  4. IO Broker stürzt seit Samstag regelmäßig ab
    5.6k
31 Beiträge 3 Kommentatoren 3.4k Aufrufe 3 Beobachtet
  • Snowboarder2611S Snowboarder2611
    Skript v.0.0.7
    *** BASE SYSTEM ***
    Architecture:   armv7l
    Docker:         false
    Virtualization: none
    Distributor ID: Raspbian
    Description:    Raspbian GNU/Linux 10 (buster)
    Release:        10
    Codename:       buster
    PRETTY_NAME="Raspbian GNU/Linux 10 (buster)"
    NAME="Raspbian GNU/Linux"
    VERSION_ID="10"
    VERSION="10 (buster)"
    VERSION_CODENAME=buster
    ID=raspbian
    ID_LIKE=debian
    HOME_URL="http://www.raspbian.org/"
    SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
    BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
    Systemuptime and Load:
     10:08:10 up  9:14,  2 users,  load average: 7.30, 7.57, 7.18
    CPU threads: 4
    *** Time and Time Zones ***
    Mon Nov 28 09:08:10 UTC 2022
    Mon Nov 28 10:08:10 CET 2022
    CET +0100
    Europe/Berlin
    *** User and Groups ***
    pi
    /home/pi
    pi adm dialout cdrom sudo audio video plugdev games users input netdev gpio i2c spi iobroker
    *** X-Server-Setup ***
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Mem:           7.9G        4.1G        189M        408M        3.6G        3.2G
    Swap:           99M         99M          0B
    Total:         8.0G        4.2G        189M
             7897 M total memory
             4119 M used memory
             1632 M active memory
             5866 M inactive memory
              189 M free memory
                4 M buffer memory
             3584 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    *** FILESYSTEM ***
    /dev/root      ext4      917G  637G  243G  73% /
    devtmpfs       devtmpfs  3.7G     0  3.7G   0% /dev
    tmpfs          tmpfs     3.9G     0  3.9G   0% /dev/shm
    tmpfs          tmpfs     3.9G  409M  3.5G  11% /run
    tmpfs          tmpfs     3.9G     0  3.9G   0% /sys/fs/cgroup
    /dev/sda1      vfat      253M   49M  204M  20% /boot
    tmpfs          tmpfs     790M     0  790M   0% /run/user/1000
    TARGET        SOURCE    FSTYPE OPTIONS
    /             /dev/sda2 ext4   rw,noatime
    |-/sys/fs/bpf none      bpf    rw,nosuid,nodev,noexec,relatime,mode=700
    `-/boot       /dev/sda1 vfat   rw,relatime,fmask=0022,dmask=0022,codepage=437,iocharset=ascii,shortname=mixed,errors=remount-ro
    /var:
    595G    /var/
    594G    /var/log
    596M    /var/cache
    591M    /var/cache/apt
    532M    /var/cache/apt/archives
    /opt/iobroker/backups:
    5.8G    /opt/iobroker/backups/
    /opt/iobroker/iobroker-data:
    Skript v.0.0.7
    *** BASE SYSTEM ***
    Docker:         false
    Release:        10
    Codename:       buster
    VERSION_ID="10"
    ID=raspbian
    ID_LIKE=debian
    CPU threads: 4
    CET +0100
    Europe/Berlin
    pi
    /home/pi
    X-Server:       false
    Desktop:
    Terminal:       tty
    *** MEMORY ***
    Swap:           99M         99M          0B
             7897 M total memory
             4119 M used memory
              189 M free memory
                4 M buffer memory
             3584 M swap cache
               99 M total swap
               99 M used swap
                0 M free swap
    *** FILESYSTEM ***
    /var:
    595G    /var/
    594G    /var/log
    596M    /var/cache
    591M    /var/cache/apt
    32G     /opt/iobroker/iobroker-data/
    31G     /opt/iobroker/iobroker-data/history
    457M    /opt/iobroker/iobroker-data/files
    184M    /opt/iobroker/iobroker-data/backup-objects
    121M    /opt/iobroker/iobroker-data/files/scenes.admin/static/js
    23M     /opt/iobroker/iobroker-data/objects.jsonl
    21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.2e59ed19.chunk.js.map
    21M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.00a59c14.chunk.js.map
    18M     /opt/iobroker/iobroker-data/files/devices.admin/static/js/2.3257a139.chunk.js.map
    16M     /opt/iobroker/iobroker-data/objects.json.migrated
    *** NodeJS-Installation ***
    /usr/bin/nodejs         v16.18.1
    /usr/bin/node           v16.18.1
    /usr/bin/npm            8.19.2
    nodejs:
      Installed: 16.18.1-deb-1nodesource1
      Candidate: 16.18.1-deb-1nodesource1
      Version table:
     *** 16.18.1-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
         10.24.0~dfsg-1~deb10u2 500
    Calling 'npm doctor' for you. Please be patient!
    npm WARN verifyCachedFiles Content garbage-collected: 4271 (496599570 bytes)
    npm WARN verifyCachedFiles Cache issues have been fixed
    Check                               Value   Recommendation/Notes
    npm ping                            ok
    npm -v                              not ok  Use npm v9.1.2
    node -v                             not ok  Use node v18.12.1 (current: v16.18.1)
    npm config get registry             ok      using default registry (https://registry.npmjs.org/)
    which git                           ok      /usr/bin/git
    Perms check on cached files         ok
    Perms check on local node_modules   ok
    Perms check on global node_modules  ok
    Perms check on local bin folder     ok
    Perms check on global bin folder    ok
    Verify cache contents               ok      verified 5170 tarballs
    npm ERR! Some problems found. See above for recommendations.
    npm ERR!     /home/iobroker/.npm/_logs/2022-11-28T09_12_18_474Z-debug-0.log
    The recommended versions for ioBroker are nodeJS v16 / npm v8!
    Don't trust the doctor if he recommends different versions!
    *** ioBroker-Installation ***
    ioBroker Status
    Ab hier hängt nun auch das Tool. Mehr macht es nicht.
    @snowboarder2611 sagte in IO Broker stürzt seit Samstag regelmäßig ab:
    Das läuft noch. Aber dein System ist so überlastet, das dauert. Ich vermute, da ist dir ein Skript explodiert.
    Irgendwas knallt dir da auch in ein Log heftig was rein:
    594G /var/log
    Schau da mal genauer rein.
    • Snowboarder2611S Offline
      Snowboarder2611
      in dem Verzeichnis liegt eine kern.log mit ca 260 GB
      Diese lade ich mir mal rüber auf meinen PC. das dauert etwas. Dann schaue ich da mal rein.
      Was ist das eigentlich für eine Logdatei? Ist diese standard?
        @snowboarder2611
        Das ist sowas von Standard...
        Ist das Log Files vom Kernel. Dem tut also irgendwas weh.
        tail -n 30 /var/log/kern.log
        zeigt die letzten 30 Zeilen. Oft reicht das schon aus um zu sehen wo es da klemmt.
          Snowboarder2611
          @thomas-braun said in IO Broker stürzt seit Samstag regelmäßig ab:
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.067715] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.067755] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.067793] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.067832] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.067871] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.067909] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.067949] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.067987] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068026] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068065] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068104] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068143] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068182] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068221] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068260] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068298] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068337] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068376] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068415] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068454] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068493] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068532] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068570] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068609] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068648] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068687] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068726] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068764] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068803] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
          Nov 28 11:30:12 raspberrypi4-iob kernel: [38220.068842] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
            Snowboarder2611
            syslog hat 98 gb und syslog.1 162 gb
            • Thomas BraunT Online
              @snowboarder2611
              Auch alles zu groß.
              Schau auch da mal mit tail rein.
                Snowboarder2611
                Syslog:
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214546] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214585] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214651] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214693] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214731] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214770] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214808] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214847] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214885] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.214975] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215019] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215059] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215098] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215138] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215177] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215217] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215256] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215367] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215443] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215483] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215522] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215582] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215624] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215725] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215771] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215811] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215851] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215890] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215929] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 11:37:36 raspberrypi4-iob kernel: [38664.215968] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Syslog.1
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863480] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863518] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863556] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863594] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863635] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863676] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863714] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863752] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863792] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863830] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863868] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863906] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863944] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.863982] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864020] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864058] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864097] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864136] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864178] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864217] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864256] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864302] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864352] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864397] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864441] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864484] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864527] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864565] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864604] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                Nov 28 00:43:28 raspberrypi4-iob kernel: [37365.864643] Unhandled prefetch abort: breakpoint debug exception (0x222) at 0x00000000
                  Snowboarder2611
                  kern.log.1 ist auch 105gb groß
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    6.963594] [drm] No displays found. Consider forcing hotplug if HDMI is attached
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    6.963732] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    6.969300] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    7.152748] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    7.153245] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    7.162442] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan  4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    8.963834] 8021q: 802.1Q VLAN Support v1.8
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    8.992480] uart-pl011 fe201000.serial: no DMA platform data
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.139838] random: crng init done
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.139867] random: 7 urandom warning(s) missed due to ratelimiting
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.274378] Adding 102396k swap on /var/swap.  Priority:-2 extents:2 across:34623152k SSFS
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.282362] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.496232] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
                  Nov 26 14:17:06 raspberrypi4-iob kernel: [    9.496502] bcmgenet fd580000.ethernet eth0: Link is Down
                  Nov 26 14:17:12 raspberrypi4-iob kernel: [   14.714559] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
                  Nov 26 14:17:12 raspberrypi4-iob kernel: [   14.714617] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761061] Bluetooth: Core ver 2.22
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761181] NET: Registered protocol family 31
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761197] Bluetooth: HCI device and connection manager initialized
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761227] Bluetooth: HCI socket layer initialized
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761250] Bluetooth: L2CAP socket layer initialized
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.761288] Bluetooth: SCO socket layer initialized
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.768309] Bluetooth: HCI UART driver ver 2.3
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.768331] Bluetooth: HCI UART protocol H4 registered
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.768461] Bluetooth: HCI UART protocol Three-wire (H5) registered
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.768790] Bluetooth: HCI UART protocol Broadcom registered
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.944665] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.944673] Bluetooth: BNEP filters: protocol multicast
                  Nov 26 14:17:13 raspberrypi4-iob kernel: [   15.944686] Bluetooth: BNEP socket layer initialized
                  Nov 26 14:17:29 raspberrypi4-iob kernel: [   31.834256] vcc-sd: disabling
                    @snowboarder2611
                    Installier da ein Bullseye in der 64Bit-Version frisch neu.
                      Snowboarder2611
                      schrieb am zuletzt editiert von Snowboarder2611
                      OK,
                      dann wird es für mich ab jetzt kompliziert.
                      Ich lasse den Pi und Broker mit einer SSD laufen.
                      Wie bekomme ich das hin, dass ich Bullseye in 64 Bit da rauf bekomme und am besten danach das Backup von Back it up drauf bekomme. Wie komme ich vor dem platt machen der SSD an diese Sicherung? In welchem Verzeichnis finde ich diese?
                      Da müsste ich ein wenig an die Hand genommen werden.
                      Ich stelle mir das so vor:
                      -SSD löschen - nur wie, damit alles sauber weg ist? Als Platte unter Windows angeschlossen wird glaube ich nicht alles angezeigt.
                      -Neues Bullseye auf die SSD -geht das so einfach? Dem Pi habe ich ja schon gesagt, dass er von SSD booten soll.
                      -IO Broker drauf
                      -Backup einspielen - hier benötige ich dann auch wieder Hilfe
                        OK,
                        -IO Broker drauf
                        @snowboarder2611
                        https://forum.iobroker.net/topic/51869/installation-auf-raspi-einfacher-geht-s-nicht
                        Backup dann halt über die von dir eingesetzte Methode.
                        Am einfachsten geht es halt mit dem Backitup-Adapter.
                          Snowboarder2611
                          Ist die Vis irgendwo gesondert gesichert? Also auch meine selbst erstellten Bilder usw?
                          Im Verzeichnis /opt/iobroker/backups liegen drei Backups 24. 25. 26.11. jeweils um die 9 mb groß.
                          Die History ist extra. Diese könnte ich dann auch noch einspielen.
                          Bevor ich die SSD platt mache will ich sicher sein, dass ich alles habe.
                          G 1 Antwort Letzte Antwort
                            guergen
                            @snowboarder2611 Mit Backitup wird auch die VIS gesichert
                              Snowboarder2611
                              Ich habe eigene Icons in der Vis verwendet. Sind diese auch schon mit in der Sicherung enthalten?
                                Snowboarder2611
                                und Blockly ist auch komplett alles dabei?
                                  @snowboarder2611
                                  Wenn es so in Backitup eingestellt war: Ja.
                                    Snowboarder2611
                                    ich teste das mal mit einer zweiten Platte. Wenn dort nach dem Backup alles da ist, dann mache ich meine richtige SSD neu.
                                      @snowboarder2611
                                      Sonst nicht?
                                      An dem Thema kommst du nicht vorbei, Backup hin oder her.
                                        Snowboarder2611
                                        Nein, neu machen ist klar.
                                        Nur komme ich auf die zerschossene SSD noch an die Daten ran, falls irgend was nicht so richtig ist nach dem Backup.
                                        Ich sehe jetzt schon, das die VIS nicht will.
                                        Ich komme nicht drauf. File index.html not found steht da.
                                        Die VIS Instanz lässt sich nicht bearbeiten über den Werkzeugschlüssel.
                                        Inhaltlich scheint unter Dateien alles da zu sein.
                                        Bei der Adapterübersicht ist laut der Info der Adapter nicht installiert.
                                        Unter Instanzen wird der Adapter angezeigt aber es ist kein Logo der VIS zu sehen.
                                        Kann ich da einfach den Adapter löschen und neu installieren? Und ist dann noch immer alles vorhanden?
                                          @snowboarder2611
                                          Die vis muss in einer alten Version installiert werden, dann das Backup drüber und final auf die aktuelle stabile Version updaten.
