  4. Solarman PV, Bosswerk MI & Deye
    1.7k
    1.5k
jetz
565 Beiträge 68 Kommentatoren 255.5k Aufrufe 65 Beobachtet
  • webwalker2001W webwalker2001
    Hallo in die Runde,
    ich bekomme ab und zu folgende Fehlermeldungen:
    solarmanpv.0 2022-11-08 08:00:11.819	error	DB closed
    solarmanpv.0 2022-11-08 08:00:11.818	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
    solarmanpv.0 2022-11-08 08:00:11.818	error	unhandled promise rejection: DB closed
    solarmanpv.0 2022-11-08 08:00:11.817	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    solarmanpv.0 2022-11-08 08:00:11.815	error	DB closed
    solarmanpv.0 2022-11-08 08:00:11.815	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
    solarmanpv.0 2022-11-08 08:00:11.814	error	unhandled promise rejection: DB closed
    solarmanpv.0 2022-11-08 08:00:11.813	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    solarmanpv.0 2022-11-08 08:00:11.809	error	DB closed
    solarmanpv.0 2022-11-08 08:00:11.808	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
    solarmanpv.0 2022-11-08 08:00:11.806	error	unhandled promise rejection: DB closed
    solarmanpv.0 2022-11-08 08:00:11.805	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    solarmanpv.0 2022-11-08 08:00:11.804	error	DB closed
    solarmanpv.0 2022-11-08 08:00:11.802	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
    solarmanpv.0 2022-11-08 08:00:11.801	error	unhandled promise rejection: DB closed
    solarmanpv.0 2022-11-08 08:00:11.798	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    solarmanpv.0 2022-11-08 08:00:11.794	error	DB closed
    solarmanpv.0 2022-11-08 08:00:11.793	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
    solarmanpv.0 2022-11-08 08:00:11.792	error	unhandled promise rejection: DB closed
    solarmanpv.0 2022-11-08 08:00:11.791	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    solarmanpv.0 2022-11-08 08:00:11.786	error	DB closed
    solarmanpv.0 2022-11-08 08:00:11.785	error	Error: DB closed at close (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:184:25) at Socket.<anonymous> (/opt/iobroker/node_modules/ioredis/built/redis/event_handler.js:151:20) at Object.onceWrapper (node:events:628:26) at Socket.emit (node:events:513:28) at TCP.<anonymous> (node:net:301:12)
    solarmanpv.0 2022-11-08 08:00:11.780	error	unhandled promise rejection: DB closed
    solarmanpv.0 2022-11-08 08:00:11.779	error	Unhandled promise rejection. This error originated either by throwing inside of an async function without a catch block, or by rejecting a promise which was not handled with .catch().
    solarmanpv.0 2022-11-08 08:00:11.776	error	DB closed
    Scheint aber sonst zu laufen.
    Mein System:
    RasPi4 mit 4GB
    Node.js v16.18.1
    NPM 8.19.2
    Admin v6.2.23
    LG
    webwalker2001
    Rene55R
    Rene55R
    Rene55
    #169
    @webwalker2001 Uiuiuiui! So sollte das aber nicht sein. Das System scheint auf den ersten Blick aktuell zu sein. Kannst du bitte den Adapter mal stoppen, etwas warten und dann neu starten. Und dann das Log mal hier einstellen. Dann schau ich mal drüber.
    webwalker2001W 1 Antwort Letzte Antwort
    • M
      M
      matthias425
      #170
      seit kurzem habe ich auch den MI600 von Bosswerk in Betrieb.
      Freudig habe ich gesehen das sich Rainer die Mühe gemacht hat einen Adapter bereit zu stellen. Vielen Dank dafür!!!
      Leider funktioniert es bei mir nicht. Ich poste mal was ich habe/bekomme, vielleicht hat jemand eine Idee die mich weiterbringt.
      Der Adapter ist installiert und läuft, Daten wurden beim Service angefragt und sind eingetragen.
      In den Objekten bekomme ich folgenden Baum:
      Fehlermeldung im Protokoll:
      2022-11-08 18:12:00.834 - info: solarmanpv.0 (1195) starting. Version 0.2.0 (non-npm: raschy/ioBroker.solarmanpv#3d5f8fd317909365be11f8677de5938a2182cc59) in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v14.19.0, js-controller: 4.0.23
      2022-11-08 18:12:04.288 - warn: solarmanpv.0 (1195) [initializeStation] error: could not retrieve token.
      2022-11-08 18:12:04.289 - info: solarmanpv.0 (1195) Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
      2022-11-08 18:12:04.803 - info: host.iobroker instance system.adapter.solarmanpv.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
      Mein System:
      Node.js: v14.19.0
      NPM: v6.14.16
      Admin: 6.2.22
      Vielen Dank und viele Grüße
      Matthias
      • M matthias425
        Mein System:
        Node.js: v14.19.0
        NPM: v6.14.16
        Admin: 6.2.22
        Matthias
        Rene55R
        Rene55R
        Rene55
        #171
        @matthias425 Hallo, wie ich sehen konnte, ist dein System noch auf mode.js 14.x. Kannst du bitte dein System auf node 16.x hochziehen. Das hatten wir gestern auch schon mal, das hat dann geholfen.
        • M
          M
          matthias425
          #172
          @Rene55 : Hallo Rene, ich habe mein System hoch gezogen
          Node.js: v16.18.0
          NPM: 8.19.2
          Admin 6.2.23
          leider hat sich das Verhalten nicht geändert
          Hast du noch eine Idee? :-)
          LG
          • M
            M
            matthias425
            #173
            @Rene55: Ergänzung, ich habe die Instanz neu installiert. Nun geht es.
            Ich denke die Lösung war die Node.js 16
            Vielen Dank!
            • M matthias425
              Vielen Dank!
              Rene55R
              Rene55R
              Rene55
              #174
              @matthias425 Hallo Matthias,
              schön dass es jetzt funktioniert hat. Ja irgendwas darin möchte gerne die aktuelle node.js Version haben. Hauptsache es fluppt.
              LG
              • Rene55R Rene55
                @burgi Hallo Thomas, ist ja fast perfekt. Die (derzeit) finale Version 0.2.0 habe ich gerade gebaut - da sollte man bei Gelegenheit updaten.
                LG Rainer
                B
                B
                Burgi
                #175
                @rene55 Hallo Rainer,
                das ist ja super, vielen Dank.
                Werde ich gleich heute Anend machen.
                Viele Grüße
                Thomas
                • C
                  C
                  cy_coe
                  #176
                  Vielen Dank für den Adapter! Mein Microinverter ist ein Deye SUN600G3
                  -EU-230. Funktioniert bestens mit diesem Adapter.
                  Rene55R B 2 Antworten Letzte Antwort
                  • C cy_coe
                    Rene55R
                    Rene55R
                    Rene55
                    #177
                    @cy_coe Danke für die Rückmeldung. Dann kann ich ja bald mal eine Liste mit funktionierenden Geräten aufstellen.
                    • Rene55R Rene55
                      webwalker2001W
                      webwalker2001W
                      webwalker2001
                      #178
                      @rene55 Hi, hier der log.
                      Aber wie gesagt, die Fehlermeldungen kommen nur manchmal. Hab noch nicht den Zusammenhang herausgefunden.
                      solarmanpv.0 2022-11-10 22:54:39.800	debug	[onReady] started: solarmanpv.0
                      solarmanpv.02 022-11-10 22:54:39.731	info	starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v16.18.1, js-controller: 4.0.23
                      solarmanpv.0 2022-11-10 22:54:43.223	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Everything done. Going to terminate till next schedule
                      solarmanpv.0 2022-11-10 22:54:43.221	debug	[onReady] finished - stopping instance
                      solarmanpv.0 2022-11-10 22:54:42.834	debug	[getDeviceData] Device ID >: 217801816 and Device SN >: 2205037328
                      solarmanpv.0 2022-11-10 22:54:42.546	debug	[initializeInverter] InverterTyp: MICRO_INVERTER
                      solarmanpv.0 2022-11-10 22:54:42.545	debug	[initializeInverter] StationID >: 2633791
                      solarmanpv.0 2022-11-10 22:54:39.731	info	starting. Version 0.2.0 in /opt/iobroker/node_modules/iobroker.solarmanpv, node: v16.18.1, js-controller: 4.0.23
                      solarmanpv.0 2022-11-10 22:54:38.613	debug	States connected to redis: 127.0.0.1:9000
                      solarmanpv.0 2022-11-10 22:54:38.380	debug	States create User PubSub Client
                      solarmanpv.0 2022-11-10 22:54:38.376	debug	States create System PubSub Client
                      solarmanpv.0 2022-11-10 22:54:38.289	debug	Redis States: Use Redis connection: 127.0.0.1:9000
                      solarmanpv.0 2022-11-10 22:54:38.150	debug	Objects connected to redis: 127.0.0.1:9001
                      solarmanpv.0 2022-11-10 22:54:38.060	debug	Objects client initialize lua scripts
                      solarmanpv.0 2022-11-10 22:54:37.837	debug	Objects create User PubSub Client
                      solarmanpv.0 2022-11-10 22:54:37.835	debug	Objects create System PubSub Client
                      solarmanpv.0 2022-11-10 22:54:37.827	debug	Objects client ready ... initialize now
                      solarmanpv.0 2022-11-10 22:54:37.718	debug	Redis Objects: Use Redis connection: 127.0.0.1:9001
                      lg
                      Webwalker2001
                        lg
                        Webwalker2001
                        Rene55R
                        Rene55R
                        Rene55
                        schrieb am zuletzt editiert von Rene55
                        #179
                        @webwalker2001 Hallo, das sieht eigentlich ganz gut aus. Station und Device wurden erkannt. Im Protokoll sehen diese Zeilen:
                        wie dubletten aus. Ist dein System sehr ausgelastet?
                        Ab und an kann eine Warnung wie diese
                        solarmanpv.0
                        2022-11-11 09:30:06.711	warn	[getDeviceData] error: AxiosError: timeout of 2000ms exceeded
                        auftreten. Das ist normal und ist dem geschuldet, dass der China-Server gerade nicht schnell genug antworten konnte.
                        • Rene55R Rene55
                          solarmanpv.0
                          webwalker2001W
                          webwalker2001W
                          webwalker2001
                          #180
                          @rene55 Mein CPU-Load liegt so zwischen 35%-50%. RAM bei ca. 50%. Sollte eigentlich passen. Kann man den Timeout evtl. irgendwo einstellen?
                          lg
                          webwalker2001
                            lg
                            webwalker2001
                            Rene55R
                            Rene55R
                            Rene55
                            #181
                            @webwalker2001 Das ist nicht vorgesehen bzw. macht auch keinen Sinn. Wenn der Server nicht in 2 Sekunden geantwortet hat, tuts der auch nicht in einer Minute. Also ignorieren und auf die nächste Abfrage warten.
                            • ralleR
                              ralleR
                              ralle
                              #182
                              Ich wolltw den Adapter auch nutzen, den API Key habe ich bekommen aber was ist der APP Secret ?
                              Bekomme ich diesen auch von "Solarman", ansonsten habe ich nur 3 Angaben die ich machen kann.
                              Starte ich den Adapter mit diesen 3 Angaben, wird dieser grün, jedoch stehen da nicht wirklich brauchbare Daten drin.
                              Ralf
                              • ralleR ralle
                                Ralf
                                #183
                                @ralle Hello, wie in der Beschreibung angegeben vorgehen, dann klappt das!
                                Ohne Appsecret und AppId funktioniert der Adapter nicht.
                                • ralleR
                                  ralleR
                                  ralle
                                  #184
                                  JA, klappt. besten dank.
                                  Hatte die ID in der Mail nicht gesehen.
                                  • ralleR ralle
                                    Rene55R
                                    Rene55R
                                    Rene55
                                    #185
                                    @ralle Ja, schön, freut mich. Viel Spaß damit.
                                    • C cy_coe
                                      B
                                      B
                                      Bambulko
                                      #186
                                      @cy_coe Kann man den Deye SUN600G3 auch über Zigbee auslesen? Ich überlege mir diesen zuzulegen. Funktioniert das auslesen auch zuverlässig?
                                      • B Bambulko
                                        Rene55R
                                        Rene55R
                                        Rene55
                                        #187
                                        @bambulko Mit der Version ist das nicht möglich. Hier werden lediglich die Daten aus der Cloud ausgelesen und im ioBroker angezeigt. Für eine direkte Auslesung per WLAN (oder evtl. Zigbee) muss noch ein anderer Adapter entwickelt werden.
                                        • Rene55R Rene55
                                          T
                                          T
                                          thilo.frank
                                          #188
                                          @rene55 Erstmal vielen Dank für diesen Adapter! Ich habe diesen gestern installiert (mein gröstes Problem war, die Installation anzuschieben...) und er läuft nahezu problemlos (gleich dazu mehr).
                                          Ich bin absuluter Neueinsteiger in der Welt von IOBroker, Github und Co., daher brauche ich vermutlich "etwas länger..." ;-)
                                          Die ganze Chose läuft bei mir auf einer Synology Diskstation.
                                          Ich habe derzeit die gleichen Fehlermeldungen wie Tigger66:
                                          https://forum.iobroker.net/assets/uploads/files/1658932142651-dfe380eb-c1d4-44b9-a88a-bc252065c762-grafik.png
                                          Mein Log hat sich gerade irgenwie geleert, daher kann ich meine Fehlermeldung hier nicht einbinden. :-(
                                          Kann ich da irgendwas machen? Oder einfach ignorieren?
                                          Thomas BraunT Rene55R 2 Antworten Letzte Antwort
                                          83.8k
