  4. node 16.19.0 installieren klappt nicht
    5.6k
12 Beiträge 3 Kommentatoren 670 Aufrufe 3 Beobachtet
  • bahnuhrB bahnuhr
    in info wird mir eine neue V angezeigt.
    Bei dem curl Befehl kommt aber die ..19 nicht. Folgende Info gibt die konsole aus:
    dieter@iobroker:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
    ## Installing the NodeSource Node.js 16.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
    OK:2 http://deb.debian.org/debian bullseye InRelease
    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
    OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    ## Confirming "bullseye" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/bullseye/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    OK:1 http://deb.debian.org/debian bullseye InRelease
    OK:2 http://deb.debian.org/debian bullseye-updates InRelease
    OK:3 http://security.debian.org/debian-security bullseye-security InRelease
    ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    Was soll man nun machen ?
    kommt die ..19 noch irgendwie ?
    crunchipC Abwesend
    crunchipC Abwesend
    @bahnuhr innerhalb einer Major Version reicht ein sudo apt update && sudo apt upgrade
    des weiteren kann es sein, das der Info Adapter noch nicht aktualisiert hat, daher noch eine veraltete Version steht
    prüfe doch auf der Konsole
    which nodejs node npm && nodejs -v && node -v && npm -v
    bahnuhrB 2 Antworten Letzte Antwort
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @crunchip sagte in node 16.19.0 installieren klappt nicht:
      hab das immer mit dem curl gemacht.
      Aber jetzt mal deinen Befehl probiert.
      In der Konsole war etliches ersichtlich.
      Geändert hat es aber nicht.
      Es ist immer noch 16.18.1
      dieter@iobroker:~$ sudo apt update && sudo apt upgrade
      [sudo] Passwort für dieter:
      Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
      Paketaktualisierung (Upgrade) wird berechnet… Fertig
      Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
        linux-image-5.10.0-13-amd64
      Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
      Die folgenden NEUEN Pakete werden installiert:
        linux-image-5.10.0-20-amd64
        linux-image-amd64
      1 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
      Es müssen 55,5 MB an Archiven heruntergeladen werden.
      Nach dieser Operation werden 318 MB Plattenplatz zusätzlich benutzt.
      Möchten Sie fortfahren? [J/n] J
      Holen:1 http://deb.debian.org/debian bullseye/main amd64 linux-image-5.10.0-20-amd64 amd64 5.10.158-2 [55,5 MB]
      Holen:2 http://deb.debian.org/debian bullseye/main amd64 linux-image-amd64 amd64 5.10.158-2 [1.484 B]
      Es wurden 55,5 MB in 6 s geholt (9.722 kB/s).
      Changelogs werden gelesen... Fertig
      Vormals nicht ausgewähltes Paket linux-image-5.10.0-20-amd64 wird gewählt.
      (Lese Datenbank ... 57640 Dateien und Verzeichnisse sind derzeit installiert.)
      Vorbereitung zum Entpacken von .../linux-image-5.10.0-20-amd64_5.10.158-2_amd64.deb ...
      Entpacken von linux-image-5.10.0-20-amd64 (5.10.158-2) ...
      Vorbereitung zum Entpacken von .../linux-image-amd64_5.10.158-2_amd64.deb ...
      Entpacken von linux-image-amd64 (5.10.158-2) über (5.10.140-1) ...
      linux-image-5.10.0-20-amd64 (5.10.158-2) wird eingerichtet ...
      I: /vmlinuz.old is now a symlink to boot/vmlinuz-5.10.0-18-amd64
      I: /initrd.img.old is now a symlink to boot/initrd.img-5.10.0-18-amd64
      I: /vmlinuz is now a symlink to boot/vmlinuz-5.10.0-20-amd64
      I: /initrd.img is now a symlink to boot/initrd.img-5.10.0-20-amd64
      /etc/kernel/postinst.d/initramfs-tools:
      update-initramfs: Generating /boot/initrd.img-5.10.0-20-amd64
      /etc/kernel/postinst.d/zz-update-grub:
      Generating grub configuration file ...
      Found linux image: /boot/vmlinuz-5.10.0-20-amd64
      Found initrd image: /boot/initrd.img-5.10.0-20-amd64
      Found linux image: /boot/vmlinuz-5.10.0-18-amd64
      Found initrd image: /boot/initrd.img-5.10.0-18-amd64
      Found linux image: /boot/vmlinuz-5.10.0-16-amd64
      Found initrd image: /boot/initrd.img-5.10.0-16-amd64
      Found linux image: /boot/vmlinuz-5.10.0-13-amd64
      Found initrd image: /boot/initrd.img-5.10.0-13-amd64
      Warning: os-prober will be executed to detect other bootable partitions.
      Its output will be used to detect bootable binaries on them and create new boot entries.
      done
      linux-image-amd64 (5.10.158-2) wird eingerichtet ...
      dieter@iobroker:~$ node -v
      v16.18.1
      dieter@iobroker:~$
      Danke.
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        dieter@iobroker:~$ which nodejs node npm && nodejs -v && node -v && npm -v
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.18.1
        v16.18.1
        8.19.2
        dieter@iobroker:~$
        Danke.
        • bahnuhrB bahnuhr
            linux-image-amd64
          done
          v16.18.1
          dieter@iobroker:~$
          crunchipC Abwesend
          crunchipC Abwesend
          @bahnuhr sagte in node 16.19.0 installieren klappt nicht:
          siehe edit: auf Konsole prüfen, nicht auf den Info Adapter verlassen, der zeigt ggf erst richtig an, wenn du den iobroker neu startest
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            Ja, das ist klar.
            Habe ja auch auf der konsole geprüft.
            Danke.
            • bahnuhrB bahnuhr
              Ja, das ist klar.
              crunchipC Abwesend
              crunchipC Abwesend
              @bahnuhr stop, ist wenn man noch im Halbschlaf ist😁
              Thema war doch erst hier, moment
              siehe https://forum.iobroker.net/topic/61014/node-18-1-vs-19-0
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                @crunchip
                @Thomas-Braun hatte hier geschrieben:
                https://forum.iobroker.net/topic/61155/bei-npm-und-node-js-immer-super-aktuell-sein/23?page=2
                dass nur die 16.18.1. rein kommt.
                Wenn ich das richtig verstehe, geht wohl die 16.19.0 nicht.
                Danke.
                • bahnuhrB bahnuhr
                  @crunchip
                  crunchipC Abwesend
                  crunchipC Abwesend
                  @bahnuhr ja, siehe edit eins zuvor
                    bahnuhrB Online
                    bahnuhrB Online
                    bahnuhr
                    @crunchip
                    ok,, abwarten.
                    Aber nochmal für mich:
                    Ist der curl Befehl falsch ?
                    Ist dein Befehl ausreichend ?
                    Danke.
                    crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                    • bahnuhrB bahnuhr
                      @crunchip
                      ok,, abwarten.
                      crunchipC Abwesend
                      crunchipC Abwesend
                      @bahnuhr ein minor update(innerhalb einer Version) so wie ich geschrieben hab, ein Wechsel einer major Version, mittels curl
                      • bahnuhrB bahnuhr
                        @crunchip
                        ok,, abwarten.
                        @bahnuhr
                        Der Befehl mit cURL dient lediglich dazu EINMAL das nodesource-Repository im Paketmanager bekannt zu machen. Im weiteren dann ganz simpel per
                        sudo apt update
                        sudo apt full-upgrade
                        Was macht ihr denn da immer für Harakiri...???
                        Siehe auch hier:
                        https://forum.iobroker.net/topic/61165/node-js-update-information/4?_=1671434060743
                        Und in meiner Signatur steht's auch drin...
