  4. Admin startet nicht mehr
    5.5k
111 Beiträge 9 Kommentatoren 19.0k Aufrufe 8 Beobachtet
  • I IceD112
    pi@ioBroker:/opt/iobroker/node_modules/iobroker.javascript $ sudo -u iobroker npm install
    npm WARN deprecated source-map-resolve@0.5.3: See https://github.com/lydell/source-map-resolve#deprecated
    npm WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    npm WARN deprecated chokidar@2.1.8: Chokidar 2 does not receive security updates since 2019. Upgrade to chokidar 3 with 15x fewer dependencies
    npm WARN deprecated uuid@3.4.0: Please upgrade  to version 7 or higher.  Older versions may use Math.random() in certain circumstances, which is known to be problematic.  See https://v8.dev/blog/math-random for details.
    npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    > iobroker.javascript@6.1.4 postinstall
    > node ./install/installTypings.js
    Installing NodeJS typings...
    latest @types: 18, installed node: 16
    added 106 packages, removed 108 packages, changed 94 packages, and audited 876 packages in 54s
    64 packages are looking for funding
      run `npm fund` for details
    11 vulnerabilities (1 low, 3 moderate, 6 high, 1 critical)
    To address issues that do not require attention, run:
      npm audit fix
    To address all issues possible (including breaking changes), run:
      npm audit fix --force
    Some issues need review, and may require choosing
    a different dependency.
    Run `npm audit` for details.
    sieht schon anders aus
    I Offline
    I Offline
    IceD112
    Startet immer noch nicht und die Version die hier steht, stimmt auch nicht mit der überein, die bei der diagnose ausgegeben wurde
    • I IceD112
      @iced112
      iobroker update
      iobroker upgrade all --debug
      I 1 Antwort Letzte Antwort
        @iced112
        iobroker update
        I Offline
        I Offline
        IceD112
        Ach, guck an. das hat beim zweiten versuch funktioniert. Beim ersten mal hat er noch die scheinbar neue version als "installtiert" angezeigt und als ich das zweite mal update ausgeführt habe war Java auf dem alten stand. Dann hat die installation, bzw. das update geklappt. Jetzt ist der Adapter auch wieder gestartet... und funktioniert auch wieder :-)
        Vielen liebe Dank dir/euch
        • I IceD112
          @iced112
          Dann zeig jetzt nochmal die Ausgabe von
          iobroker diag
            @iced112
            iobroker diag
            I Offline
            I Offline
            IceD112
            schrieb am zuletzt editiert von IceD112
            *** ioBroker Diagnosis ***
            Please stretch the window of your terminal programm (puTTY) as wide as possible        or switch to full screen
            The following checks may give hints to potential malconfigurations or errors, pl        ease post them in our forum:
            https://forum.iobroker.net
            Just copy and paste the Summary Page, including the ``` characters at start and        end.
            It helps us to help you!
            Press any key to continue
            Skript v.2022-12-13
            *** BASE SYSTEM ***
            Model           : Raspberry Pi 4 Model B Rev 1.4
            Architecture:   armv7l
            Docker:         false
            Virtualization: none
            Distributor ID: Raspbian
            Description:    Raspbian GNU/Linux 11 (bullseye)
            Release:        11
            Codename:       bullseye
            PRETTY_NAME="Raspbian GNU/Linux 11 (bullseye)"
            NAME="Raspbian GNU/Linux"
            VERSION_ID="11"
            VERSION="11 (bullseye)"
            VERSION_CODENAME=bullseye
            ID=raspbian
            ID_LIKE=debian
            HOME_URL="http://www.raspbian.org/"
            SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
            BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
            Systemuptime and Load:
             22:15:29 up  1:38,  2 users,  load average: 0.93, 0.51, 0.50
            CPU threads: 4
            *** Time and Time Zones ***
            Sun Dec 25 21:15:29 UTC 2022
            Sun Dec 25 22:15:29 CET 2022
            CET +0100
            Europe/Berlin
            *** User and Groups ***
            pi
            /home/pi
            pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
            *** X-Server-Setup ***
            X-Server:       false
            Desktop:
            Terminal:       tty
            *** MEMORY ***
            Mem:            1.9G        1.5G        179M        0.0K        212M        418M
            Swap:            99M         99M        0.0K
            Total:          2.0G        1.6G        180M
                     1872 M total memory
                     1480 M used memory
                      190 M active memory
                     1391 M inactive memory
                      179 M free memory
                       35 M buffer memory
                      176 M swap cache
                       99 M total swap
                       99 M used swap
                        0 M free swap
            *** FILESYSTEM ***
            Filesystem                                Type      Size  Used Avail Use% Mounted on
            /dev/root                                 ext4       29G  6.2G   22G  23% /
            devtmpfs                                  devtmpfs  776M     0  776M   0% /dev
            tmpfs                                     tmpfs     937M     0  937M   0% /dev/shm
            tmpfs                                     tmpfs     375M  812K  374M   1% /run
            tmpfs                                     tmpfs     5.0M  4.0K  5.0M   1% /run/lock
            /dev/mmcblk0p1                            vfat      253M   50M  203M  20% /boot
            tmpfs                                     tmpfs     188M     0  188M   0% /run/user/1000
            //192.168.178.1/IceDBox/IOBROKER/ioBroker cifs      4.1G  176M  4.0G   5% /opt/iobroker/backups
            TARGET                  SOURCE                                    FSTYPE OPTIONS
            /                       /dev/mmcblk0p2                            ext4   rw,noatime
            |-/boot                 /dev/mmcblk0p1                            vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,flush,errors=remount-ro
            `-/opt/iobroker/backups //192.168.178.1/IceDBox/IOBROKER/ioBroker cifs   rw,relatime,vers=3.1.1,cache=strict,username=ioB_Backup,uid=0,noforceuid,gid=0,noforcegid,addr=192.168.178.1,file_mode=0777,dir_mode=0777,soft,nounix,mapposix,rsize=65536,wsize=65536,bsize=1048576,echo_interval=60,actimeo=1
            /var:
            2.6G    /var/
            2.2G    /var/log/journal/25070aeb79f44c94a7f7bcc85e4ba968
            2.2G    /var/log
            138M    /var/cache
            /opt/iobroker/backups:
            148M    /opt/iobroker/backups/
            /opt/iobroker/iobroker-data:
            751M    /opt/iobroker/iobroker-data/
            344M    /opt/iobroker/iobroker-data/files
            249M    /opt/iobroker/iobroker-data/backup-objects
            74M     /opt/iobroker/iobroker-data/files/vis.0
            72M     /opt/iobroker/iobroker-data/files/telegram.admin
            139M    /opt/iobroker/iobroker-data/states.jsonl
            20M     /opt/iobroker/iobroker-data/objects.jsonl
            15M     /opt/iobroker/iobroker-data/files/telegram.admin/rules/static/js/vendors-node_modules_iobroker_adapter-react-v5_assets_devices_parseNames_d_ts-node_modules_io-1d9f06.44fe4a3f.chunk.js.map
            8.9M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js/2.7de3299d.chunk.js.map
            8.0M    /opt/iobroker/iobroker-data/backup-objects/2022-12-24_18-41_states.jsonl.gz
            *** NodeJS-Installation ***
            /usr/bin/nodejs         v16.19.0
            /usr/bin/node           v16.19.0
            /usr/bin/npm            8.19.3
            nodejs:
              Installed: 16.19.0-deb-1nodesource1
              Candidate: 16.19.0-deb-1nodesource1
              Version table:
             *** 16.19.0-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                 12.22.12~dfsg-1~deb11u1 500
            *** ioBroker-Installation ***
            ioBroker Status
            Objects type: jsonl
            States  type: jsonl
            Core adapters versions
            js-controller:  4.0.23
            admin:          6.3.5
            Adapters from github:   0
            + system.adapter.admin.0                  : admin                 : ioBroker                                 -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
            + system.adapter.hue.0                    : hue                   : ioBroker                                 -  enabled, port: 443
            + system.adapter.lgtv11.0                 : lgtv11                : ioBroker                                 -  enabled, port: 8080
            + system.adapter.shelly.0                 : shelly                : ioBroker                                 -  enabled, port: 1882, bind: 0.0.0.0
            + system.adapter.web.0                    : web                   : ioBroker                                 -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
            ioBroker-Repositories
            Active repo(s): stable
            ioBroker-Instances
            Used repository: stable
            Adapter    "accuweather"  : 1.2.1    , installed 1.2.4
            Adapter    "alexa2"       : 3.23.2   , installed 3.23.2
            Adapter    "backitup"     : 2.5.9    , installed 2.5.9
            Adapter    "bring"        : 1.8.1    , installed 1.8.1
            Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
            Adapter    "daswetter"    : 3.1.4    , installed 3.1.4
            Adapter    "denon"        : 1.13.4   , installed 1.13.4
            Adapter    "dwd"          : 2.8.3    , installed 2.8.3
            Adapter    "fb-checkpresence": 1.1.20, installed 1.1.20
            Adapter    "followthesun" : 0.4.0    , installed 0.4.0
            Adapter    "ham"          : 5.3.1    , installed 5.3.1
            Adapter    "harmony"      : 1.2.2    , installed 1.2.2
            Adapter    "heos"         : 1.10.0   , installed 1.10.0
            Adapter    "hue"          : 3.7.1    , installed 3.7.1
            Adapter    "hue-extended" : 2.0.0    , installed 2.0.0
            Adapter    "javascript"   : 6.1.4    , installed 6.1.4
            Controller "js-controller": 4.0.23   , installed 4.0.23
            Adapter    "lgtv"         : 1.1.10   , installed 1.1.10
            Adapter    "lgtv11"       : 1.0.5    , installed 1.0.5
            Adapter    "meross"       : 1.14.0   , installed 1.14.0
            Adapter    "panasonic-viera": 2.0.0  , installed 2.0.0
            Adapter    "shelly"       : 6.0.0    , installed 6.0.0
            Adapter    "socketio"     : 4.2.0    , installed 6.1.8
            Adapter    "spotify-premium": 1.2.1  , installed 1.2.2
            Adapter    "telegram"     : 1.15.2   , installed 1.15.2
            Adapter    "tr-064"       : 4.2.17   , installed 4.2.17
            Adapter    "trashschedule": 2.0.3    , installed 2.0.3
            Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
            Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
            Adapter    "vis-icontwo"  : 0.90.0   , installed 0.90.0
            Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.3
            Adapter    "web"          : 4.3.0    , installed 5.2.4
            Adapter    "ws"           : 1.3.0    , installed 2.1.3
            Adapter    "yr"           : 5.3.0    , installed 5.3.0
            Objects and States
            Objects:        26616
            States:         22293
            Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
            Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
            Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
            Reading package lists...
            Pending Updates: 0
            *** Listening Ports ***
            tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          14362      502/sshd: /usr/sbin
            tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       14530      469/iobroker.js-con
            tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       14405      469/iobroker.js-con
            tcp6       0      0 :::22                   :::*                    LISTEN      0          14364      502/sshd: /usr/sbin
            tcp6       0      0 :::61991                :::*                    LISTEN      1001       17777      1609/io.harmony.0
            tcp6       0      0 :::8082                 :::*                    LISTEN      1001       19693      1786/io.web.0
            tcp6       0      0 :::8081                 :::*                    LISTEN      1001       80147      6245/io.admin.0
            udp        0      0 0.0.0.0:49103           0.0.0.0:*                           1001       19311      1624/io.heos.0
            udp        0      0 0.0.0.0:61991           0.0.0.0:*                           1001       17778      1609/io.harmony.0
            udp        0      0 0.0.0.0:5683            0.0.0.0:*                           1001       15257      1121/io.shelly.0
            udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          12953      755/dhcpcd
            udp        0      0 0.0.0.0:53431           0.0.0.0:*                           108        10238      344/avahi-daemon: r
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       19009      1461/io.chromecast.
            udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        10236      344/avahi-daemon: r
            udp6       0      0 :::546                  :::*                                0          12964      755/dhcpcd
            udp6       0      0 :::5353                 :::*                                108        10237      344/avahi-daemon: r
            udp6       0      0 :::47412                :::*                                108        10239      344/avahi-daemon: r
            iob diag has finished.
            • I IceD112
              Skript v.2022-12-13
              *** BASE SYSTEM ***
              Docker:         false
              Release:        11
              Codename:       bullseye
              VERSION_ID="11"
              ID=raspbian
              ID_LIKE=debian
              CPU threads: 4
              CET +0100
              Europe/Berlin
              pi
              /home/pi
              X-Server:       false
              Desktop:
              Terminal:       tty
              *** MEMORY ***
              Swap:            99M         99M        0.0K
                       1872 M total memory
                       1480 M used memory
                        190 M active memory
                        179 M free memory
                         35 M buffer memory
                        176 M swap cache
                         99 M total swap
                         99 M used swap
                          0 M free swap
              *** FILESYSTEM ***
              /var:
              2.6G    /var/
              2.2G    /var/log
              138M    /var/cache
              /usr/bin/npm            8.19.3
              nodejs:
                Version table:
              ioBroker Status
              Objects type: jsonl
              States  type: jsonl
              admin:          6.3.5
              ioBroker-Instances
              Objects and States
              Objects:        26616
              States:         22293
              Pending Updates: 0
              @iced112
              Passt.
              Tendenziell geht dir aber der Arbeitsspeicher aus. Musst du mal beobachten.
                @iced112
                Passt.
                I Offline
                I Offline
                IceD112
                Ok, ist mir noch garnicht aufgefallen. Ich denke da wird auf kurz oder lang nicht mehr viel an Adaptern etc dazu kommen. Den PI kann man wohl nicht aufrüsten? Oder kann man da administrativ was dran drehen?
                • I IceD112
                  @iced112 sagte in Admin startet nicht mehr:
                  Nein.
                  Ich würde überlegen ob du die Adapter wirklich alle benötigst. Da sind bestimmt zwei, drei dabei die entbehrlich sind.
                  • P Offline
                    PhoenixCR
                    @djmarc75 sagte in Admin startet nicht mehr:
                    iobroker start admin
                    Hallo an alle, bei mir stürzt nämlich auch der Admin ab und zu ab.
                    Der Instanz ist nicht immer in die liste an. Wenn ich es Manuel starte, läuft es eine weile.
                    Der iobroker diag Befehl, gibt bei mir nur die help liste aus, komisch.
                    pi@HomeAutomation:~ $ iobroker list instances
                      system.adapter.admin.0                  : admin                 : HomeAutomation                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                    + system.adapter.backitup.0               : backitup              : HomeAutomation                           -  enabled
                    + system.adapter.chromecast.0             : chromecast            : HomeAutomation                           -  enabled
                      system.adapter.daswetter.0              : daswetter             : HomeAutomation                           - disabled
                    + system.adapter.device-reminder.0        : device-reminder       : HomeAutomation                           -  enabled
                      system.adapter.devices.0                : devices               : HomeAutomation                           -  enabled
                    + system.adapter.discovery.0              : discovery             : HomeAutomation                           -  enabled
                    + system.adapter.ds18b20.0                : ds18b20               : HomeAutomation                           -  enabled
                      system.adapter.echarts.0                : echarts               : HomeAutomation                           - disabled
                    + system.adapter.email.0                  : email                 : HomeAutomation                           -  enabled
                      system.adapter.feiertage.0              : feiertage             : HomeAutomation                           - disabled
                      system.adapter.flot.0                   : flot                  : HomeAutomation                           -  enabled
                      system.adapter.fully-tablet-control.0   : fully-tablet-control  : HomeAutomation                           - disabled
                    + system.adapter.ham.0                    : ham                   : HomeAutomation                           -  enabled
                      system.adapter.heatingcontrol.0         : heatingcontrol        : HomeAutomation                           - disabled
                      system.adapter.history.0                : history               : HomeAutomation                           -  enabled
                      system.adapter.i2c.0                    : i2c                   : HomeAutomation                           - disabled
                      system.adapter.ical.0                   : ical                  : HomeAutomation                           -  enabled
                      system.adapter.icons-icons8.0           : icons-icons8          : HomeAutomation                           -  enabled
                      system.adapter.icons-material-png.0     : icons-material-png    : HomeAutomation                           -  enabled
                      system.adapter.icons-mfd-png.0          : icons-mfd-png         : HomeAutomation                           -  enabled
                      system.adapter.icons-mfd-svg.0          : icons-mfd-svg         : HomeAutomation                           -  enabled
                      system.adapter.icons-open-icon-library-png.0: icons-open-icon-library-png: HomeAutomation                           -  enabled
                    + system.adapter.influxdb.0               : influxdb              : HomeAutomation                           -  enabled, port: 8086
                    + system.adapter.info.0                   : info                  : HomeAutomation                           -  enabled
                    + system.adapter.iot.0                    : iot                   : HomeAutomation                           -  enabled
                    + system.adapter.jarvis.0                 : jarvis                : HomeAutomation                           -  enabled
                    + system.adapter.javascript.0             : javascript            : HomeAutomation                           -  enabled
                      system.adapter.lgtv.0                   : lgtv                  : HomeAutomation                           - disabled
                    + system.adapter.modbus.0                 : modbus                : HomeAutomation                           -  enabled
                      system.adapter.modbus.1                 : modbus                : HomeAutomation                           - disabled
                    + system.adapter.modbus.2                 : modbus                : HomeAutomation                           -  enabled
                    + system.adapter.mqtt.0                   : mqtt                  : HomeAutomation                           -  enabled, port: 1885, bind: 0.0.0.0
                    + system.adapter.net-tools.0              : net-tools             : HomeAutomation                           -  enabled
                    + system.adapter.node-red.0               : node-red              : HomeAutomation                           -  enabled, port: 1880, bind: 0.0.0.0
                      system.adapter.paw.0                    : paw                   : HomeAutomation                           - disabled, port: 2323
                      system.adapter.ping.0                   : ping                  : HomeAutomation                           - disabled
                      system.adapter.pushsafer.0              : pushsafer             : HomeAutomation                           - disabled
                    + system.adapter.rpi2.0                   : rpi2                  : HomeAutomation                           -  enabled
                      system.adapter.samsung.0                : samsung               : HomeAutomation                           - disabled
                      system.adapter.samsung_tizen.0          : samsung_tizen         : HomeAutomation                           - disabled, port: 8002
                    + system.adapter.sayit.0                  : sayit                 : HomeAutomation                           -  enabled, port: 0
                      system.adapter.schoolfree.0             : schoolfree            : HomeAutomation                           -  enabled
                      system.adapter.shuttercontrol.0         : shuttercontrol        : HomeAutomation                           - disabled
                    + system.adapter.sonoff.0                 : sonoff                : HomeAutomation                           -  enabled, port: 1883, bind: 0.0.0.0
                      system.adapter.speedport.0              : speedport             : HomeAutomation                           - disabled
                    + system.adapter.tankerkoenig.0           : tankerkoenig          : HomeAutomation                           -  enabled
                    + system.adapter.telegram.0               : telegram              : HomeAutomation                           -  enabled, port: 8443, bind: 0.0.0.0
                    + system.adapter.text2command.0           : text2command          : HomeAutomation                           -  enabled
                      system.adapter.trashschedule.0          : trashschedule         : HomeAutomation                           - disabled
                    + system.adapter.tuya.0                   : tuya                  : HomeAutomation                           -  enabled
                    + system.adapter.virtualpowermeter.0      : virtualpowermeter     : HomeAutomation                           -  enabled
                      system.adapter.vis-bars.0               : vis-bars              : HomeAutomation                           -  enabled
                      system.adapter.vis-canvas-gauges.0      : vis-canvas-gauges     : HomeAutomation                           -  enabled
                      system.adapter.vis-colorpicker.0        : vis-colorpicker       : HomeAutomation                           -  enabled
                      system.adapter.vis-fancyswitch.0        : vis-fancyswitch       : HomeAutomation                           -  enabled
                      system.adapter.vis-google-fonts.0       : vis-google-fonts      : HomeAutomation                           -  enabled
                      system.adapter.vis-history.0            : vis-history           : HomeAutomation                           -  enabled
                      system.adapter.vis-hqwidgets.0          : vis-hqwidgets         : HomeAutomation                           -  enabled
                      system.adapter.vis-icontwo.0            : vis-icontwo           : HomeAutomation                           -  enabled
                    + system.adapter.vis-inventwo.0           : vis-inventwo          : HomeAutomation                           -  enabled
                      system.adapter.vis-jqui-mfd.0           : vis-jqui-mfd          : HomeAutomation                           -  enabled
                      system.adapter.vis-justgage.0           : vis-justgage          : HomeAutomation                           -  enabled
                      system.adapter.vis-keyboard.0           : vis-keyboard          : HomeAutomation                           -  enabled
                      system.adapter.vis-lcars.0              : vis-lcars             : HomeAutomation                           -  enabled
                      system.adapter.vis-map.0                : vis-map               : HomeAutomation                           -  enabled
                      system.adapter.vis-material-advanced.0  : vis-material-advanced : HomeAutomation                           -  enabled
                      system.adapter.vis-metro.0              : vis-metro             : HomeAutomation                           -  enabled
                      system.adapter.vis-players.0            : vis-players           : HomeAutomation                           -  enabled
                      system.adapter.vis-plumb.0              : vis-plumb             : HomeAutomation                           -  enabled
                      system.adapter.vis-rgraph.0             : vis-rgraph            : HomeAutomation                           -  enabled
                      system.adapter.vis.0                    : vis                   : HomeAutomation                           -  enabled
                    + system.adapter.web.0                    : web                   : HomeAutomation                           -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                      system.adapter.whatsapp-cmb.0           : whatsapp-cmb          : HomeAutomation                           - disabled
                      system.adapter.whatsapp-cmb.1           : whatsapp-cmb          : HomeAutomation                           - disabled
                      system.adapter.wifilight.0              : wifilight             : HomeAutomation                           - disabled
                    + system.adapter.yahka.0                  : yahka                 : HomeAutomation                           -  enabled
                      system.adapter.yahka.1                  : yahka                 : HomeAutomation                           - disabled
                    + instance is alive
                    pi@HomeAutomation:~ $ iobroker diag
                    iobroker [command]
                    Commands:
                      iobroker setup                                               Setup ioBroker
                      iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
                      iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
                      iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
                      iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
                      iobroker info                                                Shows the host info
                      iobroker logs [<adapter>]                                    Monitor log
                      iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
                      iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
                      iobroker rebuild [<module>]                                  Rebuild all native modules or path
                      iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
                      iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
                      iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
                      iobroker update [<repositoryUrl>]                            Update repository and list adapters
                      iobroker upgrade                                             Upgrade management
                      iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
                      iobroker object                                              Object management  [aliases: o]
                      iobroker state                                               State management  [aliases: s]
                      iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
                      iobroker list <type> [<filter>]                              List all entries, like objects
                      iobroker chmod <mode> <file>                                 Change file rights
                      iobroker chown <user> <group> <file>                         Change file ownership
                      iobroker touch <file>                                        Touch file
                      iobroker rm <file>                                           Remove file
                      iobroker file                                                File management
                      iobroker user                                                User commands
                      iobroker group                                               group management
                      iobroker host <hostname>                                     Set host to given hostname
                      iobroker set <adapter>.<instance>                            Change settings of adapter config
                      iobroker license <license.file or license.text>              Update license by given file
                      iobroker cert                                                Certificate management
                      iobroker clean <yes>                                         Clears all objects and states
                      iobroker backup                                              Create backup
                      iobroker restore <backup name or path>                       Restore a specified backup
                      iobroker validate <backup name or path>                      Validate a specified backup
                      iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
                      iobroker repo [<name>]                                       Show repo information
                      iobroker uuid                                                Show uuid of the installation  [aliases: id]
                      iobroker unsetup                                             Reset license, installation secret and language
                      iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
                      iobroker multihost                                           Multihost management
                      iobroker compact                                             compact group management
                      iobroker plugin                                              Plugin management
                      iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
                    Options:
                      --help  Show help  [boolean]
                    ich habe keine ideen mehr was es sein könnte.
                    danke schn mal im voraus für eure Hilfe.
                    • P PhoenixCR
                      + instance is alive
                      iobroker [command]
                      Commands:
                      Options:
                      @phoenixcr
                      iobroker stop
                      iobroker fix
                      iobroker start
                      iobroker diag
                      P 1 Antwort Letzte Antwort
                        @phoenixcr
                        iobroker stop
                        iobroker fix
                        iobroker start
                        iobroker diag
                        PhoenixCR
                        schrieb am zuletzt editiert von PhoenixCR
                        Hallo Thomas, danke, es hat funktioniert.
                        Anbei das Ergebnis.
                        			v.2022-12-13
                        Operatingsystem: 	Raspbian GNU/Linux 10 (buster)
                        Installation: 		Native
                        Timezone: 		Europe/Berlin
                        User-ID: 		1000
                        X-Server: 		true
                        Pending OS-Updates: 	74
                        Nodejs-Installation: 	/usr/bin/nodejs 	v16.17.1
                        			/usr/bin/node 		v16.17.1
                        			/usr/bin/npm 		8.19.2
                        ioBroker Core: 		js-controller 		4.0.23
                        			admin 			6.3.5
                        ioBroker Status: 	iobroker is running on this host.
                        Objects type: jsonl
                        States  type: jsonl
                        Pending iob updates: 	0
                        Objects: 		6537
                        States: 		5071
                        Size of iob-Database:
                        8.8M	/opt/iobroker/iobroker-data/objects.jsonl
                        6.7M	/opt/iobroker/iobroker-data/objects.json.migrated
                        6.7M	/opt/iobroker/iobroker-data/objects.json.bak.migrated
                        2.2M	/opt/iobroker/iobroker-data/states.jsonl
                        816K	/opt/iobroker/iobroker-data/states.json.migrated
                        816K	/opt/iobroker/iobroker-data/states.json.bak.migrated
                        0	/opt/iobroker/iobroker-data/states.json.broken
                        ====================== END OF SUMMARY ==================
                        P Thomas BraunT 2 Antworten Letzte Antwort
                        • P PhoenixCR
                          Anbei das Ergebnis.
                          			v.2022-12-13
                          User-ID: 		1000
                          X-Server: 		true
                          			/usr/bin/npm 		8.19.2
                          			admin 			6.3.5
                          Objects type: jsonl
                          States  type: jsonl
                          Objects: 		6537
                          States: 		5071
                          PhoenixCR
                          @phoenixcr
                          The following checks may give hints to potential malconfigurations or errors, please post them in our forum:
                          Skript v.2022-12-13
                          *** BASE SYSTEM ***
                          Docker: 	false
                          Description:	Raspbian GNU/Linux 10 (buster)
                          Release:	10
                          Codename:	buster
                          PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
                          VERSION_ID="10"
                          VERSION="10 (buster)"
                          VERSION_CODENAME=buster
                          ID=raspbian
                          ID_LIKE=debian
                           10:39:03 up  2:24,  2 users,  load average: 2.11, 2.56, 2.59
                          CPU threads: 4
                          Tue Dec 27 09:39:03 UTC 2022
                          Tue Dec 27 10:39:03 CET 2022
                          CET +0100
                          Europe/Berlin
                          pi
                          /home/pi
                          pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                          X-Server: 	true
                          Desktop: 	LXDE-pi
                          Terminal: 	x11
                          *** MEMORY ***
                          Mem:           7.9G        1.7G        4.6G        125M        1.7G        6.3G
                          Swap:           99M          0B         99M
                          Total:         8.0G        1.7G        4.7G
                                   7897 M total memory
                                   1677 M used memory
                                    526 M active memory
                                   2540 M inactive memory
                                   4551 M free memory
                                    240 M buffer memory
                                   1427 M swap cache
                                     99 M total swap
                                      0 M used swap
                                     99 M free swap
                          *** FILESYSTEM ***
                          /dev/root      ext4      118G   13G  101G  11% /
                          devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
                          tmpfs          tmpfs     3.9G  1.7M  3.9G   1% /dev/shm
                          tmpfs          tmpfs     3.9G   74M  3.8G   2% /run
                          tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
                          /dev/sda1      vfat      253M   49M  204M  20% /boot
                          tmpfs          tmpfs     790M   12K  790M   1% /run/user/1000
                          /                     /dev/sda2  ext4            rw,noatime
                          |-/sys/fs/bpf         none       bpf             rw,nosuid,nodev,noexec,relatime,mode=700
                          |-/run/user/1000/gvfs gvfsd-fuse fuse.gvfsd-fuse rw,nosuid,nodev,relatime,user_id=1000,group_id=1000
                          `-/boot               /dev/sda1  vfat            rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
                          /var:
                          2.6G	/var/
                          1.1G	/var/cache/apt/archives
                          1.1G	/var/cache/apt
                          1.1G	/var/cache
                          1002M	/var/log
                          1.8G	/opt/iobroker/backups/
                          786M	/opt/iobroker/iobroker-data/
                          509M	/opt/iobroker/iobroker-data/files
                          92M	/opt/iobroker/iobroker-data/node-red
                          91M	/opt/iobroker/iobroker-data/node-red/node_modules
                          86M	/opt/iobroker/iobroker-data/backup-objects
                          33M	/opt/iobroker/iobroker-data/files/devices.admin/static/js/main.10538062.js.map
                          9.7M	/opt/iobroker/iobroker-data/files/text2command.admin/static/js/main.bbfeb1bf.js.map
                          9.1M	/opt/iobroker/iobroker-data/files/echarts.admin/static/js/2.bbf74d5f.chunk.js.map
                          8.9M	/opt/iobroker/iobroker-data/files/echarts/static/js/2.3d2d025f.chunk.js.map
                          /usr/bin/npm 		8.19.2
                          nodejs:
                            Installed: 16.17.1-deb-1nodesource1
                            Version table:
                                  500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                           *** 16.17.1-deb-1nodesource1 100
                               10.24.0~dfsg-1~deb10u2 500
                          ioBroker Status
                          Objects type: jsonl
                          States  type: jsonl
                          admin: 		6.3.5
                          Adapters from github: 	3
                          + system.adapter.admin.0                  : admin                 : HomeAutomation                           -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                          Stable (default): http://download.iobroker.net/sources-dist.json
                          Beta (latest) : http://download.iobroker.net/sources-dist-latest.json
                          ioBroker-Instances
                          Adapter    "device-reminder": 1.2.9  , installed 1.2.9
                          Adapter    "devices"      : 1.1.2    , installed 1.1.2
                          Adapter    "ds18b20"      : 1.6.1    , installed 1.6.1
                          Adapter    "echarts"      : 1.0.12   , installed 1.0.12
                          Adapter    "email"        : 1.1.4    , installed 1.1.4
                          Adapter    "feiertage"    : 1.1.0    , installed 1.1.0
                          Adapter    "flot"         : 1.11.0   , installed 1.11.0
                          Adapter    "fullybrowser" : 2.1.2    , installed 2.1.2
                          Adapter    "heatingcontrol": 2.9.3   , installed 2.9.3
                          Adapter    "history"      : 2.2.4    , installed 2.2.4
                          Adapter    "i2c"          : 1.2.1    , installed 1.2.1
                          Adapter    "icons-open-icon-library-png": 0.1.2, installed 0.1.2
                          Adapter    "info"         : 1.9.19   , installed 1.9.19
                          Adapter    "iot"          : 1.11.9   , installed 1.11.9
                          Adapter    "jarvis"       : 3.1.2    , installed 3.1.2
                          Adapter    "modbus"       : 5.0.11   , installed 5.0.11
                          Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
                          Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
                          Adapter    "node-red"     : 4.0.0    , installed 4.0.0
                          Adapter    "paw"          : 0.3.2    , installed 0.3.2
                          Adapter    "places"       : 1.1.2    , installed 1.1.2
                          Adapter    "psa"          : 0.0.11   , installed 0.0.11
                          Adapter    "pushsafer"    : 1.0.3    , installed 1.0.3
                          Adapter    "samsung"      : 0.5.11   , installed 0.5.11
                          Adapter    "sayit"        : 1.12.3   , installed 1.12.3
                          Adapter    "schoolfree"   : 1.0.1    , installed 1.0.1
                          Adapter    "shuttercontrol": 1.4.18  , installed 1.4.18
                          Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
                          Adapter    "tankerkoenig" : 3.1.0    , installed 3.1.0
                          Adapter    "text2command" : 2.3.0    , installed 2.3.0
                          Adapter    "tuya"         : 3.11.1   , installed 3.11.1
                          Adapter    "virtualpowermeter": 1.4.6, installed 1.4.6
                          Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
                          Adapter    "vis-keyboard" : 0.0.2    , installed 0.0.2
                          Adapter    "vis-lcars"    : 1.0.4    , installed 1.0.4
                          Adapter    "vis-map"      : 1.0.4    , installed 1.0.4
                          Adapter    "vis-material-advanced": 1.7.2, installed 1.7.2
                          Adapter    "vis-players"  : 0.1.6    , installed 0.1.6
                          Adapter    "whatsapp-cmb" : 0.2.3    , installed 0.2.3
                          Adapter    "wifilight"    : 1.1.4    , installed 1.1.4
                          Adapter    "yahka"        : 0.13.1   , installed 0.13.1
                          Objects and States
                          Objects: 	6537
                          States: 	5070
                          E: Repository 'https://packages.grafana.com/oss/deb stable InRelease' changed its 'Origin' value from 'grafana stable' to '. stable'
                          E: Repository 'https://packages.grafana.com/oss/deb stable InRelease' changed its 'Label' value from 'grafana stable' to '. stable'
                          Pending Updates: 74
                          tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       1527171    25234/io.jarvis.0
                          tcp        0      0 0.0.0.0:53              0.0.0.0:*               LISTEN      0          14319      577/dnsmasq
                          tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          17752      552/sshd
                          tcp        0      0 127.0.0.1:631           0.0.0.0:*               LISTEN      0          15673      372/cupsd
                          tcp        0      0 0.0.0.0:1880            0.0.0.0:*               LISTEN      1001       1518166    21372/node-red
                          tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        14331      499/influxd
                          tcp        0      0 0.0.0.0:1883            0.0.0.0:*               LISTEN      1001       1518129    22389/io.sonoff.0
                          tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       1514484    22107/io.mqtt.0
                          tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       1514485    22107/io.mqtt.0
                          tcp        0      0 0.0.0.0:7070            0.0.0.0:*               LISTEN      0          17800      514/anydesk
                          tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       1507075    19141/iobroker.js-c
                          tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       1507068    19141/iobroker.js-c
                          tcp        0      0 0.0.0.0:35789           0.0.0.0:*               LISTEN      0          35725      514/anydesk
                          tcp6       0      0 :::8081                 :::*                    LISTEN      1001       1509661    19484/io.admin.0
                          tcp6       0      0 :::8082                 :::*                    LISTEN      1001       1532606    26604/io.web.0
                          tcp6       0      0 :::46163                :::*                    LISTEN      1001       1516423    21372/node-red
                          tcp6       0      0 :::53                   :::*                    LISTEN      0          14321      577/dnsmasq
                          tcp6       0      0 :::8086                 :::*                    LISTEN      999        19382      499/influxd
                          tcp6       0      0 :::22                   :::*                    LISTEN      0          17754      552/sshd
                          tcp6       0      0 ::1:631                 :::*                    LISTEN      0          15672      372/cupsd
                          tcp6       0      0 :::3000                 :::*                    LISTEN      117        20679      488/grafana-server
                          tcp6       0      0 :::45665                :::*                    LISTEN      1001       1518656    21372/node-red
                          udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       1518873    22710/io.tuya.0
                          udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       1518874    22710/io.tuya.0
                          udp        0      0 0.0.0.0:53              0.0.0.0:*                           0          14318      577/dnsmasq
                          udp     2624      0 0.0.0.0:68              0.0.0.0:*                           0          20843      416/dhcpcd
                          udp        0      0 0.0.0.0:631             0.0.0.0:*                           0          18488      508/cups-browsed
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1521559    24181/io.chromecast
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1516452    21372/node-red
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       1516449    21372/node-red
                          udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        15678      410/avahi-daemon: r
                          udp        0      0 0.0.0.0:50001           0.0.0.0:*                           0          22414      514/anydesk
                          udp        0      0 0.0.0.0:58711           0.0.0.0:*                           108        15680      410/avahi-daemon: r
                          udp6       0      0 :::58809                :::*                                108        15681      410/avahi-daemon: r
                          udp6       0      0 :::546                  :::*                                0          21468      416/dhcpcd
                          udp6       0      0 :::53                   :::*                                0          14320      577/dnsmasq
                          udp6       0      0 :::5353                 :::*                                108        15679      410/avahi-daemon: r
                                             Mark until here for C&P
                          • P PhoenixCR
                            Anbei das Ergebnis.
                            			v.2022-12-13
                            User-ID: 		1000
                            X-Server: 		true
                            			/usr/bin/npm 		8.19.2
                            			admin 			6.3.5
                            Objects type: jsonl
                            States  type: jsonl
                            Objects: 		6537
                            States: 		5071
                            @phoenixcr sagte in Admin startet nicht mehr:
                            buster
                            Buster hat sein End Of Life erreicht. Installier da das 'Bullseye'-Release.
                            Und zwar dann OHNE Desktop.
                              buster
                              PhoenixCR
                              ich brauche aber das Desktop, zwecks Fernzugriff.
                              Glaubst du, das ist das Problem der abstürzte?
                              Danke!
                              • P PhoenixCR
                                Danke!
                                Macht man per SSH und Kommandozeile. OHNE DESKTOP!!
                                J P 2 Antworten Letzte Antwort
                                  jhg
                                  Ich hänge mich hier mal mit einer Frage dran, da es nicht lohnt dafür einen neuen Thread zu öffnen.
                                  Nachdem ich meinen ioBroker auf neue Hardware umgezogen habe, hat der Admin adapter nun die Nummer 2.
                                  Also admin.2 und nicht admin.0.
                                  Kann das irgendwann mal Probleme machen? Sollte ich das ändern?
                                    PhoenixCR
                                    erledigt, ohne Desktop.
                                    Selber Verhältnis.
                                    In log, steht nichts Besonderes
                                    fehlt sogar der Export Knopf
                                    • P PhoenixCR
                                      Selber Verhältnis.
                                      @phoenixcr
                                      Und
                                      iobroker diag
                                      sagt nun?
                                        @phoenixcr
                                        Und
                                        iobroker diag
                                        sagt nun?
                                        PhoenixCR
                                        @thomas-braun sagte in Admin startet nicht mehr:
                                        iobroker diag
                                        Skript v.2022-12-13
                                        *** BASE SYSTEM ***
                                        Docker:         false
                                        Release:        11
                                        Codename:       bullseye
                                        VERSION_ID="11"
                                        ID=raspbian
                                        ID_LIKE=debian
                                         19:57:59 up  4:13,  1 user,  load average: 1.41, 1.63, 2.53
                                        CPU threads: 4
                                        Tue Dec 27 19:57:59 UTC 2022
                                        Tue Dec 27 19:57:59 GMT 2022
                                        GMT +0000
                                        Europe/London
                                        chris
                                        /home/chris
                                        chris adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                                        X-Server:       false
                                        Desktop:
                                        Terminal:       tty
                                        *** MEMORY ***
                                        Mem:            7.9G        1.5G        4.4G        0.0K        2.0G        6.4G
                                        Swap:            99M        1.0M         98M
                                        Total:          8.0G        1.5G        4.5G
                                                 7897 M total memory
                                                 1490 M used memory
                                                  701 M active memory
                                                 2533 M inactive memory
                                                 4388 M free memory
                                                  151 M buffer memory
                                                 1867 M swap cache
                                                   99 M total swap
                                                    1 M used swap
                                                   98 M free swap
                                        *** FILESYSTEM ***
                                        /dev/root      ext4      118G  5.0G  108G   5% /
                                        tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
                                        tmpfs          tmpfs     1.6G  1.2M  1.6G   1% /run
                                        /dev/sda1      vfat      255M   50M  206M  20% /boot
                                        tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
                                        /var:
                                        542M    /var/
                                        282M    /var/cache
                                        276M    /var/cache/apt
                                        212M    /var/cache/apt/archives
                                        98M     /var/lib
                                        240M    /opt/iobroker/backups/
                                        118M    /opt/iobroker/backups/Influxdb
                                        529M    /opt/iobroker/iobroker-data/
                                        428M    /opt/iobroker/iobroker-data/files
                                        79M     /opt/iobroker/iobroker-data/node-red/node_modules
                                        78M     /opt/iobroker/iobroker-data/files/icons-open-icon-library-png
                                        17M     /opt/iobroker/iobroker-data/objects.jsonl
                                        /usr/bin/npm            8.19.3
                                        nodejs:
                                          Version table:
                                        ioBroker Status
                                        Objects type: jsonl
                                        States  type: jsonl
                                        admin:          6.3.5
                                        Adapters from github:   2
                                        + system.adapter.admin.0                  : admin                 : homeautomationcretu                      -  enabled, port: 8081, bind: 0.0.0.0, run as: admin
                                        + system.adapter.mqtt.0                   : mqtt                  : homeautomationcretu                      -  enabled, port: 1885, bind: 0.0.0.0
                                        + system.adapter.sayit.0                  : sayit                 : homeautomationcretu                      -  enabled, port: 0
                                        + system.adapter.telegram.0               : telegram              : homeautomationcretu                      -  enabled, port: 8443, bind: 0.0.0.0
                                        + system.adapter.web.0                    : web                   : homeautomationcretu                      -  enabled, port: 8082, bind: 0.0.0.0, run as: admin
                                        ioBroker-Instances
                                        Objects and States
                                        Objects:        6463
                                        States:         5008
                                        Hit:3 https://repos.influxdata.com/debian bullseye InRelease
                                        Hit:4 https://apt.grafana.com stable InRelease
                                        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                                        Pending Updates: 0
                                        tcp        0      0 0.0.0.0:8400            0.0.0.0:*               LISTEN      1001       45447      10525/io.jarvis.0
                                        tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      0          11762      541/sshd: /usr/sbin
                                        tcp        0      0 127.0.0.1:8088          0.0.0.0:*               LISTEN      999        140894     26161/influxd
                                        tcp        0      0 0.0.0.0:1885            0.0.0.0:*               LISTEN      1001       44880      11581/io.mqtt.0
                                        tcp        0      0 0.0.0.0:1886            0.0.0.0:*               LISTEN      1001       44881      11581/io.mqtt.0
                                        tcp        0      0 127.0.0.1:9000          0.0.0.0:*               LISTEN      1001       16053      1795/iobroker.js-co
                                        tcp        0      0 127.0.0.1:9001          0.0.0.0:*               LISTEN      1001       16046      1795/iobroker.js-co
                                        tcp6       0      0 :::22                   :::*                    LISTEN      0          11764      541/sshd: /usr/sbin
                                        tcp6       0      0 :::8081                 :::*                    LISTEN      1001       16122      1823/io.admin.0
                                        tcp6       0      0 :::8082                 :::*                    LISTEN      1001       30720      7826/io.web.0
                                        tcp6       0      0 :::8086                 :::*                    LISTEN      999        141933     26161/influxd
                                        tcp6       0      0 :::3000                 :::*                    LISTEN      110        77925      17659/grafana-serve
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           1001       33946      7993/io.chromecast.
                                        udp        0      0 0.0.0.0:5353            0.0.0.0:*                           108        11593      403/avahi-daemon: r
                                        udp        0      0 0.0.0.0:6666            0.0.0.0:*                           1001       32188      7852/io.tuya.0
                                        udp        0      0 0.0.0.0:6667            0.0.0.0:*                           1001       32189      7852/io.tuya.0
                                        udp        0      0 0.0.0.0:43026           0.0.0.0:*                           108        11595      403/avahi-daemon: r
                                        udp        0      0 0.0.0.0:68              0.0.0.0:*                           0          14566      783/dhcpcd
                                        udp6       0      0 :::5353                 :::*                                108        11594      403/avahi-daemon: r
                                        udp6       0      0 :::56192                :::*                                108        11596      403/avahi-daemon: r
                                        udp6       0      0 :::546                  :::*                                0          14628      783/dhcpcd
                                        Press any key for a summary
                                        • P PhoenixCR
                                          iobroker diag
                                          Skript v.2022-12-13
                                          *** BASE SYSTEM ***
                                          Docker:         false
                                          Release:        11
                                          Codename:       bullseye
                                          VERSION_ID="11"
                                          ID=raspbian
                                          ID_LIKE=debian
                                          CPU threads: 4
                                          GMT +0000
                                          Europe/London
                                          chris
                                          /home/chris
                                          X-Server:       false
                                          Desktop:
                                          Terminal:       tty
                                          *** MEMORY ***
                                          Swap:            99M        1.0M         98M
                                                   7897 M total memory
                                                   1490 M used memory
                                                    701 M active memory
                                                   4388 M free memory
                                                    151 M buffer memory
                                                   1867 M swap cache
                                                     99 M total swap
                                                      1 M used swap
                                                     98 M free swap
                                          *** FILESYSTEM ***
                                          /var:
                                          542M    /var/
                                          282M    /var/cache
                                          276M    /var/cache/apt
                                          98M     /var/lib
                                          /usr/bin/npm            8.19.3
                                          nodejs:
                                            Version table:
                                          ioBroker Status
                                          Objects type: jsonl
                                          States  type: jsonl
                                          admin:          6.3.5
                                          ioBroker-Instances
                                          Objects and States
                                          Objects:        6463
                                          States:         5008
                                          Pending Updates: 0
                                          @phoenixcr
                                          Setz die Zeitzone richtig.
                                          Problem behoben?
