  5. Blockly zu Medikamentenbestellung *gelöst*
14 Beiträge 4 Kommentatoren 1.4k Aufrufe 3 Beobachtet
  • ArmilarA Armilar
    @surfer09
    Wäre das so wie du dir das vorstellst?
      <variables>
        <variable id="G*`]]U$zjbIZxV!:7F_o">Anzahl_verbleibende_Tage</variable>
      </variables>
      <block type="create" id="-JMH1!^#35FNI0Ie^`;p" inline="true" x="-437" y="-337">
        <field name="NAME">0_userdata.0.Test.MediCalc.1.GesamtBestand</field>
        <value name="VALUE">
          <block type="math_number" id="7DzJI5hGW{P8HO3rp4@Z">
            <field name="NUM">750</field>
          </block>
        </value>
        <value name="COMMON">
          <block type="text" id="25V5Xlr~6Muygj$6W,Tn">
            <field name="TEXT">{"type":"number"}</field>
          </block>
        </value>
        <next>
          <block type="create" id="=]3C1tlZJWn/41qK|wfN" inline="true">
            <field name="NAME">0_userdata.0.Test.MediCalc.1.Tagesbedarf</field>
              <block type="math_number" id="NeO|b*rTJl;z;K3Tk]:D">
                <field name="NUM">1</field>
              </block>
            </value>
              <block type="text" id="fo?I*MO(M3ri3;}da{VW">
              </block>
            </value>
            <next>
              <block type="comment" id="*]C2B/4J$K!I(fiO)m#x">
                <field name="COMMENT">4 Wochen = 28 Tage</field>
                <next>
                  <block type="create" id="2{Q-bqTN@iYk@VvrZlMN" inline="true">
                    <field name="NAME">0_userdata.0.Test.MediCalc.1.WarnungTage</field>
                      <block type="math_number" id="z=GG/OH})sI_uA!E*}lq">
                        <field name="NUM">28</field>
                      </block>
                    </value>
                      <block type="text" id="hSLP.7!7~v1)7![Kwy(m">
                      </block>
                    </value>
                    <next>
                      <block type="create" id="t-GN3[jiJ/s,CvuFt~!{" inline="true">
                        <field name="NAME">0_userdata.0.Test.MediCalc.1.ReichweiteTage</field>
                          <block type="math_number" id="GYh,f7H~rgdZc8IM=|22">
                            <field name="NUM">0</field>
                          </block>
                        </value>
                          <block type="text" id="bL*)m%.yOBYh(Yp_M.RV">
                          </block>
                        </value>
                        <next>
                          <block type="create" id="UGRN?Z[30$9Jm(G7[!31" inline="true">
                            <field name="NAME">0_userdata.0.Test.MediCalc.1.ReichweiteDatum</field>
                              <block type="time_get" id="*L5SEOx^=N9XOf#Lo)#.">
                                <field name="OPTION">DD.MM.YYYY</field>
                              </block>
                            </value>
                              <block type="text" id="i]xyO$b0w[ymd{06YLHC">
                                <field name="TEXT">{"type":"string"}</field>
                              </block>
                            </value>
                            <next>
                              <block type="schedule" id="h~Vvmf[N2eX6i|v+sP/.">
                                <field name="SCHEDULE">0 19 * * *</field>
                                <statement name="STATEMENT">
                                  <block type="control_ex" id="hGKVeF_y[Ws6gmb7?w`E">
                                    <field name="TYPE">false</field>
                                    <value name="OID">
                                      <shadow type="field_oid" id="dQ:xzCcTYfyzuJ[x;ANB">
                                        <field name="oid">Object ID</field>
                                      </shadow>
                                      <block type="text" id="U:2]N4j6/g~h#Djq`MJ-">
                                        <field name="TEXT">0_userdata.0.Test.MediCalc.1.GesamtBestand</field>
                                      </block>
                                    </value>
                                      <shadow type="logic_boolean" id="_}~Hgdm,C$P0GVw:V-3m">
                                      </shadow>
                                      <block type="math_arithmetic" id=")wVbnP5T9WhjG]2_-:B4" inline="false">
                                        <value name="A">
                                          <shadow type="math_number" id="LhKnFtuczwK!MAfE$e0Y">
                                          </shadow>
                                          <block type="get_value_var" id="#X+qDeeC,*HqcH=R,~c4">
                                            <value name="OID">
                                              <shadow type="text" id="6JKdrd^P0HKN,hT(X$B,">
                                              </shadow>
                                            </value>
                                          </block>
                                        </value>
                                        <value name="B">
                                          <shadow type="math_number" id="w*J{-o^/.~0#Q*$qvS/v">
                                          </shadow>
                                          <block type="get_value_var" id="f;OLGqq6jOElY#.5Amum">
                                            <value name="OID">
                                              <shadow type="text" id="Rq=Gcd*ji|Zul@DWq*_.">
                                                <field name="TEXT">0_userdata.0.Test.MediCalc.1.Tagesbedarf</field>
                                              </shadow>
                                            </value>
                                          </block>
                                        </value>
                                      </block>
                                    </value>
                                    <value name="DELAY_MS">
                                      <shadow type="math_number" id="gR{+c,mIV8XLDwZT6M~9">
                                      </shadow>
                                    </value>
                                    <next>
                                      <block type="variables_set" id="SDs$N$))#q,GuO81im*h">
                                        <field name="VAR" id="G*`]]U$zjbIZxV!:7F_o">Anzahl_verbleibende_Tage</field>
                                          <block type="math_arithmetic" id="M7-Hjb)W%D.?|PJS?^v(" inline="false">
                                            <field name="OP">DIVIDE</field>
                                            <value name="A">
                                              <shadow type="math_number" id="?13[!|PSkDOG{zKFz(ZT">
                                              </shadow>
                                              <block type="get_value_var" id="x9Mu!3SI`|O3cL.fV/sZ">
                                                <value name="OID">
                                                  <shadow type="text" id="M]#s?hWHhlfB`S:$_g@~">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                              <shadow type="math_number" id="g+x$JAg6b!*D;fa7jz8T">
                                              </shadow>
                                              <block type="get_value_var" id="3oH,)XS,%p@?b;COt~V%">
                                                <value name="OID">
                                                  <shadow type="text" id="AH+1yxbQ]VX?Gung[SE`">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                        <next>
                                          <block type="control_ex" id="-L-2(J$PKwnU*^}Z8x3.">
                                            <value name="OID">
                                              <shadow type="field_oid">
                                              </shadow>
                                              <block type="text" id="NiYbUALzNNi1wb.VtJL:">
                                                <field name="TEXT">0_userdata.0.Test.MediCalc.1.ReichweiteDatum</field>
                                              </block>
                                            </value>
                                              <shadow type="logic_boolean">
                                              </shadow>
                                              <block type="convert_from_date" id="1!Sf)U%BNaWYlcV+CcIe">
                                                  <block type="math_arithmetic" id="@%P~yjyG#$ga8);M?73R" inline="false">
                                                    <field name="OP">ADD</field>
                                                    <value name="A">
                                                      <shadow type="math_number">
                                                      </shadow>
                                                      <block type="time_get" id=":e5HvH2X/6KKnph?0M75">
                                                        <field name="OPTION">object</field>
                                                      </block>
                                                    </value>
                                                    <value name="B">
                                                      </shadow>
                                                      <block type="math_arithmetic" id="D7K^YP]/JOt$4g*#Ug_9">
                                                        <field name="OP">MULTIPLY</field>
                                                        <value name="A">
                                                          <shadow type="math_number" id="2R4#E?;]V`=$PTsI%Oq~">
                                                            <field name="NUM">86400000</field>
                                                          </shadow>
                                                        </value>
                                                        <value name="B">
                                                          </shadow>
                                                          <block type="variables_get" id="CdYx$Qx2D#:vEB)_~CSr">
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                              <shadow type="math_number" id="M^$nnL[NnOA;}!1!B#DZ">
                                              </shadow>
                                            </value>
                                            <next>
                                              <block type="control_ex" id="0sT^INHS(U{#yI3rqbws">
                                                <value name="OID">
                                                  </shadow>
                                                  <block type="text" id="?E1pghQj+w}2zTLcJ#*2">
                                                    <field name="TEXT">0_userdata.0.Test.MediCalc.1.ReichweiteTage</field>
                                                  </block>
                                                </value>
                                                  <shadow type="logic_boolean" id="+Ewf+eWz806Ih+]kX$a,">
                                                  </shadow>
                                                  <block type="variables_get" id=")Cp^Bw)Ea;4K=tXi*RIM">
                                                  </block>
                                                </value>
                                                  <shadow type="math_number" id="4{JX9mUj/T:J2_jkb=(W">
                                                  </shadow>
                                                </value>
                                                <next>
                                                  <block type="debug" id="CF:Dh:w!o9zH{]kQ}=5v">
                                                    <value name="TEXT">
                                                      <shadow type="text" id="%y57o4=UcG|.rQjY)4Jv">
                                                      </shadow>
                                                      <block type="variables_get" id="Y){Ge=^:8}27$[N@^w1U">
                                                      </block>
                                                    </value>
                                                    <next>
                                                      <block type="debug" id="3`hMN_fB-T~3!?,1tM*K">
                                                        <value name="TEXT">
                                                          <shadow type="text" id="q:W$4~FgoUW+rq*53{W{">
                                                          </shadow>
                                                          <block type="convert_from_date" id="_BC!gBUnO.nz,l%H2Q%~">
                                                              <block type="math_arithmetic" id="mD`zSu[s`oCjYN[GR^H%" inline="false">
        <value name="A">
        <shadow type="math_number" id="HU}HIg1@5KHpL~XH%eVo">
        </shadow>
        <block type="time_get" id="HzT9z^w$l~1F`dzxZGEk">
        </block>
        </value>
        <value name="B">
        <shadow type="math_number" id="r^IG$XR}a)K=QmR_rYhI">
        </shadow>
        <block type="math_arithmetic" id="+MyPdth8gKbZhX3{xZ_c">
        <value name="A">
        <shadow type="math_number" id="Gx:~gLx{@!b=nRK(TBUr">
        </shadow>
        </value>
        <value name="B">
        <shadow type="math_number" id="!H/@HF_[$9An?/]1!,6e">
        </shadow>
        <block type="variables_get" id="cP54OM`/ZH*P4Rs0;fJ#">
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                        <next>
                                                          <block type="controls_if" id="g:e^(O4fHk?pR@cUEP+!">
                                                            <value name="IF0">
                                                              <block type="logic_compare" id="MnKzN]WF-T#cW5.=L5+8">
        <field name="OP">LTE</field>
        <value name="A">
        <block type="variables_get" id="O3;FFF|/3P5*XpNL%a@;">
        </block>
        </value>
        <value name="B">
        <block type="get_value_var" id="3Ii:Ff~TKwUY+3DyAERp">
        <value name="OID">
        <shadow type="text" id="-lgRcL;n?uqC}xV_NlPw">
        <field name="TEXT">0_userdata.0.Test.MediCalc.1.WarnungTage</field>
        </shadow>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <statement name="DO0">
                                                              <block type="sendto_custom" id="[;81EZ%z$sn~Y#Gm;nYa">
        <mutation xmlns="http://www.w3.org/1999/xhtml" items="parameter1" with_statement="false"></mutation>
        <field name="INSTANCE">telegram.0</field>
        <field name="COMMAND">send</field>
        <field name="LOG"></field>
        <field name="WITH_STATEMENT">FALSE</field>
        <value name="ARG0">
        <shadow type="text" id="zV)nvs$L$f$Up0XW42ie">
        <field name="TEXT"></field>
        </shadow>
        <block type="text_join" id="+aigpuCMB,btBZ5FkKz}">
        <value name="ADD0">
        <block type="text" id="-wG3f~_D~!Xj9f#Eg(0c">
        <field name="TEXT">Warnung für Medikament 2. Aufgebraucht in</field>
        </block>
        </value>
        <value name="ADD1">
        <block type="variables_get" id="xYmw/05?Q^?5T.7xaL}t">
        </block>
        </value>
        <value name="ADD2">
        <block type="text" id="=9Vf0Ag3@ynWzOg|~Y3!">
        <field name="TEXT"> Tagen</field>
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </statement>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </next>
                                  </block>
                                </statement>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </next>
      </block>
    </xml>
    Kannst du dann auch in eine Visu einbauen
    Klein wenig zur Erklärung:
    Skript je Medikament anlegen und den Index hier 1 verändern
    In gewissen Abständen Inventur durchführen und Gesamtbestand in den Datenpunkt eintragen...
    Zu einer bestimmten Zeit (hier 19:00 Uhr)
    Wenn Zeitraum für Warnung in Tagen erreicht, dann Meldung an Telegram
    Hoffe das hilft dir und Deiner Family
    LG
    sigi234S Online
    sigi234S Online
    @armilar
    Cool, Danke.
    Denke es wäre noch Super wenn man Name des Medikaments und die Art-Menge ( mg/Tropfen/Hub) als DP hätte.
    Dann noch das ganze als Table für Vis. 😀
    • sigi234S sigi234
      @armilar
      Cool, Danke.
      ArmilarA Offline
      ArmilarA Offline
      Armilar
      Most Active Forum Testing
      @sigi234
      Ich glaube an dich... Du schaffst das... 😊
      • ArmilarA Armilar
        @surfer09
          <variables>
          </variables>
              </block>
            </value>
              </block>
            </value>
            <next>
                  </block>
                </value>
                  </block>
                </value>
                <next>
                    <next>
                          </block>
                        </value>
                          </block>
                        </value>
                        <next>
                              </block>
                            </value>
                              </block>
                            </value>
                            <next>
                                  </block>
                                </value>
                                  </block>
                                </value>
                                <next>
                                        <value name="OID">
                                          </shadow>
                                          </block>
                                        </value>
                                          </shadow>
                                            <value name="A">
                                              </shadow>
                                                <value name="OID">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                            <value name="B">
                                              </shadow>
                                                <value name="OID">
                                                  </shadow>
                                                </value>
                                              </block>
                                            </value>
                                          </block>
                                        </value>
                                          </shadow>
                                        </value>
                                        <next>
                                                <value name="A">
                                                  </shadow>
                                                    <value name="OID">
                                                      </shadow>
                                                    </value>
                                                  </block>
                                                </value>
                                                <value name="B">
                                                  </shadow>
                                                    <value name="OID">
                                                      </shadow>
                                                    </value>
                                                  </block>
                                                </value>
                                              </block>
                                            </value>
                                            <next>
                                                <value name="OID">
                                                  </shadow>
                                                  </block>
                                                </value>
                                                  </shadow>
                                                        <value name="A">
                                                          </shadow>
                                                          </block>
                                                        </value>
                                                        <value name="B">
                                                          </shadow>
                                                            <value name="A">
                                                              </shadow>
                                                            </value>
                                                            <value name="B">
                                                              </shadow>
                                                              </block>
                                                            </value>
                                                          </block>
                                                        </value>
                                                      </block>
                                                    </value>
                                                  </block>
                                                </value>
                                                  </shadow>
                                                </value>
                                                <next>
                                                    <value name="OID">
                                                      </shadow>
                                                      </block>
                                                    </value>
                                                      </shadow>
                                                      </block>
                                                    </value>
                                                      </shadow>
                                                    </value>
                                                    <next>
                                                        <value name="TEXT">
                                                          </shadow>
                                                          </block>
                                                        </value>
                                                        <next>
                                                            <value name="TEXT">
                                                              </shadow>
        <value name="A">
        </shadow>
        </block>
        </value>
        <value name="B">
        </shadow>
        <value name="A">
        </shadow>
        </value>
        <value name="B">
        </shadow>
        </block>
        </value>
        </block>
        </value>
        </block>
        </value>
                                                              </block>
                                                            </value>
                                                            <next>
        <value name="IF0">
        <value name="A">
        </block>
        </value>
        <value name="B">
        <value name="OID">
        </shadow>
        </value>
        </block>
        </value>
        </block>
        </value>
        <value name="ARG0">
        </shadow>
        <value name="ADD0">
        </block>
        </value>
        <value name="ADD1">
        </block>
        </value>
        <value name="ADD2">
        </block>
        </value>
        </block>
        </value>
        </block>
        </statement>
                                                              </block>
                                                            </next>
                                                          </block>
                                                        </next>
                                                      </block>
                                                    </next>
                                                  </block>
                                                </next>
                                              </block>
                                            </next>
                                          </block>
                                        </next>
                                      </block>
                                    </statement>
                                  </block>
                                </next>
                              </block>
                            </next>
                          </block>
                        </next>
                      </block>
                    </next>
                  </block>
                </next>
              </block>
            </next>
          </block>
        </xml>
        LG
        surfer09S Offline
        surfer09S Offline
        surfer09
        @armilar Das ist ja wirklich super. Ich werde das gleich mal nachbauen und berichten. Vielen, vielen Dank schon einmal für deine Hilfe! :-)
        • surfer09S surfer09
          ArmilarA Offline
          ArmilarA Offline
          Armilar
          @surfer09
          Siehe Spoiler... Code ist dabei
          • ArmilarA Armilar
            @sigi234
            sigi234S Online
            sigi234S Online
            @armilar sagte in Blockly zu Medikamentenbestellung:
            @sigi234
            Wird schon. 😀
            • sigi234S sigi234
              @sigi234
              Wird schon. 😀
              ArmilarA Offline
              ArmilarA Offline
              Armilar
              @sigi234
              Kannst den 2. Teil ja auch noch posten ;-)
              • ArmilarA Armilar
                @sigi234
                sigi234S Online
                sigi234S Online
                @sigi234
                Welchen meinst du?
                • sigi234S sigi234
                  @sigi234
                  Welchen meinst du?
                  ArmilarA Offline
                  ArmilarA Offline
                  Armilar
                  @sigi234
                  Na - Name und Dosis und die Vis-Aufbereitung. Langsam wird ein Schuh draus👍
                  surfer09S 1 Antwort Letzte Antwort
                  • ArmilarA Armilar
                    @sigi234
                    surfer09S Offline
                    surfer09S Offline
                    surfer09
                    @armilar: Das Skript funktioniert super! Ich habe jetzt aber den Fall, dass das Skript 13,5 Tage berechnet hat. Kann man die Tage noch als ganze Tage irgendwie festlegen?
                    Was natürlich auch noch cool wäre, wenn man über das Smartphone den Gesamtbestand neu hinterlegen könnte. Also die neue Anzahl an den Datenpunkt senden und der addiert dann die neuen Tabletten mit dem aktuellen Gesamtbestand.
                    ArmilarA madingM 2 Antworten Letzte Antwort
                      ArmilarA Offline
                      ArmilarA Offline
                      Armilar
                      @surfer09
                      Setzte da einfach ein runde (Matheblock) vor
                      Du könntest dir jetzt eine Vis bauen für das Handy mit zwei Eingabefeldern.
                      Jetzt kommen die VIS-Nerds ins Spiel
                      Ich könnte dir sagen, wie du es volldynamisch ins NSPanel bekommst ;-)
                        madingM Online
                        madingM Online
                        mading
                        schrieb am zuletzt editiert von mading
                        @surfer09 sagte in Blockly zu Medikamentenbestellung *gelöst*:
                        Erstelle dir (je Medi) einen Datenpunkt als bool. Init false. Baumdir ein blockly mit trigger auf Änderund dieses Trigger DP und falls es wahr ist, addierst du (falls notwendig eine Zahl aus einem weiteren DP falls sich die Packungsgrösse ändert) die neue Anzahl hinzu. Im vis kannst du dir einen switch button machen, der auf true stellt. Vergiss nicht im blockly den bool wert wieder auf false nach Addition zu setzen ;)
                        Alternativ schreibt der vis button eine vordefinierte zahl in einen number DP und du machst das gleiche mit einem trigger nur nicht auf das bool sondern Änderung auf number DP
