  4. Untersuchung: code 25 fehlerlösung
    apollon77A
255 Beiträge 34 Kommentatoren 78.7k Aufrufe 31 Beobachtet
    @rewenode
    iobroker upgrade node-red@VERSIONSNUMMER
    R
    R
    rewenode
    #157
    @thomas-braun Ok, die node-red Vermutung kann man wohl ausschließen.
    Update 3.3.1 auf 4.0.0 ohne Probleme und hat auch keine Spuren hinterlassen
    Used repository: stable
    Adapter    "admin"        : 6.2.22   , installed 6.2.22
    Adapter    "backitup"     : 2.4.12   , installed 2.4.12
    Adapter    "discovery"    : 3.0.5    , installed 3.0.5
    Controller "js-controller": 4.0.23   , installed 4.0.23
    Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
    iobroker@testiob:~$ iob upgrade node-red@4.0.0 --debug
    This upgrade of "node-red" will introduce the following changes:
    -> 4.0.0:
    IMPORTANT: Node.js 14.x now needed at least
    Upgrade to node-red 3.0.2, enable runtime-state features and switch editor to monaco-editor
    Correctly escape backslashes when writing setting file on Windows
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade node-red from @3.3.1 to @4.0.0 now? [(y)es, (n)o]: y
    Update node-red from @3.3.1 to @4.0.0
    NPM version: 8.15.0
    Installing iobroker.node-red@4.0.0... (System call)
    added 3 packages, removed 81 packages, and changed 23 packages in 7s
    70 packages are looking for funding
      run `npm fund` for details
    upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
    upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
    upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
    upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
    upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
    iobroker@testiob:~$ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%/}; done
    iobroker@testiob:~$
    • R rewenode
      -> 4.0.0:
      NPM version: 8.15.0
      iobroker@testiob:~$
      Thomas BraunT
      Thomas BraunT
      #158
      @rewenode
      Interessant wäre ein Log vom Neustart vom node-red, wenn der Error 25-Block auftritt.
      Und es müssen dann auch ein paar Nodes im node-red drin sein, bevorzugt binäre.
      R 3 Antworten Letzte Antwort
        @rewenode
        R
        R
        rewenode
        #159
        @thomas-braun sagte in Untersuchung: code 25 fehlerlösung:
        Werde mal versuchen das hinzubekommen. Aber wie gesagt bislang in der Testversion keine Fehler.
          @rewenode
          R
          R
          rewenode
          #160
          Kannst du da spontan welche nennen?
          • R rewenode
            Thomas BraunT
            Thomas BraunT
            #161
            @rewenode sagte in Untersuchung: code 25 fehlerlösung:
            Nein, ich verwende node-red nicht.
              @rewenode
              R
              R
              rewenode
              #162
              @thomas-braun Also ich muss dann erstmal passen.
              • frischen Docker-Contaimer aufgesetzt
              • node-red upgrade auf 3.3.1
              • ein paar nodes installiert (die ich auch im Produktivsystem habe)
              • Node-red upgrade auf 4.0.0
              • admin upgrade
              Keinerlei Fehler ;-(
              Keine Ahnung ab wann der sich einschleicht.
              NWHN 1 Antwort Letzte Antwort
              • R rewenode
                • admin upgrade
                NWHN
                NWHN
                NWH
                #163
                Bei mir ist es auch so, dass ich keine Update mehr machen kann.
                Habe mit dem nur Schau-Befehl bei mir nachgeschaut, finde da allerdings auch keine Fehler.
                NPM 8.15.0
                Node 16.17.1
                Js- Controller 4.0.23
                root@iobroker:/opt/iobroker/node_modules# for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" !
                -iname ".local-chromium"); do echo ${i%}; done
                /opt/iobroker/node_modules/@babel/.runtime-cSN2FFol
                /opt/iobroker/node_modules/@types/.whatwg-url-st9gKEiR
                /opt/iobroker/node_modules/@types/.webidl-conversions-sTwlFPEN
                /opt/iobroker/node_modules/@node-red/.editor-api-Xk7v1FU7
                /opt/iobroker/node_modules/@node-red/.editor-client-FpqhSpDH
                /opt/iobroker/node_modules/@node-red/.nodes-oC2yqxJN
                /opt/iobroker/node_modules/@node-red/.registry-ccnbcuRd
                /opt/iobroker/node_modules/@node-red/.runtime-1jQRdxlO
                /opt/iobroker/node_modules/@node-red/.util-sbKUIGKV
                /opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ
                /opt/iobroker/node_modules/iobroker.web/node_modules/.accepts-OXiUlc3Q
                /opt/iobroker/node_modules/iobroker.web/node_modules/.bytes-1xgHDNBN
                /opt/iobroker/node_modules/iobroker.web/node_modules/.body-parser-UqURhhX1
                /opt/iobroker/node_modules/iobroker.web/node_modules/.cookie-tK2ONQ1o
                /opt/iobroker/node_modules/iobroker.web/node_modules/.depd-C51S9yJW
                /opt/iobroker/node_modules/iobroker.web/node_modules/.destroy-qlf2lv5l
                /opt/iobroker/node_modules/iobroker.web/node_modules/.http-errors-Za9l7C18
                /opt/iobroker/node_modules/iobroker.web/node_modules/.inherits-TuGh0LXN
                /opt/iobroker/node_modules/iobroker.web/node_modules/.mime-types-PeP4UgEO
                /opt/iobroker/node_modules/iobroker.web/node_modules/.mime-db-kRSHCEJi
                /opt/iobroker/node_modules/iobroker.web/node_modules/.ms-eKzAxOLx
                /opt/iobroker/node_modules/iobroker.web/node_modules/.negotiator-cgjfl5da
                /opt/iobroker/node_modules/iobroker.web/node_modules/.on-finished-xF1T4SnU
                Was müsste ich jetzt tun...?
                Node Red läuft auch nicht da immer diesr Fehler kommt.
                warn	node:internal/modules/cjs/loader:959 throw err; ^ Error: Cannot find module 'jsonfile/utils' Require stack: - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/node-red/red.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15) at Function.Module._load (node:internal/modules/cjs/loader:804:27) at Module.require (node:internal/modules/cjs/loader:1028:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js:3:23) at Module._compile (node:internal/modules/cjs/loader:1126:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) at Module.load (node:internal/modules/cjs/loader:1004:32) at Function.Module._load (node:internal/modules/cjs/loader:839:12) at Module.require (node:internal/modules/cjs/loader:1028:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/node-red/red.js' ] }
                node-red.0
                2022-10-03 21:21:29.034	info	node-red exited with 1
                node-red.0
                2022-10-03 21:21:29.030	warn	node:internal/modules/cjs/loader:959 throw err; ^ Error: Cannot find module 'jsonfile/utils' Require stack: - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/node-red/red.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15) at Function.Module._load (node:internal/modules/cjs/loader:804:27) at Module.require (node:internal/modules/cjs/loader:1028:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js:3:23) at Module._compile (node:internal/modules/cjs/loader:1126:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) at Module.load (node:internal/modules/cjs/loader:1004:32) at Function.Module._load (node:internal/modules/cjs/loader:839:12) at Module.require (node:internal/modules/cjs/loader:1028:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/node-red/red.js' ] }
                • NWHN NWH
                  NPM 8.15.0
                  Node 16.17.1
                  node-red.0
                  node-red.0
                  Thomas BraunT
                  Thomas BraunT
                  #164
                  @nwh sagte in Untersuchung: code 25 fehlerlösung:
                  Dich als user und nicht als root einloggen.
                    NWHN
                    NWHN
                    NWH
                    #165
                    @thomas-braun ich mache das über die Konsole vom Docker auf der Synology.
                    Wüsste gar nicht wie das anders ginge.
                    • NWHN NWH
                      Thomas BraunT
                      Thomas BraunT
                      #166
                      @nwh
                      Bei Docker bin ich eh raus. Keinen Bock auf den Kram.
                        @nwh
                        NWHN
                        NWHN
                        NWH
                        #167
                        @thomas-braun na dann....
                        • NWHN NWH
                          Thomas BraunT
                          Thomas BraunT
                          #168
                          @nwh
                          Lösch die Verzeichnisse.
                            @nwh
                            NWHN
                            NWHN
                            NWH
                            #169
                            @thomas-braun tjo das kann ich nicht, da ich mich damit nicht auskenne. Leider.
                            Hilft es was wenn ich NodeRed lösche? in der IOB Oberfläche.
                            • NWHN NWH
                              Thomas BraunT
                              Thomas BraunT
                              #170
                              @nwh
                              Wir schauen jetzt erstmal etwas herum.
                              cd /opt/iobroker/
                              npm ls body-parser
                                @nwh
                                cd /opt/iobroker/
                                npm ls body-parser
                                NWHN
                                NWHN
                                NWH
                                #171
                                npm ls body-parser
                                root@iobroker:/opt/iobroker# npm ls body-parser
                                sudo: Hostname iobroker kann nicht aufgelöst werden: Zu diesem Hostnamen gehört keine Adresse
                                iobroker.inst@2.0.3 /opt/iobroker
                                ├─┬ iobroker.admin@6.2.22
                                │ ├── body-parser@1.20.0
                                │ └─┬ express@4.18.1
                                │   └── body-parser@1.20.0 deduped
                                ├─┬ iobroker.node-red@4.0.0 invalid: "3.3.1" from the root project
                                │ └─┬ node-red@3.0.2
                                │   ├─┬ @node-red/editor-api@3.0.2
                                │   │ └── body-parser@1.20.0 deduped
                                │   └─┬ @node-red/nodes@3.0.2
                                └─┬ iobroker.web@4.3.0
                                • NWHN NWH
                                  npm ls body-parser
                                  Thomas BraunT
                                  Thomas BraunT
                                  #172
                                  @nwh
                                  npm ls destroy
                                    @nwh
                                    npm ls destroy
                                    NWHN
                                    NWHN
                                    NWH
                                    #173
                                    npm ls destroy
                                    root@iobroker:/opt/iobroker# npm ls destroy
                                    └─┬ iobroker.admin@6.2.22
                                      ├─┬ body-parser@1.20.0
                                      │ └── destroy@1.2.0
                                      └─┬ express@4.18.1
                                        └─┬ send@0.18.0
                                          └── destroy@1.2.0 deduped
                                    • NWHN NWH
                                      npm ls destroy
                                        │ └── destroy@1.2.0
                                        └─┬ express@4.18.1
                                          └─┬ send@0.18.0
                                      Thomas BraunT
                                      Thomas BraunT
                                      #174
                                      @nwh
                                      npm ls
                                      Erstmal nur das Ende der Ausgabe.
                                        @nwh
                                        npm ls
                                        NWHN
                                        NWHN
                                        NWH
                                        #175
                                        @thomas-braun 😰
                                        npm ERR! code ELSPROBLEMS
                                        npm ERR! extraneous: @types/caseless@0.12.2 /opt/iobroker/node_modules/@types/caseless
                                        npm ERR! extraneous: @types/request@2.48.8 /opt/iobroker/node_modules/@types/request
                                        npm ERR! extraneous: @types/tough-cookie@4.0.2 /opt/iobroker/node_modules/@types/tough-cookie
                                        npm ERR! extraneous: coffeescript@1.12.7 /opt/iobroker/node_modules/coffeescript
                                        npm ERR! invalid: iobroker.node-red@4.0.0 /opt/iobroker/node_modules/iobroker.node-red
                                        npm ERR! extraneous: node-inspect@2.0.0 /opt/iobroker/node_modules/node-inspect
                                        npm ERR! extraneous: picocolors@1.0.0 /opt/iobroker/node_modules/picocolors
                                        npm ERR! extraneous: suncalc2@1.8.1 /opt/iobroker/node_modules/suncalc2
                                        npm ERR! extraneous: virtual-tsc@0.6.2 /opt/iobroker/node_modules/virtual-tsc
                                        npm ERR! extraneous: wake_on_lan@1.0.0 /opt/iobroker/node_modules/wake_on_lan
                                        npm ERR!     /opt/iobroker/.npm/_logs/2022-10-03T19_56_02_335Z-debug-0.log
                                        • NWHN NWH
                                          @thomas-braun 😰
                                          Thomas BraunT
                                          Thomas BraunT
                                          #176
                                          @nwh
                                          Und immer wieder node-red...
                                          npm prune
                                          iobroker update
                                          83.9k
