  4. Test Adapter Midea Geräten v1.x.x
    6.3k
mideadimstalnethomenethome plus
434 Beiträge 68 Kommentatoren 124.1k Aufrufe 67 Beobachtet
  • M Marc9025
    @tombox
    ich habe jetzt noch mal installiert und das zeigt er mir an.
    Unter Instanzen wird der Adapter mir nicht angezeigt aber unter Objekten gibt es einen Ordner midea. Da gibt es aber nur den Ordner admin
    $ iobroker url https://github.com/TA2k/ioBroker.midea --host raspberrypi --debug
    install TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96
    NPM version: 6.14.17
    Installing TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96... (System call)
    iobroker.midea@0.1.0 postinstall /opt/iobroker/node_modules/iobroker.midea> node ./pythonPackages.js
    Start Python package installation
    Python 3.9.2Python 3 found
    pip 22.2.2 from /home/iobroker/.local/lib/python3.9/site-packages/pip (python 3.9)Installing midea-beautiful-air
    WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/
    npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
    npm WARN http-cookie-agent@4.0.1 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
    npm WARN pythonia@1.0.0 requires a peer of ws@^7.5.1 but none is installed. You must install peer dependencies yourself.
    npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):
    • iobroker.midea@0.1.0updated 1 package in 356.909s
    143 packages are looking for funding run npm fund for details
    upload [2] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/index_m.html index_m.html text/html
    upload [1] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/jsonConfig.json jsonConfig.json application/json
    upload [0] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/midea.png midea.png image/png
    Process exited with code 0
    tombox
    #187
    @marc9025 Python packages ist zur zeit sehr langsam probier in ein paar stunden nochmal
    • T tombox
      Marc9025
      #188
      @tombox
      jetzt hat es funktioniert.
      Jetzt aber zu meiner 2 Frage :)
      ich habe ja nicht die midea app sondern die AC Freedom. Damit wird es nicht gehen oder ?
      • M Marc9025
        @tombox
        tombox
        #189
        @marc9025 https://github.com/TA2k/ioBroker.midea/issues/154
        • T tombox
          Marc9025
          #190
          @tombox
          aber ich gerade gesehen.
          Braust du noch Zugansdaten zum testen ?
          • M Marc9025
            @tombox
            tombox
            #191
            @marc9025 Nein die Geräte können nicht in den adapter integriert werden
            • T tombox
              Marc9025
              #192
              @tombox
              okay das ist schade, dann habe ich wohl Pech gehabt.
                Marc9025
                #193
                @tombox
                hallo noch mal,
                ich habe versucht die Klimaanlage von einem Kollegen hinzuzufügen (nethome app).
                Der Login hat geklappt und er übergibt auch den String mit den daten(im log)
                Aber er erstellt keine Datenpunkte und er gibt die Beiden Fehler aus:
                midea.0
                2022-10-06 15:27:32.344 error TypeError: objectString.replaceAll is not a function at Midea.pythonToJson (/opt/iobroker/node_modules/iobroker.midea/main.js:177:8) at Midea.getDeviceList (/opt/iobroker/node_modules/iobroker.midea/main.js:115:36) at processTicksAndRejections (internal/process/task_queues.js:95:5) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:79:5)
                midea.0
                2022-10-06 15:27:32.338 error TypeError: objectString.replaceAll is not a function
                • M Marc9025
                  @tombox
                  hallo noch mal,
                  midea.0
                  midea.0
                  tombox
                  #194
                  @marc9025 Sicher eine node 14 installation. Bitte nochmal installieren dann sollte es auch damit gehen
                  • T tombox
                    Marc9025
                    #195
                    @tombox
                    die ist schon drauf.
                    PlatformBetriebssystem:linux
                    Architektur:arm64
                    CPUs:4
                    Geschwindigkeit:1500 MHz
                    Modell:unknown
                    RAM:3.7 GB
                    System-Betriebszeit:22:37:51
                    Node.js:v14.20.1
                    time:1665052542656
                    timeOffset:-120
                    Adapter-Anzahl:435
                    NPM:6.14.17
                    Datenträgergröße:117.1 GB
                    Freier Festplattenspeicher:108.1 GB
                    Betriebszeit:22:37:32
                    Aktive Instanzen:17
                    Pfad:/opt/iobroker/
                    aktiv:true
                    _nodeCurrent:14.20.1
                    _nodeNewest:14.20.1
                    _nodeNewestNext:16.17.1
                    _npmCurrent:6.14.17
                    _npmNewest:6.14.17
                    _npmNewestNext:8.15.0
                    • M Marc9025
                      @tombox
                      Architektur:arm64
                      CPUs:4
                      Modell:unknown
                      RAM:3.7 GB
                      Node.js:v14.20.1
                      time:1665052542656
                      timeOffset:-120
                      Adapter-Anzahl:435
                      NPM:6.14.17
                      Aktive Instanzen:17
                      Pfad:/opt/iobroker/
                      aktiv:true
                      _nodeNewest:14.20.1
                      _npmCurrent:6.14.17
                      _npmNewest:6.14.17
                      #196
                      @marc9025
                      Die würde ich auf die derzeitig empfohlene Version 16 heben.
                        @marc9025
                        Marc9025
                        schrieb am zuletzt editiert von Marc9025
                        #197
                        super das update war es.
                        @tombox weißt ob jemand an die Integration von der AC Freedom app arbeitet ?
                          Marc9025
                          #198
                          @tombox
                          leider kommt alle 5 Minuten im Log der fehler
                           	2022-10-06 17:28:17.602	error	*** PY *** Python Error Call to 'appliance_state' failed: > appliance_state = await this.midea_beautiful.appliance_state$({ at Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:156:29) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.midea/main.js:226:9) ... across the bridge ... > six.raise_from(e, None) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:445) at raise_from (<string>:3) > httplib_response = conn.getresponse() at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:440) > response.begin() at getresponse (/usr/lib/python3.9/http/client.py:1347) > version, status, reason = self._read_status() at begin (/usr/lib/python3.9/http/client.py:307) > line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1") at _read_status (/usr/lib/python3.9/http/client.py:268) > return self._sock.recv_into(b) at readinto (/usr/lib/python3.9/socket.py:704) > return self.read(nbytes, buffer) at recv_into (/usr/lib/python3.9/ssl.py:1241) > return self._sslobj.read(len, buffer) at read (/usr/lib/python3.9/ssl.py:1099) > resp = conn.urlopen( at send (/usr/lib/python3/dist-packages/requests/adapters.py:439) > retries = retries.increment( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:755) > raise six.reraise(type(error), error, _stacktrace) at increment (/usr/lib/python3/dist-packages/urllib3/util/retry.py:532) > raise value at reraise (/usr/lib/python3/dist-packages/six.py:719) > httplib_response = self._make_request( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:699) > self._raise_timeout(err=e, url=url, timeout_value=read_timeout) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:447) > raise ReadTimeoutError( at _raise_timeout (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:336) > response = requests.post( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:273) > return request('post', url, data=data, json=json, **kwargs) at post (/usr/lib/python3/dist-packages/requests/api.py:119) > return session.request(method=method, url=url, **kwargs) at request (/usr/lib/python3/dist-packages/requests/api.py:61) > resp = self.send(prep, **send_kwargs) at request (/usr/lib/python3/dist-packages/requests/sessions.py:542) > r = adapter.send(request, **kwargs) at send (/usr/lib/python3/dist-packages/requests/sessions.py:655) > raise ReadTimeout(e, request=request) at send (/usr/lib/python3/dist-packages/requests/adapters.py:529) > appliance.identify(cloud, use_cloud) at appliance_state (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:1046) > self.refresh(cloud if use_cloud else None) at identify (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:831) > responses = self._status(cmd, cloud) at refresh (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:381) > responses = cloud.appliance_transparent_send(self.appliance_id, data) at _status (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:538) > response = self.api_request( at appliance_transparent_send (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:526) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > self._retry_check(endpoint, cause) at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:335) > raise CloudRequestError( at _retry_check (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:350) *** JS *** midea_beautiful.exceptions.CloudRequestError: Too many retries while calling /v1/appliance/transparent/send, last error HTTPSConnectionPool(host='mapp.appsmb.com', port=443): Read timed out. (read timeout=2)
                          midea.0
                          2022-10-06 17:28:17.601	error	Error
                          Die Datenpunkte werden jetzt zwar angezeigt aber die Klima reagiert nicht drauf.
                          • M Marc9025
                            @tombox
                            midea.0
                            #199
                            @marc9025
                            Setz das bitte in CodeTags.
                              @marc9025
                              Marc9025
                              #200
                              Habe ich erledigt oder doch lieber ein Screenshot?
                              • M Marc9025
                                tombox
                                #201
                                @marc9025 Ist das bei allen apps die du in den Einstellungen auswählen kannst
                                • T tombox
                                  Marc9025
                                  #202
                                  @tombox
                                  wie meinst du das ?
                                  alles andern apps funktionieren ganz normal
                                  • M Marc9025
                                    @tombox
                                    wie meinst du das ?
                                    tombox
                                    #203
                                    @marc9025 du kannst in den adapter Einstellungen verschiedene apps auswählen
                                    • R Offline
                                      Raducanu
                                      schrieb am zuletzt editiert von Raducanu
                                      #204
                                      Meine neue Dimstal / Midea AC lässt sich mit dem Adapter nicht steuern.
                                      Datenpunkte werden angelegt, die angezeigten Werte passen auch, sobald ich aber die Anlage steuern will, passiert nichts.
                                      Hier z.B. Powerstate von "false" -> "true"
                                      2022-10-14 09:06:53.480 - debug: midea.0 (3198) Command: {"data":[170,30,172,0,0,0,0,0,3,2,64,67,138,20,127,127,0,63,0,0,0,0,0,0,0,0,0,0,0,156]}
                                      2022-10-14 09:06:53.481 - debug: midea.0 (3198) Command + Header: [90,90,1,16,90,0,32,0,1,0,0,0,189,179,57,14,12,5,20,20,29,129,0,0,0,16,0,0,0,4,2,0,0,1,0,0,0,0,0,0,170,30,172,0,0,0,0,0,3,2,64,67,138,20,127,127,0,63,0,0,0,0,0,0,0,0,0,0,0,156,55,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0,0]
                                      2022-10-14 09:07:03.080 - debug: midea.0 (3198) {"errorCode":"3176","msg":"The asyn reply does not exist ","result":null}
                                      • Adapter version: 0.0.7
                                      • JS-Controller version: 4.0.23
                                      • Node version: v16.14.2
                                      • Operating system: Ubuntu 18.04.6 LTS
                                      MatzebhvM 1 Antwort Letzte Antwort
                                      • R Raducanu
                                        MatzebhvM Offline
                                        MatzebhvM Offline
                                        Matzebhv
                                        #205
                                        @raducanu: gleiches Problem hier. Auch auf git kommen keine Reaktionen mehr, keine Ahnung ob am Adapter noch etwas gemacht wird.
                                        • MatzebhvM Matzebhv
                                          sushbone
                                          schrieb am zuletzt editiert von sushbone
                                          #206
                                          Habe leider ebenfalls ein Problem mit dem Adapter. Habe mir letzte Woche den Comfee Luftentfeuchter 20L/24h MDDF-20DEN7-WF gekauft. Steuerung über NetHome Plus App (klappt einwandfrei und zuverlässig).
                                          Heute ioBroker Midea Adapter ausprobiert. Login scheint einwandfrei zu klappen nachdem ich meine Daten eingegeben habe (ich vermute der erste Loginfehler-Eintrag aus den Logs kommt nach der Installation des Adapter bevor man seine Daten eingibt?). Danach kommen allerdings dann eine von Warnungen im Log.
                                          Der Adapter wird unter Objekte angelegt und er erkennt dass ich eine Klimaanlage registriert habe.
                                          Allerdings werden lediglich unter unter "general" ein paar Daten angelegt.
                                          Im wichtigen Teil unter Status bleiben die meisten Datenpunkte leider auf null.
                                          Ich vermute der Adapter kennt den Gerätetyp nicht und legt deswegen keine spezifischen Werte an?!
                                          Wird der Adapter noch weiterentwickelt wo man ggf. helfen kann das Gerät einzupflegen?
                                          Oder haben andere ähnliche Schwierigkeiten und das ist kein Problem meines spezifischen Geräts?
                                          Procedural Terrain/Universe programing [Unity3D/C#/C++ on CPU/GPU] - http://www.zdarsky.info/v4/programing/procedural-universe-generation/
                                          draexlerD 1 Antwort Letzte Antwort
