  4. Test Adapter Midea Geräten v1.x.x
    6.3k
mideadimstalnethomenethome plus
434 Beiträge 68 Kommentatoren 124.1k Aufrufe 67 Beobachtet
  • M Marc9025
    @tombox
    Erstmal vielen dank für deine Mühe.
    Ich habe 2 Fragen ;)
    Leider bekomme ich den Adapter bei mir nicht installiert das steht im log :
    host.raspberrypi
    2022-10-06 10:03:41.408 info iobroker exit 0
    host.raspberrypi
    2022-10-06 10:03:40.307 info iobroker upload [0] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/midea.png midea.png image/png
    host.raspberrypi
    2022-10-06 10:03:40.295 info iobroker upload [1] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/jsonConfig.json jsonConfig.json application/json
    host.raspberrypi
    2022-10-06 10:03:40.193 info iobroker upload [2] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/index_m.html index_m.html text/html
    host.raspberrypi
    2022-10-06 10:03:40.074 info iobroker 143 packages are looking for funding run npm fund for details
    host.raspberrypi
    2022-10-06 10:03:37.088 info iobroker + iobroker.midea@0.1.0updated 1 package in 301.601s
    host.raspberrypi
    2022-10-06 10:03:37.086 info iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    host.raspberrypi
    2022-10-06 10:03:37.052 info iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
    host.raspberrypi
    2022-10-06 10:03:37.011 info iobroker npm WARN pythonia@1.0.0 requires a peer of ws@^7.5.1 but none is installed. You must install peer dependencies yourself.
    host.raspberrypi
    2022-10-06 10:03:36.979 info iobroker npm WARN http-cookie-agent@4.0.1 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
    host.raspberrypi
    2022-10-06 10:03:36.949 info iobroker npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
    host.raspberrypi
    2022-10-06 10:03:30.908 info iobroker Installing midea-beautiful-air
    host.raspberrypi
    2022-10-06 10:03:30.907 info iobroker pip 22.2.2 from /home/iobroker/.local/lib/python3.9/site-packages/pip (python 3.9)
    host.raspberrypi
    2022-10-06 10:03:24.788 info iobroker Python 3 found
    host.raspberrypi
    2022-10-06 10:03:24.787 info iobroker Python 3.9.2
    host.raspberrypi
    2022-10-06 10:03:24.763 info iobroker Start Python package installation
    host.raspberrypi
    2022-10-06 10:03:24.761 info iobroker
    host.raspberrypi
    2022-10-06 10:03:24.617 info iobroker > iobroker.midea@0.1.0 postinstall /opt/iobroker/node_modules/iobroker.midea> node ./pythonPackages.js
    host.raspberrypi
    2022-10-06 10:03:24.616 info iobroker
    ist es vielleicht weil ich eine 64 Bit Version habe?
    Ich habe eine Quick Connet Klimaanlage von Dimstal. Leider benutz diese eine andere app.
    https://play.google.com/store/apps/details?id=com.broadlink.acfreedom&hl=de&gl=US
    ist da die Einbindung auch möglich?
    #184
    @marc9025 sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
    Nein, bei mir läuft der Adapter auch auf einem 64bit RaspberryOS.
    Dein Log ist auch nicht vollständig. Der Anfang und das Ende fehlt vermutlich.
    • M Marc9025
      @tombox
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      host.raspberrypi
      tombox
      #185
      @marc9025 Installation sieht gut aus. Hast du manuell eine Instanz erstellt?
      • T tombox
        Marc9025
        #186
        @tombox
        ich habe jetzt noch mal installiert und das zeigt er mir an.
        Unter Instanzen wird der Adapter mir nicht angezeigt aber unter Objekten gibt es einen Ordner midea. Da gibt es aber nur den Ordner admin
        $ iobroker url https://github.com/TA2k/ioBroker.midea --host raspberrypi --debug
        install TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96
        NPM version: 6.14.17
        Installing TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96... (System call)
        Python 3.9.2Python 3 found
        pip 22.2.2 from /home/iobroker/.local/lib/python3.9/site-packages/pip (python 3.9)Installing midea-beautiful-air
        WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/
        • iobroker.midea@0.1.0updated 1 package in 356.909s
        Process exited with code 0
        • M Marc9025
          @tombox
          tombox
          #187
          @marc9025 Python packages ist zur zeit sehr langsam probier in ein paar stunden nochmal
          • T tombox
            Marc9025
            #188
            @tombox
            jetzt hat es funktioniert.
            Jetzt aber zu meiner 2 Frage :)
            ich habe ja nicht die midea app sondern die AC Freedom. Damit wird es nicht gehen oder ?
            • M Marc9025
              @tombox
              tombox
              #189
              @marc9025 https://github.com/TA2k/ioBroker.midea/issues/154
              • T tombox
                Marc9025
                #190
                @tombox
                aber ich gerade gesehen.
                Braust du noch Zugansdaten zum testen ?
                • M Marc9025
                  @tombox
                  tombox
                  #191
                  @marc9025 Nein die Geräte können nicht in den adapter integriert werden
                  • T tombox
                    Marc9025
                    #192
                    @tombox
                    okay das ist schade, dann habe ich wohl Pech gehabt.
                      Marc9025
                      #193
                      @tombox
                      hallo noch mal,
                      ich habe versucht die Klimaanlage von einem Kollegen hinzuzufügen (nethome app).
                      Der Login hat geklappt und er übergibt auch den String mit den daten(im log)
                      Aber er erstellt keine Datenpunkte und er gibt die Beiden Fehler aus:
                      midea.0
                      2022-10-06 15:27:32.344 error TypeError: objectString.replaceAll is not a function at Midea.pythonToJson (/opt/iobroker/node_modules/iobroker.midea/main.js:177:8) at Midea.getDeviceList (/opt/iobroker/node_modules/iobroker.midea/main.js:115:36) at processTicksAndRejections (internal/process/task_queues.js:95:5) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:79:5)
                      midea.0
                      2022-10-06 15:27:32.338 error TypeError: objectString.replaceAll is not a function
                      • M Marc9025
                        @tombox
                        hallo noch mal,
                        midea.0
                        midea.0
                        tombox
                        #194
                        @marc9025 Sicher eine node 14 installation. Bitte nochmal installieren dann sollte es auch damit gehen
                        • T tombox
                          Marc9025
                          #195
                          @tombox
                          die ist schon drauf.
                          PlatformBetriebssystem:linux
                          Architektur:arm64
                          CPUs:4
                          Geschwindigkeit:1500 MHz
                          Modell:unknown
                          RAM:3.7 GB
                          System-Betriebszeit:22:37:51
                          Node.js:v14.20.1
                          time:1665052542656
                          timeOffset:-120
                          Adapter-Anzahl:435
                          NPM:6.14.17
                          Datenträgergröße:117.1 GB
                          Freier Festplattenspeicher:108.1 GB
                          Betriebszeit:22:37:32
                          Aktive Instanzen:17
                          Pfad:/opt/iobroker/
                          aktiv:true
                          _nodeCurrent:14.20.1
                          _nodeNewest:14.20.1
                          _nodeNewestNext:16.17.1
                          _npmCurrent:6.14.17
                          _npmNewest:6.14.17
                          _npmNewestNext:8.15.0
                          • M Marc9025
                            @tombox
                            Architektur:arm64
                            CPUs:4
                            Modell:unknown
                            RAM:3.7 GB
                            Node.js:v14.20.1
                            time:1665052542656
                            timeOffset:-120
                            Adapter-Anzahl:435
                            NPM:6.14.17
                            Aktive Instanzen:17
                            Pfad:/opt/iobroker/
                            aktiv:true
                            _nodeNewest:14.20.1
                            _npmCurrent:6.14.17
                            _npmNewest:6.14.17
                            #196
                            @marc9025
                            Die würde ich auf die derzeitig empfohlene Version 16 heben.
                              @marc9025
                              Marc9025
                              schrieb am zuletzt editiert von Marc9025
                              #197
                              super das update war es.
                              @tombox weißt ob jemand an die Integration von der AC Freedom app arbeitet ?
                                Marc9025
                                #198
                                @tombox
                                leider kommt alle 5 Minuten im Log der fehler
                                 	2022-10-06 17:28:17.602	error	*** PY *** Python Error Call to 'appliance_state' failed: > appliance_state = await this.midea_beautiful.appliance_state$({ at Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:156:29) at Timeout._onTimeout (/opt/iobroker/node_modules/iobroker.midea/main.js:226:9) ... across the bridge ... > six.raise_from(e, None) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:445) at raise_from (<string>:3) > httplib_response = conn.getresponse() at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:440) > response.begin() at getresponse (/usr/lib/python3.9/http/client.py:1347) > version, status, reason = self._read_status() at begin (/usr/lib/python3.9/http/client.py:307) > line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1") at _read_status (/usr/lib/python3.9/http/client.py:268) > return self._sock.recv_into(b) at readinto (/usr/lib/python3.9/socket.py:704) > return self.read(nbytes, buffer) at recv_into (/usr/lib/python3.9/ssl.py:1241) > return self._sslobj.read(len, buffer) at read (/usr/lib/python3.9/ssl.py:1099) > resp = conn.urlopen( at send (/usr/lib/python3/dist-packages/requests/adapters.py:439) > retries = retries.increment( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:755) > raise six.reraise(type(error), error, _stacktrace) at increment (/usr/lib/python3/dist-packages/urllib3/util/retry.py:532) > raise value at reraise (/usr/lib/python3/dist-packages/six.py:719) > httplib_response = self._make_request( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:699) > self._raise_timeout(err=e, url=url, timeout_value=read_timeout) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:447) > raise ReadTimeoutError( at _raise_timeout (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:336) > response = requests.post( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:273) > return request('post', url, data=data, json=json, **kwargs) at post (/usr/lib/python3/dist-packages/requests/api.py:119) > return session.request(method=method, url=url, **kwargs) at request (/usr/lib/python3/dist-packages/requests/api.py:61) > resp = self.send(prep, **send_kwargs) at request (/usr/lib/python3/dist-packages/requests/sessions.py:542) > r = adapter.send(request, **kwargs) at send (/usr/lib/python3/dist-packages/requests/sessions.py:655) > raise ReadTimeout(e, request=request) at send (/usr/lib/python3/dist-packages/requests/adapters.py:529) > appliance.identify(cloud, use_cloud) at appliance_state (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:1046) > self.refresh(cloud if use_cloud else None) at identify (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:831) > responses = self._status(cmd, cloud) at refresh (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:381) > responses = cloud.appliance_transparent_send(self.appliance_id, data) at _status (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:538) > response = self.api_request( at appliance_transparent_send (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:526) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > self._retry_check(endpoint, cause) at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:335) > raise CloudRequestError( at _retry_check (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:350) *** JS *** midea_beautiful.exceptions.CloudRequestError: Too many retries while calling /v1/appliance/transparent/send, last error HTTPSConnectionPool(host='mapp.appsmb.com', port=443): Read timed out. (read timeout=2)
                                midea.0
                                2022-10-06 17:28:17.601	error	Error
                                Die Datenpunkte werden jetzt zwar angezeigt aber die Klima reagiert nicht drauf.
                                • M Marc9025
                                  @tombox
                                  midea.0
                                  #199
                                  @marc9025
                                  Setz das bitte in CodeTags.
                                    @marc9025
                                    Marc9025
                                    #200
                                    Habe ich erledigt oder doch lieber ein Screenshot?
                                    • M Marc9025
                                      tombox
                                      #201
                                      @marc9025 Ist das bei allen apps die du in den Einstellungen auswählen kannst
                                      • T tombox
                                        Marc9025
                                        #202
                                        @tombox
                                        wie meinst du das ?
                                        alles andern apps funktionieren ganz normal
                                        • M Marc9025
                                          @tombox
                                          wie meinst du das ?
                                          tombox
                                          #203
                                          @marc9025 du kannst in den adapter Einstellungen verschiedene apps auswählen
