  4. IO Broker stürzt seit Samstag regelmäßig ab
    5.6k
31 Beiträge 3 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • Snowboarder2611S Offline
    Snowboarder2611
    kern.log.1 ist auch 105gb groß
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    6.963594] [drm] No displays found. Consider forcing hotplug if HDMI is attached
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    6.963732] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    6.969300] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    7.152748] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    7.153245] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    7.162442] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    8.963834] 8021q: 802.1Q VLAN Support v1.8
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    8.992480] uart-pl011 fe201000.serial: no DMA platform data
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.139838] random: crng init done
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.139867] random: 7 urandom warning(s) missed due to ratelimiting
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.274378] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:34623152k SSFS
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.282362] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.496232] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
    Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.496502] bcmgenet fd580000.ethernet eth0: Link is Down
    Nov 26 14:17:12 raspberrypi4-iob kernel: [   14.714559] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
    Nov 26 14:17:12 raspberrypi4-iob kernel: [   14.714617] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761061] Bluetooth: Core ver 2.22
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761181] NET: Registered protocol family 31
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761197] Bluetooth: HCI device and connection manager initialized
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761227] Bluetooth: HCI socket layer initialized
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761250] Bluetooth: L2CAP socket layer initialized
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761288] Bluetooth: SCO socket layer initialized
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.768309] Bluetooth: HCI UART driver ver 2.3
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.768331] Bluetooth: HCI UART protocol H4 registered
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.768461] Bluetooth: HCI UART protocol Three-wire (H5) registered
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.768790] Bluetooth: HCI UART protocol Broadcom registered
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.944665] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.944673] Bluetooth: BNEP filters: protocol multicast
    Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.944686] Bluetooth: BNEP socket layer initialized
    Nov 26 14:17:29 raspberrypi4-iob kernel: [   31.834256] vcc-sd: disabling
    • Snowboarder2611S Snowboarder2611
      @snowboarder2611
      Installier da ein Bullseye in der 64Bit-Version frisch neu.
        Snowboarder2611
        schrieb am zuletzt editiert von Snowboarder2611
        OK,
        dann wird es für mich ab jetzt kompliziert.
        Ich lasse den Pi und Broker mit einer SSD laufen.
        Wie bekomme ich das hin, dass ich Bullseye in 64 Bit da rauf bekomme und am besten danach das Backup von Back it up drauf bekomme. Wie komme ich vor dem platt machen der SSD an diese Sicherung? In welchem Verzeichnis finde ich diese?
        Da müsste ich ein wenig an die Hand genommen werden.
        Ich stelle mir das so vor:
        -SSD löschen - nur wie, damit alles sauber weg ist? Als Platte unter Windows angeschlossen wird glaube ich nicht alles angezeigt.
        -Neues Bullseye auf die SSD -geht das so einfach? Dem Pi habe ich ja schon gesagt, dass er von SSD booten soll.
        -IO Broker drauf
        -Backup einspielen - hier benötige ich dann auch wieder Hilfe
          OK,
          -IO Broker drauf
          @snowboarder2611
          https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
          Backup dann halt über die von dir eingesetzte Methode.
          Am einfachsten geht es halt mit dem Backitup-Adapter.
            Snowboarder2611
            Ist die Vis irgendwo gesondert gesichert? Also auch meine selbst erstellten Bilder usw?
            Im Verzeichnis /opt/iobroker/backups liegen drei Backups 24. 25. 26.11. jeweils um die 9 mb groß.
            Die History ist extra. Diese könnte ich dann auch noch einspielen.
            Bevor ich die SSD platt mache will ich sicher sein, dass ich alles habe.
            G 1 Antwort Letzte Antwort
              guergen
              @snowboarder2611 Mit Backitup wird auch die VIS gesichert
                Snowboarder2611
                Ich habe eigene Icons in der Vis verwendet. Sind diese auch schon mit in der Sicherung enthalten?
                  Snowboarder2611
                  und Blockly ist auch komplett alles dabei?
                    @snowboarder2611
                    Wenn es so in Backitup eingestellt war: Ja.
                      Snowboarder2611
                      ich teste das mal mit einer zweiten Platte. Wenn dort nach dem Backup alles da ist, dann mache ich meine richtige SSD neu.
                        @snowboarder2611
                        Sonst nicht?
                        An dem Thema kommst du nicht vorbei, Backup hin oder her.
                          Snowboarder2611
                          Nein, neu machen ist klar.
                          Nur komme ich auf die zerschossene SSD noch an die Daten ran, falls irgend was nicht so richtig ist nach dem Backup.
                          Ich sehe jetzt schon, das die VIS nicht will.
                          Ich komme nicht drauf. File index.html not found steht da.
                          Die VIS Instanz lässt sich nicht bearbeiten über den Werkzeugschlüssel.
                          Inhaltlich scheint unter Dateien alles da zu sein.
                          Bei der Adapterübersicht ist laut der Info der Adapter nicht installiert.
                          Unter Instanzen wird der Adapter angezeigt aber es ist kein Logo der VIS zu sehen.
                          Kann ich da einfach den Adapter löschen und neu installieren? Und ist dann noch immer alles vorhanden?
                            @snowboarder2611
                            Die vis muss in einer alten Version installiert werden, dann das Backup drüber und final auf die aktuelle stabile Version updaten.
                              Snowboarder2611
                              Oh je,
                              und wie mache ich das jetzt?
                              IO Broker komplett wieder löschen? und dann alles von vorne?
                                Oh je,
                                @snowboarder2611
                                Nö, nur die Vis runterdrücken.
                                  Snowboarder2611
                                  also Vis löschen (den Adapter), dann neu installieren. OK
                                  Aber woher kommen die Backup Dateien? Soll ich dann einfach noch einmal das eben eingespielte Backup von Bachitup drüber laufen lassen?
                                    @snowboarder2611
                                    iobroker upgrade vis@1.4.10
                                    dann Update nochmal draufwerfen.
                                      Snowboarder2611
                                      soweit ist alles auf der neuen Platte am laufen. Ich beobachte das jetzt und werde, wenn alles OK ist morgen die ursprüngliche Platte neu aufsetzen.
                                      Vielen lieben Dank für die schnelle und kompretente Hilfe.
                                      Hier im Forum bekommt man immer nette Hilfestellungen.
                                        Snowboarder2611
                                        Eine kurze Frage habe ich noch.
                                        Was hat es eigentlich mit dem timeOffset von -60 bei den Systeminformationen zu tun?
                                        Ist das so richtig?
                                          Ist das so richtig?
                                          @snowboarder2611 sagte in IO Broker stürzt seit Samstag regelmäßig ab:
                                          Ist das so richtig?
                                          Ja. Das ist der Zeitabstand der Zeitzone in der du bist zur Nullzeit. Im Winter 60 Minuten, im Sommer 120.
