  3. Einsteigerfragen
  4. Automatisierung
  5. eCharts Zeitraum in Vis per Button ändern
    1.0k
Geplant Angeheftet Gesperrt Verschoben Automatisierung
70 Beiträge 9 Kommentatoren 10.8k Aufrufe 12 Beobachtet
  • N nettworker
    Ich deinstalliere den noch mal
    MCU
    @nettworker Du hast Einstellungen nicht korrekt.
    http://download.iobroker.net/sources-dist-latest.json
    • N nettworker
      @mcu
      host.iobroker
      2022-11-07 19:31:13.471	info	Updating repository "stable" under "http://download.iobroker.net/sources-dist.json"
      host.iobroker
      2022-11-07 19:31:13.456	warn	Requested repository "latest" does not exist in config.
      host.iobroker
      2022-11-07 19:31:09.449	info	iobroker rebuild
      host.iobroker
      2022-11-07 19:31:09.448	warn	adapter "javascript" seems to be installed for a different version of Node.js. Trying to rebuild it... 1 attempt
      host.iobroker
      2022-11-07 19:31:09.445	info	system.adapter.javascript.0 will be rebuilt
      host.iobroker
      2022-11-07 19:31:09.443	info	Adapter system.adapter.javascript.0 needs rebuild and will be restarted afterwards.
      host.iobroker
      2022-11-07 19:31:09.442	error	instance system.adapter.javascript.0 terminated with code 1 (JS_CONTROLLER_STOPPED)
      host.iobroker
      2022-11-07 19:31:09.440	error	Caught by controller[0]: }
      host.iobroker
      2022-11-07 19:31:09.439	error	Caught by controller[0]: requestPath: 'coffeescript'
      host.iobroker
      2022-11-07 19:31:09.438	error	Caught by controller[0]: path: '/opt/iobroker/node_modules/iobroker.javascript/node_modules/coffeescript/package.json',
      host.iobroker
      2022-11-07 19:31:09.437	error	Caught by controller[0]: code: 'MODULE_NOT_FOUND',
      host.iobroker
      2022-11-07 19:31:09.436	error	Caught by controller[0]: at Module.load (node:internal/modules/cjs/loader:1033:32) {
      host.iobroker
      2022-11-07 19:31:09.435	error	Caught by controller[0]: at Object.Module._extensions..js (node:internal/modules/cjs/loader:1209:10)
      host.iobroker
      2022-11-07 19:31:09.434	error	Caught by controller[0]: at Module._compile (node:internal/modules/cjs/loader:1155:14)
      host.iobroker
      2022-11-07 19:31:09.433	error	Caught by controller[0]: at Object.<anonymous> (/opt/iobroker/node_modules/iobroker.javascript/main.js:21:24)
      host.iobroker
      2022-11-07 19:31:09.431	error	Caught by controller[0]: at require (node:internal/modules/cjs/helpers:103:18)
      host.iobroker
      2022-11-07 19:31:09.430	error	Caught by controller[0]: at Module.require (node:internal/modules/cjs/loader:1057:19)
      HomoranH Offline
      HomoranH Offline
      @nettworker was ist das für ein Schnipsel?
      wie alt Ist dein iobroker?
      wie und wo installiert?
      N 1 Antwort Letzte Antwort
      • N nettworker
        @nettworker
        Da scheint mir aber auch mit nodeJS was nicht zu stimmen.
        sudo ln -s /usr/bin/node /usr/bin/nodejs &> /dev/null
        uname -m && test -f /opt/scripts/.docker_config/.thisisdocker && echo "Docker-Installation" || echo "Kein Docker" && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && echo $DESKTOP_SESSION && pwd && sudo apt-get update &> /dev/null && sudo apt-get update && apt-cache policy nodejs
        iobroker repo list
        • N nettworker
          @nettworker
          Du könntest auch das iob diag - Skript noch testen:
          https://forum.iobroker.net/topic/59549/iob-diag-skript
            N Offline
            N Offline
            nettworker
            Läuft auf nem Raspi 3B+ ( mehr schlecht als Recht :) )
            aktuelles Betriebssystem
            aktueller iobroker ( alles erst vor ein paar Tagen isntalliert )
            DJMarc75D HomoranH 2 Antworten Letzte Antwort
              @nettworker
              iobroker repo list
              N Offline
              N Offline
              nettworker
              iobroker repo list
              armv7l
              Kein Docker
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.18.0
              v16.18.0
              8.19.2
              4.0.23
              pi
              pi adm dialout cdrom sudo audio video plugdev games users input render netdev gpio i2c spi iobroker
              tty
              /home/pi
              Hit:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
              Hit:2 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:3 https://deb.nodesource.com/node_16.x bullseye InRelease
              Hit:4 https://repos.influxdata.com/debian bullseye InRelease
              Hit:5 https://packages.grafana.com/enterprise/deb stable InRelease
              Reading package lists... Done
              nodejs:
              Installed: 16.18.0-deb-1nodesource1
              Candidate: 16.18.1-deb-1nodesource1
              Version table:
              16.18.1-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main armhf Packages
              *** 16.18.0-deb-1nodesource1 100
              12.22.12~dfsg-1~deb11u1 500
              stable : http://download.iobroker.net/sources-dist.json
              beta : http://download.iobroker.net/sources-dist-latest.json
              Active repo(s): latest, stable
              • N nettworker
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                @nettworker sagte in eCharts Zeitraum in Vis per Button ändern:
                Läuft auf nem Raspi 3B+ ( mehr schlecht als Recht )
                1GB RAM --- System total überfordert bei Deinen installierten Adaptern.
                Lehrling seit 1975 !!!
                • N nettworker
                  iobroker repo list
                  armv7l
                  Kein Docker
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.18.0
                  v16.18.0
                  8.19.2
                  4.0.23
                  pi
                  tty
                  /home/pi
                  nodejs:
                  Version table:
                  MCU
                  @nettworker Für solche Dinge solltest du den CodeTag nutzen:
                  Einfach klicken und dann das einfügen.
                  Oder jetzt hinterher markieren und dann CodeTag klicken.
                  Dazu auf die drei Punkte auf dem Beitrag klicken, den du ändern möchtest ( du kannst nur Deine ändern) und dann bearbeiten.
                  • M MCU
                    N Offline
                    N Offline
                    nettworker
                    schrieb am zuletzt editiert von nettworker
                    @mcu
                    Lasst uns das Mal zurück stellen. Ich warte auf neue Hardware, dann gibt's eh ne Neuinstallation.
                    Wollte zwar hier noch was üben, aber das System scheint ja verbogen zu sein.
                    Was empfehlt ihr denn? Debian mit Docker?
                    • Thomas BraunT Online
                      Debian
                      Egal auf was...
                      Ich bevorzuge allerdings bei meinen Systemen eine native Installation.
                      • N nettworker
                        @mcu
                        DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @nettworker was für Hardware?
                        • DJMarc75D DJMarc75
                          N Offline
                          N Offline
                          nettworker
                          @djmarc75
                          Micro PC, ist wohl ein i3 mit 8gb usw.
                          • N nettworker
                            @djmarc75
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            Ah, ok... also Du weisst nicht so genau was Du gekauft hast? Mutige Geschichte 😳
                            N 2 Antworten Letzte Antwort
                              N Offline
                              N Offline
                              nettworker
                              @djmarc75
                              Ist von einem Kollegen aus einem It Systemhaus.
                              Der war da nur kurzzeitig an einem Fernseher angeschlossen und kann jetzt weg.
                              Da frag ich nicht lang 😂 für ne KB
                                N Offline
                                N Offline
                                nettworker
                                @djmarc75
                                Die bekommen jetzt neue lüfterlose mit Atom Prozessor. Mal sehen ob ich da noch welche kaufen kann, die sind sehr günstig....
                                • N nettworker
                                  @djmarc75
                                  DJMarc75D Offline
                                  DJMarc75D Offline
                                  DJMarc75
                                  Jo, ist wie Aktiengeschäft wenn man sich nicht auskennt...
                                  Intel Atom ist der Markenname einer Reihe von Mikroprozessoren und Ein-Chip-Systemen, die von der Firma Intel für den Einsatz in besonders preisgünstigen und energiesparenden Systemen entwickelt werden. Die Erstvorstellung von Produkten unter diesem Markennamen erfolgte im Jahr 2008.
                                  Kann quasi alles sein 😁
                                  Aber jetzt wirds auch OffTopic !
                                    N Offline
                                    N Offline
                                    nettworker
                                    @djmarc75
                                    Ist mir schon alles klar.
                                    Ich hab nur noch keine genauen Daten, da die Kisten gerade erst bei Gigabyte produziert werden und noch nicht da sind.
                                    Und wenn der Preis stimmt der mir genannt wurde, dann kann ich für den derzeitigen Preis eines Raspi 4 2 Stück davon kaufen. Bei den derzeitigen Preisen also kaum Risiko und da ich nicht damit handeln will noch weniger Risiko 🤣
                                    • N nettworker
                                      @djmarc75
                                      DJMarc75D Offline
                                      DJMarc75D Offline
                                      DJMarc75
                                      das mag wohl im Moment echt so sein ! ... hatte vor 12 Monaten noch 2 RPI4 mit 8GB inklusive Gehaüse mit Lüftern für 240 € gekauft... heut krieg ich für den Preis nur noch nen halben Meter RPI-Wurst ... ohne Darm 🤕
                                      • N nettworker
                                        HomoranH Offline
                                        HomoranH Offline
                                        das kann nicht sein!
                                        allerdings fehlt noch die Antwort auf
                                        @homoran sagte in eCharts Zeitraum in Vis per Button ändern:
                                        nach der offiziellen Anleitung dürfte kein Repo mit Namen latest existieren!
                                        • N nettworker
                                          @djmarc75
                                          HomoranH Offline
                                          HomoranH Offline
                                          die brauchst du auch. Je nach Atom leistet der auch nur die Hälfte vom Pi4
                                          ein Benchmark unter 1000 ist IMHO schon knapp.
                                          ab 3000 wird es sinnvoll (mit mind. 8GB RAM, besser 16)
                                          und nur weil i3 draufsteht, muss das noch lange kein Rennpferd sein.
