<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[node 16.19.0 installieren klappt nicht]]></title><description><![CDATA[<p dir="auto">Hallo,<br />
in info wird mir eine neue V angezeigt.<br />
<img src="/assets/uploads/files/1671431100489-0cf6ff1b-e2a3-4452-8801-f5ade2b8e41f-image.png" alt="0cf6ff1b-e2a3-4452-8801-f5ade2b8e41f-image.png" class=" img-fluid img-markdown" /></p>
<p dir="auto">Bei dem curl Befehl kommt aber die ..19 nicht. Folgende Info gibt die konsole aus:</p>
<pre><code>dieter@iobroker:/opt/iobroker$ curl -sL https://deb.nodesource.com/setup_16.x | sudo -E bash -
## Installing the NodeSource Node.js 16.x repo...
## Populating apt-get cache...
+ apt-get update
OK:1 http://security.debian.org/debian-security bullseye-security InRelease
OK:2 http://deb.debian.org/debian bullseye InRelease
OK:3 http://deb.debian.org/debian bullseye-updates InRelease
OK:4 https://deb.nodesource.com/node_16.x bullseye InRelease
## Confirming "bullseye" is supported...
+ curl -sLf -o /dev/null 'https://deb.nodesource.com/node_16.x/dists/bullseye/Release'
## Adding the NodeSource signing key to your keyring...
+ curl -s https://deb.nodesource.com/gpgkey/nodesource.gpg.key | gpg --dearmor | tee /usr/share/keyrings/nodesource.gpg &gt;/dev/null
## Creating apt sources list file for the NodeSource Node.js 16.x repo...
+ echo 'deb [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' &gt; /etc/apt/sources.list.d/nodesource.list
+ echo 'deb-src [signed-by=/usr/share/keyrings/nodesource.gpg] https://deb.nodesource.com/node_16.x bullseye main' &gt;&gt; /etc/apt/sources.list.d/nodesource.list
## Running `apt-get update` for you...
+ apt-get update
OK:1 http://deb.debian.org/debian bullseye InRelease
OK:2 http://deb.debian.org/debian bullseye-updates InRelease
OK:3 http://security.debian.org/debian-security bullseye-security InRelease
## Run `sudo apt-get install -y nodejs` to install Node.js 16.x and npm
## You may also need development tools to build native addons:
     sudo apt-get install gcc g++ make
## To install the Yarn package manager, run:
     curl -sL https://dl.yarnpkg.com/debian/pubkey.gpg | gpg --dearmor | sudo tee /usr/share/keyrings/yarnkey.gpg &gt;/dev/null
     echo "deb [signed-by=/usr/share/keyrings/yarnkey.gpg] https://dl.yarnpkg.com/debian stable main" | sudo tee /etc/apt/sources.list.d/yarn.list
     sudo apt-get update &amp;&amp; sudo apt-get install yarn
</code></pre>
<p dir="auto">Was soll man nun machen ?<br />
kommt die ..19 noch irgendwie ?</p>
]]></description><link>https://forum.iobroker.net/topic/61167/node-16-19-0-installieren-klappt-nicht</link><generator>RSS for Node</generator><lastBuildDate>Thu, 14 May 2026 16:45:20 GMT</lastBuildDate><atom:link href="https://forum.iobroker.net/topic/61167.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 19 Dec 2022 06:27:41 GMT</pubDate><ttl>60</ttl><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 07:20:02 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a></p>
<p dir="auto">Der Befehl mit cURL dient lediglich dazu EINMAL das nodesource-Repository im Paketmanager bekannt zu machen. Im weiteren dann ganz simpel per</p>
<pre><code>sudo apt update
sudo apt full-upgrade
</code></pre>
<p dir="auto">Was macht ihr denn da immer für Harakiri...???</p>
<p dir="auto">Siehe auch hier:<br />
<a href="https://forum.iobroker.net/topic/61165/node-js-update-information/4?_=1671434060743">https://forum.iobroker.net/topic/61165/node-js-update-information/4?_=1671434060743</a></p>
<p dir="auto">Und in meiner Signatur steht's auch drin...</p>
]]></description><link>https://forum.iobroker.net/post/912561</link><guid isPermaLink="true">https://forum.iobroker.net/post/912561</guid><dc:creator><![CDATA[Thomas Braun]]></dc:creator><pubDate>Mon, 19 Dec 2022 07:20:02 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:45:21 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a> ein <strong>minor</strong> update(innerhalb einer Version) so wie ich geschrieben hab, ein Wechsel einer <strong>major</strong> Version, mittels curl</p>
]]></description><link>https://forum.iobroker.net/post/912554</link><guid isPermaLink="true">https://forum.iobroker.net/post/912554</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:45:21 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:43:16 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a></p>
<p dir="auto">ok,, abwarten.</p>
<p dir="auto">Aber nochmal für mich:<br />
Ist der curl Befehl falsch ?<br />
Ist dein Befehl ausreichend ?</p>
]]></description><link>https://forum.iobroker.net/post/912552</link><guid isPermaLink="true">https://forum.iobroker.net/post/912552</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:43:16 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:42:31 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a> ja, siehe edit eins zuvor</p>
]]></description><link>https://forum.iobroker.net/post/912551</link><guid isPermaLink="true">https://forum.iobroker.net/post/912551</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:42:31 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:41:29 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a></p>
<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/thomas-braun" aria-label="Profile: Thomas-Braun">@<bdi>Thomas-Braun</bdi></a> hatte hier geschrieben:<br />
<a href="https://forum.iobroker.net/topic/61155/bei-npm-und-node-js-immer-super-aktuell-sein/23?page=2">https://forum.iobroker.net/topic/61155/bei-npm-und-node-js-immer-super-aktuell-sein/23?page=2</a></p>
<p dir="auto">dass nur die 16.18.1. rein kommt.</p>
<p dir="auto">Wenn ich das richtig verstehe, geht wohl die 16.19.0 nicht.</p>
]]></description><link>https://forum.iobroker.net/post/912550</link><guid isPermaLink="true">https://forum.iobroker.net/post/912550</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:41:29 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:41:25 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a> stop, ist wenn man noch im Halbschlaf ist<img src="https://forum.iobroker.net/assets/plugins/nodebb-plugin-emoji/emoji/android/1f601.png?v=ba16ebd4856" class="not-responsive emoji emoji-android emoji--grin" style="height:23px;width:auto;vertical-align:middle" title=":grin:" alt="😁" /></p>
<p dir="auto">Thema war doch erst hier, <s>moment</s></p>
<p dir="auto">siehe <a href="https://forum.iobroker.net/topic/61014/node-18-1-vs-19-0">https://forum.iobroker.net/topic/61014/node-18-1-vs-19-0</a></p>
]]></description><link>https://forum.iobroker.net/post/912549</link><guid isPermaLink="true">https://forum.iobroker.net/post/912549</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:41:25 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:36:43 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> sagte in <a href="/post/912547">node 16.19.0 installieren klappt nicht</a>:</p>
<blockquote>
<p dir="auto">auf Konsole prüfen, nicht auf den Info Adapter verlassen, der zeigt ggf erst richtig an, wenn du den iobroker neu startest</p>
</blockquote>
<p dir="auto">Ja, das ist klar.<br />
Habe ja auch auf der konsole geprüft.</p>
]]></description><link>https://forum.iobroker.net/post/912548</link><guid isPermaLink="true">https://forum.iobroker.net/post/912548</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:36:43 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:36:03 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a> sagte in <a href="/post/912545">node 16.19.0 installieren klappt nicht</a>:</p>
<blockquote>
<p dir="auto">Geändert hat es aber nicht.</p>
</blockquote>
<p dir="auto">siehe edit: auf Konsole prüfen, nicht auf den Info Adapter verlassen, der zeigt ggf erst richtig an, wenn du den iobroker neu startest</p>
]]></description><link>https://forum.iobroker.net/post/912547</link><guid isPermaLink="true">https://forum.iobroker.net/post/912547</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:36:03 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:35:19 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> sagte in <a href="/post/912540">node 16.19.0 installieren klappt nicht</a>:</p>
<blockquote>
<p dir="auto">which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v</p>
</blockquote>
<pre><code>dieter@iobroker:~$ which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v
/usr/bin/nodejs
/usr/bin/node
/usr/bin/npm
v16.18.1
v16.18.1
8.19.2
dieter@iobroker:~$
</code></pre>
]]></description><link>https://forum.iobroker.net/post/912546</link><guid isPermaLink="true">https://forum.iobroker.net/post/912546</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:35:19 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:34:38 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/crunchip" aria-label="Profile: crunchip">@<bdi>crunchip</bdi></a> sagte in <a href="/post/912540">node 16.19.0 installieren klappt nicht</a>:</p>
<blockquote>
<p dir="auto">sudo apt update &amp;&amp; sudo apt upgrade</p>
</blockquote>
<p dir="auto">hab das immer mit dem curl gemacht.<br />
Aber jetzt mal deinen Befehl probiert.</p>
<p dir="auto">In der Konsole war etliches ersichtlich.<br />
Geändert hat es aber nicht.<br />
Es ist immer noch 16.18.1</p>
<pre><code>dieter@iobroker:~$ sudo apt update &amp;&amp; sudo apt upgrade
[sudo] Passwort für dieter:
Aktualisierung für 1 Paket verfügbar. Führen Sie »apt list --upgradable« aus, um es anzuzeigen.
Paketaktualisierung (Upgrade) wird berechnet… Fertig
Das folgende Paket wurde automatisch installiert und wird nicht mehr benötigt:
  linux-image-5.10.0-13-amd64
Verwenden Sie »sudo apt autoremove«, um es zu entfernen.
Die folgenden NEUEN Pakete werden installiert:
  linux-image-5.10.0-20-amd64
Die folgenden Pakete werden aktualisiert (Upgrade):
  linux-image-amd64
1 aktualisiert, 1 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
Es müssen 55,5 MB an Archiven heruntergeladen werden.
Nach dieser Operation werden 318 MB Plattenplatz zusätzlich benutzt.
Möchten Sie fortfahren? [J/n] J
Holen:1 http://deb.debian.org/debian bullseye/main amd64 linux-image-5.10.0-20-amd64 amd64 5.10.158-2 [55,5 MB]
Holen:2 http://deb.debian.org/debian bullseye/main amd64 linux-image-amd64 amd64 5.10.158-2 [1.484 B]
Es wurden 55,5 MB in 6 s geholt (9.722 kB/s).
Changelogs werden gelesen... Fertig
Vormals nicht ausgewähltes Paket linux-image-5.10.0-20-amd64 wird gewählt.
(Lese Datenbank ... 57640 Dateien und Verzeichnisse sind derzeit installiert.)
Vorbereitung zum Entpacken von .../linux-image-5.10.0-20-amd64_5.10.158-2_amd64.deb ...
Entpacken von linux-image-5.10.0-20-amd64 (5.10.158-2) ...
Vorbereitung zum Entpacken von .../linux-image-amd64_5.10.158-2_amd64.deb ...
Entpacken von linux-image-amd64 (5.10.158-2) über (5.10.140-1) ...
linux-image-5.10.0-20-amd64 (5.10.158-2) wird eingerichtet ...
I: /vmlinuz.old is now a symlink to boot/vmlinuz-5.10.0-18-amd64
I: /initrd.img.old is now a symlink to boot/initrd.img-5.10.0-18-amd64
I: /vmlinuz is now a symlink to boot/vmlinuz-5.10.0-20-amd64
I: /initrd.img is now a symlink to boot/initrd.img-5.10.0-20-amd64
/etc/kernel/postinst.d/initramfs-tools:
update-initramfs: Generating /boot/initrd.img-5.10.0-20-amd64
/etc/kernel/postinst.d/zz-update-grub:
Generating grub configuration file ...
Found linux image: /boot/vmlinuz-5.10.0-20-amd64
Found initrd image: /boot/initrd.img-5.10.0-20-amd64
Found linux image: /boot/vmlinuz-5.10.0-18-amd64
Found initrd image: /boot/initrd.img-5.10.0-18-amd64
Found linux image: /boot/vmlinuz-5.10.0-16-amd64
Found initrd image: /boot/initrd.img-5.10.0-16-amd64
Found linux image: /boot/vmlinuz-5.10.0-13-amd64
Found initrd image: /boot/initrd.img-5.10.0-13-amd64
Warning: os-prober will be executed to detect other bootable partitions.
Its output will be used to detect bootable binaries on them and create new boot entries.
done
linux-image-amd64 (5.10.158-2) wird eingerichtet ...
dieter@iobroker:~$ node -v
v16.18.1
dieter@iobroker:~$
</code></pre>
]]></description><link>https://forum.iobroker.net/post/912545</link><guid isPermaLink="true">https://forum.iobroker.net/post/912545</guid><dc:creator><![CDATA[bahnuhr]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:34:38 GMT</pubDate></item><item><title><![CDATA[Reply to node 16.19.0 installieren klappt nicht on Mon, 19 Dec 2022 06:34:37 GMT]]></title><description><![CDATA[<p dir="auto"><a class="plugin-mentions-user plugin-mentions-a" href="/user/bahnuhr" aria-label="Profile: bahnuhr">@<bdi>bahnuhr</bdi></a> innerhalb einer Major Version reicht ein sudo apt update &amp;&amp; sudo apt upgrade</p>
<p dir="auto">des weiteren kann es sein, das der Info Adapter noch nicht aktualisiert hat, daher noch eine veraltete Version steht<br />
prüfe doch auf der Konsole</p>
<pre><code>which nodejs node npm &amp;&amp; nodejs -v &amp;&amp; node -v &amp;&amp; npm -v
</code></pre>
]]></description><link>https://forum.iobroker.net/post/912540</link><guid isPermaLink="true">https://forum.iobroker.net/post/912540</guid><dc:creator><![CDATA[crunchip]]></dc:creator><pubDate>Mon, 19 Dec 2022 06:34:37 GMT</pubDate></item></channel></rss>
