  4. Node.js für ioBroker update klappt nicht
92 Beiträge 13 Kommentatoren 28.7k Aufrufe 10 Beobachtet
  • B buchner51
    @thomas-braun sagte in Node.js für ioBroker update klappt nicht:
    which nodejs node npm && nodejs -v && node -v && npm -v && sudo apt update && sudo apt update && apt policy nodejs
    /usr/bin/nodejs
    /usr/bin/node
    /usr/bin/npm
    v14.18.2
    v14.18.2
    6.14.15
    OK:1 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    OK:2 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:3 https://deb.nodesource.com/node_14.x bullseye InRelease
    Alle Pakete sind aktuell.
    OK:1 http://archive.raspberrypi.org/debian bullseye InRelease
    OK:2 http://raspbian.raspberrypi.org/raspbian bullseye InRelease
    nodejs:
      Installiert:           14.18.2-deb-1nodesource1
      Installationskandidat: 14.18.2-deb-1nodesource1
      Versionstabelle:
     *** 14.18.2-deb-1nodesource1 500
            500 https://deb.nodesource.com/node_14.x bullseye/main armhf Packages
         12.22.5~dfsg-2~11u1 500
    hier nochmal alles.
    @buchner51
    Ja, das passt. Und was ist dein Problem?
      @buchner51
      buchner51
      Blockly im ioBroker läuft nicht, es bringt jedes Script einen Fehler:
      22:41:02.511 error javascript.0 (8184) script.js.iqontroll.Abfall compile failed: at script.js.iqontroll.Abfall:10
      Im log steht folgendes:
      javascript.0
      2021-12-22 22:41:02.517 error at processImmediate (internal/timers.js:466:21)
      javascript.0
      2021-12-22 22:41:02.517 error at Immediate._onImmediate (/opt/iobroker/node_modules/iobroker.javascript/main.js:1311:17)
      javascript.0
      2021-12-22 22:41:02.516 error at /opt/iobroker/node_modules/iobroker.javascript/main.js:1832:17
      javascript.0
      2021-12-22 22:41:02.516 error at prepareScript (/opt/iobroker/node_modules/iobroker.javascript/main.js:1731:37)
      javascript.0
      2021-12-22 22:41:02.515 error at createVM (/opt/iobroker/node_modules/iobroker.javascript/main.js:1482:28)
      javascript.0
      2021-12-22 22:41:02.515 error at Object.createScript (vm.js:262:10)
      javascript.0
      2021-12-22 22:41:02.514 error at new Script (vm.js:102:7)
      javascript.0
      2021-12-22 22:41:02.513 error SyntaxError: Unexpected token '/'
      javascript.0
      2021-12-22 22:41:02.513 error ^
      javascript.0
      2021-12-22 22:41:02.512 error function say ( message , alexas = '24bd6505' ) / / use alexas = ['#YOUR ALEXA ID 1#', '#YOUR ALEXA ID 2#'] für die Standard-Sprachausgabe von mehreren Geräten (auch # ersetzen)
      javascript.0
      2021-12-22 22:41:02.511 error script.js.iqontroll.Abfall compile failed: at script.js.iqontroll.Abfall:10
      ich hatte Probleme nach einem Update und hab alles neu aufgesetzt.
      • B buchner51
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        javascript.0
        @buchner51 sagte in Node.js für ioBroker update klappt nicht:
        hast du scripte unter global?
          buchner51
          ja, ich werde Wahnsinnig.
          jetzt hab ich extra drauf geachtet das ich da kein rein schiebe.
          Man sieht ja auch global nur mit der Expertenansicht.
          Das muss wohl beim Import passiert sein.
          Danke für die Hilfe.
          • B buchner51
            Torsten28
            ich bin mir grade nicht sicher, was ich, bzw. ob ich was falsch mache.
            Auch bei mir ist es so, das ich angeblich die Version 12.18.4 lt. ioBroker habe.
            Im IoBroker steht drin das es eine neue Version gibt
            "v12.18.4 (Es gibt eine neuere Version: v12.22.12 - Empfohlene Version v14.19.3)"
            Ich habe den Blog durchgearbeitet und eben dann auch die folgende Ablage gestartet:
            /usr/local/bin/nodejs
            /usr/local/bin/node
            /usr/local/bin/npm
            v12.18.4
            v12.18.4
            6.14.6
            OK:1 http://raspbian.raspberrypi.org/raspbian buster InRelease
            OK:2 http://archive.raspberrypi.org/debian buster InRelease
            OK:3 https://deb.nodesource.com/node_14.x buster InRelease
            nodejs:
              Installiert:           14.19.3-deb-1nodesource1
              Installationskandidat: 14.19.3-deb-1nodesource1
              Versionstabelle:
             *** 14.19.3-deb-1nodesource1 500
                    500 https://deb.nodesource.com/node_14.x buster/main armhf Packages
                 10.24.0~dfsg-1~deb10u1 500
            Im Gegensatz zum Kollegen, habe ich dort aber aber wirklich die Version 12.18.4 stehen, weiter unten aber die 14.19.3.
            Wenn ich die Installation nochmal anstarte, sagt er auch, das es bereits die neue Version ist.
            sudo apt-get install -y nodejs
            nodejs ist schon die neueste Version (14.19.3-deb-1nodesource1).
            0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
            Warum sagt ioBroker, das es die 12 er Version ist und auch bei node -v kommt die 12.18.4 version raus?
            Kann mir da jemand einen Tip geben?
            • T Torsten28
              /usr/local/bin/node
              /usr/local/bin/npm
              v12.18.4
              v12.18.4
              6.14.6
              nodejs:
                Versionstabelle:
              @torsten28
              Ließ die Anleitung aus meiner Signatur.
                @torsten28
                Torsten28
                @thomas-braun Jupp, die habe ich ja auch durch gearbeitet
                • T Torsten28
                  @torsten28 Dann sollte ja auch klar sein, dass
                  /usr/local/bin/
                  der falsche Pfad ist.
                    /usr/local/bin/
                    Torsten28
                    Hey, alles klar ....
                    Habe ich irgendwie übersehen.
                    Habe das nun neu installiert und siehe da, auch in den richtigen Ordner ... :-)
                    Alles super, danke :-)
                    W 1 Antwort Letzte Antwort
                    • T Torsten28
                      W Offline
                      W Offline
                      Willi-Wunder
                      schrieb am zuletzt editiert von Willi-Wunder
                      Hi, hab das gleiche Problem beim Updaten, neue Version erscheint nicht. Soweit ich das gecheckt habe, liegt es wohl am Pfad mit /usr/local/bin/node. Wie kann ich das korrigieren?
                      pi@raspberrypi:~ $ which nodejs node npm && nodejs -v && node -v && npm -v && apt policy nodejs
                      /usr/bin/nodejs
                      /usr/local/bin/node
                      /usr/local/bin/npm
                      v16.17.0
                      v16.17.0
                      8.15.0
                      nodejs:
                        Installiert:           16.18.0-deb-1nodesource1
                        Installationskandidat: 16.18.0-deb-1nodesource1
                        Versionstabelle:
                       *** 16.18.0-deb-1nodesource1 500
                              500 https://deb.nodesource.com/node_16.x buster/main armhf Packages
                           10.24.0~dfsg-1~deb10u2 500
                      Wollte eigentlich Node.js + NPM updaten.
                      Kann mir jemand helfen?
                      Vielen Dank.
                      Gruß Willi
                      • W Willi-Wunder
                        /usr/bin/nodejs
                        /usr/local/bin/node
                        /usr/local/bin/npm
                        v16.17.0
                        v16.17.0
                        8.15.0
                        nodejs:
                          Versionstabelle:
                        Vielen Dank.
                        Gruß Willi
                        @willi-wunder
                        https://forum.iobroker.net/topic/35090/howto-nodejs-installation-und-upgrades-unter-debian/2
                          @willi-wunder
                          W Offline
                          W Offline
                          Willi-Wunder
                          Mega, vielen Dank, läuft jetzt :-) 👍
                          • W Willi-Wunder
                            @willi-wunder
                            Okay, was sagt:
                            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                            nun?
                              @willi-wunder
                              Okay, was sagt:
                              nun?
                              W Offline
                              W Offline
                              Willi-Wunder
                              pi@raspberrypi:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                              ln: die symbolische Verknüpfung '/usr/bin/nodejs' konnte nicht angelegt werden: Die Datei existiert bereits
                              pi@raspberrypi:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && echo $XDG_SESSION_TYPE && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                              armv7l
                              /usr/bin/nodejs
                              /usr/bin/node
                              /usr/bin/npm
                              v16.18.0
                              v16.18.0
                              8.19.2
                              4.0.23
                              pi
                              pi adm dialout cdrom sudo audio video plugdev games users input netdev lpadmin gpio i2c spi iobroker
                              x11
                              /home/pi
                              OK:3 https://deb.nodesource.com/node_16.x buster InRelease
                              nodejs:
                                Versionstabelle:
                              pi@raspberrypi:~ $
                              • W Willi-Wunder
                                armv7l
                                /usr/bin/nodejs
                                /usr/bin/node
                                /usr/bin/npm
                                v16.18.0
                                v16.18.0
                                8.19.2
                                4.0.23
                                pi
                                x11
                                /home/pi
                                nodejs:
                                  Versionstabelle:
                                pi@raspberrypi:~ $
                                @willi-wunder
                                Ja, passt soweit.
                                Aber betreib das Ding OHNE Desktop.
                                  @willi-wunder
                                  Ja, passt soweit.
                                  W Offline
                                  W Offline
                                  Willi-Wunder
                                  Was meinst du genau damit? Hab den Rasp und greife mit VNC drauf zu, alles Lokal. Oder verstehe ich was falsch?
                                  • W Willi-Wunder
                                    @willi-wunder
                                    Ja, macht man nicht.
                                    Man greift über SSH auf die Kommandozeile zu.
                                      @willi-wunder
                                      W Offline
                                      W Offline
                                      Willi-Wunder
                                      Bin nur Anwender und arbeite mich in solche Dinge erst noch rein. Darf ich fragen was dagegen spricht? Ich finde es praktisch, jetzt werden die Profis die Hände vermutlich über den Kopf zusammen schlagen 🕶
                                      • W Willi-Wunder
                                        @willi-wunder sagte in Node.js für ioBroker update klappt nicht:
                                        Zu Ressourcenhungig, zu umständlich, zu unsicher, zu aufwändig zu administrieren, usw...
                                        Wozu brauchst du da einen vollen Desktop mit VNC-Server?
                                        Den ioBroker bedienst du entweder über das Webinterface oder über eine SSH-Verbindung im Terminal. Wozu also den ganzen unnötigen Zinnober?
                                          W Offline
                                          W Offline
                                          Willi-Wunder
                                          Vielen Dank für den Hinweis. Hab mir darüber keine großen Gedanken gemacht, bei mir läuft nicht so viel, hab es nur für meine Heizung und die Rollos. Da es auch nur im internen Netzwerk läuft, sollte die Sicherheit denke ich gegeben sein. Putty hab ich eigentlich auch auf dem PC, könnte man VNC auch abschalten, reicht das?
                                          Nochmals vielen Dank für die schnelle Hilfe, TOP
