  4. ERROR: Process exited with code 25 NPM Update usw
    5.6k
42 Beiträge 5 Kommentatoren 5.4k Aufrufe 3 Beobachtet
  • N n811e
    @thomas-braun said in ERROR: Process exited with code 25 NPM Update usw:
    iobroker update
    Das kommt als Rückmeldung
    pi@raspberrypi:~ $ iobroker update
    Used repository: stable
    Adapter    "admin"        : 6.2.23   , installed 6.2.22 [Updatable]
    Adapter    "alexa2"       : 3.21.0   , installed 3.19.9 [Updatable]
    Adapter    "alias-manager": 1.2.4    , installed 1.2.4
    Adapter    "backitup"     : 2.5.4    , installed 2.4.12 [Updatable]
    Adapter    "chromecast"   : 2.3.1    , installed 2.3.1
    Adapter    "cloud"        : 4.2.2    , installed 4.2.2
    Adapter    "device-watcher": 2.0.2   , installed 1.0.0  [Updatable]
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Adapter    "ecovacs-deebot": 1.4.4   , installed 1.4.4
    Adapter    "firetv"       : 1.0.0    , installed 1.0.0
    Adapter    "history"      : 2.2.0    , installed 2.2.0
    Adapter    "hm-rega"      : 3.0.40   , installed 3.0.40
    Adapter    "hm-rpc"       : 1.15.12  , installed 1.15.12
    Adapter    "homeconnect"  : 1.1.0    , installed 1.0.1  [Updatable]
    Adapter    "influxdb"     : 3.1.8    , installed 3.1.8
    Adapter    "iot"          : 1.11.9   , installed 1.11.9
    Adapter    "jarvis"       : 3.0.15   , installed 3.0.13 [Updatable]
    Adapter    "javascript"   : 6.0.3    , installed 6.0.0  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "material"     : 1.1.2    , installed 1.1.2
    Adapter    "mqtt"         : 4.0.7    , installed 4.0.7
    Adapter    "net-tools"    : 0.2.0    , installed 0.2.0
    Adapter    "node-red"     : 4.0.0    , installed 4.0.0
    Adapter    "onvif"        : 0.4.4    , installed 0.4.4
    Adapter    "pushover"     : 3.0.3    , installed 3.0.3
    Adapter    "samsung"      : 0.5.8    , installed 0.5.8
    Adapter    "shelly"       : 6.0.0    , installed 6.0.0
    Adapter    "simple-api"   : 2.7.0    , installed 2.7.0
    Adapter    "sonoff"       : 2.5.1    , installed 2.5.1
    Adapter    "synology"     : 2.1.13   , installed 2.1.9  [Updatable]
    Adapter    "tankerkoenig" : 2.1.1    , installed 2.1.1
    Adapter    "tr-064"       : 4.2.16   , installed 4.2.16
    Adapter    "upnp"         : 1.0.21   , installed 1.0.21
    Adapter    "vis-canvas-gauges": 0.1.5, installed 0.1.5
    Adapter    "vis-colorpicker": 1.2.0  , installed 1.2.0
    Adapter    "vis-hqwidgets": 1.3.0    , installed 1.3.0
    Adapter    "vis-icontwo"  : 0.89.0   , installed 0.89.0
    Adapter    "vis-inventwo" : 3.3.1    , installed 3.3.1
    Adapter    "worx"         : 2.0.3    , installed 1.6.6  [Updatable]
    Adapter    "yahka"        : 0.13.1   , installed 0.13.1
    Adapter    "zigbee"       : 1.7.5    , installed 1.7.5
    pi@raspberrypi:~ $
    @n811e
    iobroker upgrade admin --debug
    Ist das Ding hier:
    https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
    N 1 Antwort Letzte Antwort
      @n811e
      Ist das Ding hier:
      N Offline
      N Offline
      n811e
      iobroker ugrade admin --debug
      Ich habe den iobroker gestoppt und dann folgendes ausgeführt:
      pi@raspberrypi:~ $ iobroker stop
      pi@raspberrypi:~ $ iobroker ugrade admin --debug
      iobroker [command]
      Commands:
        iobroker setup                                               Setup ioBroker
        iobroker start [all|<adapter>.<instance>]                    Starts the js-controller or a specified adapter instance
        iobroker stop [<adapter>.<instance>]                         stops the js-controller or a specified adapter instance
        iobroker restart [<adapter>.<instance>]                      Restarts js-controller or a specified adapter instance  [aliases: r]
        iobroker debug <adapter>[.<instance>]                        Starts a Node.js debugging session for the adapter instance
        iobroker info                                                Shows the host info
        iobroker logs [<adapter>]                                    Monitor log
        iobroker add <adapter> [desiredNumber]                       Add instance of adapter  [aliases: a]
        iobroker install <adapter>                                   Installs a specified adapter  [aliases: i]
        iobroker rebuild [<module>]                                  Rebuild all native modules or path
        iobroker url <url> [<name>]                                  Install adapter from specified url, e.g. GitHub
        iobroker del <adapter>                                       Remove adapter and all instances from this host  [aliases: delete]
        iobroker del <adapter>.<instance>                            Remove adapter instance  [aliases: delete]
        iobroker update [<repositoryUrl>]                            Update repository and list adapters
        iobroker upgrade                                             Upgrade management
        iobroker upload [all|<adapter>]                              Upload management  [aliases: u]
        iobroker object                                              Object management  [aliases: o]
        iobroker state                                               State management  [aliases: s]
        iobroker message <adapter>[.instance] <command> [<message>]  Send message to adapter instance/s
        iobroker list <type> [<filter>]                              List all entries, like objects
        iobroker chmod <mode> <file>                                 Change file rights
        iobroker chown <user> <group> <file>                         Change file ownership
        iobroker touch <file>                                        Touch file
        iobroker rm <file>                                           Remove file
        iobroker file                                                File management
        iobroker user                                                User commands
        iobroker group                                               group management
        iobroker host <hostname>                                     Set host to given hostname
        iobroker set <adapter>.<instance>                            Change settings of adapter config
        iobroker license <license.file or license.text>              Update license by given file
        iobroker cert                                                Certificate management
        iobroker clean <yes>                                         Clears all objects and states
        iobroker backup                                              Create backup
        iobroker restore <backup name or path>                       Restore a specified backup
        iobroker validate <backup name or path>                      Validate a specified backup
        iobroker status [all|<adapter>.<instance>]                   Status of ioBroker or adapter instance  [aliases: isrun]
        iobroker repo [<name>]                                       Show repo information
        iobroker uuid                                                Show uuid of the installation  [aliases: id]
        iobroker unsetup                                             Reset license, installation secret and language
        iobroker fix                                                 Execute the installation fixer script, this updates your ioBroker installation
        iobroker multihost                                           Multihost management
        iobroker compact                                             compact group management
        iobroker plugin                                              Plugin management
        iobroker version [<adapter>]                                 Show version of js-controller or specified adapter  [aliases: v]
      Options:
        --help  Show help  [boolean]
      • N n811e
        iobroker [command]
        Commands:
        Options:
        @n811e
        Da fehlt ein p
        N 2 Antworten Letzte Antwort
          @n811e
          Da fehlt ein p
          N Offline
          N Offline
          n811e
          @n811e
          Da fehlt ein p
          Vielen Dank für den Hinweis.
          Jetzt habe ich wieder keinen Webzugriff auf ioBroker.
          Wenn ich jetzt iobroker add admin --enabled --port 8089 ausführen würde, käme ich wieder drauf, hätte aber eine neu Admin Instanz und das Thema ginge von vorn los
          Was kann ich jetzt am besten machen?
            @n811e
            Da fehlt ein p
            N Offline
            N Offline
            n811e
            @n811e
            Da fehlt ein p
            Ausgeworfen hat er:
            pi@raspberrypi:~ $ iobroker upgrade admin --debug
            This upgrade of "admin" will introduce the following changes:
            -> 6.2.23:
            Prepare for future js-controller versions
            Corrected deletion of objects
            Would you like to upgrade admin from @6.2.22 to @6.2.23 now? [(y)es, (n)o]: y
            Update admin from @6.2.22 to @6.2.23
            host.raspberrypi Adapter "system.adapter.admin.3" is stopped.
            NPM version: 8.19.2
            Installing iobroker.admin@6.2.23... (System call)
            npm ERR! code ENOTEMPTY
            npm ERR! syscall rename
            npm ERR! path /opt/iobroker/node_modules/acorn
            npm ERR! dest /opt/iobroker/node_modules/.acorn-zHERliMH
            npm ERR! errno -39
            npm ERR! ENOTEMPTY: directory not empty, rename '/opt/iobroker/node_modules/acorn' -> '/opt/iobroker/node_modules/.acorn-zHERliMH'
            npm ERR!     /home/iobroker/.npm/_logs/2022-11-20T15_39_58_825Z-debug-0.log
            host.raspberrypi Cannot install iobroker.admin@6.2.23: 217
            • N n811e
              @n811e
              Da fehlt ein p
              Ausgeworfen hat er:
              -> 6.2.23:
              NPM version: 8.19.2
              npm ERR! errno -39
              HomoranH Offline
              HomoranH Offline
              @n811e sagte in ERROR: Process exited with code 25 NPM Update usw:
              217
              hier ist es zwar ein 217, aber ich denke du solltest mal das oben angepinnte Procedere für Error 25 durchgehen
                217
                N Offline
                N Offline
                n811e
                @homoran said in ERROR: Process exited with code 25 NPM Update usw:
                217
                Ja, aber genau da bin ich ja dran. Der erste Schritt war das mit dem --debug und hier gehts ja dann schon nicht weiter
                Oder habe ich etwas falsch verstanden?
                GlasfaserG HomoranH 2 Antworten Letzte Antwort
                • N n811e
                  217
                  GlasfaserG Offline
                  GlasfaserG Offline
                  Das meint @Homoran
                  • N n811e
                    217
                    HomoranH Offline
                    HomoranH Offline
                    was definierst du mit falsch!
                    der Befehl mit angehängtem --debug ist ja nur dazu da, um die mögliche Ursache zu finden, indem detailliertere Fehlermeldungen ausgeworfen werden.
                    Dies ist z.B. die Info mit ENOTEMPTY und der dazu gehörenden Aufforderung, ein Verzeichnis mit einer kryptischen Bezeichnung umzubenennen.
                    üblicherweise käme jetzt noch der ERROR25, bei dir aber der 217
                    • GlasfaserG Glasfaser
                      Das meint @Homoran
                      N Offline
                      N Offline
                      n811e
                      @glasfaser said in ERROR: Process exited with code 25 NPM Update usw:
                      Das meint @Homoran
                      Ja, dass ist doch das, was ich versuche abzuarbeiten. Aber da steht doch nur das mit dem --debug drin.
                      Danach wird es so kryptisch, dass ich kein Wort verstehe geschweige denn umzusetzen.
                      Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                      • N n811e
                        Das meint @Homoran
                        @n811e
                        Du musst das auch nicht verstehen. Nur den ersten Befehlseinzeiler in dein Terminal kopieren.
                        • N n811e
                          Das meint @Homoran
                          GlasfaserG Offline
                          GlasfaserG Offline
                          @n811e
                          Nimm doch einmal diesen Befehl :
                          for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do rm -rf ${i%%/}; done
                            N Offline
                            N Offline
                            n811e
                            Naja, mit falsch definiere ich, ob ich irgendwo einen Fehler mache.
                            Ich kann dieser Anleitung außer --debug (was ich jetzt gelern habe, dass das hinter iobroker upgrade adapterName kommt) nicht weiter folgen.
                            • N n811e
                              GlasfaserG Offline
                              GlasfaserG Offline
                              siehe Antwort über deine !
                                @n811e
                                N Offline
                                N Offline
                                n811e
                                @n811e
                                Das habe ich jetzt probiert, im Terminal sehe ich keine Regung. Muss da etwas passieren? Zugriff auf das Webinterface habe ich dadurch auch nicht erhalten.
                                An dem Befehl muss ich nichts ändern?
                                GlasfaserG HomoranH 3 Antworten Letzte Antwort
                                • N n811e
                                  @n811e
                                  GlasfaserG Offline
                                  GlasfaserG Offline
                                  NEIN ... nicht´s daran ändern !!
                                  Das nicht´s kommt ist richtig !
                                  • N n811e
                                    @n811e
                                    HomoranH Offline
                                    HomoranH Offline
                                    so weit sind wir noch nicht, bitte keine operative Hektik
                                    https://forum.iobroker.net/post/884324
                                    was kommt jetzt bei iobroker upgrade wasauchimmer --debug ??
                                    • N n811e
                                      @n811e
                                      GlasfaserG Offline
                                      GlasfaserG Offline
                                      @n811e
                                      und jetzt
                                      "müßte" dann ohne Fehler durchlaufen
                                        N Offline
                                        N Offline
                                        n811e
                                        jetzt kommt das:
                                        pi@raspberrypi:~ $ iobroker upgrade device-watcher --debug
                                        This upgrade of "device-watcher" will introduce the following changes:
                                        -> 2.0.2:
                                        added status to battery list
                                        batt devices which are offline are now still included in the battery list
                                        small improvements of translations
                                        offline time settings: you can use 0 instead of -1 (it will be the new standard)
                                        improvements of adaptername
                                        fixed issues [#66](https://github.com/ciddi89/ioBroker.device-watcher/issues/66) & [#67](https://github.com/ciddi89/ioBroker.device-watcher/issues/67)
                                        repaired blacklist notifications
                                        added handling for blacklist object
                                        -> 2.0.1:
                                        If the device is offline, set signal strength to '0%'
                                        If the device is offline, set battery to ' - '
                                        repair some small issues in the lists
                                        -> 2.0.0:
                                        added Lupusec, HS100 adapter, Zigbee2MQTT and MaxCube
                                        changed name of Homematic to HM-RPC
                                        made a completly makeover of the blacklist
                                        clean up the code and shorten some
                                        -> 1.1.0:
                                        removed indicatoren for daily sent messages
                                        changed selector for shelly devices
                                        added Zigbee2MQTT adapter
                                        added cron function to use own time for daily overview messages
                                        -> 1.0.1:
                                        added WLED, Ikea Tradfri, Roomba, HmIp, Tado, Netatmo, Yeelight-2, Unifi, Nut and Meross adapter
                                        fixed battery message
                                        corrected and repaired some issues of last contact time
                                        added support for old HM devices
                                        some small refactoring of code
                                        changed shelly selector from dp rssi to dp online
                                        BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
                                        Would you like to upgrade device-watcher from @1.0.0 to @2.0.2 now? [(y)es, (n)o]: y
                                        Update device-watcher from @1.0.0 to @2.0.2
                                        NPM version: 8.19.2
                                        Installing iobroker.device-watcher@2.0.2... (System call)
                                        added 7 packages, removed 1508 packages, and changed 7 packages in 28s
                                        36 packages are looking for funding
                                          run `npm fund` for details
                                        Update "system.adapter.device-watcher.0"
                                        upload [19] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/device-watcher.png device-watcher.png image/png
                                        upload [18] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/de/translations.json i18n/de/translations.json application/json
                                        upload [17] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/en/translations.json i18n/en/translations.json application/json
                                        upload [16] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/es/translations.json i18n/es/translations.json application/json
                                        upload [15] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
                                        upload [14] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/it/translations.json i18n/it/translations.json application/json
                                        upload [13] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
                                        upload [12] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
                                        upload [11] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
                                        upload [10] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
                                        upload [9] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/uk/translations.json i18n/uk/translations.json application/json
                                        upload [8] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
                                        upload [7] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/add_blacklist.png images/add_blacklist.png image/png
                                        upload [6] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list1.png images/list1.png image/png
                                        upload [5] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list2.png images/list2.png image/png
                                        upload [4] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/images/list3.png images/list3.png image/png
                                        upload [3] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/index_m.html index_m.html text/html
                                        upload [2] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/jsonConfig.json jsonConfig.json application/json
                                        upload [1] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/style.css style.css text/css
                                        upload [0] device-watcher.admin /opt/iobroker/node_modules/iobroker.device-watcher/admin/words.js words.js application/javascript
                                        pi@raspberrypi:~ $
                                        HomoranH GlasfaserG 2 Antworten Letzte Antwort
                                        • N n811e
                                          jetzt kommt das:
                                          -> 2.0.2:
                                          -> 2.0.1:
                                          -> 2.0.0:
                                          -> 1.1.0:
                                          -> 1.0.1:
                                          NPM version: 8.19.2
                                          pi@raspberrypi:~ $
                                          HomoranH Offline
                                          HomoranH Offline
                                          jetzt kommt das:
                                          sieht das aus wie
                                          Ist doch jetzt alles gefixt.
