  4. Test Adapter Midea Geräten v1.x.x
    6.3k
mideadimstalnethomenethome plus
434 Beiträge 68 Kommentatoren 124.1k Aufrufe 67 Beobachtet
  • G gosund
    @tombox
    Leider funktioniert die 0.1.0 nicht bei mir:
    midea.0
    	2022-09-11 14:38:09.030	error	*** PY *** Python Error Call to 'appliance_state' failed: > appliance_state = await this.midea_beautiful.appliance_state$({ at async Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:156:29) at async Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:80:5) ... across the bridge ... > six.raise_from(e, None) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:445) at raise_from (<string>:3) > httplib_response = conn.getresponse() at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:440) > response.begin() at getresponse (/usr/lib/python3.9/http/client.py:1347) > version, status, reason = self._read_status() at begin (/usr/lib/python3.9/http/client.py:307) > line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1") at _read_status (/usr/lib/python3.9/http/client.py:268) > return self._sock.recv_into(b) at readinto (/usr/lib/python3.9/socket.py:704) > return self.read(nbytes, buffer) at recv_into (/usr/lib/python3.9/ssl.py:1241) > return self._sslobj.read(len, buffer) at read (/usr/lib/python3.9/ssl.py:1099) > resp = conn.urlopen( at send (/usr/lib/python3/dist-packages/requests/adapters.py:439) > retries = retries.increment( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:755) > raise six.reraise(type(error), error, _stacktrace) at increment (/usr/lib/python3/dist-packages/urllib3/util/retry.py:532) > raise value at reraise (/usr/lib/python3/dist-packages/six.py:719) > httplib_response = self._make_request( at urlopen (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:699) > self._raise_timeout(err=e, url=url, timeout_value=read_timeout) at _make_request (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:447) > raise ReadTimeoutError( at _raise_timeout (/usr/lib/python3/dist-packages/urllib3/connectionpool.py:336) > response = requests.post( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:273) > return request('post', url, data=data, json=json, **kwargs) at post (/usr/lib/python3/dist-packages/requests/api.py:119) > return session.request(method=method, url=url, **kwargs) at request (/usr/lib/python3/dist-packages/requests/api.py:61) > resp = self.send(prep, **send_kwargs) at request (/usr/lib/python3/dist-packages/requests/sessions.py:542) > r = adapter.send(request, **kwargs) at send (/usr/lib/python3/dist-packages/requests/sessions.py:655) > raise ReadTimeout(e, request=request) at send (/usr/lib/python3/dist-packages/requests/adapters.py:529) > appliance.identify(cloud, use_cloud) at appliance_state (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:1046) > self.refresh(cloud if use_cloud else None) at identify (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:831) > responses = self._status(cmd, cloud) at refresh (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:381) > responses = cloud.appliance_transparent_send(self.appliance_id, data) at _status (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/lan.py:538) > response = self.api_request( at appliance_transparent_send (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:526) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > return self.api_request( at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:342) > return self._retry_api_request( at api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:285) > self._retry_check(endpoint, cause) at _retry_api_request (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:335) > raise CloudRequestError( at _retry_check (/home/iobroker/.local/lib/python3.9/site-packages/midea_beautiful/cloud.py:350) *** JS *** midea_beautiful.exceptions.CloudRequestError: Too many retries while calling /v1/appliance/transparent/send, last error HTTPSConnectionPool(host='mapp.appsmb.com', port=443): Read timed out. (read timeout=2)
    midea.0
    	2022-09-11 14:38:09.029	error	Error
    midea.0
    	2022-09-11 14:37:50.251	info	function () { [native code] }
    midea.0
    	2022-09-11 14:37:50.249	info	[{id=145135534918692, address=xx.xx.xx.xx, port=6444, version=3, name=KLIMAANLAGE_XXXX, online=True, type=0xac, subtype=0, flags=0, extra=1, reserved=0, mac=30b23748e50f, ssid=net_ac_E50F, udp_version=4000000, protocol=069fcd, version=3.0.8, sn=000000P0000000Q130B2XXXXXXXX0000, state=[Air conditioner]{id=14500000000****, type=0xac mode=4, running=False, turbo=False, fan_speed=102, turbo_fan=False, purifier=False, dryer=False, target_temperature=28.0, indoor_temperature=24.4, outdoor_temperature=2.2250738585072014e-308, vertical_swing=False horizontal_swing=False comfort_sleep=False, error_code=0, prompt=False, supports={'eco': 1, 'mode': 1, 'fan_swing': 1, 'electricity': 0, 'strong_fan': 1, 'fan_speed': 1, 'temperature0': 32, 'temperature1': 60, 'temperature2': 32, 'temperature3': 60, 'temperature4': 32, 'temperature5': 60, 'temperature6': 0}}}]
    midea.0
    	2022-09-11 14:37:50.246	info	Found 1 devices
    tombox
    #178
    @gosund Das sieht aber nicht so schlecht aus. Ein Objekt müsste eigentlich geschrieben haben. Kommt der Fehler bei jedem Update oder unregelmäßig.
    G 1 Antwort Letzte Antwort
    • T tombox
      gosund
      #179
      @tombox
      Ist gerade etwas schwierig, da ich wieder auf meine alte Installation umgeschaltet habe. Soweit ich das sehe, kommt der Fehler, wenn ich versuche die Anlage über das Objekt einzuschalten.
      Welche App soll ich in den Einstellungen wählen?
      Kommuniziert Dein Adapter eigentlich über die Cloud oder direkt mit der Anlage im LAN?
      • G gosund
        @tombox
        tombox
        #180
        @gosund Über die cloud. App muss man wählen bei der man registriert bzw austesten
        reindeer-webR S 2 Antworten Letzte Antwort
        • T tombox
          reindeer-webR Offline
          reindeer-web
          #181
          @tombox
          Ich nutze den Entfeuchter Midea MDDF-20DEN7-WF.
          Mit der Version 0.1.0 ist es mir jetzt endlich gelungen, Datenpunkte zu erhalten, die ich in meiner Visualisierung anzeigen lassen kann.
          Leider kommen immer wieder (alle paar Stunden) diese beiden identischen Fehlermeldungen:
          SyntaxError: Unexpected token b in JSON at position 84 at JSON.parse (<anonymous>) at Midea.updateDevices (/opt/iobroker/node_modules/iobroker.midea/main.js:166:32) at runMicrotasks (<anonymous>) at processTicksAndRejections (node:internal/process/task_queues:96:5)
          • T tombox
            stefan-ohg
            schrieb am zuletzt editiert von stefan-ohg
            #182
            Post bitte ignorieren, habe meinen Fehler gefunden, kann den Post aber nicht löschen.
            Gruß Stefan
              Marc9025
              #183
              @tombox
              Erstmal vielen dank für deine Mühe.
              Ich habe 2 Fragen ;)
              Leider bekomme ich den Adapter bei mir nicht installiert das steht im log :
              host.raspberrypi
              2022-10-06 10:03:41.408 info iobroker exit 0
              host.raspberrypi
              2022-10-06 10:03:40.307 info iobroker upload [0] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/midea.png midea.png image/png
              host.raspberrypi
              2022-10-06 10:03:40.295 info iobroker upload [1] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/jsonConfig.json jsonConfig.json application/json
              host.raspberrypi
              2022-10-06 10:03:40.193 info iobroker upload [2] midea.admin /opt/iobroker/node_modules/iobroker.midea/admin/index_m.html index_m.html text/html
              host.raspberrypi
              2022-10-06 10:03:40.074 info iobroker 143 packages are looking for funding run npm fund for details
              host.raspberrypi
              2022-10-06 10:03:37.088 info iobroker + iobroker.midea@0.1.0updated 1 package in 301.601s
              host.raspberrypi
              2022-10-06 10:03:37.086 info iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: osx-temperature-sensor@1.0.7 (node_modules/osx-temperature-sensor):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for osx-temperature-sensor@1.0.7: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
              host.raspberrypi
              2022-10-06 10:03:37.052 info iobroker npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@2.3.2 (node_modules/fsevents):npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@2.3.2: wanted {"os":"darwin","arch":"any"} (current: {"os":"linux","arch":"arm64"})
              host.raspberrypi
              2022-10-06 10:03:37.011 info iobroker npm WARN pythonia@1.0.0 requires a peer of ws@^7.5.1 but none is installed. You must install peer dependencies yourself.
              host.raspberrypi
              2022-10-06 10:03:36.979 info iobroker npm WARN http-cookie-agent@4.0.1 requires a peer of tough-cookie@^4.0.0 but none is installed. You must install peer dependencies yourself.
              host.raspberrypi
              2022-10-06 10:03:36.949 info iobroker npm WARN crc@4.1.1 requires a peer of buffer@>=6.0.3 but none is installed. You must install peer dependencies yourself.
              host.raspberrypi
              2022-10-06 10:03:30.908 info iobroker Installing midea-beautiful-air
              host.raspberrypi
              2022-10-06 10:03:30.907 info iobroker pip 22.2.2 from /home/iobroker/.local/lib/python3.9/site-packages/pip (python 3.9)
              host.raspberrypi
              2022-10-06 10:03:24.788 info iobroker Python 3 found
              host.raspberrypi
              2022-10-06 10:03:24.787 info iobroker Python 3.9.2
              host.raspberrypi
              2022-10-06 10:03:24.763 info iobroker Start Python package installation
              host.raspberrypi
              2022-10-06 10:03:24.761 info iobroker
              host.raspberrypi
              2022-10-06 10:03:24.617 info iobroker > iobroker.midea@0.1.0 postinstall /opt/iobroker/node_modules/iobroker.midea> node ./pythonPackages.js
              host.raspberrypi
              2022-10-06 10:03:24.616 info iobroker
              ist es vielleicht weil ich eine 64 Bit Version habe?
              Ich habe eine Quick Connet Klimaanlage von Dimstal. Leider benutz diese eine andere app.
              https://play.google.com/store/apps/details?id=com.broadlink.acfreedom&hl=de&gl=US
              ist da die Einbindung auch möglich?
              Thomas BraunT T 2 Antworten Letzte Antwort
              • M Marc9025
                @tombox
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                host.raspberrypi
                #184
                @marc9025 sagte in Test Adapter Midea Dimstal Klimaanlagen v0.0.x:
                Nein, bei mir läuft der Adapter auch auf einem 64bit RaspberryOS.
                Dein Log ist auch nicht vollständig. Der Anfang und das Ende fehlt vermutlich.
                • M Marc9025
                  @tombox
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  host.raspberrypi
                  tombox
                  #185
                  @marc9025 Installation sieht gut aus. Hast du manuell eine Instanz erstellt?
                  • T tombox
                    Marc9025
                    #186
                    @tombox
                    ich habe jetzt noch mal installiert und das zeigt er mir an.
                    Unter Instanzen wird der Adapter mir nicht angezeigt aber unter Objekten gibt es einen Ordner midea. Da gibt es aber nur den Ordner admin
                    $ iobroker url https://github.com/TA2k/ioBroker.midea --host raspberrypi --debug
                    install TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96
                    NPM version: 6.14.17
                    Installing TA2k/ioBroker.midea#6e0c2b5bf9a3f7f19b7827bf20bc2b48c0281d96... (System call)
                    Python 3.9.2Python 3 found
                    pip 22.2.2 from /home/iobroker/.local/lib/python3.9/site-packages/pip (python 3.9)Installing midea-beautiful-air
                    WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'ReadTimeoutError("HTTPSConnectionPool(host='www.piwheels.org', port=443): Read timed out. (read timeout=15)")': /simple/midea-beautiful-air/
                    • iobroker.midea@0.1.0updated 1 package in 356.909s
                    Process exited with code 0
                    • M Marc9025
                      @tombox
                      tombox
                      #187
                      @marc9025 Python packages ist zur zeit sehr langsam probier in ein paar stunden nochmal
                      • T tombox
                        Marc9025
                        #188
                        @tombox
                        jetzt hat es funktioniert.
                        Jetzt aber zu meiner 2 Frage :)
                        ich habe ja nicht die midea app sondern die AC Freedom. Damit wird es nicht gehen oder ?
                        • M Marc9025
                          @tombox
                          tombox
                          #189
                          @marc9025 https://github.com/TA2k/ioBroker.midea/issues/154
                          • T tombox
                            Marc9025
                            #190
                            @tombox
                            aber ich gerade gesehen.
                            Braust du noch Zugansdaten zum testen ?
                            • M Marc9025
                              @tombox
                              tombox
                              #191
                              @marc9025 Nein die Geräte können nicht in den adapter integriert werden
                              • T tombox
                                Marc9025
                                #192
                                @tombox
                                okay das ist schade, dann habe ich wohl Pech gehabt.
                                  Marc9025
                                  #193
                                  @tombox
                                  hallo noch mal,
                                  ich habe versucht die Klimaanlage von einem Kollegen hinzuzufügen (nethome app).
                                  Der Login hat geklappt und er übergibt auch den String mit den daten(im log)
                                  Aber er erstellt keine Datenpunkte und er gibt die Beiden Fehler aus:
                                  midea.0
                                  2022-10-06 15:27:32.344 error TypeError: objectString.replaceAll is not a function at Midea.pythonToJson (/opt/iobroker/node_modules/iobroker.midea/main.js:177:8) at Midea.getDeviceList (/opt/iobroker/node_modules/iobroker.midea/main.js:115:36) at processTicksAndRejections (internal/process/task_queues.js:95:5) at Midea.onReady (/opt/iobroker/node_modules/iobroker.midea/main.js:79:5)
                                  midea.0
                                  2022-10-06 15:27:32.338 error TypeError: objectString.replaceAll is not a function
                                  • M Marc9025
                                    @tombox
                                    hallo noch mal,
                                    midea.0
                                    midea.0
                                    tombox
                                    #194
                                    @marc9025 Sicher eine node 14 installation. Bitte nochmal installieren dann sollte es auch damit gehen
                                    • T tombox
                                      Marc9025
                                      #195
                                      @tombox
                                      die ist schon drauf.
                                      PlatformBetriebssystem:linux
                                      Architektur:arm64
                                      CPUs:4
                                      Geschwindigkeit:1500 MHz
                                      Modell:unknown
                                      RAM:3.7 GB
                                      System-Betriebszeit:22:37:51
                                      Node.js:v14.20.1
                                      time:1665052542656
                                      timeOffset:-120
                                      Adapter-Anzahl:435
                                      NPM:6.14.17
                                      Datenträgergröße:117.1 GB
                                      Freier Festplattenspeicher:108.1 GB
                                      Betriebszeit:22:37:32
                                      Aktive Instanzen:17
                                      Pfad:/opt/iobroker/
                                      aktiv:true
                                      _nodeCurrent:14.20.1
                                      _nodeNewest:14.20.1
                                      _nodeNewestNext:16.17.1
                                      _npmCurrent:6.14.17
                                      _npmNewest:6.14.17
                                      _npmNewestNext:8.15.0
                                      • M Marc9025
                                        @tombox
                                        Architektur:arm64
                                        CPUs:4
                                        Modell:unknown
                                        RAM:3.7 GB
                                        Node.js:v14.20.1
                                        time:1665052542656
                                        timeOffset:-120
                                        Adapter-Anzahl:435
                                        NPM:6.14.17
                                        Aktive Instanzen:17
                                        Pfad:/opt/iobroker/
                                        aktiv:true
                                        _nodeNewest:14.20.1
                                        _npmCurrent:6.14.17
                                        _npmNewest:6.14.17
                                        #196
                                        @marc9025
                                        Die würde ich auf die derzeitig empfohlene Version 16 heben.
                                          @marc9025
                                          Marc9025
                                          schrieb am zuletzt editiert von Marc9025
                                          #197
                                          super das update war es.
                                          @tombox weißt ob jemand an die Integration von der AC Freedom app arbeitet ?
