lovelace uinspanelsonoff
8.1k Beiträge 280 Kommentatoren 8.4m Aufrufe 260 Beobachtet
  • G Gre4t0ne
    @armilar Du bist echt ein Wahnsinn Danke :))
    Er hat mir aber jetzt nur 1 Alias angelegt (Player Sonos Lautstärke )und wieder etliche Warnungen im Log:
    javascript.1
    2022-10-30 10:10:46.201	warn	Could not add alias subscription: Expected alias alias.0.NSPanel_1.Media.PlayerSonos to be of type "state", got "channel"
    javascript.1
    2022-10-30 10:10:46.199	warn	Expected alias alias.0.NSPanel_1.Media.PlayerSonos to be of type "state", got "channel"
    javascript.0
    2022-10-30 10:10:44.493	info	State value to set for "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" has to be type "number" but received type "string"
    javascript.0
    2022-10-30 10:10:44.475	warn	at processImmediate (internal/timers.js:437:9)
    javascript.0
    2022-10-30 10:10:44.474	warn	at runNextTicks (internal/process/task_queues.js:60:5)
    javascript.0
    2022-10-30 10:10:44.474	warn	at fulfilled (script.js.NSPanel:5:58)
    javascript.0
    2022-10-30 10:10:44.474	warn	at Object.next (script.js.NSPanel:14:53)
    javascript.0
    2022-10-30 10:10:44.473	warn	at step (script.js.NSPanel:33:23)
    javascript.0
    2022-10-30 10:10:44.473	warn	at script.js.NSPanel:854:42
    javascript.0
    2022-10-30 10:10:44.472	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:81:16
    javascript.0
    2022-10-30 10:10:44.471	warn	at new Promise (<anonymous>)
    javascript.0
    2022-10-30 10:10:44.471	warn	at /opt/iobroker/node_modules/iobroker.javascript/lib/tools.js:82:16
    javascript.0
    2022-10-30 10:10:44.470	warn	at setState (/opt/iobroker/node_modules/iobroker.javascript/lib/sandbox.js:1689:20)
    javascript.0
    2022-10-30 10:10:44.453	warn	You are assigning a string to the state "0_userdata.0.NSPanel.1.Berry_Driver.currentVersion" which expects a number. Please fix your code to use a number or change the state type to string. This warning might become an error in future versions.
    javascript.0
    2022-10-30 10:10:44.006	warn	Could not add alias subscription: Expected alias alias.0.NSPanel_1.Media.PlayerSonos to be of type "state", got "channel"
    javascript.0
    2022-10-30 10:10:44.004	warn	Expected alias alias.0.NSPanel_1.Media.PlayerSonos to be of type "state", got "channel"
    ArmilarA Offline
    ArmilarA Offline
    Armilar
    Most Active Forum Testing
    #525
    @gre4t0ne sagte in SONOFF NSPanel mit Lovelace UI:
    Den DP mal löschen. Wird automatisch neu angelegt. Falls dann immer noch string --> auf number umbiegen
    Die restlichen Warnungen werden weg sein, wenn der Alias sauber läuft.
    Du hast jetzt nur einen Alias, weil das Skript immer nur eine IP berücksichtigen kann. Falls du mehr hast, musst du das Skript auch entsprechend einsetzten um weitere Aliase zu bauen. Die sollten dann natürlich anders heißen...
    Also nicht alle PlayerSonos, sondern sprechende Namen wie z.B. SonosOneKueche
    • G Gre4t0ne
      javascript.1
      javascript.1
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      javascript.0
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      #526
      Versuche mal diesen Sonos erstmal an den Start zu bekommen, bevor du jetzt weitere anlegst
      • G Offline
        Gre4t0ne
        #527
        Habe den DP currentVersion gelöscht (der war aber eh number)
        wurde aber noch nicht autom. wieder angelegt...
        Bekam jetzt weniger errors:
        warn	Could not add alias subscription: Expected alias alias.0.NSPanel_1.Media.PlayerSonosKueche to be of type "state", got "channel"
        warn	Expected alias alias.0.NSPanel_1.Media.PlayerSonosKueche to be of type "state", got "channel"
        • G Gre4t0ne
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          #528
          Das sind keine error sondern warnings. Ignoriere die erstmal. Sag bescheid, wenn der Player läuft... Wenn dann immer noch warnings, dann lässt sich das auch beheben.
          • G Offline
            Gre4t0ne
            #529
            Habe jetzt wieder
            let Sonos: PageMedia =
                "type": "cardMedia",
                "heading": "Sonos",
                "useColor": true,
                "subPage": false,
                "parent": undefined,
                "items": [<PageItem>{
                            adapterPlayerInstance: "sonos.0.",
                            mediaDevice: "192_168_178_32",
                            speakerList: ['Terrasse']
            eingefügt ABER ab "Page Item" wird alles unterwellt (wie bei einem Syntax Error) und das Skript hat folgende Errors:
            javascript.0 (29599) script.js.NSPanel: TypeScript compilation failed: "items": [<PageItem>{ ^ ERROR: Conversion of type '{ id: string; adapterPlayerInstance: string; mediaDevice: string; speakerList: string[]; }' to type 'PageItem' may be a mistake because neither type sufficiently overlaps with the other. If this was intentional, convert the expression to 'unknown' first. Type '{ id: string; adapterPlayerInstance: string; mediaDevice: string; speakerList: string[]; }' is missing the following properties from type 'PageItem': icon, icon2, onColor, offColor, and 13 more.
            Ich habe auch keine Speaker List Terrasse aber an der scheitert es whs. eher nicht
            ArmilarA 2 Antworten Letzte Antwort
            • G Gre4t0ne
              Habe jetzt wieder
                  "heading": "Sonos",
                  "useColor": true,
                  "subPage": false,
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              #530
              @gre4t0ne
              Die Definition ist okay.
              Hast du wirklich den gesamten unteren Teil aus dem aktuellen Script auf github ersetzt?
              Das sieht für mich so aus, als würdest du neue PageItem Parameter in ein altes Skript einfügen...
              G 1 Antwort Letzte Antwort
              • G Gre4t0ne
                Habe jetzt wieder
                    "heading": "Sonos",
                    "useColor": true,
                    "subPage": false,
                ArmilarA Offline
                ArmilarA Offline
                Armilar
                #531
                Da solltest du Küche eintragen. Sieht halt nur besser aus.
                Falls du dich wunderst warum Terrasse? Ich habe die "nutzlosen" Sonos-Geräte alle aus dem Haus verbannt. Die haben alle einen wirklich guten Sound, aber das wars dann auch schon. Mir sind die zu unflexibel.
                • ArmilarA Armilar
                  @gre4t0ne
                  Gre4t0ne
                  #532
                  Habe jetzt wieder das andere probiert hiermit funktioniert es:
                  var Sonos: PageMedia =
                      "heading": "Sonos",
                      "useColor": true,
                      "subPage": false,
                       "items": [<PageItem>{ id: "alias.0.NSPanel_1.Media.PlayerSonosKueche" }]
                  jetzt muss ich nur noch einen Senderwechsel oder Playlist zusammenbringen
                  Start Stop Lauter Leiser funktioniert. (mit dem Sender der zuletzt eingestellt war)
                  • G Gre4t0ne
                        "heading": "Sonos",
                        "useColor": true,
                        "subPage": false,
                    Gre4t0ne
                    #533
                    @gre4t0ne Problem ist sobald ich eine 2. Zeile z.b. adapterPlayerInstance: "sonos.0.", dazuschreibe dann fängt er an die Zeile zu unterkringeln.
                    wie wenn er nur einen PageItem zulässt...
                    • G Gre4t0ne
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      #534
                      @gre4t0ne
                      Geh mal nach unten in den Code-Block...
                      Wenn der nicht genauso aussieht. Dann ist dein Skript zu alt...
                      type PageItem = {
                          icon: (string | undefined),
                          icon2: (string | undefined),
                          onColor: (RGB | undefined),
                          offColor: (RGB | undefined),
                          useColor: (boolean | undefined),
                          interpolateColor: (boolean | undefined),
                          minValueBrightness: (number | undefined),
                          maxValueBrightness: (number | undefined),
                          minValueColorTemp: (number | undefined),
                          maxValueColorTemp: (number | undefined),
                          minValue: (number | undefined),
                          maxValue: (number | undefined),
                          name: (string | undefined),
                          secondRow: (string | undefined),
                          buttonText: (string | undefined),
                          unit: (string | undefined),
                          navigate: (boolean | undefined),
                          colormode: (string | undefined),
                          adapterPlayerInstance: (string | undefined),
                          mediaDevice: (string | undefined),
                          targetPage: (string | undefined),
                          speakerList: (string[] | undefined),
                          hidePassword: (boolean | undefined)
                      https://raw.githubusercontent.com/joBr99/nspanel-lovelace-ui/main/ioBroker/NsPanelTs.ts
                      Ist bestimmt beim kopieren etwas schief gelaufen
                      • WalW Offline
                        WalW Offline
                        Wal
                        #535
                        Falls jemand den internen Sensor nutzen möchte, mit dieser Regel kann man ihn als MQTT-Objekt anzeigen lassen und im Alias zuordnen.
                        Rule1 ON ANALOG#Temperature1!=%Var1% DO backlog publish %topic%/stat/Temperature %value%; Var1 %value% ENDON
                        Walter
                        DoorIO-Adapter
                        • SternmiereS Offline
                          SternmiereS Offline
                          Sternmiere
                          #536
                          Moin,
                          es ist mir aktuell zu umständlich, neue Seiten für das NSPanel immer am Live-Panel zu entwerfen und zu vertesten. Dazu habe ich mit der Hilfe von @Armilar bei mir einen Emulator für das NSPanel eingerichtet.
                          Die Informationen zum Einrichten des Emulator sind hier zwar im Forum zu finden, jedoch gut versteckt im alten Thread (https://forum.iobroker.net/topic/50888/sonoff-nspanel/452). Daher habe ich im Wiki vom NSPanel-Repository eine Seite zur Einrictung des Emulator hinterlegt (https://github.com/joBr99/nspanel-lovelace-ui/wiki/NSPanel-Nextion-Editor).
                          Sollten noch Fragen dazu aufkommen, dann meldet Euch gerne bei mir.
                          Ansonsten viel Spaß beim entwerfen Eurer Seiten mit dem Emulator :)
                          Do not look upon this world with fear and loathing. Bravely face whatever the gods offer.
                          -- Morihei Ueshiba
                          • WalW Wal
                            ArmilarA Offline
                            ArmilarA Offline
                            Armilar
                            #537
                            @wal
                            Guter Hinweis, aber wirf auch mal einen Blick auf
                            0_userdata.0.NSPanel.1.Sensor.ANALOG.Temperature ;-)
                            • G Offline
                              Gre4t0ne
                              #538
                              Gibt es eine Möglichkeit eine PushNotification per Blockly Skript auf den Screensaver zu senden (z.B.: per mqtt)?
                              Es gab doch auch mal eine Howto Seite mit einer step-by-step Anleitungen wie man z.B.: den Müllkalender und die 2. Relaistaste als Button einbaut - ich finde sie nicht mehr...
                              • G Gre4t0ne
                                ArmilarA Offline
                                ArmilarA Offline
                                Armilar
                                #539
                                @gre4t0ne
                                Schreibe mal was in diese Datenpunkte (Pfad entsprechend anpassen) und beobachte was passiert.
                                0_userdata.0.NSPanel.X.ScreensaverInfo.popupNotifyHeading
                                0_userdata.0.NSPanel.X.ScreensaverInfo.popupNotifyText
                                Direkt per DP (nicht per Mqtt oder Vodoo ;-) )
                                Klick oder (bei doppelklick) auf den Screensaver... und die Nachricht ist weg.
                                • G Gre4t0ne
                                  ArmilarA Offline
                                  ArmilarA Offline
                                  Armilar
                                  #540
                                  Sieh mal untern in meinen Footer...
                                  • jayjojaysonJ Offline
                                    jayjojayson
                                    schrieb am zuletzt editiert von jayjojayson
                                    #541
                                    Hallo, ich bin schon länger hier angemeldet und lese normalerweise leise mit.. ;) Erst einmal vielen lieben Dank für das tolle Script zum NSPanel. Ich bin total begeistert und habe am Wochenende meins auf LovelaceUI umgestellt. Das Flashen und die weiteren Schritte haben laut Anleitung alle super funktioniert und Screensaver sowie die ersten Seiten sind programmiert bzw. konfiguriert. Der Screensaver zeigt mir auch die aktuell produzierten KWH vom Solar an, top. :)
                                    Nun zu meiner Frage. Ich würde mir gerne einfache Daten wie die aktuelle Wattzahl vom Solar, der Waschmaschine und co auf einer Seite anzeigen lassen. Dazu muss ich, wie beschrieben, einen alias mit Gerät "Info" anlegen und die gewünschten Infos mit neu erzeugten Zuständen darin ablegen. Also im Prinzip wie bei den einer Lampe, Alias anlegen, Zustände angeben und freuen. Leider funktioniert das bei normalen Informationen bei mir nicht. Möchte gerne eine einfache Seite erstellen, auf der Beispieldaten (Texte und Zahlen aus Datenpunkten) dargestellt werden, also eine Infotafel sozusagen.
                                    Ich habe auch noch im NSPanel Script gelesen, das externe Datenpunkte über 0.userdata eingebunden werden können.
                                    Wähle ich zum Beispiel eine meiner Variablen in 0.userdata aus und binde sie direkt auf einer Seite im NSPanel Script ein, klappt das auch nicht. Könnt ihr mir bitte mit Beispiel helfen, wie ich eine solche Infoseite erstelle. Lieben Dank, Beste Grüße JayScreenshot 2022-11-01 161429.jpg
                                    • jayjojaysonJ jayjojayson
                                      Kuckuckmann
                                      schrieb am zuletzt editiert von Kuckuckmann
                                      #542
                                      @jayjojayson
                                      Hi jay,
                                      willkommen hier im Forum.
                                      hast Du denn mal eine Beispiel Card, welche Du getestet hast?
                                      Kannst Du die hier mal posten?
                                      //Update:
                                      Ich habe das mal bei mir getestet, wichtig ist:
                                      • Du musst eine cardEntities verwenden, auf cardGrid funktioniert es nicht
                                      • Für Deine Datenpunkte, egal ob das manuelle oder aus einem Adapter sind, musst Du einen Info Alias anlegen
                                      • Auf der cardEntities listest Du dann die Info Aliase auf.
                                      Hier ein Beispiel, siehe letzte Zeile:
                                      var Testseite: PageEntities =
                                          "type": "cardEntities",
                                          "heading": "Testseite cardEntities",
                                          "useColor": true,
                                          "subPage": false,
                                          "parent": Testseite,
                                          "items": [
                                      		<PageItem>{ navigate: true, id: "Home", icon: "home-import-outline", offColor: White, onColor: White, name: "Home"},
                                              <PageItem>{ id: "alias.0.Shelly.ShellyShutterTest", icon: "window-shutter", name: "Rolladen test", interpolateColor: true},
                                      		<PageItem>{ id: "alias.0.SchlossTest", icon: "motion-sensor", offColor: MSRed, onColor: MSGreen, name: "SchlossTest"},
                                      		<PageItem>{ id: "alias.0.TestPanel.PC_Ecke", icon: "motion-sensor", offColor: MSRed, onColor: MSGreen, name: "PC_Ecke"},
                                      LG
                                      NSPanel Dokumentation im GitHub Wiki:
                                      jayjojaysonJ 1 Antwort Letzte Antwort
                                      • K Kuckuckmann
                                        @jayjojayson
                                        Hi jay,
                                        //Update:
                                            "useColor": true,
                                            "subPage": false,
                                            "items": [
                                        LG
                                        jayjojayson
                                        #543
                                        @kuckuckmann Danke für deine rasche Antwort und Danke für die Willkommensgrüße.
                                        Das ich eine cardEntities nutzen muss, dachte ich mir schon. Habe jetzt nochmal deine Testseite übernommen und eingebunden, aber ich sehe einfach keine Daten, nur die Überschrift Infoseite. Code anbei.
                                        //Infoseite
                                        var Infoseite: PageEntities =
                                            "heading": "Infoseite",
                                            "useColor": true,
                                            "subPage": false,
                                            "parent": Infoseite,
                                            "items": [
                                        		<PageItem>{ id: "alias.0.NSPanel.Info.Info.STROMWATT", icon: "motion-sensor", offColor: MSRed, onColor: MSGreen, name: "Strom-Watt"},
                                        Ich denke der Fehler liegt beim Anlegen des Alias "Info". Er will zuerst beim Anlegen des Gerätes "Info" einen Datenpunkt mit State, aber eigentlich sind die Datenpunkte die man anzeigen lassen möchte doch alle Values und keine States.
                                        Screenshot 2022-11-01 183927.jpg Screenshot 2022-11-01 184240.jpg Screenshot 2022-11-01 184129.jpg
                                        Hier mache ich irgendwas falsch und bekomme daher keine Werte angezeigt. Hast du den Stromwert innerhalb eines Aktors, also hast du eine Steckdose angelegt, die auch geschaltet werden kann und nebenbei liefert dieser alias daher auch den Stromwert?
                                          //Infoseite
                                              "useColor": true,
                                              "subPage": false,
                                              "items": [
                                          Kuckuckmann
                                          #544
                                          @jayjojayson
                                          Hey ich denke ich sehe das Problem schon: Du musst den Wert von STROMWATT nach ACTUAL setzen. Dann wird Dir auch was angezeigt werden.
                                          Die Konfiguration der cardEntities passt, soweit ich das überblicke.
                                          LG
