  4. GoodWe Wechselrichter und ioBroker
94 Beiträge 19 Kommentatoren 32.0k Aufrufe 21 Beobachtet
  • L Langer
    @jb1985
    Als erstes mal Danke für Deine Arbeit!!
    Bekomme nach Start der Javascript's folgende Fehlermeldungen:
    javascript.0
    2022-09-02 15:36:16.460	warn	script.js.common.PVAnlage.Goodwe: Fehler Python: ERROR:root:RequestException: HTTPSConnectionPool(host='semsportal.com', port=443): Read timed out. (read timeout=10)ERROR:root:RequestException during do_login(): HTTPSConnectionPool(host='semsportal.com', port=443): Read timed out. (read timeout=10)ERROR:root:Failed to log in, bailingERROR:root:no inverter data, try True, trying again in 30 secondsERROR:root:RequestException: HTTPSConnectionPool(host='semsportal.com', port=443): Read timed out. (read timeout=10)ERROR:root:RequestException: HTTPSConnectionPool(host='semsportal.com', port=443): Read timed out. (read timeout=10)ERROR:root:Failed to call GoodWe API url='https://semsportal.com/api/v1/PowerStation/GetMonitorDetailByPowerstationId'Traceback (most recent call last): File "/home/master/pygoodwe-master/allinone.py", line 8, in <module> gw = SingleInverter( File "/home/master/pygoodwe-master/pygoodwe/__init__.py", line 446, in __init__ super().__init__(system_id, account, password, **kwargs) File "/home/master/pygoodwe-master/pygoodwe/__init__.py", line 60, in __init__ self.getCurrentReadings(raw=True) File "/home/master/pygoodwe-master/pygoodwe/__init__.py", line 456, in getCurrentReadings super().getCurrentReadings(self, raw) File "/home/master/pygoodwe-master/pygoodwe/__init__.py", line 98, in getCurrentReadings retval = self.getCurrentReadings( File "/home/master/pygoodwe-master/pygoodwe/__init__.py", line 456, in getCurrentReadings super().getCurrentReadings(self, raw) File "/home/master/pygoodwe-master/pygoodwe/__init__.py", line 93, in getCurrentReadings if retry < maxretries:TypeError: '<' not supported between instances of 'SingleInverter' and 'int'
    und zwar alle 5 Minuten.
    Bekomme alle Werte.
    Wurde alles nach Deiner Anleitung Installiert. Wo habe ich eine Fehler gemacht?
    Vorab vielen Dank!!
    MfG
    Wastl
    JB1985J
    JB1985J
    JB1985
    @langer du hast gar kein Fehler gemacht, wenn deine Daten aktualisiert werden.
    Ich weiß auch nicht, ob es am Wechselrichter (schafft die mehrmaligen Anfragen nicht?) liegt oder an einer Überlastung des SEMS Portals.
    Zu sehen daran:
    Ich hab das in der App auch. Wenn ich manchmal aktualisieren will, kommt ein Fehler, dass die Daten nicht abgerufen werden. Weiß jetzt die genaue Fehlermeldung nicht.
    L 1 Antwort Letzte Antwort
    • JB1985J JB1985
      Zu sehen daran:
      L
      L
      Langer
      schrieb am zuletzt editiert von Langer
      @jb1985
      Danke für Deine Antwort, hat bei mir etwas gedauert.
      Eine Frage noch, besteht die Möglichkeit alle Werte nach ioBroker in einen Datenpunkt zu speichern?
      Würde gerne weitere Daten auslesen.
      MfG
      Wastl
      JB1985J 1 Antwort Letzte Antwort
      • L Langer
        @jb1985
        MfG
        Wastl
        JB1985J
        JB1985J
        JB1985
        @langer sagte in GoodWe Wechselrichter und ioBroker:
        Du kannst speichern wo du willst. Du musst nur die Scripte anpassen.
        Kannst du auch machen. Wie gesagt, man muss nur die Scripte anpassen.
        • JB1985J JB1985
          L
          L
          Langer
          @jb1985
          Danke für Deine Antwort. Könntest Du mir ein kleines Beispiel geben, wo ich etwas ändern müßte?
          MfG
          Wastl
          • L Langer
            @jb1985
            MfG
            Wastl
            JB1985J
            JB1985J
            JB1985
            @langer hier wird in die Datenpunkte geschrieben:
            exec('/home/pi/pygoodwe-master/allinone.py', function (error, stdout, stderr) {
               if(error) log('Fehler Python: ' + stderr, 'warn');
               else if(stdout) {
                  let arr = stdout.split('\n');
               setState('Datenpunkte.0.PV-Anlage.PV-Power', arr[0], true);
               setState('Datenpunkte.0.PV-Anlage.PV_Batterie_Status', arr[1], true);
               setState('Datenpunkte.0.PV-Anlage.PV_Batterie_Ladung', arr[2], true);
               setState('Datenpunkte.0.PV-Anlage.PV_Haus_Last', arr[3], true);
               setState('Datenpunkte.0.PV-Anlage.PV_Strom_zu_Stadtwerken', arr[4], true);
               setState('Datenpunkte.0.PV-Anlage.PV_Strom_Heute', arr[5], true);
               setState('Datenpunkte.0.PV-Anlage.PV_Strom_Gesamt', arr[6], true);
            allinone.py musst du dann erweitern.
            Wenn du aber keine Programmierkenntnisse hast, wird es schwierig.
            Bin auch nicht der Hardcore Programmierer.
            • JB1985J JB1985
                 else if(stdout) {
              L
              L
              Langer
              @jb1985
              Nochmal Danke.
              Habe in allinone.py folgende Zeile eingefügt, "print(f"{gw.data}")" und bekomme auf dem Bildschirm die Ausgabe des Inhaltes von "gw.data".
              Wie bekomme ich den kompletten Inhalt von "gw.data" nach ioBroker?
              MfG
              Wastl
              • L Langer
                @jb1985
                Nochmal Danke.
                MfG
                Wastl
                JB1985J
                JB1985J
                JB1985
                @langer mit
                Datenpunkte.0.PV-Anlage.PV_Strom_Gesamt' > musst du ändern in deinen Datenpunkt.
                arr[6], > musst du arr[7],
                machen oder evtl. höher. Der zählt immer einen höher.
                • X
                  X
                  xReactz
                  Danke für das tolle Script + Anleitung! Läuft 1A bei mir.
                  Leider ist das Sems Portal dann schwer mit dem Handy erreichbar und sehr träge trotz 60sec timeout.
                  Hab nun endlich einen LAN Dongle und würde gerne per Modbus TCP mit dem IoBroker auslesen. Hast du bzw. jemand hier Erfahrung damit ?
                  Modbus Verbindung steht schon mal, leider bekomme ich noch keine Werte in meine Register.
                  • X xReactz
                    JB1985J
                    JB1985J
                    JB1985
                    @xreactz ich habe von Anfang an das LAN Dongle.
                    Als Tipp vorab! Trage eine statische IP ein. Bei DHCP verliert das LAN Dongle die Verbindung.
                    Mir ist nicht bekannt, dass GoodWe und Modbus TCP funktionieren. Wenn du da weiter kommst, dann berichte gerne mal hier.
                    X 1 Antwort Letzte Antwort
                    • JB1985J JB1985
                      X
                      X
                      xReactz
                      @jb1985
                      Kurze Rückmeldung betreffend meiner Anfrage "Anbindung mittel Modbus", hab nun einen Stabile Verbindung mittels Modbus zum Wechselrichter👍
                      Anbindung mittels Modbus TCP am Goodwe Wechselrichter ist mit der Lan Box also möglich. Wichtig ist das keine Aliases benutzt werden dürfen!
                      • X xReactz
                        @jb1985
                        JB1985J
                        JB1985J
                        JB1985
                        @xreactz können wir uns da irgendwie austauschen? Vielleicht machst du ein neues Thema im ioBroker Forum auf?
                        Ich habe es mit modbus v5.0.5 probiert.
                        • X
                          X
                          xReactz
                          @jb1985
                          Hab ein eigenes Topic erstellt: https://forum.iobroker.net/topic/59207/goodwe-wechselrichter-und-modbus-tcp
                          Hoffe es hilft, ich bin schon auf eure Rückmeldungen gespannt ! 🤝
                          • JB1985J JB1985
                            da man im Netz nichts findet, wie man ein GoodWe Wechselrichter abfragen und in ioBroker verwalten kann, schreibe ich hier ein kleines HowTo, da es kein Adapter dafür gibt.
                            Ich gehe davon aus, dass Ihr bereits ein Account im SEMS Portal habt. Vom SEMS Portal kommen nämlich die Daten.
                            HowTo:
                            1. pygoodwe installieren:
                            sudo pip3 install pygoodwe
                            1. Danach holt Ihr euch den Source Code "pygoodwe" von yaleman aus Github:
                            wget https://github.com/yaleman/pygoodwe/archive/master.zip
                            unzip master.zip
                            cd pygoodwe-master
                            1. Die Zugangsdaten vom SEMS Portal trägt Ihr nun in der config.py ein:
                            mv config.py.example config.py
                            args = {
                            'gw_station_id' : 'aaabbbbb-cccc-dddd-eeee-ffffffgggggg' ,
                            'gw_account' : 'user@example.com',
                            'gw_password' : 'darkHorseBatteryStaple123',
                            'city' : 'London',
                            1. Werte vom GoodWe Wechselrichter abfragen:
                            ./allinone.py
                             #!/usr/bin/env python3
                            import json
                            from config import args
                            from pygoodwe import SingleInverter, API
                            #print("Single Inverter")
                                    system_id=args.get('gw_station_id', '1'),
                                    account=args.get('gw_account', 'thiswillnotwork'),
                                    password=args.get('gw_password', 'thiswillnotwork'),
                            # print("Grabbing data")
                            gw.getCurrentReadings()
                            # Ausgabe PV Anlage
                            print(json.dumps(gw.data.get('inverter').get('out_pac'), indent=2))
                            pvdata = gw.data.get('inverter',{}).get('out_pac',"")
                            # Batterie in %
                            socdata = gw.data.get('inverter',{}).get('soc',)
                            if socdata:
                                    print("{}".format(socdata))
                            # Batterie Ladestatus
                            print(json.dumps(gw.data.get('inverter').get('battery_power'), ))
                            batterydata = gw.data.get('inverter',{}).get('battery_power',)
                            # Stromlast vom Haus
                            print(f"{gw.getLoadFlow()}")
                            # Strom ins Stromnetz
                            print(f"{gw.getPmeter()}")
                            # Strom Produktion Heute
                            print(json.dumps(gw.data.get('inverter').get('eday'), indent=2))
                            # Strom Produktion Gesamt
                            print(json.dumps(gw.data.get('inverter').get('etotal'), indent=2))
                            Ihr könnt beliebig viele Werte Abfragen und ins Script rein werfen und erweitern. Für mich sind das die wichtigsten Werte.
                            1. Die Abgefragten Werte müssen in ioBroker rein:
                            Dafür habe ich ein javascript Script, welches in ioBroker ausgeführt wird.
                               else if(stdout) {
                            Die Datenpunkte müsst Ihr vorher anlegen. Bei ausführen des Scriptes müssten alle werte in den jeweiligen Datenpunkten drin sein.
                            Damit dies auch aktualisiert wird, habe ich mit Blockly ein Zeitplan erstellt, der das Script alle 2 Minuten ausführt.
                            schedule("*/2 * * * *", function () {
                              setState("javascript.0.scriptEnabled.PV_Anlage.Skript_1"/*scriptEnabled.PV_Anlage.Skript_1*/, true);
                              setStateDelayed("javascript.0.scriptEnabled.PV_Anlage.Skript_1"/*scriptEnabled.PV_Anlage.Skript_1*/, false, 50000, false);
                            Damit habt Ihr nun alle Werte in ioBroker :-)
                            Meine Visualisierung sieht dann so aus:
                            Viel Spaß damit!
                            K
                            K
                            Kasalevi
                            @jb1985 Vielen Dank für Deine Beschreibung. Top. Ich war tagelang happy. Nun bekomme ich plötzlich immer folgende Meldung. Kannst Du mir helfen?
                            ERROR:root:RequestException: 403 Client Error: Forbidden for url: https://semsportal.com/api/v1/PowerStation/GetMonitorDetailByPowerstationId
                            File "/home/pi/pygoodwe-master/allinone.py", line 8, in <module>
                            File "/home/pi/pygoodwe-master/pygoodwe/init.py", line 446, in init
                            super().init(system_id, account, password, **kwargs)
                            File "/home/pi/pygoodwe-master/pygoodwe/init.py", line 60, in init
                            File "/home/pi/pygoodwe-master/pygoodwe/init.py", line 456, in getCurrentReadings
                            File "/home/pi/pygoodwe-master/pygoodwe/init.py", line 98, in getCurrentReadings
                            File "/home/pi/pygoodwe-master/pygoodwe/init.py", line 93, in getCurrentReadings
                            • K Kasalevi
                              JB1985J
                              JB1985J
                              JB1985
                              @kasalevi
                              scheinbar scheint sich die API URL geändert zu haben, siehe hier -> https://github.com/yaleman/pygoodwe/issues/175
                              Du musst in der pygoodwe/init.py die URL von v1 in v2 ändern. Danach sollte es funktionieren.
                              • JB1985J JB1985
                                @kasalevi
                                K
                                K
                                Kasalevi
                                schrieb am zuletzt editiert von Kasalevi
                                @jb1985 das wars. großartiger support. danke
                                • U
                                  U
                                  Unbeliveable89
                                  Hallo, erstmal Dank für das tolle Script! Nach anfänglichen Schwierigkeiten hat es eine Weile ganz gut funktioniert. Die Umstellung auf die v2-API klappte auch reibungslos.
                                  Jetzt verursacht nur der Wert der "Last" ein Problem, welches ist nach stundenlanger Recherche immer noch nicht beheben konnte. Evtl. hat hier einen einen Tipp?
                                  script.js.common.goodwe: Fehler Python: Traceback (most recent call last): File "/opt/iobroker/pygoodwe/allinone.py", line 33, in <module> print(f"{gw.getLoadFlow()}") File "/opt/iobroker/pygoodwe/pygoodwe/__init__.py", line 353, in getLoadFlow if self.data['powerflow']['bettery'].endswith('(W)'):TypeError: 'NoneType' object is not subscriptable
                                  Wenn ich in der allinone.py den zugehörigen Befehl auskommentiere funktioniert der Rest fehlerfrei:
                                  LG Alex
                                  • U Unbeliveable89
                                    LG Alex
                                    JB1985J
                                    JB1985J
                                    JB1985
                                    @unbeliveable89 komisch, da es bei mir weiterhin funktioniert. Ich denke, würde es bei den anderen auch nicht funktionieren, hätten die sich sicherlich schon gemeldet.
                                    • U
                                      U
                                      Unbeliveable89
                                      Hmm, wirklich verrückt. Ich habe auch schon die neue init.py (0.0.17) übernommen, keine Auswirkungen. Alles funktioniert, nur der PowerFlow/die Last nicht.
                                      Dann kann ich mir nur noch vorstellen, dass im WR selbst etwas verstellt wurde. GoodWe hat hier nämlich vor Wochen Updates eingespielt, da die Werte teilweise etwas inkonsequent waren.
                                      Ansonsten bin ich wirklich Ratlos. Falls jemand noch etwas weiß, gerne mitteilen. :-)
                                      Guten Rutsch allen!
                                      • N
                                        N
                                        Nr5lebt
                                        @JB1985 Hallo JB
                                        Jetzt hat dein Script so lange gearbeitet und jetzt will es nicht mehr. Kannst du mir mal wieder helfen?
                                        Danke im vorraus
                                        • N Nr5lebt
                                          @JB1985 Hallo JB
                                          Danke im vorraus
                                          JB1985J
                                          JB1985J
                                          JB1985
                                          schrieb am zuletzt editiert von JB1985
                                          @nr5lebt die Lösung steht weiter oben. Du musst die API URL von v1 nach v2 ändern.
                                          https://forum.iobroker.net/topic/34626/goodwe-wechselrichter-und-iobroker/51?_=1672938480858
                                          N 1 Antwort Letzte Antwort
                                          83.8k
