  4. Alexa2 Adapter 3.18.x (BETA)
449 Beiträge 38 Kommentatoren 138.7k Aufrufe 42 Beobachtet
  • apollon77A apollon77
    @esp8266 sagte in Alexa2 Adapter 3.18.x (BETA):
    Schedule restart: 0 6 * * *
    Und verrätst Du mir noch warum du das drin hast? Ich brauch das nicht.
    ESP8266E
    ESP8266E
    ESP8266
    schrieb am zuletzt editiert von ESP8266
    #419
    @apollon77 sagte in Alexa2 Adapter 3.18.x (BETA):
    Noch von irgendwelchen Ur-Zeiten.
    Ich habe nun 2 X Manuell ein neues Cookie angefordert.
    Zeit
    Nachricht
    host.iobroker
    	2022-10-27 17:32:57.412	info	Do not restart adapter system.adapter.alexa2.0 because desired by instance
    host.iobroker
    	2022-10-27 17:32:57.411	error	instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    alexa2.0
    	2022-10-27 17:32:56.632	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    alexa2.0
    	2022-10-27 17:32:55.629	error	Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
    alexa2.0
    	2022-10-27 17:32:55.298	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
    host.iobroker
    	2022-10-27 17:32:51.600	info	instance system.adapter.alexa2.0 started with pid 18481
    host.iobroker
    	2022-10-27 17:32:49.015	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.iobroker
    	2022-10-27 17:32:48.433	info	stopInstance system.adapter.alexa2.0 send kill signal
    alexa2.0
    	2022-10-27 17:32:48.376	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    alexa2.0
    	2022-10-27 17:32:48.368	info	terminating
    alexa2.0
    	2022-10-27 17:32:48.364	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    	2022-10-27 17:32:48.348	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
    alexa2.0
    	2022-10-27 17:32:48.184	info	Update cookie in adapter configuration ... restarting ...
    alexa2.0
    	2022-10-27 17:31:41.476	error	Error: You can try to get the cookie manually by opening http://192.168XXXX:37625/ with your browser.
    alexa2.0
    	2022-10-27 17:31:41.475	error	Error:
    alexa2.0
    	2022-10-27 17:31:40.429	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
    host.iobroker
    	2022-10-27 17:31:36.562	info	instance system.adapter.alexa2.0 started with pid 18331
    host.iobroker
    	2022-10-27 17:30:37.299	info	instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.iobroker
    	2022-10-27 17:30:31.533	info	Do not restart adapter system.adapter.alexa2.0 because desired by instance
    host.iobroker
    	2022-10-27 17:30:31.532	error	instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    alexa2.0
    	2022-10-27 17:30:30.827	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    alexa2.0
    	2022-10-27 17:30:29.821	error	Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
    alexa2.0
    	2022-10-27 17:30:29.367	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
    host.iobroker
    	2022-10-27 17:30:24.251	info	instance system.adapter.alexa2.0 started with pid 18186
    host.iobroker
    	2022-10-27 17:30:21.728	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    alexa2.0
    	2022-10-27 17:30:21.072	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    alexa2.0
    	2022-10-27 17:30:21.067	info	terminating
    host.iobroker
    	2022-10-27 17:30:21.062	info	stopInstance system.adapter.alexa2.0 send kill signal
    alexa2.0
    	2022-10-27 17:30:21.044	info	Got terminate signal TERMINATE_YOURSELF
    host.iobroker
    	2022-10-27 17:30:20.990	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
    host.iobroker
    	2022-10-27 17:30:20.785	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
    alexa2.0
    	2022-10-27 17:30:20.779	info	Update cookie in adapter configuration ... restarting ...
    host.iobroker
    	2022-10-27 17:30:10.099	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.iobroker
    	2022-10-27 17:30:08.990	info	instance system.adapter.ical.0 started with pid 18143
    host.iobroker
    	2022-10-27 17:30:04.663	info	instance system.adapter.daswetter.0 started with pid 18119
    host.iobroker
    	2022-10-27 17:30:00.384	info	instance system.adapter.dwd.0 started with pid 18099
    alexa2.0
    	2022-10-27 17:28:41.309	error	Error: You can try to get the cookie manually by opening http://192.168.XXXX:41955/ with your browser.
    alexa2.0
    	2022-10-27 17:28:41.307	error	Error:
    alexa2.0
    	2022-10-27 17:28:40.315	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
    • ESP8266E ESP8266
      Zeit
      Nachricht
      host.iobroker
      host.iobroker
      alexa2.0
      alexa2.0
      alexa2.0
      host.iobroker
      host.iobroker
      host.iobroker
      alexa2.0
      alexa2.0
      alexa2.0
      host.iobroker
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      alexa2.0
      alexa2.0
      alexa2.0
      host.iobroker
      host.iobroker
      alexa2.0
      alexa2.0
      host.iobroker
      alexa2.0
      host.iobroker
      host.iobroker
      alexa2.0
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      alexa2.0
      alexa2.0
      alexa2.0
      apollon77A
      apollon77A
      #420
      ok, dann machmer mal was anderes ... gehe mal mit SSH auf den Host und mache
      • adapter beenden
      • cd /opt/iobroker/node_modules/iobroker.alexa2
      • schaue ob es da ein crashCheck-alexa.0.json gibt und wenn ja lösche es
      • adapter starten
      Irgendwie hat sich da bei dir der Crash Check verklemmt
      ESP8266E 2 Antworten Letzte Antwort
        • adapter beenden
        • adapter starten
        ESP8266E
        ESP8266E
        ESP8266
        #421
        @apollon77 , jetzt wurde er Grün. Hat wohl etwas Zeit gebraucht.
          • adapter beenden
          • adapter starten
          ESP8266E
          ESP8266E
          ESP8266
          #422
          @apollon77 , Schedule ist raus....irgenwann mal in den Anfangszeiten gewesen und dann nicht mehr drauf geachtet.
          • ESP8266E ESP8266
            J
            J
            Jan.S100
            schrieb am zuletzt editiert von Jan.S100
            #423
            Im Moment kommen keine Daten von meinem Luftgütesensor rein. 😱
            Auch das schalten einer Steckdose funktioniert nicht über den entsprechenden Eintrag.
            Der Adapter ist aktualisiert auf 3.19.10 und im normalen Log ist nichts zu sehen.
            • J Jan.S100
              padrinoP
              padrinoP
              padrino
              #424
              Sieht aus, als würde
              alexa2.0.Smart-Home-Devices.xxxx.powerState
              nicht mehr ein Gerät schalten können (true/false hat keine Auswirkung).
              Muss mal schauen, ob ich ein debug noch machen kann... =)
              • padrinoP padrino
                apollon77A
                apollon77A
                #425
                @padrino mach kein Debug. Es ist aktuell ggf limitiert. je mehr ihr gerade rumversucht umso schlimmer ists am Ende
                  padrinoP
                  padrinoP
                  padrino
                  #426
                  Zu spät :(
                  Bin jetzt ganz raus...
                  alexa2.0 2022-10-27 19:41:57.842 debug (8400) Alexa-Remote: rate exceeded response ... "
                  http://192.168.178.29:8081/#:~:text=Meldung-,alexa2.0,(8400) Alexa-Remote%3A rate exceeded response ...,-Retrying...
                  Stell den Adapter jetzt aus...
                  • padrinoP padrino
                    Zu spät :(
                    apollon77A
                    apollon77A
                    #427
                    @padrino Du kannst Ihn starten ... das rate limit ist wieder nur bei den smart home device dingen
                    ggf stell das aktualisieren der werte aus ... aber sonst kann er an bleiben
                    padrinoP R 2 Antworten Letzte Antwort
                      padrinoP
                      padrinoP
                      padrino
                      schrieb am zuletzt editiert von padrino
                      #428
                      @apollon77
                      Habe die Aktualisierung eigentlich hier eh aus... 🤷
                        R
                        R
                        RolfFrie
                        #429
                        @apollon77
                        ich nutze Version 3.19.10 ( node: v16.18.0, js-controller: 4.0.23 )
                        Leider ist mein Ordner Smart-Home-Devices bis auf deleteAll/discoverDevices seit dem letzten alexa2-Update komplett leer. Echo-Devices werden normal erzeugt. Danach folgt:
                        Subscribing to states...
                        Deleting the following states: ["Echo-Devices.G0xxxx.Alarm"
                        ices.G0xxxx.Reminder.triggered","Echo-Devices.G0xxxx
                        Alexa-Push-Connection (macDms = true) established. Disable Polling
                        Initialization Done ...
                        Und das war's.
                        Folgendes habe ich bereits ohne Erfolg versucht:
                        Löschen des Ordners Alexa2
                        Cookie neu erzeugen
                        crashCheck-alexa2.0.json löschen
                        und immer wieder Adapter neustarten.
                        NIX
                        BananaJoeB apollon77A 2 Antworten Letzte Antwort
                        • R RolfFrie
                          @apollon77
                          Und das war's.
                          Cookie neu erzeugen
                          NIX
                          BananaJoeB
                          BananaJoeB
                          BananaJoe
                          #430
                          @rolffrie Sind die denn in der App drin? Ich habe bei mir auch gerade erste Anfang der Woche gehabt das Alexa sämtliche Smarthome-Geräte die nicht Echos oder Fire TVs waren vergessen hat
                          R 1 Antwort Letzte Antwort
                          • R RolfFrie
                            @apollon77
                            Und das war's.
                            Cookie neu erzeugen
                            NIX
                            apollon77A
                            apollon77A
                            #431
                            @rolffrie dann sind die Objekte leider vor dem Update auf die 3.19.10 gelöscht worden. Dann musst du warten bis Amazon das mit der Sperre wieder lockert oder ich mal von denen Feedback bekomme :-( ist gerade wenig befriedigend.
                            Spätestens nächste Woche mache ich was drum herum aber am Ende bleibt die Frage ob das Daten regelmäßig lesen nicht vllt besser wieder raus sollte :-(
                              R
                              R
                              RolfFrie
                              #432
                              @apollon77
                              D.h. Daten regelmäßig lesen sollte dann durch das Lesen auf manuelle Anforderung ersetzt werden?
                              Denn einige Daten als solches sind schon ziemlich essenziell für meine Umgebung.
                              Müsste man dann Routinen nutzen, die z.B. vor dem Lesen der Daten die Daten zusätzlich manuell von Amazon anfordert?
                              • BananaJoeB BananaJoe
                                R
                                R
                                RolfFrie
                                #433
                                @bananajoe
                                Die App ist VOLL mit SmartHomeGeräten. Aber in alexa2 ist nix.
                                • R RolfFrie
                                  @bananajoe
                                  M
                                  M
                                  moritzn
                                  #434
                                  @rolffrie said in Alexa2 Adapter 3.18.x (BETA):
                                  @bananajoe
                                  Ich klinge mich hier ein mit dem gleichen Problem, die Geräte waren allerdings vorgestern schon vor dem Update auf die neue Version nicht mehr ansprechbar; nach dem Update waren sie komplett weg.
                                  Die "Limit reached" Meldung tauchte ab und zu im Debug log auf.
                                  • M moritzn
                                    @bananajoe
                                    R
                                    R
                                    RolfFrie
                                    #435
                                    @moritzn
                                    Ich bin mir nicht sicher ggf. war dies auch schon vor dem Update bei mir.
                                    • DJMarc75D
                                      DJMarc75D
                                      DJMarc75
                                      #436
                                      @moritzn @RolfFrie
                                      Das Ratelimit trat am Donnerstag in den frühen Morgenstunden in Kraft und unabhängig von der Adapterversion.
                                      Wichtig ist jetzt bitte Geduld aufzubringen, keinen Adapterneustart machen und auch bitte NICHT die SmarthomeDevices manuell abrufen.
                                      Wie @apollon77 schrieb arbeitet er daran das ganze zu fixen. Erster Fix war ja die jetzt neuste Version 3.19.10, da mit Vorgängerversionen KEINE Steuerung mehr ALLER Funktionen gegeben war (nach Neustart des Adapters).
                                      Also habt Geduld 😀
                                      Lehrling seit 1975 !!!
                                      ESP8266E 1 Antwort Letzte Antwort
                                      • R RolfFrie
                                        @apollon77
                                        apollon77A
                                        apollon77A
                                        #437
                                        @rolffrie Also generell ist die Farge ob Du nicht für die "essentiellen Geräte" mal einen Adapter Request stellst das es vllt zu einer nativen Anbindung kommt bzw die Adapter nutzt die mit den Geräten direkt reden können (z.B SmartLife/Tuya wie oben).
                                        Zur Neuen Version sage ich was wenn Sie heute im Laufe des tages fertig wird
                                        • DJMarc75D DJMarc75
                                          @moritzn @RolfFrie
                                          Also habt Geduld 😀
                                          ESP8266E
                                          ESP8266E
                                          ESP8266
                                          #438
                                          ....oder alles über IOT realisieren. Das habe ich schon von Anfang an und keine Probleme damit.
                                          Das wäre auch eine Entlastung für den Adapter.
                                          84.1k
