  4. Problem hoch Drei (JavaScript, HOST, Admin)
    5.6k
52 Beiträge 4 Kommentatoren 5.8k Aufrufe 3 Beobachtet
  • KenjiK Kenji
    @thomas-braun said in Problem hoch Drei (JavaScript, HOST, Admin):
    iob repo unset 'Stable (default)'
    pi@raspberrypi:/ $ iob repo unset 'Stable (default)'
    Repository "Stable (default)" deactivated.
    live-stable   : http://iobroker.live/repo/sources-dist.json
    live-beta     : http://iobroker.live/repo/sources-dist-latest.json
    Active repo(s): stable
    pi@raspberrypi:/ $
    @kenji
    Die Repos sind jetzt sauber. Wie schaut es beim Thema nodejs aus?
    cd ~
    sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
    uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    KenjiK 1 Antwort Letzte Antwort
      @kenji
      cd ~
      KenjiK Offline
      KenjiK Offline
      Kenji
      pi@raspberrypi:/ $
      pi@raspberrypi:/ $ sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
      pi@raspberrypi:/ $
      pi@raspberrypi:/ $
      pi@raspberrypi:/ $ uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs        -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt update &> /dev/null && sudo apt update && ap       t policy nodejs
      armv7l
      Kein Docker
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.1
      v16.17.1
      8.15.0
      4.0.21
      pi
      pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
      tty
      OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
      OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
      OK:3 https://deb.nodesource.com/node_16.x bullseye InRelease
      Aktualisierung für 74 Pakete verfügbar. Führen Sie »apt list --upgradable« aus, um sie anzuzeigen.
      nodejs:
        Installiert:           16.17.1-deb-1nodesource1
        Installationskandidat: 16.18.1-deb-1nodesource1
        Versionstabelle:
           16.18.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
       *** 16.17.1-deb-1nodesource1 100
           12.22.12~dfsg-1~deb11u1 500
      pi@raspberrypi:/ $
      • KenjiK Kenji
        pi@raspberrypi:/ $
        pi@raspberrypi:/ $
        pi@raspberrypi:/ $
        armv7l
        Kein Docker
        /usr/bin/nodejs
        /usr/bin/node
        /usr/bin/npm
        v16.17.1
        v16.17.1
        8.15.0
        4.0.21
        pi
        tty
        nodejs:
          Versionstabelle:
        pi@raspberrypi:/ $
        @kenji
        cd ~
        iob stop
        sudo apt update
        sudo apt full-upgrade
        sudo reboot
        System regelmäßig updaten!
        • CodierknechtC Codierknecht
          Ja, aber dann um einzelne Befehle abzusetzen.
          Gleich mit su fortan als root zu agieren ist sicher die schlechteste aller Varianten.
          Und wenn man hier im Forum so mitliest dünkt einem schnell, dass root oft meist die Wurzel allen Übels ist ;-)
          @codierknecht sagte in Problem hoch Drei (JavaScript, HOST, Admin):
          da bin ich voll be dir!
          Aber deine Formulierung kann auch für die Verwendung von nur sudo missgedeutet werden
          CodierknechtC KenjiK 2 Antworten Letzte Antwort
            CodierknechtC Online
            Codierknecht
            @homoran sagte in Problem hoch Drei (JavaScript, HOST, Admin):
            Punkt für Dich.
            @Kenji
            Also zur Klarstellung: sudo xxx wird (wie man weiter oben sieht) durchaus schon mal benötigt.
            Aber in der Regel niemals im Zusammenhang mit ioBroker sondern nur für das System (Linux) an sich.
            HmIP|ZigBee|Tasmota|Unifi
            Zabbix Certified Specialist
              KenjiK Offline
              KenjiK Offline
              Kenji
              @homoran Also ich werde keine IOB Befehle mehr als "sudo" oder "Root" ausführen. Ich versuche aus jedem Problem was mit zu nehmen und zu lernen. :)
                Punkt für Dich.
                @Kenji
                KenjiK Offline
                KenjiK Offline
                Kenji
                @codierknecht Das ist mir jetzt auf jeden Fall klar geworden und ich hoffe das lesen noch mehr Leute hier. Damit es weniger solcher Fälle geben wird.
                • KenjiK Kenji
                  @kenji sagte in Problem hoch Drei (JavaScript, HOST, Admin):
                  Da hab ich die Hoffnung schon fast aufgegeben...
                  Irgendwer kommt halt immer auf die Idee mit dem root durch das System zu bulldoozern. Funktioniert im ersten Moment auch, die Haken und Kinken tauchen dann erst viel später auf.
                    KenjiK Offline
                    KenjiK Offline
                    Kenji
                    @thomas-braun Hast auch meinen höchsten Respekt für die Arbeit hier. Die Anderen natürlich auch! Bin nämlich eigentlich total begeistern vom IoBroker und habe dadurch Linux erst kennen gelernt.
                    Echt super.
                    • KenjiK Kenji
                      Echt super.
                      @kenji
                      Updates durch?
                      Dann
                      for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                      iob update
                      iob upgrade all
                      iob stop
                      iob upgrade self
                      iob start
                        @kenji
                        Updates durch?
                        Dann
                        iob update
                        iob upgrade all
                        iob stop
                        iob upgrade self
                        iob start
                        KenjiK Offline
                        KenjiK Offline
                        Kenji
                        @thomas-braun 50% ... :)
                        • KenjiK Kenji
                          @kenji
                          Fertig? Lüppt das jetzt?
                            @kenji
                            KenjiK Offline
                            KenjiK Offline
                            Kenji
                            @thomas-braun Pi Ist neu gestartet und jetzt führe ich den zweiten Block aus :)
                            iob update
                            iob upgrade all
                            iob stop
                            iob upgrade self
                            iob start
                            Sehr cool kann man die Adapter auch in Zukunft so updaten? oder besser über die Oberfläche im Admin?
                            • KenjiK Kenji
                              iob update
                              iob upgrade all
                              iob stop
                              iob upgrade self
                              iob start
                              @kenji
                              Ich bevorzuge die Konsole...
                                @kenji
                                KenjiK Offline
                                KenjiK Offline
                                Kenji
                                Sollte man diesen Befehl bei behalten wenn man die Adapter so über die Konsole Hochzieht?
                                Muss gesteht weiß nicht genau was er macht. Glaub er löscht irgendwas...
                                • KenjiK Kenji
                                  @kenji
                                  Eigentlich sollte der nur einmal verwendet werden müssen.
                                  Beim Wechsel auf npm8 kann es dazu kommen, dass bestimmte temporäre Verzeichnisse gelöscht werden müssen.
                                    @kenji
                                    Updates durch?
                                    Dann
                                    iob update
                                    iob upgrade all
                                    iob stop
                                    iob upgrade self
                                    iob start
                                    KenjiK Offline
                                    KenjiK Offline
                                    Kenji
                                    Hier die Ausgabe vom zweiten Block, fall benötigt. Ich starte den IoBroker jetzt mal wieder und gucke was passiert...
                                    pi@raspberrypi:~ $ for i in $(find /opt/iobroker/node_modules -type d -iname ".*        -????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                                    pi@raspberrypi:~ $ iob update
                                    Used repository: stable
                                    Adapter    "admin"        : 6.3.3    , installed 5.3.8  [Updatable]
                                    Adapter    "backitup"     : 2.5.9    , installed 2.5.9
                                    Adapter    "discovery"    : 3.1.0    , installed 3.0.5  [Updatable]
                                    Adapter    "fritzdect"    : 2.2.6    , installed 2.2.6
                                    Adapter    "growatt"      : 2.0.0    , installed 2.0.0
                                    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
                                    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
                                    Adapter    "info"         : 1.9.19   , installed 1.9.19
                                    Adapter    "javascript"   : 6.0.3    , installed 6.0.3
                                    Controller "js-controller": 4.0.23   , installed 4.0.21 [Updatable]
                                    Adapter    "rssfeed"      : 2.6.1    , installed 2.6.1
                                    Adapter    "simple-api"   : 2.7.0    , installed 2.6.4  [Updatable]
                                    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
                                    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
                                    pi@raspberrypi:~ $ iob upgrade all
                                    This upgrade of "simple-api" will introduce the following changes:
                                    -> 2.7.0:
                                    Allow use of ack flag for setBulk post requests
                                    Return ack flag too on getBulk
                                    -> 2.6.5:
                                    Added support aggregate and count for queries
                                    Would you like to upgrade simple-api from @2.6.4 to @2.7.0 now? [(y)es, (n)o]: y
                                    Update simple-api from @2.6.4 to @2.7.0
                                    NPM version: 8.19.2
                                    Installing iobroker.simple-api@2.7.0... (System call)
                                    added 6 packages, removed 667 packages, and changed 9 packages in 6m
                                    40 packages are looking for funding
                                      run `npm fund` for details
                                    upload [13] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    upload [12] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    upload [11] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    upload [10] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    upload [9] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    upload [8] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    upload [7] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    upload [6] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    upload [5] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    upload [4] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    upload [3] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index.html index.html text/html
                                    upload [2] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/index_m.html index_m.html text/html
                                    upload [1] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/simple-api.png simple-api.png image/png
                                    upload [0] simple-api.admin /opt/iobroker/node_modules/iobroker.simple-api/admin/words.js words.js application/javascript
                                    This upgrade of "discovery" will introduce the following changes:
                                    -> 3.1.0:
                                    Corrected syntax error in the german translation
                                    -> 3.0.6:
                                    Prepare for future js-controller versions
                                    Prevent crash cases
                                    Would you like to upgrade discovery from @3.0.5 to @3.1.0 now? [(y)es, (n)o]: y
                                    Update discovery from @3.0.5 to @3.1.0
                                    NPM version: 8.19.2
                                    Installing iobroker.discovery@3.1.0... (System call)
                                    added 1 package, removed 674 packages, and changed 2 packages in 13s
                                    Update "system.adapter.discovery.0"
                                    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
                                    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
                                    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
                                    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
                                    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
                                    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
                                    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
                                    This upgrade of "admin" will at least introduce the following changes:
                                    -> 6.3.3:
                                    Corrected icons in object browser
                                    -> 6.3.2:
                                    Added `useNative` option to `sendTo` JSON Config component
                                    Added `checkLicense` and `uuid` components to JSON Config
                                    Corrected the news handler
                                    -> 6.2.23:
                                    Corrected deletion of objects
                                    -> 6.2.22:
                                    Corrected admin4 adapter settings
                                    -> 6.2.21:
                                    Corrected small JSON config issue
                                    -> 6.2.20:
                                    Corrected GUI issues
                                    -> 6.2.19:
                                    Corrected some issues
                                    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                    Would you like to upgrade admin from @5.3.8 to @6.3.3 now? [(y)es, (n)o]: y
                                    Update admin from @5.3.8 to @6.3.3
                                    NPM version: 8.19.2
                                    Installing iobroker.admin@6.3.3... (System call)
                                    added 8 packages, removed 3 packages, and changed 10 packages in 2m
                                    41 packages are looking for funding
                                    Update "system.adapter.admin.0"
                                    upload [52] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
                                    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js.map custom/customComponents.js.map application/json
                                    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/zh-cn.json custom/i18n/zh-cn.json application/json
                                    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js.map application/json
                                    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
                                    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
                                    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
                                    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
                                    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
                                    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
                                    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
                                    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
                                    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
                                    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
                                    pi@raspberrypi:~ $ iob stop
                                    pi@raspberrypi:~ $ iob upgrade self
                                    Update js-controller from @4.0.21 to @4.0.23
                                    Stopped Objects DB
                                    Stopped States DB
                                    NPM version: 8.19.2
                                    Installing iobroker.js-controller@4.0.23... (System call)
                                    added 1 package, removed 2 packages, and changed 59 packages in 2m
                                    pi@raspberrypi:~ $
                                    • KenjiK Offline
                                      KenjiK Offline
                                      Kenji
                                      Mmh ... leider noch kein Lebenszeichen im Browser vom Admin.
                                      http://192.168.178.3:8081/#tab-intro
                                      Das update hat aber glaub fast überall geklappt:
                                      pi@raspberrypi:~ $ iob update -i
                                      Adapter    "admin"        : 6.3.3    , installed 6.3.3
                                      Adapter    "javascript"   : 6.0.3    , installed 5.2.21 [Updatable]
                                      Controller "js-controller": 4.0.23   , installed 4.0.23
                                      Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
                                      pi@raspberrypi:~ $
                                      • KenjiK Kenji
                                        pi@raspberrypi:~ $
                                        @kenji
                                        iob update
                                        iob upgrade javascript --debug
                                          @kenji
                                          iob update
                                          KenjiK Offline
                                          KenjiK Offline
                                          Kenji
                                          pi@raspberrypi:~ $ iob upgrade javascript --debug
                                          This upgrade of "javascript" will at least introduce the following changes:
                                          -> 6.0.3:
                                          Downgrade Typescript to prevent errors with global typescript scripts
                                          -> 6.0.2:
                                          -> 6.0.1:
                                          Fixed the wizard schedule
                                          Done small fixes on GUI
                                          -> 6.0.0:
                                          Removed support of coffeescript
                                          All coffee-scripts will be compiled to javascript permanently
                                          -> 5.8.10:
                                          Added variable timeout block
                                          Added `getInterval` and `getTimeout` blocks
                                          Added `sendTo` for scripts and message trigger blocks
                                          Corrected the syntax highlighting
                                          -> 5.8.9:
                                          -> 5.8.8:
                                          Corrected error by start of GUI
                                          Would you like to upgrade javascript from @5.2.21 to @6.0.3 now? [(y)es, (n)o]: y
                                          Update javascript from @5.2.21 to @6.0.3
                                          NPM version: 8.19.2
                                          Installing iobroker.javascript@6.0.3... (System call)
                                          added 2 packages, removed 8 packages, and changed 4 packages in 7m
                                          Update "system.adapter.javascript.0"
                                          upload [254] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/adminWords.js adminWords.js application/javascript
                                          upload [250] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/LICENSE google-blockly/LICENSE null
                                          upload [200] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/google-blockly/own/msg/fr.js google-blockly/own/msg/fr.js application/javascript
                                          upload [150] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Amplifier.6f5d18048328386033f8.svg static/media/Amplifier.6f5d18048328386033f8.svg image/svg+xml
                                          upload [100] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Heater.b53bccc334bbb9238a36.svg static/media/Heater.b53bccc334bbb9238a36.svg image/svg+xml
                                          upload [90] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Light.21f1a5dfcc93f8ba1214.svg static/media/Light.21f1a5dfcc93f8ba1214.svg image/svg+xml
                                          upload [80] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Office.7e6a38218390b655e270.svg static/media/Office.7e6a38218390b655e270.svg image/svg+xml
                                          upload [70] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Receiver.26b5ae166395a6dcb83f.svg static/media/Receiver.26b5ae166395a6dcb83f.svg image/svg+xml
                                          upload [60] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Speaker.db548379676317470c4f.svg static/media/Speaker.db548379676317470c4f.svg image/svg+xml
                                          upload [50] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Toilet.83604dd2daafb67067dd.svg static/media/Toilet.83604dd2daafb67067dd.svg image/svg+xml
                                          upload [40] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/Water.f50411984c5c24fa574d.svg static/media/Water.f50411984c5c24fa574d.svg image/svg+xml
                                          upload [30] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/static/media/names.e7efb5283d98000c74ac.txt static/media/names.e7efb5283d98000c74ac.txt text/plain
                                          upload [20] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.js vs/editor/editor.main.js application/javascript
                                          upload [19] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.de.js vs/editor/editor.main.nls.de.js application/javascript
                                          upload [18] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.es.js vs/editor/editor.main.nls.es.js application/javascript
                                          upload [17] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.fr.js vs/editor/editor.main.nls.fr.js application/javascript
                                          upload [16] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.it.js vs/editor/editor.main.nls.it.js application/javascript
                                          upload [15] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ja.js vs/editor/editor.main.nls.ja.js application/javascript
                                          upload [14] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.js vs/editor/editor.main.nls.js application/javascript
                                          upload [13] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ko.js vs/editor/editor.main.nls.ko.js application/javascript
                                          upload [12] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.ru.js vs/editor/editor.main.nls.ru.js application/javascript
                                          upload [11] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-cn.js vs/editor/editor.main.nls.zh-cn.js application/javascript
                                          upload [10] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/editor/editor.main.nls.zh-tw.js vs/editor/editor.main.nls.zh-tw.js application/javascript
                                          upload [9] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssMode.js vs/language/css/cssMode.js application/javascript
                                          upload [8] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/css/cssWorker.js vs/language/css/cssWorker.js application/javascript
                                          upload [7] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlMode.js vs/language/html/htmlMode.js application/javascript
                                          upload [6] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/html/htmlWorker.js vs/language/html/htmlWorker.js application/javascript
                                          upload [5] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonMode.js vs/language/json/jsonMode.js application/javascript
                                          upload [4] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/json/jsonWorker.js vs/language/json/jsonWorker.js application/javascript
                                          upload [3] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsMode.js vs/language/typescript/tsMode.js application/javascript
                                          upload [2] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/language/typescript/tsWorker.js vs/language/typescript/tsWorker.js application/javascript
                                          upload [1] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/loader.js vs/loader.js application/javascript
                                          upload [0] javascript.admin /opt/iobroker/node_modules/iobroker.javascript/admin/vs/monaco.d.ts vs/monaco.d.ts video/mp2t
                                          pi@raspberrypi:~ $
                                          pi@raspberrypi:~ $
                                          Das Update scheint jetzt geklappt zu haben.
