  4. Alexa2 Adapter 3.18.x (BETA)
449 Beiträge 38 Kommentatoren 148.2k Aufrufe 42 Beobachtet
  • ESP8266E ESP8266
    @apollon77 , ich schrieb ja schon, das die letzte Version installiert ist.
    Der Alexa2 Adapter war schon vorher Rot.
    host.iobroker
    	2022-10-27 17:10:36.002	info	Restart adapter system.adapter.alexa2.0 because enabled
    host.iobroker
    	2022-10-27 17:10:36.001	info	instance system.adapter.alexa2.0 scheduled normal terminated and will be restarted on schedule.
    host.iobroker
    	2022-10-27 17:10:42.718	info	Do not restart adapter system.adapter.alexa2.0 because desired by instance
    host.iobroker
    	2022-10-27 17:10:42.718	error	instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    alexa2.0
    	2022-10-27 17:10:42.066	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    alexa2.0
    	2022-10-27 17:10:41.063	error	Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
    alexa2.0
    	2022-10-27 17:10:40.778	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
    host.iobroker
    	2022-10-27 17:10:37.182	info	instance system.adapter.alexa2.0 started with pid 15890
    host.iobroker
    host.iobroker
    host.iobroker
    host.iobroker
    host.iobroker
    host.iobroker
    host.iobroker
    host.iobroker
    alexa2.0
    	2022-10-27 17:10:35.211	info	Terminated (START_IMMEDIATELY_AFTER_STOP): Without reason2
    alexa2.0
    	2022-10-27 17:10:35.208	error	Error: Error while checking Authentication: Error: 401 Unauthorized
    alexa2.0
    	2022-10-27 17:10:34.716	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
    host.iobroker
    	2022-10-27 17:10:30.480	info	instance system.adapter.alexa2.0 started with pid 15863
    host.iobroker
    	2022-10-27 17:10:06.611	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.iobroker
    	2022-10-27 17:10:00.110	info	instance system.adapter.dwd.0 started with pid 15788
    host.iobroker
    	2022-10-27 17:05:06.590	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
    host.iobroker
    	2022-10-27 17:05:00.116	info	instance system.adapter.dwd.0 started with pid 15243
    host.iobroker
    	2022-10-27 17:01:44.408	info	Do not restart adapter system.adapter.alexa2.0 because desired by instance
    host.iobroker
    	2022-10-27 17:01:44.407	error	instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
    alexa2.0
    	2022-10-27 17:01:43.784	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
    alexa2.0
    	2022-10-27 17:01:43.783	debug	Plugin sentry destroyed
    alexa2.0
    	2022-10-27 17:01:42.781	error	Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
    alexa2.0
    	2022-10-27 17:01:42.625	debug	Schedule restart: 0 6 * * *
    alexa2.0
    	2022-10-27 17:01:42.517	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
    alexa2.0
    	2022-10-27 17:01:41.849	debug	Plugin sentry Initialize Plugin (enabled=true)
    apollon77A
    apollon77A
    #417
    @esp8266 sagte in Alexa2 Adapter 3.18.x (BETA):
    heisst das da was mit dem Cookie nicht stimmt.
    Am besten bei gestopptem Alexa2 einmal ins Admin des adapters gehen und "cookie neu machen" klicken. Dann Konfig speichern. Dann Alexa2 neu starten und neue Cookie holen.
    • ESP8266E ESP8266
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      alexa2.0
      alexa2.0
      alexa2.0
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      alexa2.0
      alexa2.0
      alexa2.0
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      host.iobroker
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      alexa2.0
      apollon77A
      apollon77A
      #418
      Und verrätst Du mir noch warum du das drin hast? Ich brauch das nicht.
      ESP8266E 1 Antwort Letzte Antwort
      • apollon77A apollon77
        ESP8266E
        ESP8266E
        ESP8266
        schrieb am zuletzt editiert von ESP8266
        #419
        @apollon77 sagte in Alexa2 Adapter 3.18.x (BETA):
        Noch von irgendwelchen Ur-Zeiten.
        Ich habe nun 2 X Manuell ein neues Cookie angefordert.
        Zeit
        Nachricht
        host.iobroker
        	2022-10-27 17:32:57.412	info	Do not restart adapter system.adapter.alexa2.0 because desired by instance
        host.iobroker
        	2022-10-27 17:32:57.411	error	instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        alexa2.0
        	2022-10-27 17:32:56.632	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        alexa2.0
        	2022-10-27 17:32:55.629	error	Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
        alexa2.0
        	2022-10-27 17:32:55.298	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
        host.iobroker
        	2022-10-27 17:32:51.600	info	instance system.adapter.alexa2.0 started with pid 18481
        host.iobroker
        	2022-10-27 17:32:49.015	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.iobroker
        	2022-10-27 17:32:48.433	info	stopInstance system.adapter.alexa2.0 send kill signal
        alexa2.0
        	2022-10-27 17:32:48.376	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        alexa2.0
        	2022-10-27 17:32:48.368	info	terminating
        alexa2.0
        	2022-10-27 17:32:48.364	info	Got terminate signal TERMINATE_YOURSELF
        host.iobroker
        	2022-10-27 17:32:48.348	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
        alexa2.0
        	2022-10-27 17:32:48.184	info	Update cookie in adapter configuration ... restarting ...
        alexa2.0
        	2022-10-27 17:31:41.476	error	Error: You can try to get the cookie manually by opening http://192.168XXXX:37625/ with your browser.
        alexa2.0
        	2022-10-27 17:31:41.475	error	Error:
        alexa2.0
        	2022-10-27 17:31:40.429	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
        host.iobroker
        	2022-10-27 17:31:36.562	info	instance system.adapter.alexa2.0 started with pid 18331
        host.iobroker
        	2022-10-27 17:30:37.299	info	instance system.adapter.daswetter.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.iobroker
        	2022-10-27 17:30:31.533	info	Do not restart adapter system.adapter.alexa2.0 because desired by instance
        host.iobroker
        	2022-10-27 17:30:31.532	error	instance system.adapter.alexa2.0 terminated by request of the instance itself and will not be restarted, before user restarts it.
        alexa2.0
        	2022-10-27 17:30:30.827	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        alexa2.0
        	2022-10-27 17:30:29.821	error	Adapter seems to have issues and crashed three times in a row. Disabling!! Please start again and check logs.
        alexa2.0
        	2022-10-27 17:30:29.367	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
        host.iobroker
        	2022-10-27 17:30:24.251	info	instance system.adapter.alexa2.0 started with pid 18186
        host.iobroker
        	2022-10-27 17:30:21.728	info	instance system.adapter.alexa2.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        alexa2.0
        	2022-10-27 17:30:21.072	info	Terminated (ADAPTER_REQUESTED_TERMINATION): Without reason
        alexa2.0
        	2022-10-27 17:30:21.067	info	terminating
        host.iobroker
        	2022-10-27 17:30:21.062	info	stopInstance system.adapter.alexa2.0 send kill signal
        alexa2.0
        	2022-10-27 17:30:21.044	info	Got terminate signal TERMINATE_YOURSELF
        host.iobroker
        	2022-10-27 17:30:20.990	info	stopInstance system.adapter.alexa2.0 (force=false, process=true)
        host.iobroker
        	2022-10-27 17:30:20.785	info	instance system.adapter.ical.0 terminated with code 0 (NO_ERROR)
        alexa2.0
        	2022-10-27 17:30:20.779	info	Update cookie in adapter configuration ... restarting ...
        host.iobroker
        	2022-10-27 17:30:10.099	info	instance system.adapter.dwd.0 terminated with code 11 (ADAPTER_REQUESTED_TERMINATION)
        host.iobroker
        	2022-10-27 17:30:08.990	info	instance system.adapter.ical.0 started with pid 18143
        host.iobroker
        	2022-10-27 17:30:04.663	info	instance system.adapter.daswetter.0 started with pid 18119
        host.iobroker
        	2022-10-27 17:30:00.384	info	instance system.adapter.dwd.0 started with pid 18099
        alexa2.0
        	2022-10-27 17:28:41.309	error	Error: You can try to get the cookie manually by opening http://192.168.XXXX:41955/ with your browser.
        alexa2.0
        	2022-10-27 17:28:41.307	error	Error:
        alexa2.0
        	2022-10-27 17:28:40.315	info	starting. Version 3.19.10 in /opt/iobroker/node_modules/iobroker.alexa2, node: v14.20.1, js-controller: 4.0.23
        • ESP8266E ESP8266
          Zeit
          Nachricht
          host.iobroker
          host.iobroker
          alexa2.0
          alexa2.0
          alexa2.0
          host.iobroker
          host.iobroker
          host.iobroker
          alexa2.0
          alexa2.0
          alexa2.0
          host.iobroker
          alexa2.0
          alexa2.0
          alexa2.0
          alexa2.0
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          alexa2.0
          alexa2.0
          alexa2.0
          host.iobroker
          host.iobroker
          alexa2.0
          alexa2.0
          host.iobroker
          alexa2.0
          host.iobroker
          host.iobroker
          alexa2.0
          host.iobroker
          host.iobroker
          host.iobroker
          host.iobroker
          alexa2.0
          alexa2.0
          alexa2.0
          apollon77A
          apollon77A
          #420
          ok, dann machmer mal was anderes ... gehe mal mit SSH auf den Host und mache
          • adapter beenden
          • cd /opt/iobroker/node_modules/iobroker.alexa2
          • schaue ob es da ein crashCheck-alexa.0.json gibt und wenn ja lösche es
          • adapter starten
          Irgendwie hat sich da bei dir der Crash Check verklemmt
          ESP8266E 2 Antworten Letzte Antwort
            • adapter beenden
            • adapter starten
            ESP8266E
            ESP8266E
            ESP8266
            #421
            @apollon77 , jetzt wurde er Grün. Hat wohl etwas Zeit gebraucht.
              • adapter beenden
              • adapter starten
              ESP8266E
              ESP8266E
              ESP8266
              #422
              @apollon77 , Schedule ist raus....irgenwann mal in den Anfangszeiten gewesen und dann nicht mehr drauf geachtet.
              • ESP8266E ESP8266
                J
                J
                Jan.S100
                schrieb am zuletzt editiert von Jan.S100
                #423
                Im Moment kommen keine Daten von meinem Luftgütesensor rein. 😱
                Auch das schalten einer Steckdose funktioniert nicht über den entsprechenden Eintrag.
                Der Adapter ist aktualisiert auf 3.19.10 und im normalen Log ist nichts zu sehen.
                • J Jan.S100
                  padrinoP
                  padrinoP
                  padrino
                  #424
                  Sieht aus, als würde
                  alexa2.0.Smart-Home-Devices.xxxx.powerState
                  nicht mehr ein Gerät schalten können (true/false hat keine Auswirkung).
                  Muss mal schauen, ob ich ein debug noch machen kann... =)
                  • padrinoP padrino
                    apollon77A
                    apollon77A
                    #425
                    @padrino mach kein Debug. Es ist aktuell ggf limitiert. je mehr ihr gerade rumversucht umso schlimmer ists am Ende
                      padrinoP
                      padrinoP
                      padrino
                      #426
                      Zu spät :(
                      Bin jetzt ganz raus...
                      alexa2.0 2022-10-27 19:41:57.842 debug (8400) Alexa-Remote: rate exceeded response ... "
                      http://192.168.178.29:8081/#:~:text=Meldung-,alexa2.0,(8400) Alexa-Remote%3A rate exceeded response ...,-Retrying...
                      Stell den Adapter jetzt aus...
                      • padrinoP padrino
                        Zu spät :(
                        apollon77A
                        apollon77A
                        #427
                        @padrino Du kannst Ihn starten ... das rate limit ist wieder nur bei den smart home device dingen
                        ggf stell das aktualisieren der werte aus ... aber sonst kann er an bleiben
                        padrinoP R 2 Antworten Letzte Antwort
                          padrinoP
                          padrinoP
                          padrino
                          schrieb am zuletzt editiert von padrino
                          #428
                          @apollon77
                          Habe die Aktualisierung eigentlich hier eh aus... 🤷
                            R
                            R
                            RolfFrie
                            #429
                            @apollon77
                            ich nutze Version 3.19.10 ( node: v16.18.0, js-controller: 4.0.23 )
                            Leider ist mein Ordner Smart-Home-Devices bis auf deleteAll/discoverDevices seit dem letzten alexa2-Update komplett leer. Echo-Devices werden normal erzeugt. Danach folgt:
                            Subscribing to states...
                            Deleting the following states: ["Echo-Devices.G0xxxx.Alarm"
                            ices.G0xxxx.Reminder.triggered","Echo-Devices.G0xxxx
                            Alexa-Push-Connection (macDms = true) established. Disable Polling
                            Initialization Done ...
                            Und das war's.
                            Folgendes habe ich bereits ohne Erfolg versucht:
                            Löschen des Ordners Alexa2
                            Cookie neu erzeugen
                            crashCheck-alexa2.0.json löschen
                            und immer wieder Adapter neustarten.
                            NIX
                            BananaJoeB apollon77A 2 Antworten Letzte Antwort
                            • R RolfFrie
                              @apollon77
                              Und das war's.
                              Cookie neu erzeugen
                              NIX
                              BananaJoeB
                              BananaJoeB
                              BananaJoe
                              #430
                              @rolffrie Sind die denn in der App drin? Ich habe bei mir auch gerade erste Anfang der Woche gehabt das Alexa sämtliche Smarthome-Geräte die nicht Echos oder Fire TVs waren vergessen hat
                              R 1 Antwort Letzte Antwort
                              • R RolfFrie
                                @apollon77
                                Und das war's.
                                Cookie neu erzeugen
                                NIX
                                apollon77A
                                apollon77A
                                #431
                                @rolffrie dann sind die Objekte leider vor dem Update auf die 3.19.10 gelöscht worden. Dann musst du warten bis Amazon das mit der Sperre wieder lockert oder ich mal von denen Feedback bekomme :-( ist gerade wenig befriedigend.
                                Spätestens nächste Woche mache ich was drum herum aber am Ende bleibt die Frage ob das Daten regelmäßig lesen nicht vllt besser wieder raus sollte :-(
                                  R
                                  R
                                  RolfFrie
                                  #432
                                  @apollon77
                                  D.h. Daten regelmäßig lesen sollte dann durch das Lesen auf manuelle Anforderung ersetzt werden?
                                  Denn einige Daten als solches sind schon ziemlich essenziell für meine Umgebung.
                                  Müsste man dann Routinen nutzen, die z.B. vor dem Lesen der Daten die Daten zusätzlich manuell von Amazon anfordert?
                                  • BananaJoeB BananaJoe
                                    R
                                    R
                                    RolfFrie
                                    #433
                                    @bananajoe
                                    Die App ist VOLL mit SmartHomeGeräten. Aber in alexa2 ist nix.
                                    • R RolfFrie
                                      @bananajoe
                                      M
                                      M
                                      moritzn
                                      #434
                                      @rolffrie said in Alexa2 Adapter 3.18.x (BETA):
                                      @bananajoe
                                      Ich klinge mich hier ein mit dem gleichen Problem, die Geräte waren allerdings vorgestern schon vor dem Update auf die neue Version nicht mehr ansprechbar; nach dem Update waren sie komplett weg.
                                      Die "Limit reached" Meldung tauchte ab und zu im Debug log auf.
                                      • M moritzn
                                        @bananajoe
                                        R
                                        R
                                        RolfFrie
                                        #435
                                        @moritzn
                                        Ich bin mir nicht sicher ggf. war dies auch schon vor dem Update bei mir.
                                        • DJMarc75D
                                          DJMarc75D
                                          DJMarc75
                                          #436
                                          @moritzn @RolfFrie
                                          Das Ratelimit trat am Donnerstag in den frühen Morgenstunden in Kraft und unabhängig von der Adapterversion.
                                          Wichtig ist jetzt bitte Geduld aufzubringen, keinen Adapterneustart machen und auch bitte NICHT die SmarthomeDevices manuell abrufen.
                                          Wie @apollon77 schrieb arbeitet er daran das ganze zu fixen. Erster Fix war ja die jetzt neuste Version 3.19.10, da mit Vorgängerversionen KEINE Steuerung mehr ALLER Funktionen gegeben war (nach Neustart des Adapters).
                                          Also habt Geduld 😀
                                          Lehrling seit 1975 !!!
                                          33.2k
                                          84.3k
