  4. ioBroker Synology Adapter
615 Beiträge 62 Kommentatoren 236.3k Aufrufe 54 Beobachtet
  • dslraserD dslraser
    @glasfaser sagte in ioBroker Synology Adapter:
    Cool .... mit Livebewegung ,extra für den Thread
    Auch Schnappschuss über den Adapter gerade getestet, funktioniert auch. 😊
    <block xmlns="https://developers.google.com/blockly/xml" type="on_ext" id="z|_YiJg+yu9AqZ+$G?j0" x="137" y="113">
     <value name="OID0">
       <shadow type="field_oid" id="{a)L]|n=$0}yK=wxkT3e">
         <field name="oid">synology.0.SurveillanceStation.cameras.Tür.motionDetected</field>
       </shadow>
     </value>
     <statement name="STATEMENT">
       <block type="controls_if" id="ltHZT$4h8|.wnLs+!FSK">
         <value name="IF0">
           <block type="on_source" id="7|X=oOX|??J?zQmc@4C-">
           </block>
         </value>
         <statement name="DO0">
           <block type="comment" id="_u,vea5EHP=7ePIWO,O_">
             <field name="COMMENT">Eingang</field>
             <next>
               <block type="control" id="W{]b(Cz8V`eo~^{l6#F8">
                 <field name="OID">synology.0.SurveillanceStation.getSnapshotCamera</field>
                 <value name="VALUE">
                   <block type="text" id="Y.(R).T3:WX_kv2IY),h">
                     <field name="TEXT">9</field>
                   </block>
                 </value>
                 <next>
                   <block type="timeouts_cleartimeout" id="fnj{DSY%){X*CJPEfz^z">
                     <field name="NAME">eingangscam</field>
                     <next>
                       <block type="timeouts_settimeout" id="wi*ruivRgrT3ZLNc06Wj">
                         <field name="DELAY">1000</field>
                         <field name="UNIT">ms</field>
                           <block type="sendto_custom" id="-?kbg%Xud6Z@l_?`p-wL">
                             <mutation xmlns="http://www.w3.org/1999/xhtml" items="text,caption,user" with_statement="false"></mutation>
                             <field name="INSTANCE">telegram.0</field>
                             <field name="COMMAND">send</field>
                             <field name="LOG"></field>
                             <field name="WITH_STATEMENT">FALSE</field>
                             <value name="ARG0">
                               <shadow type="text" id="vD7GW1^_]ydn,_Fsz`3M">
                                 <field name="TEXT">/opt/iobroker/iobroker-data/synology_0/snapshotCam_9.jpg</field>
                               </shadow>
                             </value>
                             <value name="ARG1">
                               <shadow type="text" id="df{3K-fkyF}jGr/Z_F4=">
                                 <field name="TEXT">👀Eingangskamera Bewegung erkannt 👀</field>
                               </shadow>
                             </value>
                             <value name="ARG2">
                               <shadow type="text" id="d,%mxv[9eX)?AqC.(qhs">
                                 <field name="TEXT">Heiko</field>
                               </shadow>
                             </value>
                           </block>
                         </statement>
                       </block>
                     </next>
                   </block>
                 </next>
               </block>
             </next>
           </block>
         </statement>
         <statement name="ELSE">
           <block type="telegram" id="vZ4PUx)R0v9#5ee6vvLp">
             <value name="MESSAGE">
               <shadow type="text" id="A]58q~+YZeT-4J}YN54t">
                 <field name="TEXT">keine Bewegung mehr am Eingang</field>
               </shadow>
             </value>
             <value name="USERNAME">
               <block type="text" id="N9ay#VElnPLqtX2=@h8N">
               </block>
             </value>
           </block>
         </statement>
       </block>
     </statement>
    </block>
    Kellerkind-86
    #606
    @dslraser
    ich hab noch mal eine frage zum post hier.
    Ich verstehe noch nicht ganz was dieser datenpunkte bedeutet (get snapshot by camera number)
    ich habe mehrere cameras.. der trigger (Motion detected) befindet sich beispielsweise an der Haustüre....
    verstehe ich..
    aber was ist wenn jemand hinterm haus kommt.. die kamera sendet mir ja dann kein bild da der Trigger bzw bewegungserkenner an der haustüre ist.
    ich würde ja gerne alles zusammen packen.
    wenn einer der kameras oder bewegungsmelder eine bewegeung erkennt, soll diese besagte kamera ein Bild machen und an telegram senden.
    bei einer kamera verstehe ich das ja.. klappt ja auch schon so prima..
    aber mit mehreren verstehe ich das noch nicht.
    sorry.
    danke für die Hilfe
    Gruss Marcell
    Gruß Marcell
    • K Kellerkind-86
      @dslraser
      verstehe ich..
      sorry.
      danke für die Hilfe
      Gruss Marcell
      dslraserD Offline
      dslraserD Offline
      dslraser
      #607
      @kellerkind-86
      das ist auch nur ein Beispiel für eine Kamera. Dann machst Du eben so viele Blocklys wie Du Kameras hast. (die haben ja jeweils eine ID Nummer)
        @kellerkind-86
        Kellerkind-86
        #608
        @dslraser
        ah okay. dachte es geht auch alles in einem blockly.. aber sonst weiss ich bescheid.
        danke.
        Gruß Marcell
        • K Kellerkind-86
          @dslraser
          danke.
          dslraserD Offline
          dslraserD Offline
          dslraser
          #609
          @kellerkind-86
          geht ja auch in einem Blockly. Einfach den Inhalt dieses Blocklys „vervielfältigen“.
            Kellerkind-86
            #610
            @dslraser oh ok das wusste ich nicht.
            einfach die trigger nicht zusammenhängen sondern unterteilen, oder ?
            Gruß Marcell
            • K Kellerkind-86
              dslraserD Offline
              dslraserD Offline
              dslraser
              #611
              @kellerkind-86
              ja
              • NegaleinN Negalein
                Per SMTP gibt es ja dafür etwas ...
                was bedeutet im DP dann 2? Soll das nein sein? Findet man da wo was darüber?
                mcm1957M Online
                mcm1957M Online
                mcm1957
                #612
                @negalein said in ioBroker Synology Adapter:
                Schau mal dieses Dokument durch:
                https://global.download.synology.com/download/Document/Software/DeveloperGuide/Firmware/DSM/All/enu/Synology_DiskStation_MIB_Guide.pdf
                Habs nicht explizit durchsucht, könnte aber gut sein, dass da drin steht.
                McM
                Support Repositoryverwaltung.
                LESEN - gute Forenbeitrage
                  @tobi68 sagte in ioBroker Synology Adapter:
                  bei mir läuft die 1.1.3
                  DSM 6.2.4
                  Surveillance Station 8.2.9
                  bei mir laufen die gleichen Versionen
                  Will halt MotionDetected von ne Kamera abfragen.
                  Funktioniert das überhaupt bei irgendwem in welcher Version?
                  Meine DS zeichnet die erkannten Bewegungen auf, in DSCam kann ich mit den Sprungmarken arbeiten..
                  gerade mal getestet, funktioniert bei mir
                  18.9.2021, 11:08:19.591	[warn ]: javascript.0 (321) script.js.99_Test.Kamera-Syno: Bewegung am Parkplatz erkannt
                  18.9.2021, 11:09:33.034	[warn ]: javascript.0 (321) script.js.99_Test.Kamera-Syno: keine Bewegung mehr am Parkplatz
                  johobo
                  #613
                  @dslraser hey. Hab es soweit umgesetzt und angepasst. Bei mir sendet Telegram aber kein Bild sondern den Link als Text. Was ist da falsch?
                  • J johobo
                    GlasfaserG Offline
                    GlasfaserG Offline
                    #614
                    @johobo sagte in ioBroker Synology Adapter:
                    Was ist da falsch?
                    Keine Ahnung ohne weitere Angaben ... sehr schwer zu finden .
                    teste mal :
                    https://forum.iobroker.net/post/688155
                    • GlasfaserG Glasfaser
                      Was ist da falsch?
                      teste mal :
                      johobo
                      #615
                      @glasfaser lag daran, dass kein Bild hinterlegt war der GetSnapshot funktionierte wohl nicht. hab alles neu gestartet, dann ging es.
                      trotzdem Danke!!!
