  3. Einsteigerfragen
  4. Automatisierung
  5. eCharts Zeitraum in Vis per Button ändern
    1.0k
Geplant Angeheftet Gesperrt Verschoben Automatisierung
70 Beiträge 9 Kommentatoren 10.8k Aufrufe 12 Beobachtet
  • N nettworker
    @mcu
    auch den CUL/culfw ?
    MCU
    @nettworker Nein.
    Dann sollte jetzt auf der linken Seite ein "Scripte" erscheinen:
    N 2 Antworten Letzte Antwort
    • M MCU
      @nettworker Nein.
      N Offline
      N Offline
      nettworker
      @mcu
      Der mag wohl nicht :(
      • N nettworker
        @mcu
        MCU
        @nettworker Steht im LOG / Protokolle irgendetwas dazu drin?
        Sonst einmal das System neu starten.
        Auf der console: (RaspberrySystem?)
        iob stop
        sudo reboot
        N 1 Antwort Letzte Antwort
        • M MCU
          iob stop
          sudo reboot
          N Offline
          N Offline
          nettworker
          @mcu
          host.iobroker
          2022-11-07 19:31:13.471	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
          host.iobroker
          2022-11-07 19:31:13.456	warn	Requested repository "latest" does not exist in config.
          host.iobroker
          2022-11-07 19:31:09.449	info	iobroker rebuild
          host.iobroker
          2022-11-07 19:31:09.448	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
          host.iobroker
          2022-11-07 19:31:09.445	info	system.adapter.javascript.0 will be rebuilt
          host.iobroker
          2022-11-07 19:31:09.443	info	Adapter system.adapter.javascript.0 needs rebuild and will be restarted afterwards.
          host.iobroker
          2022-11-07 19:31:09.442	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
          host.iobroker
          2022-11-07 19:31:09.440	error	Caught by controller[0]: }
          host.iobroker
          2022-11-07 19:31:09.439	error	Caught by controller[0]: requestPath: 'coffeescript'
          host.iobroker
          2022-11-07 19:31:09.438	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
          host.iobroker
          2022-11-07 19:31:09.437	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
          host.iobroker
          2022-11-07 19:31:09.436	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1033:32) {
          host.iobroker
          2022-11-07 19:31:09.435	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
          host.iobroker
          2022-11-07 19:31:09.434	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
          host.iobroker
          2022-11-07 19:31:09.433	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
          host.iobroker
          2022-11-07 19:31:09.431	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
          host.iobroker
          2022-11-07 19:31:09.430	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
          N HomoranH 2 Antworten Letzte Antwort
          • N nettworker
            @mcu
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            host.iobroker
            N Offline
            N Offline
            nettworker
            Ich deinstalliere den noch mal
            M Thomas BraunT 3 Antworten Letzte Antwort
            • N nettworker
              MCU
              @nettworker Du hast Einstellungen nicht korrekt.
              http://download.iobroker.net/sources-dist-latest.json
              • N nettworker
                @mcu
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                host.iobroker
                HomoranH Offline
                HomoranH Offline
                @nettworker was ist das für ein Schnipsel?
                wie alt Ist dein iobroker?
                wie und wo installiert?
                • N nettworker
                  @nettworker
                  Da scheint mir aber auch mit nodeJS was nicht zu stimmen.
                  sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
                  uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
                  iobroker repo list
                  • N nettworker
                    @nettworker
                    Du könntest auch das iob diag - Skript noch testen:
                    https://forum.iobroker.net/topic/59549/iob-diag-skript
                      N Offline
                      N Offline
                      nettworker
                      Läuft auf nem Raspi 3B+ ( mehr schlecht als Recht :) )
                      aktuelles Betriebssystem
                      aktueller iobroker ( alles erst vor ein paar Tagen isntalliert )
                      DJMarc75D HomoranH 2 Antworten Letzte Antwort
                        @nettworker
                        iobroker repo list
                        N Offline
                        N Offline
                        nettworker
                        iobroker repo list
                        armv7l
                        Kein Docker
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.18.0
                        v16.18.0
                        8.19.2
                        4.0.23
                        pi
                        pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
                        tty
                        /home/pi
                        Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
                        Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
                        Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Hit:4 https://repos.influxdata.com/debian bullseye InRelease
                        Hit:5 https://packages.grafana.com/enterprise/deb stable InRelease
                        Reading package lists... Done
                        nodejs:
                        Installed: 16.18.0-deb-1nodesource1
                        Candidate: 16.18.1-deb-1nodesource1
                        Version table:
                        16.18.1-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
                        *** 16.18.0-deb-1nodesource1 100
                        12.22.12~dfsg-1~deb11u1 500
                        stable : http://download.iobroker.net/sources-dist.json
                        beta : http://download.iobroker.net/sources-dist-latest.json
                        Active repo(s): latest, stable
                        • N nettworker
                          DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @nettworker sagte in eCharts Zeitraum in Vis per Button ändern:
                          Läuft auf nem Raspi 3B+ ( mehr schlecht als Recht )
                          1GB RAM --- System total überfordert bei Deinen installierten Adaptern.
                          Lehrling seit 1975 !!!
                          • N nettworker
                            iobroker repo list
                            armv7l
                            Kein Docker
                            /usr/bin/nodejs
                            /usr/bin/node
                            /usr/bin/npm
                            v16.18.0
                            v16.18.0
                            8.19.2
                            4.0.23
                            pi
                            tty
                            /home/pi
                            nodejs:
                            Version table:
                            MCU
                            @nettworker Für solche Dinge solltest du den CodeTag nutzen:
                            Einfach klicken und dann das einfügen.
                            Oder jetzt hinterher markieren und dann CodeTag klicken.
                            Dazu auf die drei Punkte auf dem Beitrag klicken, den du ändern möchtest ( du kannst nur Deine ändern) und dann bearbeiten.
                            • M MCU
                              N Offline
                              N Offline
                              nettworker
                              schrieb am zuletzt editiert von nettworker
                              @mcu
                              Lasst uns das Mal zurück stellen. Ich warte auf neue Hardware, dann gibt's eh ne Neuinstallation.
                              Wollte zwar hier noch was üben, aber das System scheint ja verbogen zu sein.
                              Was empfehlt ihr denn? Debian mit Docker?
                              • Thomas BraunT Online
                                Debian
                                Egal auf was...
                                Ich bevorzuge allerdings bei meinen Systemen eine native Installation.
                                • N nettworker
                                  @mcu
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  @nettworker was für Hardware?
                                  • DJMarc75D DJMarc75
                                    N Offline
                                    N Offline
                                    nettworker
                                    @djmarc75
                                    Micro PC, ist wohl ein i3 mit 8gb usw.
                                    • N nettworker
                                      @djmarc75
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      Ah, ok... also Du weisst nicht so genau was Du gekauft hast? Mutige Geschichte 😳
                                        N Offline
                                        N Offline
                                        nettworker
                                        @djmarc75
                                        Ist von einem Kollegen aus einem It Systemhaus.
                                        Der war da nur kurzzeitig an einem Fernseher angeschlossen und kann jetzt weg.
                                        Da frag ich nicht lang 😂 für ne KB
                                          N Offline
                                          N Offline
                                          nettworker
                                          @djmarc75
                                          Die bekommen jetzt neue lüfterlose mit Atom Prozessor. Mal sehen ob ich da noch welche kaufen kann, die sind sehr günstig....
