    6.8k
lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.5m Aufrufe 260 Beobachtet
  • M matrose65
    @armilar
    javascript.0 (26651) script.js.common.NSPanel.NSPanel_1: TypeScript compilation failed: await createAliasAsync(config.weatherEntity + '.ICON', 'accuweather.0.Current.WeatherIcon', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ICON' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP', 'accuweather.0.Current.Temperature', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature', name: 'TEMP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP_MIN', 'accuweather.0.Daily.Day1.Temperature.Minimum', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature.forecast.0', name: 'TEMP_MIN' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(config.weatherEntity + '.TEMP_MAX', 'accuweather.0.Daily.Day1.Temperature.Maximum', true, <iobJS.StateCommon>{ type: 'number', role: 'value.temperature.max.forecast.0', name: 'TEMP_MAX' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessDay.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_brightnessDay', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessDay.SET', NSPanel_Path + 'NSPanel_Dimmode_brightnessDay', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourDay.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_hourDay', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourDay.SET', NSPanel_Path + 'NSPanel_Dimmode_hourDay', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessNight.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_brightnessNight', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.brightnessNight.SET', NSPanel_Path + 'NSPanel_Dimmode_brightnessNight', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourNight.ACTUAL', NSPanel_Path + 'NSPanel_Dimmode_hourNight', true, <iobJS.StateCommon>{ type: 'number', role: 'value', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Dimmode.hourNight.SET', NSPanel_Path + 'NSPanel_Dimmode_hourNight', true, <iobJS.StateCommon>{ type: 'number', role: 'level', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'autoUpdate.ACTUAL', NSPanel_Path + 'NSPanel_autoUpdate', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'autoUpdate.SET', NSPanel_Path + 'NSPanel_autoUpdate', true, <iobJS.StateCommon>{ type: 'boolean', role: 'switch', name: 'SET' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'ipAddress.ACTUAL', NSPanel_Path + 'NSPanel_ipAddress', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.BerryDriver.ACTUAL', NSPanel_Path + 'Berry_Driver.currentVersion', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Uptime.ACTUAL', NSPanel_Path + 'Tasmota.Uptime', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Version.ACTUAL', NSPanel_Path + 'Tasmota.Version', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Hardware.ACTUAL', NSPanel_Path + 'Tasmota.Hardware', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.AP.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.AP', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.SSId.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.SSId', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.BSSId.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.BSSId', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Channel.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Channel', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Mode.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Mode', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.RSSI.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.RSSI', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Tasmota.Wifi.Signal.ACTUAL', NSPanel_Path + 'Tasmota.Wifi.Signal', true, <iobJS.StateCommon>{ type: 'number', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.TFTVersion.ACTUAL', NSPanel_Path + 'Display_Firmware.currentVersion', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Display.Model.ACTUAL', NSPanel_Path + 'NSPanel_Version', true, <iobJS.StateCommon>{ type: 'string', role: 'state', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + '.Player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + '.Player.currentAlbum', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + '.Player.currentArtist', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + '.Player.currentTitle', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + '.Player.controlNext', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + '.Player.controlPrevious', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + '.Player.controlPlay', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + '.Player.controlPause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + '.Commands.deviceStop', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + '.Player.currentState', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + '.Player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + 'player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + 'player.album', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + 'player.artistName', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + 'player.trackName', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.CONTEXT_DESCRIPTION', dpPath + 'player.contextDescription', true, <iobJS.StateCommon>{ type: 'string', role: 'media.station', name: 'CONTEXT_DESCRIPTION' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + 'player.skipPlus', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + 'player.skipMinus', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + 'player.play', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + 'player.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + 'player.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + 'player.isPlaying', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + 'player.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ACTUAL', dpPath + '.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'value.volume', name: 'ACTUAL' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ALBUM', dpPath + '.current_album', true, <iobJS.StateCommon>{ type: 'string', role: 'media.album', name: 'ALBUM' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.ARTIST', dpPath + '.current_artist', true, <iobJS.StateCommon>{ type: 'string', role: 'media.artist', name: 'ARTIST' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.TITLE', dpPath + '.current_title', true, <iobJS.StateCommon>{ type: 'string', role: 'media.title', name: 'TITLE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.CONTEXT_DESCRIPTION', dpPath + '.current_station', true, <iobJS.StateCommon>{ type: 'string', role: 'media.station', name: 'CONTEXT_DESCRIPTION' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.NEXT', dpPath + '.next', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.next', name: 'NEXT' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PREV', dpPath + '.prev', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.prev', name: 'PREV' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PLAY', dpPath + '.play', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.play', name: 'PLAY' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.PAUSE', dpPath + '.pause', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.pause', name: 'PAUSE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STOP', dpPath + '.stop', true, <iobJS.StateCommon>{ type: 'boolean', role: 'button.stop', name: 'STOP' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.STATE', dpPath + '.state_simple', true, <iobJS.StateCommon>{ type: 'boolean', role: 'media.state', name: 'STATE' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(id + '.VOLUME', dpPath + '.volume', true, <iobJS.StateCommon>{ type: 'number', role: 'level.volume', name: 'VOLUME' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Sensor.ANALOG.Temperature.ACTUAL', NSPanel_Path + 'Sensor.ANALOG.Temperature', true, <iobJS.StateCommon>{ type: 'number', 'unit': '°C' }); ^ ERROR: Cannot find name 'createAliasAsync'. await createAliasAsync(AliasPath + 'Sensor.ESP32.Temperature.ACTUAL', NSPanel_Path + 'Sensor.ESP32.Temperature', true, <iobJS.StateCommon>{ type: 'number', 'unit': '°C' }); ^ ERROR: Cannot find name 'createAliasAsync'.
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #630
    @matrose65
    Gleiches Problem... Du hast den JS-Adapter nicht auf v6.1.3 upgedatet. Es sind aktuell im Skript neue Alias-Funktionen drin und die gibt es erst seit dem 3.11.2022
    siehe auch: https://forum.iobroker.net/post/888302 von gestern (und die nachfolgenden 2 Posts)
    2 Möglichkeiten:
    • Version 3.5.0.5 mit einem aktualisierten JavaScript-Adapter auf v6.1.3
    • Version 3.5.0.4 ohne Update JS-Adapter.
    Die 6.1.3 läuft prima. Falls du auch noch ein veraltetes node.js hast, solltest du das vorher upgraden. Die empfohlene node.js Version ist 16.18.1 (empfohlen). Die 18er hat noch Fehler und "nein" - ist nicht besser
    also wenn node-v im Linux-Terminal kleiner als 16.X.X ist, dann
    https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian
    M J 2 Antworten Letzte Antwort
    • ArmilarA Armilar
      @matrose65
      2 Möglichkeiten:
      matrose65
      #631
      @armilar
      Hallo zurück und ein super großes DANKE.
      Habe den JS auf 6.1.3 gebracht und es klappt.
      Ich habe das auch schon mal gelesen und habe die Einstellung auf Beta gesetzt.
      Aber da gab es keine Änderungen und dann habe ich es wohl wieder aus den Augen verloren.
      Also nochmal Danke und ihr macht eine super Arbeit
      • M matrose65
        @armilar
        ArmilarA Offline
        ArmilarA Offline
        Armilar
        #632
        @matrose65
        Super das es klappt... 😊
        Und immer schön das node.js aktuell halten. Wäre sonst wie ein Rolls Royce mit 'nem Taschenrechner von 1970 als Boardcomputer ;-)
        • ArmilarA Armilar
          @matrose65
          matrose65
          #633
          @armilar
          Da bin ich eigentlich immer aktuell zur Zeit 16.18.1
          Und alle Adapter auch aktuell.
          Eine Frage noch: Seit der zweiten Neuinstallation zeigt der Temperatur Sensor keine richtigen Werte an
          Jetzt 3.0 °C und er liegt nicht im Kühlschrank
          • M matrose65
            @armilar
            ArmilarA Offline
            ArmilarA Offline
            Armilar
            #634
            @matrose65
            Uiii, dann ist es bei dir im Zimmer kälter als im Kühlschrank? 😂
            Ich wusste vor ein paar Tagen schon, dass die Frage kommt und habe sie hier: https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Tasmota-FAQ#21--interner-raum-temperatursensor beantwortet.
            EDIT: mit der 2 Zahl etwas spielen, bis die Temperatur passt.
            • K Kuckuckmann
              @armilar @carlos
              Gehäuse dafür gibt es zum Beispiel bei Thingiverse zum Drucken ;-)
              Bsp. inkl ESP: https://www.thingiverse.com/thing:2767312
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #635
              @kuckuckmann
              Warum wundert es mich nicht, dass du die DIY-Variante für das NSPanel kennst ;-)
              • ArmilarA Armilar
                @matrose65
                matrose65
                #636
                @armilar
                Eigentlich ist es ganz mollig warm. 👍 😇
                Ich wollte den Sensor auch nicht benutzen, habe mich nur gewundert weil er bei der ersten Runde ganz vernünftige Temperaturen angezeigt hat.
                Schau ich mir morgen mal an. Muss jetzt Schluss machen, um 04 Uhr klingelt der Wecker ⏲
                • M matrose65
                  @armilar
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  #637
                  @matrose65
                  Ja dann gute N8... viel Spass beim Kalibrieren morgen
                  • ArmilarA Armilar
                    @kuckuckmann
                    Kuckuckmann
                    #638
                    @armilar
                    Ja hey,man muss die Möglichkeiten ausloten :-D
                    NSPanel Dokumentation im GitHub Wiki:
                    • K Kuckuckmann
                      @armilar
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #639
                      @kuckuckmann 👍
                      • ArmilarA Armilar
                        @matrose65
                        matrose65
                        #640
                        @armilar
                        Guten Abend nochmal
                        So habe es fertig kalibriert. Der erste Befehl war gut. Siehe hier und nochmal Danke
                        ArmilarA WalW 2 Antworten Letzte Antwort
                        • M matrose65
                          @armilar
                          Guten Abend nochmal
                          ArmilarA Offline
                          ArmilarA Offline
                          Armilar
                          #641
                          @matrose65
                          sieht auch gleich viel muckeliger aus 😊
                          P.S.: bei -2°C kannst du dich auch viel besser im Kühlschrank aufwärmen ;-)
                          • M matrose65
                            @armilar
                            Guten Abend nochmal
                            WalW Offline
                            WalW Offline
                            Wal
                            #642
                            @matrose65 ,
                            du musst das Teil 1-2 Stunden in Betrieb haben und dann kalibrieren, danach stimmen die Werte in etwa.
                            Walter
                            DoorIO-Adapter
                            • ArmilarA Armilar
                              @marius-kossinna sagte in SONOFF NSPanel mit Lovelace UI:
                              defaultCard
                              Zu 1) Was ist die defaultCard? Hättest du einen Link? Ein Screenshot würde mir auch schon helfen
                              Zu 2) cardAlarm hat @Kuckuckmann hier https://github.com/joBr99/nspanel-lovelace-ui/wiki/ioBroker---FAQ-&-Anleitungen#2-alarm-page beschrieben. Es gibt zwei Blockly's und eines davon beinhaltet die Konfiguration mit der PIN im ioBroker.
                              Grundsätzlich ist das TS-Script entkoppelt von deiner eigenen individuellen Logik, so dass es nicht zu "unglücklich" gelösten Anwendungsfällen kommen kann. Die cardAlarm-Funktionalität ist so angelegt, dass nicht jeder wildfremde einfach mal so den Alarm aktivieren kann. Somit ist die Eingabe einer PIN bei Aktivierung und Deaktivierung erforderlich (kann natürlich fest sein, siehe Beispiel).
                              tomsport2022
                              #643
                              @armilar said in SONOFF NSPanel mit Lovelace UI:
                              defaultCard
                              Gibt es eigentlich die Möglichkeit, die AlarmCard zur Pin Eingabe aufzurufen, wenn zB eine Alarmbedingung vorliegt bzw. extern via IOBroker bzw. eine angelegte Variable getriggert wird, dass nur diese am Display aufscheint und auswählbar ist?
                              • T tomsport2022
                                defaultCard
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #644
                                @tomsport2022
                                Indirekt jein.
                                Ich sag's mal so. Der Screensaver wird immer über einen gewissen eingestellten Zeitraum aktiv sein, jedoch kannst du mit einem entsprechenden Event eine spezielle Seite aufrufen und kurzzeitig übersteuern.
                                Nehmen wir mal an, die Tür geht auf oder jemand läuft durch einen Bereich eines Bewegunsmelders, dann könntest du die cardAlarm aufschalten. Das macht aus meiner Sicht auch nur Sinn, wenn ein zusätzlicher Datenpunkt diese Aktion (eigene Logik) erwartet. Nachdem der Timer für den Screensaver (z.B. 20 Sekunden) zuschlägt wird wieder der Screensaver aktiv.
                                Nur diese cardAlarm auswählbar machen und sonst keine andere geht nicht, wird aber aktuell bei den HA's im github ebenfalls diskutiert. Das heißt aber noch nicht, dass die Lösung kommen wird ;-)
                                T J 2 Antworten Letzte Antwort
                                • ArmilarA Armilar
                                  @tomsport2022
                                  Indirekt jein.
                                  tomsport2022
                                  #645
                                  @tomsport2022
                                  Indirekt jein.
                                  Ok danke für die Info und die schnelle Antwort. Ich werde dies dann mal austesten. Wie sieht so ein Aufruf aus?
                                  • T tomsport2022
                                    @tomsport2022
                                    Indirekt jein.
                                    ArmilarA Offline
                                    ArmilarA Offline
                                    Armilar
                                    #646
                                    @tomsport2022
                                    Du hast einen Datenpunkt der sieht so aus
                                    Dann sollte dein externes Script eine solche Zeile zusammenbauen (JSON), wobei die 14 im Beispiel eine pageID ist.
                                    {"pagetype": "page", "pageId": 14}
                                    Wie findest du die pageID der z.B. cardAlarm? Du zählst in deiner "export const Config" die Seiten ab 0 beginnend.
                                    Ach ja... und nun nur noch das JSON zusammenbauen und in den Datenpunkt schreiben. Dann wird die Seite aufgerufen
                                    • ArmilarA Armilar
                                      @tomsport2022
                                      tomsport2022
                                      #647
                                      @tomsport2022
                                      Super vielen Dank wieder mal :) !
                                      ArmilarA 2 Antworten Letzte Antwort
                                      • T tomsport2022
                                        @tomsport2022
                                        ArmilarA Offline
                                        ArmilarA Offline
                                        Armilar
                                        #648
                                        @tomsport2022 😊
                                        Ist glaube ich auch noch nicht in der Wiki --> also "Top Secret" ;-)
                                        Ich schreibe es demnächst mal rein.
                                        • T tomsport2022
                                          @tomsport2022
                                          ArmilarA Offline
                                          ArmilarA Offline
                                          Armilar
                                          #649
                                          @tomsport2022 sagte in SONOFF NSPanel mit Lovelace UI:
                                          {"pagetype": "subpage","pageId": 2}
                                          Funktioniert im Übrigen auch für die SubPages...
