.4
    Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
    Adapter    "backitup"     : 2.5.9    , installed 2.5.9
    Adapter    "bring"        : 1.8.1    , installed 1.8.1
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
    Adapter    "denon"        : 1.13.4   , installed 1.13.4
    Adapter    "dwd"          : 2.8.3    , installed 2.8.3
    Adapter    "fb-checkpresence": 1.1.20, installed 1.1.20
    Adapter    "followthesun" : 0.4.0    , installed 0.4.0
    Adapter    "ham"          : 5.3.1    , installed 5.3.1
    Adapter    "harmony"      : 1.2.2    , installed 1.2.2
    Adapter    "heos"         : 1.10.0   , installed 1.10.0
    Adapter    "hue"          : 3.7.1    , installed 3.7.1
    Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
    Adapter    "javascript"   : 6.1.4    , installed 6.1.4
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
    Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
    Adapter    "meross"       : 1.14.0   , installed 1.14.0
    Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "socketio"     : 4.2.0    , installed 6.1.8
    Adapter    "spotify-premium": 1.2.1  , installed 1.2.2
    Adapter    "telegram"     : 1.15.2   , installed 1.15.2
    Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
    Adapter    "trashschedule": 2.0.3    , installed 2.0.3
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
    Adapter    "web"          : 4.3.0    , installed 5.2.4
    Adapter    "ws"           : 1.3.0    , installed 2.1.3
    Adapter    "yr"           : 5.3.0    , installed 5.3.0
    Objects and States
    Objects:        26616
    States:         22293
    Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
    Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
    Reading package lists...
    Pending Updates: 0
    *** Listening Ports ***
    tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14362      502/sshd: /usr/sbin
    tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14530      469/iobroker.js-con
    tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14405      469/iobroker.js-con
    tcp6       0      0 :::22                   :::*                    LISTEN      0          14364      502/sshd: /usr/sbin
    tcp6       0      0 :::61991                :::*                    LISTEN      1001       17777      1609/io.harmony.0
    tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19693      1786/io.web.0
    tcp6       0      0 :::8081                 :::*                    LISTEN      1001       80147      6245/io.admin.0
    udp        0      0 0.0.0.0:49103           0.0.0.0:*                           1001       19311      1624/io.heos.0
    udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       17778      1609/io.harmony.0
    udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15257      1121/io.shelly.0
    udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12953      755/dhcpcd
    udp        0      0 0.0.0.0:53431           0.0.0.0:*                           108        10238      344/avahi-daemon: r
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       19009      1461/io.chromecast.
    udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10236      344/avahi-daemon: r
    udp6       0      0 :::546                  :::*                                0          12964      755/dhcpcd
    udp6       0      0 :::5353                 :::*                                108        10237      344/avahi-daemon: r
    udp6       0      0 :::47412                :::*                                108        10239      344/avahi-daemon: r
    iob diag has finished.
    • I IceD112
      Skript v.2022-12-13
      *** BASE SYSTEM ***
      Docker:         false
      Release:        11
      Codename:       bullseye
      VERSION_ID="11"
      ID=raspbian
      ID_LIKE=debian
      CPU threads: 4
      CET +0100
      Europe/Berlin
      pi
      /home/pi
      X-Server:       false
      Desktop:
      Terminal:       tty
      *** MEMORY ***
      Swap:            99M         99M        0.0K
               1872 M total memory
               1480 M used memory
                190 M active memory
                179 M free memory
                 35 M buffer memory
                176 M swap cache
                 99 M total swap
                 99 M used swap
                  0 M free swap
      *** FILESYSTEM ***
      /var:
      2.6G    /var/
      2.2G    /var/log
      138M    /var/cache
      /usr/bin/npm            8.19.3
      nodejs:
        Version table:
      ioBroker Status
      Objects type: jsonl
      States  type: jsonl
      admin:          6.3.5
      ioBroker-Instances
      Objects and States
      Objects:        26616
      States:         22293
      Pending Updates: 0
      @iced112
      Passt.
      Tendenziell geht dir aber der Arbeitsspeicher aus. Musst du mal beobachten.
      I 1 Antwort Letzte Antwort
        @iced112
        Passt.
        I Offline
        I Offline
        IceD112
        Ok, ist mir noch garnicht aufgefallen. Ich denke da wird auf kurz oder lang nicht mehr viel an Adaptern etc dazu kommen. Den PI kann man wohl nicht aufrüsten? Oder kann man da administrativ was dran drehen?
        • I IceD112
          @iced112 sagte in Admin startet nicht mehr:
          Nein.
          Ich würde überlegen ob du die Adapter wirklich alle benötigst. Da sind bestimmt zwei, drei dabei die entbehrlich sind.
          • P Offline
            PhoenixCR
            @djmarc75 sagte in Admin startet nicht mehr:
            iobroker start admin
            Hallo an alle, bei mir stürzt nämlich auch der Admin ab und zu ab.
            Der Instanz ist nicht immer in die liste an. Wenn ich es Manuel starte, läuft es eine weile.
            Der iobroker diag Befehl, gibt bei mir nur die help liste aus, komisch.
            pi@HomeAutomation:~ $ iobroker list instances
              system.adapter.admin.0                  : admin                 : HomeAutomation                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.backitup.0               : backitup              : HomeAutomation                           -  enabled
            + system.adapter.chromecast.0             : chromecast            : HomeAutomation                           -  enabled
              system.adapter.daswetter.0              : daswetter             : HomeAutomation                           - disabled
            + system.adapter.device-reminder.0        : device-reminder       : HomeAutomation                           -  enabled
              system.adapter.devices.0                : devices               : HomeAutomation                           -  enabled
            + system.adapter.discovery.0              : discovery             : HomeAutomation                           -  enabled
            + system.adapter.ds18b20.0                : ds18b20               : HomeAutomation                           -  enabled
              system.adapter.echarts.0                : echarts               : HomeAutomation                           - disabled
            + system.adapter.email.0                  : email                 : HomeAutomation                           -  enabled
              system.adapter.feiertage.0              : feiertage             : HomeAutomation                           - disabled
              system.adapter.flot.0                   : flot                  : HomeAutomation                           -  enabled
              system.adapter.fully-tablet-control.0   : fully-tablet-control  : HomeAutomation                           - disabled
            + system.adapter.ham.0                    : ham                   : HomeAutomation                           -  enabled
              system.adapter.heatingcontrol.0         : heatingcontrol        : HomeAutomation                           - disabled
              system.adapter.history.0                : history               : HomeAutomation                           -  enabled
              system.adapter.i2c.0                    : i2c                   : HomeAutomation                           - disabled
              system.adapter.ical.0                   : ical                  : HomeAutomation                           -  enabled
              system.adapter.icons-icons8.0           : icons-icons8          : HomeAutomation                           -  enabled
              system.adapter.icons-material-png.0     : icons-material-png    : HomeAutomation                           -  enabled
              system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeAutomation                           -  enabled
              system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : HomeAutomation                           -  enabled
              system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: HomeAutomation                           -  enabled
            + system.adapter.influxdb.0               : influxdb              : HomeAutomation                           -  enabled, port: 8086
            + system.adapter.info.0                   : info                  : HomeAutomation                           -  enabled
            + system.adapter.iot.0                    : iot                   : HomeAutomation                           -  enabled
            + system.adapter.jarvis.0                 : jarvis                : HomeAutomation                           -  enabled
            + system.adapter.javascript.0             : javascript            : HomeAutomation                           -  enabled
              system.adapter.lgtv.0                   : lgtv                  : HomeAutomation                           - disabled
            + system.adapter.modbus.0                 : modbus                : HomeAutomation                           -  enabled
              system.adapter.modbus.1                 : modbus                : HomeAutomation                           - disabled
            + system.adapter.modbus.2                 : modbus                : HomeAutomation                           -  enabled
            + system.adapter.mqtt.0                   : mqtt                  : HomeAutomation                           -  enabled, port: 1885, bind: 0.0.0.0
            + system.adapter.net-tools.0              : net-tools             : HomeAutomation                           -  enabled
            + system.adapter.node-red.0               : node-red              : HomeAutomation                           -  enabled, port: 1880, bind: 0.0.0.0
              system.adapter.paw.0                    : paw                   : HomeAutomation                           - disabled, port: 2323
              system.adapter.ping.0                   : ping                  : HomeAutomation                           - disabled
              system.adapter.pushsafer.0              : pushsafer             : HomeAutomation                           - disabled
            + system.adapter.rpi2.0                   : rpi2                  : HomeAutomation                           -  enabled
              system.adapter.samsung.0                : samsung               : HomeAutomation                           - disabled
              system.adapter.samsung_tizen.0          : samsung_tizen         : HomeAutomation                           - disabled, port: 8002
            + system.adapter.sayit.0                  : sayit                 : HomeAutomation                           -  enabled, port: 0
              system.adapter.schoolfree.0             : schoolfree            : HomeAutomation                           -  enabled
              system.adapter.shuttercontrol.0         : shuttercontrol        : HomeAutomation                           - disabled
            + system.adapter.sonoff.0                 : sonoff                : HomeAutomation                           -  enabled, port: 1883, bind: 0.0.0.0
              system.adapter.speedport.0              : speedport             : HomeAutomation                           - disabled
            + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeAutomation                           -  enabled
            + system.adapter.telegram.0               : telegram              : HomeAutomation                           -  enabled, port: 8443, bind: 0.0.0.0
            + system.adapter.text2command.0           : text2command          : HomeAutomation                           -  enabled
              system.adapter.trashschedule.0          : trashschedule         : HomeAutomation                           - disabled
            + system.adapter.tuya.0                   : tuya                  : HomeAutomation                           -  enabled
            + system.adapter.virtualpowermeter.0      : virtualpowermeter     : HomeAutomation                           -  enabled
              system.adapter.vis-bars.0               : vis-bars              : HomeAutomation                           -  enabled
              system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : HomeAutomation                           -  enabled
              system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeAutomation                           -  enabled
              system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : HomeAutomation                           -  enabled
              system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeAutomation                           -  enabled
              system.adapter.vis-history.0            : vis-history           : HomeAutomation                           -  enabled
              system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeAutomation                           -  enabled
              system.adapter.vis-icontwo.0            : vis-icontwo           : HomeAutomation                           -  enabled
            + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeAutomation                           -  enabled
              system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeAutomation                           -  enabled
              system.adapter.vis-justgage.0           : vis-justgage          : HomeAutomation                           -  enabled
              system.adapter.vis-keyboard.0           : vis-keyboard          : HomeAutomation                           -  enabled
              system.adapter.vis-lcars.0              : vis-lcars             : HomeAutomation                           -  enabled
              system.adapter.vis-map.0                : vis-map               : HomeAutomation                           -  enabled
              system.adapter.vis-material-advanced.0  : vis-material-advanced : HomeAutomation                           -  enabled
              system.adapter.vis-metro.0              : vis-metro             : HomeAutomation                           -  enabled
              system.adapter.vis-players.0            : vis-players           : HomeAutomation                           -  enabled
              system.adapter.vis-plumb.0              : vis-plumb             : HomeAutomation                           -  enabled
              system.adapter.vis-rgraph.0             : vis-rgraph            : HomeAutomation                           -  enabled
              system.adapter.vis.0                    : vis                   : HomeAutomation                           -  enabled
            + system.adapter.web.0                    : web                   : HomeAutomation                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
              system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeAutomation                           - disabled
              system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : HomeAutomation                           - disabled
              system.adapter.wifilight.0              : wifilight             : HomeAutomation                           - disabled
            + system.adapter.yahka.0                  : yahka                 : HomeAutomation                           -  enabled
              system.adapter.yahka.1                  : yahka                 : HomeAutomation                           - disabled
            + instance is alive
            pi@HomeAutomation:~ $ iobroker diag
            iobroker [command]
            Commands:
              iobroker setup                                               Setup ioBroker
              iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
              iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
              iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
              iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
              iobroker info                                                Shows the host info
              iobroker logs [<adapter>]                                    Monitor log
              iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
              iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
              iobroker rebuild [<module>]                                  Rebuild all native modules or path
              iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
              iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
              iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
              iobroker update [<repositoryUrl>]                            Update repository and list adapters
              iobroker upgrade                                             Upgrade management
              iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
              iobroker object                                              Object management  [aliases: o]
              iobroker state                                               State management  [aliases: s]
              iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
              iobroker list <type> [<filter>]                              List all entries, like objects
              iobroker chmod <mode> <file>                                 Change file rights
              iobroker chown <user> <group> <file>                         Change file ownership
              iobroker touch <file>                                        Touch file
              iobroker rm <file>                                           Remove file
              iobroker file                                                File management
              iobroker user                                                User commands
              iobroker group                                               group management
              iobroker host <hostname>                                     Set host to given hostname
              iobroker set <adapter>.<instance>                            Change settings of adapter config
              iobroker license <license.file or license.text>              Update license by given file
              iobroker cert                                                Certificate management
              iobroker clean <yes>                                         Clears all objects and states
              iobroker backup                                              Create backup
              iobroker restore <backup name or path>                       Restore a specified backup
              iobroker validate <backup name or path>                      Validate a specified backup
              iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
              iobroker repo [<name>]                                       Show repo information
              iobroker uuid                                                Show uuid of the installation  [aliases: id]
              iobroker unsetup                                             Reset license, installation secret and language
              iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
              iobroker multihost                                           Multihost management
              iobroker compact                                             compact group management
              iobroker plugin                                              Plugin management
              iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
            Options:
              --help  Show help  [boolean]
            ich habe keine ideen mehr was es sein könnte.
            danke schn mal im voraus für eure Hilfe.
            • P PhoenixCR
              + instance is alive
              iobroker [command]
              Commands:
              Options:
              @phoenixcr
              iobroker stop
              iobroker fix
              iobroker start
              iobroker diag
              P 1 Antwort Letzte Antwort
                @phoenixcr
                iobroker stop
                iobroker fix
                iobroker start
                iobroker diag
                PhoenixCR
                schrieb am zuletzt editiert von PhoenixCR
                Hallo Thomas, danke, es hat funktioniert.
                Anbei das Ergebnis.
                			v.2022-12-13
                Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
                Installation: 		Native
                Timezone: 		Europe/Berlin
                User-ID: 		1000
                X-Server: 		true
                Pending OS-Updates: 	74
                Nodejs-Installation: 	/usr/bin/nodejs 	v16.17.1
                			/usr/bin/node 		v16.17.1
                			/usr/bin/npm 		8.19.2
                ioBroker Core: 		js-controller 		4.0.23
                			admin 			6.3.5
                ioBroker Status: 	iobroker is running on this host.
                Objects type: jsonl
                States  type: jsonl
                Pending iob updates: 	0
                Objects: 		6537
                States: 		5071
                Size of iob-Database:
                8.8M	/opt/iobroker/iobroker-data/objects.jsonl
                6.7M	/opt/iobroker/iobroker-data/objects.json.migrated
                6.7M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                2.2M	/opt/iobroker/iobroker-data/states.jsonl
                816K	/opt/iobroker/iobroker-data/states.json.migrated
                816K	/opt/iobroker/iobroker-data/states.json.bak.migrated
                0	/opt/iobroker/iobroker-data/states.json.broken
                ====================== END OF SUMMARY ==================
                P Thomas BraunT 2 Antworten Letzte Antwort
                • P PhoenixCR
                  Anbei das Ergebnis.
                  			v.2022-12-13
                  User-ID: 		1000
                  X-Server: 		true
                  			/usr/bin/npm 		8.19.2
                  			admin 			6.3.5
                  Objects type: jsonl
                  States  type: jsonl
                  Objects: 		6537
                  States: 		5071
                  PhoenixCR
                  @phoenixcr
                  The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                  Skript v.2022-12-13
                  *** BASE SYSTEM ***
                  Docker: 	false
                  Description:	Raspbian GNU/Linux 10 (buster)
                  Release:	10
                  Codename:	buster
                  PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                  VERSION_ID="10"
                  VERSION="10 (buster)"
                  VERSION_CODENAME=buster
                  ID=raspbian
                  ID_LIKE=debian
                   10:39:03 up  2:24,  2 users,  load average: 2.11, 2.56, 2.59
                  CPU threads: 4
                  Tue Dec 27 09:39:03 UTC 2022
                  Tue Dec 27 10:39:03 CET 2022
                  CET +0100
                  Europe/Berlin
                  pi
                  /home/pi
                  pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                  X-Server: 	true
                  Desktop: 	LXDE-pi
                  Terminal: 	x11
                  *** MEMORY ***
                  Mem:           7.9G        1.7G        4.6G        125M        1.7G        6.3G
                  Swap:           99M          0B         99M
                  Total:         8.0G        1.7G        4.7G
                           7897 M total memory
                           1677 M used memory
                            526 M active memory
                           2540 M inactive memory
                           4551 M free memory
                            240 M buffer memory
                           1427 M swap cache
                             99 M total swap
                              0 M used swap
                             99 M free swap
                  *** FILESYSTEM ***
                  /dev/root      ext4      118G   13G  101G  11% /
                  devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                  tmpfs          tmpfs     3.9G  1.7M  3.9G   1% /dev/shm
                  tmpfs          tmpfs     3.9G   74M  3.8G   2% /run
                  tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                  /dev/sda1      vfat      253M   49M  204M  20% /boot
                  tmpfs          tmpfs     790M   12K  790M   1% /run/user/1000
                  /                     /dev/sda2  ext4            rw,noatime
                  |-/sys/fs/bpf         none       bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                  |-/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                  `-/boot               /dev/sda1  vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                  /var:
                  2.6G	/var/
                  1.1G	/var/cache/apt/archives
                  1.1G	/var/cache/apt
                  1.1G	/var/cache
                  1002M	/var/log
                  1.8G	/opt/iobroker/backups/
                  786M	/opt/iobroker/iobroker-data/
                  509M	/opt/iobroker/iobroker-data/files
                  92M	/opt/iobroker/iobroker-data/node-red
                  91M	/opt/iobroker/iobroker-data/node-red/node_modules
                  86M	/opt/iobroker/iobroker-data/backup-objects
                  33M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                  9.7M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
                  9.1M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
                  8.9M	/opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
                  /usr/bin/npm 		8.19.2
                  nodejs:
                    Installed: 16.17.1-deb-1nodesource1
                    Version table:
                          500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                   *** 16.17.1-deb-1nodesource1 100
                       10.24.0~dfsg-1~deb10u2 500
                  ioBroker Status
                  Objects type: jsonl
                  States  type: jsonl
                  admin: 		6.3.5
                  Adapters from github: 	3
                  + system.adapter.admin.0                  : admin                 : HomeAutomation                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                  Stable (default): http://download.iobroker.net/sources-dist.json
                  Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                  ioBroker-Instances
                  Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                  Adapter    "devices"      : 1.1.2    , installed 1.1.2
                  Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
                  Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                  Adapter    "email"        : 1.1.4    , installed 1.1.4
                  Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                  Adapter    "flot"         : 1.11.0   , installed 1.11.0
                  Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                  Adapter    "heatingcontrol": 2.9.3   , installed 2.9.3
                  Adapter    "history"      : 2.2.4    , installed 2.2.4
                  Adapter    "i2c"          : 1.2.1    , installed 1.2.1
                  Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                  Adapter    "info"         : 1.9.19   , installed 1.9.19
                  Adapter    "iot"          : 1.11.9   , installed 1.11.9
                  Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                  Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                  Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                  Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                  Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                  Adapter    "paw"          : 0.3.2    , installed 0.3.2
                  Adapter    "places"       : 1.1.2    , installed 1.1.2
                  Adapter    "psa"          : 0.0.11   , installed 0.0.11
                  Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
                  Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                  Adapter    "sayit"        : 1.12.3   , installed 1.12.3
                  Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                  Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
                  Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                  Adapter    "tankerkoenig" : 3.1.0    , installed 3.1.0
                  Adapter    "text2command" : 2.3.0    , installed 2.3.0
                  Adapter    "tuya"         : 3.11.1   , installed 3.11.1
                  Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                  Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                  Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                  Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                  Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                  Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                  Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                  Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                  Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                  Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                  Objects and States
                  Objects: 	6537
                  States: 	5070
                  E: Repository 'https://packages.grafana.com/oss/deb stable InRelease' changed its 'Origin' value from 'grafana stable' to '. stable'
                  E: Repository 'https://packages.grafana.com/oss/deb stable InRelease' changed its 'Label' value from 'grafana stable' to '. stable'
                  Pending Updates: 74
                  tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1527171    25234/io.jarvis.0
                  tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          14319      577/dnsmasq
                  tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17752      552/sshd
                  tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15673      372/cupsd
                  tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       1518166    21372/node-red
                  tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14331      499/influxd
                  tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1518129    22389/io.sonoff.0
                  tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       1514484    22107/io.mqtt.0
                  tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       1514485    22107/io.mqtt.0
                  tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          17800      514/anydesk
                  tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1507075    19141/iobroker.js-c
                  tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1507068    19141/iobroker.js-c
                  tcp        0      0 0.0.0.0:35789           0.0.0.0:*               LISTEN      0          35725      514/anydesk
                  tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1509661    19484/io.admin.0
                  tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1532606    26604/io.web.0
                  tcp6       0      0 :::46163                :::*                    LISTEN      1001       1516423    21372/node-red
                  tcp6       0      0 :::53                   :::*                    LISTEN      0          14321      577/dnsmasq
                  tcp6       0      0 :::8086                 :::*                    LISTEN      999        19382      499/influxd
                  tcp6       0      0 :::22                   :::*                    LISTEN      0          17754      552/sshd
                  tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15672      372/cupsd
                  tcp6       0      0 :::3000                 :::*                    LISTEN      117        20679      488/grafana-server
                  tcp6       0      0 :::45665                :::*                    LISTEN      1001       1518656    21372/node-red
                  udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1518873    22710/io.tuya.0
                  udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1518874    22710/io.tuya.0
                  udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          14318      577/dnsmasq
                  udp     2624      0 0.0.0.0:68              0.0.0.0:*                           0          20843      416/dhcpcd
                  udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18488      508/cups-browsed
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1521559    24181/io.chromecast
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1516452    21372/node-red
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1516449    21372/node-red
                  udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15678      410/avahi-daemon: r
                  udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          22414      514/anydesk
                  udp        0      0 0.0.0.0:58711           0.0.0.0:*                           108        15680      410/avahi-daemon: r
                  udp6       0      0 :::58809                :::*                                108        15681      410/avahi-daemon: r
                  udp6       0      0 :::546                  :::*                                0          21468      416/dhcpcd
                  udp6       0      0 :::53                   :::*                                0          14320      577/dnsmasq
                  udp6       0      0 :::5353                 :::*                                108        15679      410/avahi-daemon: r
                                     Mark until here for C&P
                  • P PhoenixCR
                    Anbei das Ergebnis.
                    			v.2022-12-13
                    User-ID: 		1000
                    X-Server: 		true
                    			/usr/bin/npm 		8.19.2
                    			admin 			6.3.5
                    Objects type: jsonl
                    States  type: jsonl
                    Objects: 		6537
                    States: 		5071
                    @phoenixcr sagte in Admin startet nicht mehr:
                    buster
                    Buster hat sein End Of Life erreicht. Installier da das 'Bullseye'-Release.
                    Und zwar dann OHNE Desktop.
                      buster
                      PhoenixCR
                      ich brauche aber das Desktop, zwecks Fernzugriff.
                      Glaubst du, das ist das Problem der abstürzte?
                      Danke!
                      • P PhoenixCR
                        Danke!
                        Macht man per SSH und Kommandozeile. OHNE DESKTOP!!
                        J P 2 Antworten Letzte Antwort
                          jhg
                          Ich hänge mich hier mal mit einer Frage dran, da es nicht lohnt dafür einen neuen Thread zu öffnen.
                          Nachdem ich meinen ioBroker auf neue Hardware umgezogen habe, hat der Admin adapter nun die Nummer 2.
                          Also admin.2 und nicht admin.0.
                          Kann das irgendwann mal Probleme machen? Sollte ich das ändern?
                            PhoenixCR
                            erledigt, ohne Desktop.
                            Selber Verhältnis.
                            In log, steht nichts Besonderes
                            fehlt sogar der Export Knopf
                            • P PhoenixCR
                              Selber Verhältnis.
                              @phoenixcr
                              Und
                              iobroker diag
                              sagt nun?
                                @phoenixcr
                                Und
                                iobroker diag
                                sagt nun?
                                PhoenixCR
                                @thomas-braun sagte in Admin startet nicht mehr:
                                iobroker diag
                                Skript v.2022-12-13
                                *** BASE SYSTEM ***
                                Docker:         false
                                Release:        11
                                Codename:       bullseye
                                VERSION_ID="11"
                                ID=raspbian
                                ID_LIKE=debian
                                 19:57:59 up  4:13,  1 user,  load average: 1.41, 1.63, 2.53
                                CPU threads: 4
                                Tue Dec 27 19:57:59 UTC 2022
                                Tue Dec 27 19:57:59 GMT 2022
                                GMT +0000
                                Europe/London
                                chris
                                /home/chris
                                chris adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                X-Server:       false
                                Desktop:
                                Terminal:       tty
                                *** MEMORY ***
                                Mem:            7.9G        1.5G        4.4G        0.0K        2.0G        6.4G
                                Swap:            99M        1.0M         98M
                                Total:          8.0G        1.5G        4.5G
                                         7897 M total memory
                                         1490 M used memory
                                          701 M active memory
                                         2533 M inactive memory
                                         4388 M free memory
                                          151 M buffer memory
                                         1867 M swap cache
                                           99 M total swap
                                            1 M used swap
                                           98 M free swap
                                *** FILESYSTEM ***
                                /dev/root      ext4      118G  5.0G  108G   5% /
                                tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                                /dev/sda1      vfat      255M   50M  206M  20% /boot
                                tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                                /var:
                                542M    /var/
                                282M    /var/cache
                                276M    /var/cache/apt
                                212M    /var/cache/apt/archives
                                98M     /var/lib
                                240M    /opt/iobroker/backups/
                                118M    /opt/iobroker/backups/Influxdb
                                529M    /opt/iobroker/iobroker-data/
                                428M    /opt/iobroker/iobroker-data/files
                                79M     /opt/iobroker/iobroker-data/node-red/node_modules
                                78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                                17M     /opt/iobroker/iobroker-data/objects.jsonl
                                /usr/bin/npm            8.19.3
                                nodejs:
                                  Version table:
                                ioBroker Status
                                Objects type: jsonl
                                States  type: jsonl
                                admin:          6.3.5
                                Adapters from github:   2
                                + system.adapter.admin.0                  : admin                 : homeautomationcretu                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                + system.adapter.mqtt.0                   : mqtt                  : homeautomationcretu                      -  enabled, port: 1885, bind: 0.0.0.0
                                + system.adapter.sayit.0                  : sayit                 : homeautomationcretu                      -  enabled, port: 0
                                + system.adapter.telegram.0               : telegram              : homeautomationcretu                      -  enabled, port: 8443, bind: 0.0.0.0
                                + system.adapter.web.0                    : web                   : homeautomationcretu                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                ioBroker-Instances
                                Objects and States
                                Objects:        6463
                                States:         5008
                                Hit:3 https://repos.influxdata.com/debian bullseye InRelease
                                Hit:4 https://apt.grafana.com stable InRelease
                                Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                Pending Updates: 0
                                tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       45447      10525/io.jarvis.0
                                tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11762      541/sshd: /usr/sbin
                                tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        140894     26161/influxd
                                tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       44880      11581/io.mqtt.0
                                tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       44881      11581/io.mqtt.0
                                tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16053      1795/iobroker.js-co
                                tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16046      1795/iobroker.js-co
                                tcp6       0      0 :::22                   :::*                    LISTEN      0          11764      541/sshd: /usr/sbin
                                tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16122      1823/io.admin.0
                                tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30720      7826/io.web.0
                                tcp6       0      0 :::8086                 :::*                    LISTEN      999        141933     26161/influxd
                                tcp6       0      0 :::3000                 :::*                    LISTEN      110        77925      17659/grafana-serve
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33946      7993/io.chromecast.
                                udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11593      403/avahi-daemon: r
                                udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32188      7852/io.tuya.0
                                udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32189      7852/io.tuya.0
                                udp        0      0 0.0.0.0:43026           0.0.0.0:*                           108        11595      403/avahi-daemon: r
                                udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14566      783/dhcpcd
                                udp6       0      0 :::5353                 :::*                                108        11594      403/avahi-daemon: r
                                udp6       0      0 :::56192                :::*                                108        11596      403/avahi-daemon: r
                                udp6       0      0 :::546                  :::*                                0          14628      783/dhcpcd
                                Press any key for a summary
                                • P PhoenixCR
                                  iobroker diag
                                  Skript v.2022-12-13
                                  *** BASE SYSTEM ***
                                  Docker:         false
                                  Release:        11
                                  Codename:       bullseye
                                  VERSION_ID="11"
                                  ID=raspbian
                                  ID_LIKE=debian
                                  CPU threads: 4
                                  GMT +0000
                                  Europe/London
                                  chris
                                  /home/chris
                                  X-Server:       false
                                  Desktop:
                                  Terminal:       tty
                                  *** MEMORY ***
                                  Swap:            99M        1.0M         98M
                                           7897 M total memory
                                           1490 M used memory
                                            701 M active memory
                                           4388 M free memory
                                            151 M buffer memory
                                           1867 M swap cache
                                             99 M total swap
                                              1 M used swap
                                             98 M free swap
                                  *** FILESYSTEM ***
                                  /var:
                                  542M    /var/
                                  282M    /var/cache
                                  276M    /var/cache/apt
                                  98M     /var/lib
                                  /usr/bin/npm            8.19.3
                                  nodejs:
                                    Version table:
                                  ioBroker Status
                                  Objects type: jsonl
                                  States  type: jsonl
                                  admin:          6.3.5
                                  ioBroker-Instances
                                  Objects and States
                                  Objects:        6463
                                  States:         5008
                                  Pending Updates: 0
                                  @phoenixcr
                                  Setz die Zeitzone richtig.
                                  Problem behoben?
                                  • P PhoenixCR
                                    + instance is alive
                                    iobroker [command]
                                    Commands:
                                    Options:
                                    ist das alles an Informationen?
                                      @phoenixcr
                                      Problem behoben?
                                      PhoenixCR
                                      Zurzeit ja.
                                      Vielen Dank.
                                        PhoenixCR
                                        Siehe oben.
                                        Aber im Moment läuft es.
                                          @phoenixcr
                                          Problem behoben?
                                          PhoenixCR
                                          geht wieder nicht
                                          und der diag bleibt hängen beim repositories
                                          /var:
                                          864M    /var/
                                          358M    /var/lib
                                          282M    /var/cache
                                          276M    /var/cache/apt
                                          263M    /var/lib/influxdb
                                          588M    /opt/iobroker/backups/
                                          345M    /opt/iobroker/backups/influxdbold
                                          302M    /opt/iobroker/backups/influxdbold/data
                                          261M    /opt/iobroker/backups/influxdbold/data/iobroker
                                          229M    /opt/iobroker/backups/influxdbold/data/iobroker/autogen
                                          554M    /opt/iobroker/iobroker-data/
                                          84M     /opt/iobroker/iobroker-data/node-red/node_modules
                                          22M     /opt/iobroker/iobroker-data/objects.jsonl
                                          /usr/bin/npm            8.19.3
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          No connection to databases possible ...
                                          admin:          6.3.5
