  4. Test Adapter Midea Geräten v1.x.x
    6.3k
mideadimstalnethomenethome plus
434 Beiträge 68 Kommentatoren 124.1k Aufrufe 67 Beobachtet
  • T tombox
    @gosund ihr könnt mal die GitHub version probieren und berichten wie die funktioniert
    gosund
    schrieb am zuletzt editiert von gosund
    #177
    @tombox
    Leider funktioniert die 0.1.0 nicht bei mir:
    midea.0
    	2022-09-11 14:38:09.030	error	*** PY *** Python Error Call to 'appliance_state' failed: > appliance_state = await this.midea_beautiful.appliance_state$({ at async Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:156:29) at async Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:80:5) ... across the bridge ... > six.raise_from(e, None) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:445) at raise_from (<string>:3) > httplib_response = conn.getresponse() at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:440) > response.begin() at getresponse (/usr/lib/python3.9/http/client.py:1347) > version, status, reason = self._read_status() at begin (/usr/lib/python3.9/http/client.py:307) > line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1") at _read_status (/usr/lib/python3.9/http/client.py:268) > return self._sock.recv_into(b) at readinto (/usr/lib/python3.9/socket.py:704) > return self.read(nbytes, buffer) at recv_into (/usr/lib/python3.9/ssl.py:1241) > return self._sslobj.read(len, buffer) at read (/usr/lib/python3.9/ssl.py:1099) > resp = conn.urlopen( at send (/usr/lib/python3/dist-packages/requests/adapters.py:439) > retries = retries.increment( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:755) > raise six.reraise(type(error), error, _stacktrace) at increment (/usr/lib/python3/dist-packages/urllib3/util/retry.py:532) > raise value at reraise (/usr/lib/python3/dist-packages/six.py:719) > httplib_response = self._make_request( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:699) > self._raise_timeout(err=e, url=url, timeout_value=read_timeout) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:447) > raise ReadTimeoutError( at _raise_timeout (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:336) > response = requests.post( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:273) > return request('post', url, data=data, json=json, **kwargs) at post (/usr/lib/python3/dist-packages/requests/api.py:119) > return session.request(method=method, url=url, **kwargs) at request (/usr/lib/python3/dist-packages/requests/api.py:61) > resp = self.send(prep, **send_kwargs) at request (/usr/lib/python3/dist-packages/requests/sessions.py:542) > r = adapter.send(request, **kwargs) at send (/usr/lib/python3/dist-packages/requests/sessions.py:655) > raise ReadTimeout(e, request=request) at send (/usr/lib/python3/dist-packages/requests/adapters.py:529) > appliance.identify(cloud, use_cloud) at appliance_state (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:1046) > self.refresh(cloud if use_cloud else None) at identify (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:831) > responses = self._status(cmd, cloud) at refresh (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:381) > responses = cloud.appliance_transparent_send(self.appliance_id, data) at _status (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:538) > response = self.api_request( at appliance_transparent_send (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:526) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > self._retry_check(endpoint, cause) at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:335) > raise CloudRequestError( at _retry_check (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:350) *** JS *** midea_beautiful.exceptions.CloudRequestError: Too many retries while calling /v1/appliance/transparent/send, last error HTTPSConnectionPool(host='mapp.appsmb.com', port=443): Read timed out. (read timeout=2)
    midea.0
    	2022-09-11 14:38:09.029	error	Error
    midea.0
    	2022-09-11 14:37:50.251	info	function () { [native code] }
    midea.0
    	2022-09-11 14:37:50.249	info	[{id=145135534918692, address=xx.xx.xx.xx, port=6444, version=3, name=KLIMAANLAGE_XXXX, online=True, type=0xac, subtype=0, flags=0, extra=1, reserved=0, mac=30b23748e50f, ssid=net_ac_E50F, udp_version=4000000, protocol=069fcd, version=3.0.8, sn=000000P0000000Q130B2XXXXXXXX0000, state=[Air conditioner]{id=14500000000****, type=0xac mode=4, running=False, turbo=False, fan_speed=102, turbo_fan=False, purifier=False, dryer=False, target_temperature=28.0, indoor_temperature=24.4, outdoor_temperature=2.2250738585072014e-308, vertical_swing=False horizontal_swing=False comfort_sleep=False, error_code=0, prompt=False, supports={'eco': 1, 'mode': 1, 'fan_swing': 1, 'electricity': 0, 'strong_fan': 1, 'fan_speed': 1, 'temperature0': 32, 'temperature1': 60, 'temperature2': 32, 'temperature3': 60, 'temperature4': 32, 'temperature5': 60, 'temperature6': 0}}}]
    midea.0
    	2022-09-11 14:37:50.246	info	Found 1 devices
    • G gosund
      @tombox
      midea.0
      midea.0
      midea.0
      midea.0
      midea.0
      tombox
      #178
      @gosund Das sieht aber nicht so schlecht aus. Ein Objekt müsste eigentlich geschrieben haben. Kommt der Fehler bei jedem Update oder unregelmäßig.
      G 1 Antwort Letzte Antwort
      • T tombox
        gosund
        #179
        @tombox
        Ist gerade etwas schwierig, da ich wieder auf meine alte Installation umgeschaltet habe. Soweit ich das sehe, kommt der Fehler, wenn ich versuche die Anlage über das Objekt einzuschalten.
        Welche App soll ich in den Einstellungen wählen?
        Kommuniziert Dein Adapter eigentlich über die Cloud oder direkt mit der Anlage im LAN?
        • G gosund
          @tombox
          tombox
          #180
          @gosund Über die cloud. App muss man wählen bei der man registriert bzw austesten
          reindeer-webR S 2 Antworten Letzte Antwort
          • T tombox
            reindeer-webR Offline
            reindeer-web
            #181
            @tombox
            Ich nutze den Entfeuchter Midea MDDF-20DEN7-WF.
            Mit der Version 0.1.0 ist es mir jetzt endlich gelungen, Datenpunkte zu erhalten, die ich in meiner Visualisierung anzeigen lassen kann.
            Leider kommen immer wieder (alle paar Stunden) diese beiden identischen Fehlermeldungen:
            SyntaxError: Unexpected token b in JSON at position 84 at JSON.parse (<anonymous>) at Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:166:32) at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5)
            • T tombox
              stefan-ohg
              schrieb am zuletzt editiert von stefan-ohg
              #182
              Post bitte ignorieren, habe meinen Fehler gefunden, kann den Post aber nicht löschen.
              Gruß Stefan
                Marc9025
                #183
                @tombox
                Erstmal vielen dank für deine Mühe.
                Ich habe 2 Fragen ;)
                Leider bekomme ich den Adapter bei mir nicht installiert das steht im log :
                host.raspberrypi
                2022-10-06 10:03:41.408 info iobroker exit 0
                host.raspberrypi
                2022-10-06 10:03:40.307 info iobroker upload [0] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/midea.png midea.png image/png
                host.raspberrypi
                2022-10-06 10:03:40.295 info iobroker upload [1] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/jsonConfig.json jsonConfig.json application/json
                host.raspberrypi
                2022-10-06 10:03:40.193 info iobroker upload [2] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/index_m.html index_m.html text/html
                host.raspberrypi
                2022-10-06 10:03:40.074 info iobroker 143 packages are looking for funding run npm fund for details
                host.raspberrypi
                2022-10-06 10:03:37.088 info iobroker + iobroker.midea@0.1.0updated 1 package in 301.601s
                host.raspberrypi
                2022-10-06 10:03:37.086 info iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                host.raspberrypi
                2022-10-06 10:03:37.052 info iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
                host.raspberrypi
                2022-10-06 10:03:37.011 info iobroker npm WARN pythonia@1.0.0 requires a peer of ws@^7.5.1 but none is installed. You must install peer dependencies yourself.
                host.raspberrypi
                2022-10-06 10:03:36.979 info iobroker npm WARN http-cookie-agent@4.0.1 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
                host.raspberrypi
                2022-10-06 10:03:36.949 info iobroker npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
                host.raspberrypi
                2022-10-06 10:03:30.908 info iobroker Installing midea-beautiful-air
                host.raspberrypi
                2022-10-06 10:03:30.907 info iobroker pip 22.2.2 from /home/iobroker/.local/lib/python3.9/site-packages/pip (python 3.9)
                host.raspberrypi
                2022-10-06 10:03:24.788 info iobroker Python 3 found
                host.raspberrypi
                2022-10-06 10:03:24.787 info iobroker Python 3.9.2
                host.raspberrypi
                2022-10-06 10:03:24.763 info iobroker Start Python package installation
                host.raspberrypi
                2022-10-06 10:03:24.761 info iobroker
                host.raspberrypi
                2022-10-06 10:03:24.617 info iobroker > iobroker.midea@0.1.0 postinstall /opt/iobroker/node_modules/iobroker.midea> node ./pythonPackages.js
                host.raspberrypi
                2022-10-06 10:03:24.616 info iobroker
                ist es vielleicht weil ich eine 64 Bit Version habe?
                Ich habe eine Quick Connet Klimaanlage von Dimstal. Leider benutz diese eine andere app.
                https://play.google.com/store/apps/details?id=com.broadlink.acfreedom&hl=de&gl=US
                ist da die Einbindung auch möglich?
                Thomas BraunT T 2 Antworten Letzte Antwort
                • M Marc9025
                  @tombox
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  #184
                  @marc9025 sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
                  Nein, bei mir läuft der Adapter auch auf einem 64bit RaspberryOS.
                  Dein Log ist auch nicht vollständig. Der Anfang und das Ende fehlt vermutlich.
                  • M Marc9025
                    @tombox
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    host.raspberrypi
                    tombox
                    #185
                    @marc9025 Installation sieht gut aus. Hast du manuell eine Instanz erstellt?
                    • T tombox
                      Marc9025
                      #186
                      @tombox
                      ich habe jetzt noch mal installiert und das zeigt er mir an.
                      Unter Instanzen wird der Adapter mir nicht angezeigt aber unter Objekten gibt es einen Ordner midea. Da gibt es aber nur den Ordner admin
                      $ iobroker url https://github.com/TA2k/ioBroker.midea --host raspberrypi --debug
                      install TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96
                      NPM version: 6.14.17
                      Installing TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96... (System call)
                      Python 3.9.2Python 3 found
                      pip 22.2.2 from /home/iobroker/.local/lib/python3.9/site-packages/pip (python 3.9)Installing midea-beautiful-air
                      WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/
                      • iobroker.midea@0.1.0updated 1 package in 356.909s
                      Process exited with code 0
                      • M Marc9025
                        @tombox
                        tombox
                        #187
                        @marc9025 Python packages ist zur zeit sehr langsam probier in ein paar stunden nochmal
                        • T tombox
                          Marc9025
                          #188
                          @tombox
                          jetzt hat es funktioniert.
                          Jetzt aber zu meiner 2 Frage :)
                          ich habe ja nicht die midea app sondern die AC Freedom. Damit wird es nicht gehen oder ?
                          • M Marc9025
                            @tombox
                            tombox
                            #189
                            @marc9025 https://github.com/TA2k/ioBroker.midea/issues/154
                            • T tombox
                              Marc9025
                              #190
                              @tombox
                              aber ich gerade gesehen.
                              Braust du noch Zugansdaten zum testen ?
                              • M Marc9025
                                @tombox
                                tombox
                                #191
                                @marc9025 Nein die Geräte können nicht in den adapter integriert werden
                                • T tombox
                                  Marc9025
                                  #192
                                  @tombox
                                  okay das ist schade, dann habe ich wohl Pech gehabt.
                                    Marc9025
                                    #193
                                    @tombox
                                    hallo noch mal,
                                    ich habe versucht die Klimaanlage von einem Kollegen hinzuzufügen (nethome app).
                                    Der Login hat geklappt und er übergibt auch den String mit den daten(im log)
                                    Aber er erstellt keine Datenpunkte und er gibt die Beiden Fehler aus:
                                    midea.0
                                    2022-10-06 15:27:32.344 error TypeError: objectString.replaceAll is not a function at Midea.pythonToJson (/opt/iobroker/node_modules/iobroker.midea/main.js:177:8) at Midea.getDeviceList (/opt/iobroker/node_modules/iobroker.midea/main.js:115:36) at processTicksAndRejections (internal/process/task_queues.js:95:5) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:79:5)
                                    midea.0
                                    2022-10-06 15:27:32.338 error TypeError: objectString.replaceAll is not a function
                                    • M Marc9025
                                      @tombox
                                      hallo noch mal,
                                      midea.0
                                      midea.0
                                      tombox
                                      #194
                                      @marc9025 Sicher eine node 14 installation. Bitte nochmal installieren dann sollte es auch damit gehen
                                      • T tombox
                                        Marc9025
                                        #195
                                        @tombox
                                        die ist schon drauf.
                                        PlatformBetriebssystem:linux
                                        Architektur:arm64
                                        CPUs:4
                                        Geschwindigkeit:1500 MHz
                                        Modell:unknown
                                        RAM:3.7 GB
                                        System-Betriebszeit:22:37:51
                                        Node.js:v14.20.1
                                        time:1665052542656
                                        timeOffset:-120
                                        Adapter-Anzahl:435
                                        NPM:6.14.17
                                        Datenträgergröße:117.1 GB
                                        Freier Festplattenspeicher:108.1 GB
                                        Betriebszeit:22:37:32
                                        Aktive Instanzen:17
                                        Pfad:/opt/iobroker/
                                        aktiv:true
                                        _nodeCurrent:14.20.1
                                        _nodeNewest:14.20.1
                                        _nodeNewestNext:16.17.1
                                        _npmCurrent:6.14.17
                                        _npmNewest:6.14.17
                                        _npmNewestNext:8.15.0
                                        • M Marc9025
                                          @tombox
                                          Architektur:arm64
                                          CPUs:4
                                          Modell:unknown
                                          RAM:3.7 GB
                                          Node.js:v14.20.1
                                          time:1665052542656
                                          timeOffset:-120
                                          Adapter-Anzahl:435
                                          NPM:6.14.17
                                          Aktive Instanzen:17
                                          Pfad:/opt/iobroker/
                                          aktiv:true
                                          _nodeNewest:14.20.1
                                          _npmCurrent:6.14.17
                                          _npmNewest:6.14.17
                                          #196
                                          @marc9025
                                          Die würde ich auf die derzeitig empfohlene Version 16 heben.
