  4. node 16.19.0 installieren klappt nicht
    5.6k
12 Beiträge 3 Kommentatoren 670 Aufrufe 3 Beobachtet
  • bahnuhrB Online
    bahnuhrB Online
    bahnuhr
    in info wird mir eine neue V angezeigt.
    Bei dem curl Befehl kommt aber die ..19 nicht. Folgende Info gibt die konsole aus:
    dieter@iobroker:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
    ## Installing the NodeSource Node.js 16.x repo...
    ## Populating apt-get cache...
    + apt-get update
    OK:1 http://security.debian.org/debian-security bullseye-security InRelease
    OK:2 http://deb.debian.org/debian bullseye InRelease
    OK:3 http://deb.debian.org/debian bullseye-updates InRelease
    OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
    ## Confirming "bullseye" is supported...
    + curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/bullseye/Release'
    ## Adding the NodeSource signing key to your keyring...
    + curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg >/dev/null
    ## Creating apt sources list file for the NodeSource Node.js 16.x repo...
    + echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' > /etc/apt/sources.list.d/nodesource.list
    + echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' >> /etc/apt/sources.list.d/nodesource.list
    ## Running `apt-get update` for you...
    + apt-get update
    OK:1 http://deb.debian.org/debian bullseye InRelease
    OK:2 http://deb.debian.org/debian bullseye-updates InRelease
    OK:3 http://security.debian.org/debian-security bullseye-security InRelease
    ## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
    ## You may also need development tools to build native addons:
         sudo apt-get install gcc g++ make
    ## To install the Yarn package manager, run:
         curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg >/dev/null
         echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
         sudo apt-get update && sudo apt-get install yarn
    Was soll man nun machen ?
    kommt die ..19 noch irgendwie ?
    Danke.
    • bahnuhrB bahnuhr
      + apt-get update
      + apt-get update
      crunchipC Abwesend
      crunchipC Abwesend
      @bahnuhr innerhalb einer Major Version reicht ein sudo apt update && sudo apt upgrade
      des weiteren kann es sein, das der Info Adapter noch nicht aktualisiert hat, daher noch eine veraltete Version steht
      prüfe doch auf der Konsole
      which nodejs node npm && nodejs -v && node -v && npm -v
      bahnuhrB 2 Antworten Letzte Antwort
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @crunchip sagte in node 16.19.0 installieren klappt nicht:
        hab das immer mit dem curl gemacht.
        Aber jetzt mal deinen Befehl probiert.
        In der Konsole war etliches ersichtlich.
        Geändert hat es aber nicht.
        Es ist immer noch 16.18.1
        dieter@iobroker:~$ sudo apt update && sudo apt upgrade
        [sudo] Passwort für dieter:
        Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
        Paketaktualisierung (Upgrade) wird berechnet… Fertig
        Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
          linux-image-5.10.0-13-amd64
        Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
        Die folgenden NEUEN Pakete werden installiert:
          linux-image-5.10.0-20-amd64
          linux-image-amd64
        1 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
        Es müssen 55,5 MB an Archiven heruntergeladen werden.
        Nach dieser Operation werden 318 MB Plattenplatz zusätzlich benutzt.
        Möchten Sie fortfahren? [J/n] J
        Holen:1 http://deb.debian.org/debian bullseye/main amd64 linux-image-5.10.0-20-amd64 amd64 5.10.158-2 [55,5 MB]
        Holen:2 http://deb.debian.org/debian bullseye/main amd64 linux-image-amd64 amd64 5.10.158-2 [1.484 B]
        Es wurden 55,5 MB in 6 s geholt (9.722 kB/s).
        Changelogs werden gelesen... Fertig
        Vormals nicht ausgewähltes Paket linux-image-5.10.0-20-amd64 wird gewählt.
        (Lese Datenbank ... 57640 Dateien und Verzeichnisse sind derzeit installiert.)
        Vorbereitung zum Entpacken von .../linux-image-5.10.0-20-amd64_5.10.158-2_amd64.deb ...
        Entpacken von linux-image-5.10.0-20-amd64 (5.10.158-2) ...
        Vorbereitung zum Entpacken von .../linux-image-amd64_5.10.158-2_amd64.deb ...
        Entpacken von linux-image-amd64 (5.10.158-2) über (5.10.140-1) ...
        linux-image-5.10.0-20-amd64 (5.10.158-2) wird eingerichtet ...
        I: /vmlinuz.old is now a symlink to boot/vmlinuz-5.10.0-18-amd64
        I: /initrd.img.old is now a symlink to boot/initrd.img-5.10.0-18-amd64
        I: /vmlinuz is now a symlink to boot/vmlinuz-5.10.0-20-amd64
        I: /initrd.img is now a symlink to boot/initrd.img-5.10.0-20-amd64
        /etc/kernel/postinst.d/initramfs-tools:
        update-initramfs: Generating /boot/initrd.img-5.10.0-20-amd64
        /etc/kernel/postinst.d/zz-update-grub:
        Generating grub configuration file ...
        Found linux image: /boot/vmlinuz-5.10.0-20-amd64
        Found initrd image: /boot/initrd.img-5.10.0-20-amd64
        Found linux image: /boot/vmlinuz-5.10.0-18-amd64
        Found initrd image: /boot/initrd.img-5.10.0-18-amd64
        Found linux image: /boot/vmlinuz-5.10.0-16-amd64
        Found initrd image: /boot/initrd.img-5.10.0-16-amd64
        Found linux image: /boot/vmlinuz-5.10.0-13-amd64
        Found initrd image: /boot/initrd.img-5.10.0-13-amd64
        Warning: os-prober will be executed to detect other bootable partitions.
        Its output will be used to detect bootable binaries on them and create new boot entries.
        done
        linux-image-amd64 (5.10.158-2) wird eingerichtet ...
        dieter@iobroker:~$ node -v
        v16.18.1
        dieter@iobroker:~$
        Danke.
          bahnuhrB Online
          bahnuhrB Online
          bahnuhr
          dieter@iobroker:~$ which nodejs node npm && nodejs -v && node -v && npm -v
          /usr/bin/nodejs
          /usr/bin/node
          /usr/bin/npm
          v16.18.1
          v16.18.1
          8.19.2
          dieter@iobroker:~$
          Danke.
          • bahnuhrB bahnuhr
              linux-image-amd64
            done
            v16.18.1
            dieter@iobroker:~$
            crunchipC Abwesend
            crunchipC Abwesend
            @bahnuhr sagte in node 16.19.0 installieren klappt nicht:
            siehe edit: auf Konsole prüfen, nicht auf den Info Adapter verlassen, der zeigt ggf erst richtig an, wenn du den iobroker neu startest
              bahnuhrB Online
              bahnuhrB Online
              bahnuhr
              Ja, das ist klar.
              Habe ja auch auf der konsole geprüft.
              Danke.
              • bahnuhrB bahnuhr
                Ja, das ist klar.
                crunchipC Abwesend
                crunchipC Abwesend
                @bahnuhr stop, ist wenn man noch im Halbschlaf ist😁
                Thema war doch erst hier, moment
                siehe https://forum.iobroker.net/topic/61014/node-18-1-vs-19-0
                  bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  @crunchip
                  @Thomas-Braun hatte hier geschrieben:
                  https://forum.iobroker.net/topic/61155/bei-npm-und-node-js-immer-super-aktuell-sein/23?page=2
                  dass nur die 16.18.1. rein kommt.
                  Wenn ich das richtig verstehe, geht wohl die 16.19.0 nicht.
                  Danke.
                  • bahnuhrB bahnuhr
                    @crunchip
                    crunchipC Abwesend
                    crunchipC Abwesend
                    @bahnuhr ja, siehe edit eins zuvor
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      @crunchip
                      ok,, abwarten.
                      Aber nochmal für mich:
                      Ist der curl Befehl falsch ?
                      Ist dein Befehl ausreichend ?
                      Danke.
                      crunchipC Thomas BraunT 2 Antworten Letzte Antwort
                      • bahnuhrB bahnuhr
                        @crunchip
                        ok,, abwarten.
                        crunchipC Abwesend
                        crunchipC Abwesend
                        @bahnuhr ein minor update(innerhalb einer Version) so wie ich geschrieben hab, ein Wechsel einer major Version, mittels curl
                        • bahnuhrB bahnuhr
                          @crunchip
                          ok,, abwarten.
                          @bahnuhr
                          Der Befehl mit cURL dient lediglich dazu EINMAL das nodesource-Repository im Paketmanager bekannt zu machen. Im weiteren dann ganz simpel per
                          sudo apt update
                          sudo apt full-upgrade
                          Was macht ihr denn da immer für Harakiri...???
                          Siehe auch hier:
                          https://forum.iobroker.net/topic/61165/node-js-update-information/4?_=1671434060743
                          Und in meiner Signatur steht's auch drin...
