Adapter: Worx Landroid v2.x.x
@maik-gadow sagte in Adapter: Worx Landroid:
Wo kann ich jetzt noch (und wie) suchen?
Im Log File?
iobroker logs --watch | uniqund mit dem Adapter 'herumspielen' (Neustart z. B.)
Vom Adapter Neustarten hab ich schon fast ne Sehnenscheidenentzündung ;)```
2022-10-04 16:40:45.360 - info: host.iobroker instance system.adapter.worx.0 started with pid 11032 2022-10-04 16:40:46.082 - info: worx.0 (11032) starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.worx, node: v16.17.1, js-controller: 4.0.23 2022-10-04 16:40:46.095 - info: worx.0 (11032) landxcape is selected 2022-10-04 16:40:46.309 - error: worx.0 (11032) Could not Connect to Worx Server: StatusCodeError: 404 - {"message":"Not Found","code":"404.000"} 2022-10-04 16:40:46.309 - error: worx.0 (11032) ERROR: StatusCodeError: 404 - {"message":"Not Found","code":"404.000"} -
2022-10-04 16:40:45.360 - info: host.iobroker instance system.adapter.worx.0 started with pid 11032 2022-10-04 16:40:46.082 - info: worx.0 (11032) starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.worx, node: v16.17.1, js-controller: 4.0.23 2022-10-04 16:40:46.095 - info: worx.0 (11032) landxcape is selected 2022-10-04 16:40:46.309 - error: worx.0 (11032) Could not Connect to Worx Server: StatusCodeError: 404 - {"message":"Not Found","code":"404.000"} 2022-10-04 16:40:46.309 - error: worx.0 (11032) ERROR: StatusCodeError: 404 - {"message":"Not Found","code":"404.000"}404 heißt: Der Server hat gerade Mittagspause.
2022-10-04 16:40:45.360 - info: host.iobroker instance system.adapter.worx.0 started with pid 11032 2022-10-04 16:40:46.082 - info: worx.0 (11032) starting. Version 1.6.6 in /opt/iobroker/node_modules/iobroker.worx, node: v16.17.1, js-controller: 4.0.23 2022-10-04 16:40:46.095 - info: worx.0 (11032) landxcape is selected 2022-10-04 16:40:46.309 - error: worx.0 (11032) Could not Connect to Worx Server: StatusCodeError: 404 - {"message":"Not Found","code":"404.000"} 2022-10-04 16:40:46.309 - error: worx.0 (11032) ERROR: StatusCodeError: 404 - {"message":"Not Found","code":"404.000"}@maik-gadow Du verwendest noch die 1.6.6 bei der der Login nicht mehr funktioniert. In iobroker sollte dir eigentlich ein Update angezeit werden auf 1.7.0.
Gruß//Lucky
Gruß//Lucky
Aber nur wenn Beta gefahren wird:
github: 2.0.0 latest: 1.7.0 for 5 days stable: 1.6.6 for 3 months -
Gruß//Lucky
leider nicht :(
Installierte Instanzen:
Verfügbare Version:
1.6.6
Installierte Version:
1.6.6@Thomas-Braun
scheint eine never ending Mittagspause zu sein :) -
leider nicht :(
Verfügbare Version:
1.6.6
1.6.6@Thomas-Braun
scheint eine never ending Mittagspause zu sein :)@maik-gadow sagte in Adapter: Worx Landroid:
Nö, mit der Beta-Version 1.7.0 beendest du die offenbar.
@thomas-braun Stimmt, hatte tombox ja oben beschrieben
@maik-gadow Warte auf die 2.0.0 oder in den Systemeinstellungen auf Beta stellen und NUR den Worx installieren.
Danke für den Support
1.7.0 und der Status ist grün :)jetzt muss ich nur noch Gardena (smartgarden) das Laufen beibringen ;)
Habe gerade festgestellt, dass der Adapter 2.0.0 bei mir die Datenpunkte jede Minute aktualisiert. Habe die 3.26, vorher gab es ca. alle 10 Minuten eine Aktualisierung.
Ist das bei euch auch der Fall?
Ich hatte schon alle relevanten Scripte deaktiviert, die minütliche Aktualisierung bleibt aber.
Liegt das am Adapter oder hat WORX was geändert? -
Liegt das am Adapter oder hat WORX was geändert?@ksy sagte in Adapter: Worx Landroid:
Das war früher auch schon so aber da wurde nur geprüft, ob der Worx Online ist. Jetzt werden jede Minute auch die rawMqtt Daten aktualisiert. Zusätzliche Aktualisierung kommt dann wenn MQTT was schickt. Zu sehen im Datenpunkt rawMqtt.last_status.timestamp = letzte MQTT Aktualisierung
Gruß//Lucky
Gruß//Lucky
@lucky_esa
Ok, Danke für den Hinweis.
Noch eine Frage:
Widerspricht das nicht der Vorgehensweise von WORX, die Aktualisierung der Daten nur noch in einem längeren Zeitintervall zu senden, wegen Traffic, Kosten usw.? Bei der 3.28 glaube ich sind es ca. 50 Minuten.
Oder hat das damit nichts zu tun?
Habe hier halt auch schon gelesen, dass man für 24 Std. gesperrt werden kann, wenn die Daten zu oft abgefragt werden.Grüße
Klaus -
@lucky_esa
Noch eine Frage:
Klaus@ksy sagte in Adapter: Worx Landroid:
@lucky_esa
Noch eine Frage:
Widerspricht das nicht der Vorgehensweise von WORX, die Aktualisierung der Daten nur noch in einem längeren Zeitintervall zu senden, wegen Traffic, Kosten usw.?Den Intervall können wir natürlich anpassen aber seit dem du diesen Adapter hast fragst du (unbewusst) 24/7 deine Daten jede Minute ab. Diese wurden aber nie in rawMqtt aktualisiert.
Und wurdest du jemals gesperrt?
Aber wenn ihr wollt kann ich euch einen Intervall-Angabe in den Einstellungen hinzufügen!
Der Aktualisierungs-Intervall in der 3.28 hat sich geändert und ja, hier wird traffic eingespart. Bei mir kommt Nachts bis zu 8 Stunden keine Daten.
Abfrage Cloud => Jede Minute Anfrage vom Adapter zur Cloud
Automatische Daten Mqtt => Nur bei wichtigen Ereignisse wie z. Bsp. Error, Statusmeldungen oder du sendest einen Befehl (Hier wurden die 10 Minuten wohl entfernt)Gruß//Lucky
@lucky_esa
Noch eine Frage:
@lucky_esa
Ok, verstanden.
Ich brauche dann keine Möglichkeit ein Intervall einzustellen. Im Gegenteil, die Aktualisierung in rawMqtt sehe ich als Vorteil. -
Es werden allerdings nur Daten aktualisiert wenn Änderungen in der APP durchgeführt werden wie z. Bsp. das Zurücksetzen der Klingenarbeitszeit oder halt Offline oder Online.
Wenn du Worx was Gutes tun möchtest dann lösche die APP und steuer alles über iobroker :-)Gruß//Lucky
@lucky_esa
Dann hätte ich aber ein Problem, wenn Worx was ändert und weder der Adapter noch die Desktop-App funzt.
War ja vor kurzem so, da konnte ich die Teile nur noch mit der App steuern.
@lucky_esa
Noch eine Frage:
@lucky_esa Der Server darf auf jedenfall nicht angepollt werden um die daten zu aktualisieren. Das ist eine Vereinbarung mit den Entwicklern von Worx.
@meistertr Das habe ich mir gedacht. OK, werde mich daran halten allerdings ist auf dem GIT derzeit ein Workaround da es Themen mit Node 18 gibt.
Gruß//Lucky
Gruß//Lucky
Also, jetzt bin echt verwirrt.
Bedeutet das jetzt im Klartext: die Aktualisierung im Minutentakt ist nicht ok?
Ich hatte einige Steuerungen bei der 3.26 per Script auf die 10-Minuten-Aktualisierung ausgelegt (Garage Tor auf, zu, Kantenschnitt, Mähvorgang, Heimfahrt usw.)
Habe deswegen auch festgestellt, dass mir der Status jede Minute "Kantenschnitt" ansagt, obwohl ich ja vorher nur eine 10-min.-Aktualisierung hatte. Bei mir dauert der KS ca. 8 Min.
War jetzt schon dran, die Skripte umzuschreiben.
@Meistertr
Dann ist meine Vermutung doch richtig, dass nicht jede Minute abgefragt werden darf? -
@Meistertr
