  4. Untersuchung: code 25 fehlerlösung
    apollon77A
255 Beiträge 34 Kommentatoren 79.0k Aufrufe 31 Beobachtet
    @lcars
    Dann ist es auch was anderes.
    Fehler 25 ist ja nur die Meldung, das irgendwo ein Fehler aufgetreten ist, die genaue Ursache muss man sich anschauen.
    R
    R
    rewenode
    schrieb am zuletzt editiert von rewenode
    #153
    @thomas-braun Also, das muss bei @lcars irgend etwas Anderes sein.
    Hab das grad mal nachgestellt. Geht ja Dank docker in Windeseile ;-)
    Hier mal die komplette Session:
    Last login: Mon Oct  3 14:32:53 on ttys001
    ❯ docker exec -u 1000:1000 -ti iobroker /bin/bash
    iobroker@testiob:~$ iob update -i
    Used repository: stable
    Adapter    "admin"        : 6.2.22   , installed 5.3.8  [Updatable]
    Adapter    "backitup"     : 2.4.12   , installed 2.4.9  [Updatable]
    Adapter    "discovery"    : 3.0.5    , installed 3.0.3  [Updatable]
    Controller "js-controller": 4.0.23   , installed 4.0.23
    iobroker@testiob:~$ for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" ! -iname ".local-chromium"); do echo ${i%/}; done
    iobroker@testiob:~$ iob upgrade discovery@3.0.5 --debug
    This upgrade of "discovery" will introduce the following changes:
    -> 3.0.5:
    Fix potential crash cases reported by Sentry
    -> 3.0.4:
    Disable configuration settings for this adapter
    Would you like to upgrade discovery from @3.0.3 to @3.0.5 now? [(y)es, (n)o]: y
    Update discovery from @3.0.3 to @3.0.5
    NPM version: 8.15.0
    Installing iobroker.discovery@3.0.5... (System call)
    changed 1 package in 1s
    38 packages are looking for funding
      run `npm fund` for details
    Update "system.adapter.discovery.0"
    upload [6] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/discovery.png discovery.png image/png
    upload [5] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index.html index.html text/html
    upload [4] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/index_m.html index_m.html text/html
    upload [3] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings.html settings.html text/html
    upload [2] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/settings_m.html settings_m.html text/html
    upload [1] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/translateTools.js translateTools.js application/javascript
    upload [0] discovery.admin /opt/iobroker/node_modules/iobroker.discovery/admin/words.js words.js application/javascript
    iobroker@testiob:~$ iob upgrade admin@6.2.22 --debug
    This upgrade of "admin" will at least introduce the following changes:
    -> 6.2.22:
    Corrected admin4 adapter settings
    -> 6.2.21:
    Corrected small JSON config issue
    -> 6.2.20:
    Corrected GUI issues
    -> 6.2.19:
    Corrected some issues
    -> 6.2.18:
    Corrected GUI bugs on custom settings
    -> 6.2.17:
    Corrected GUI bug on intro tab
    -> 6.2.16:
    Corrected many GUI issues
    Added `stable` flag for repositories
    Added reset button for repositories
    Improved `writeFile` function for socket communication
    BE CAREFUL: THIS IS A MAJOR UPGRADE, WHICH WILL MOST LIKELY INTRODUCE BREAKING CHANGES!
    Would you like to upgrade admin from @5.3.8 to @6.2.22 now? [(y)es, (n)o]: y
    Update admin from @5.3.8 to @6.2.22
    host.testiob Adapter "system.adapter.admin.0" is stopped.
    NPM version: 8.15.0
    Installing iobroker.admin@6.2.22... (System call)
    added 6 packages, and changed 4 packages in 8s
    Update "system.adapter.admin.0"
    upload [51] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/admin.png admin.png image/png
    upload [50] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/customComponents.js custom/customComponents.js application/javascript
    upload [40] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/i18n/ru.json custom/i18n/ru.json application/json
    upload [30] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js custom/static/js/node_modules_prop-types_index_js.512eddf9.chunk.js application/javascript
    upload [20] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js application/javascript
    upload [19] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map custom/static/js/vendors-node_modules_mui_material_Accordion_index_js-node_modules_mui_material_AccordionDetai-57e02d.0886b730.chunk.js.map application/json
    upload [18] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js application/javascript
    upload [17] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map custom/static/js/vendors-node_modules_mui_material_index_js.40e01f69.chunk.js.map application/json
    upload [16] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js application/javascript
    upload [15] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_index_js-node_modules_mui_utils_esm_capitalize_js-node_module-19fe07.82575832.chunk.js.map application/json
    upload [14] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js application/javascript
    upload [13] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map custom/static/js/vendors-node_modules_mui_styles_withStyles_withStyles_js.6d998ff2.chunk.js.map application/json
    upload [12] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js application/javascript
    upload [11] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map custom/static/js/vendors-node_modules_react-dom_index_js.51544235.chunk.js.map application/json
    upload [10] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/de/translations.json i18n/de/translations.json application/json
    upload [9] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/en/translations.json i18n/en/translations.json application/json
    upload [8] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/es/translations.json i18n/es/translations.json application/json
    upload [7] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
    upload [6] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/it/translations.json i18n/it/translations.json application/json
    upload [5] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
    upload [4] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
    upload [3] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
    upload [2] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
    upload [1] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
    upload [0] admin.admin /opt/iobroker/node_modules/iobroker.admin/admin/jsonConfig.json5 jsonConfig.json5 application/json5
    host.testiob Adapter "system.adapter.admin.0" is started
    iobroker@testiob:~$ iob upgrade backitup@2.4.12 --debug
    This upgrade of "backitup" will introduce the following changes:
    -> 2.4.12:
    Fix WebDav Error Handling
    -> 2.4.11:
    Filesize Check added
    dependencies updated
    Fix mySql Backup
    Fix pgSql Backup
    -> 2.4.10:
    Code cleaning
    Disclaimer added
    Travis Support removed
    Fix backup-download with ssl
    Would you like to upgrade backitup from @2.4.9 to @2.4.12 now? [(y)es, (n)o]: y
    Update backitup from @2.4.9 to @2.4.12
    host.testiob Adapter "system.adapter.backitup.0" is stopped.
    NPM version: 8.15.0
    Installing iobroker.backitup@2.4.12... (System call)
    removed 1 package, and changed 10 packages in 3s
    Update "system.adapter.backitup.0"
    upload [10] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/adapter-settings.js adapter-settings.js application/javascript
    upload [9] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.png backitup.png image/png
    upload [8] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/backitup.svg backitup.svg image/svg+xml
    upload [7] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index.html index.html text/html
    upload [6] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.html index_m.html text/html
    upload [5] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/index_m.js index_m.js application/javascript
    upload [4] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/style.css style.css text/css
    upload [3] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.css tab_m.css text/css
    upload [2] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.html tab_m.html text/html
    upload [1] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/tab_m.js tab_m.js application/javascript
    upload [0] backitup.admin /opt/iobroker/node_modules/iobroker.backitup/admin/words.js words.js application/javascript
    host.testiob Adapter "system.adapter.backitup.0" is started
    In einem frischen Container alle 3 Adapter ohne die geringsten Probleme und blitzartig geupdated.
    Werde etwas später mal den NR-Adapter in den Testcontainer (ältere Version) installieren und dann nochmal testen.
    • R rewenode
      -> 3.0.5:
      -> 3.0.4:
      NPM version: 8.15.0
      -> 6.2.22:
      -> 6.2.21:
      -> 6.2.20:
      -> 6.2.19:
      -> 6.2.18:
      -> 6.2.17:
      -> 6.2.16:
      NPM version: 8.15.0
      -> 2.4.12:
      -> 2.4.11:
      Fix mySql Backup
      Fix pgSql Backup
      -> 2.4.10:
      Code cleaning
      Disclaimer added
      NPM version: 8.15.0
      Thomas BraunT
      Thomas BraunT
      #154
      @rewenode sagte in Untersuchung: code 25 fehlerlösung:
      Sag ich ja
      • R
        R
        rewenode
        #155
        @thomas-braun Wie bekomme ich denn eine ältere Node-red version installiert? Bekomme nur die 4.0.0 angeboten
        Sorry, kaum macht manns richtig. Schon gefunden
        • R rewenode
          Thomas BraunT
          Thomas BraunT
          #156
          @rewenode
          iobroker upgrade node-red@VERSIONSNUMMER
          R 1 Antwort Letzte Antwort
            @rewenode
            R
            R
            rewenode
            #157
            @thomas-braun Ok, die node-red Vermutung kann man wohl ausschließen.
            Update 3.3.1 auf 4.0.0 ohne Probleme und hat auch keine Spuren hinterlassen
            Adapter    "admin"        : 6.2.22   , installed 6.2.22
            Adapter    "backitup"     : 2.4.12   , installed 2.4.12
            Adapter    "discovery"    : 3.0.5    , installed 3.0.5
            Adapter    "node-red"     : 4.0.0    , installed 3.3.1  [Updatable]
            iobroker@testiob:~$ iob upgrade node-red@4.0.0 --debug
            This upgrade of "node-red" will introduce the following changes:
            -> 4.0.0:
            IMPORTANT: Node.js 14.x now needed at least
            Upgrade to node-red 3.0.2, enable runtime-state features and switch editor to monaco-editor
            Correctly escape backslashes when writing setting file on Windows
            Would you like to upgrade node-red from @3.3.1 to @4.0.0 now? [(y)es, (n)o]: y
            Update node-red from @3.3.1 to @4.0.0
            NPM version: 8.15.0
            Installing iobroker.node-red@4.0.0... (System call)
            added 3 packages, removed 81 packages, and changed 23 packages in 7s
            70 packages are looking for funding
            upload [14] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/bcrypt.min.js bcrypt.min.js application/javascript
            upload [13] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/de/translations.json i18n/de/translations.json application/json
            upload [12] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/en/translations.json i18n/en/translations.json application/json
            upload [11] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/es/translations.json i18n/es/translations.json application/json
            upload [10] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/fr/translations.json i18n/fr/translations.json application/json
            upload [9] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/it/translations.json i18n/it/translations.json application/json
            upload [8] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/nl/translations.json i18n/nl/translations.json application/json
            upload [7] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pl/translations.json i18n/pl/translations.json application/json
            upload [6] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/pt/translations.json i18n/pt/translations.json application/json
            upload [5] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/ru/translations.json i18n/ru/translations.json application/json
            upload [4] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/i18n/zh-cn/translations.json i18n/zh-cn/translations.json application/json
            upload [3] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index.html index.html text/html
            upload [2] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/index_m.html index_m.html text/html
            upload [1] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/node-red.png node-red.png image/png
            upload [0] node-red.admin /opt/iobroker/node_modules/iobroker.node-red/admin/words.js words.js application/javascript
            iobroker@testiob:~$
            • R rewenode
              -> 4.0.0:
              NPM version: 8.15.0
              iobroker@testiob:~$
              Thomas BraunT
              Thomas BraunT
              #158
              @rewenode
              Interessant wäre ein Log vom Neustart vom node-red, wenn der Error 25-Block auftritt.
              Und es müssen dann auch ein paar Nodes im node-red drin sein, bevorzugt binäre.
              R 3 Antworten Letzte Antwort
                @rewenode
                R
                R
                rewenode
                #159
                @thomas-braun sagte in Untersuchung: code 25 fehlerlösung:
                Werde mal versuchen das hinzubekommen. Aber wie gesagt bislang in der Testversion keine Fehler.
                  @rewenode
                  R
                  R
                  rewenode
                  #160
                  Kannst du da spontan welche nennen?
                  • R rewenode
                    Thomas BraunT
                    Thomas BraunT
                    #161
                    Nein, ich verwende node-red nicht.
                      @rewenode
                      R
                      R
                      rewenode
                      #162
                      @thomas-braun Also ich muss dann erstmal passen.
                      • frischen Docker-Contaimer aufgesetzt
                      • node-red upgrade auf 3.3.1
                      • ein paar nodes installiert (die ich auch im Produktivsystem habe)
                      • Node-red upgrade auf 4.0.0
                      • admin upgrade
                      Keinerlei Fehler ;-(
                      Keine Ahnung ab wann der sich einschleicht.
                      NWHN 1 Antwort Letzte Antwort
                      • R rewenode
                        • admin upgrade
                        NWHN
                        NWHN
                        NWH
                        #163
                        Bei mir ist es auch so, dass ich keine Update mehr machen kann.
                        Habe mit dem nur Schau-Befehl bei mir nachgeschaut, finde da allerdings auch keine Fehler.
                        NPM 8.15.0
                        Node 16.17.1
                        Js- Controller 4.0.23
                        root@iobroker:/opt/iobroker/node_modules# for i in $(find /opt/iobroker/node_modules -type d -iname ".*-????????" !
                        -iname ".local-chromium"); do echo ${i%}; done
                        /opt/iobroker/node_modules/@babel/.runtime-cSN2FFol
                        /opt/iobroker/node_modules/@types/.whatwg-url-st9gKEiR
                        /opt/iobroker/node_modules/@types/.webidl-conversions-sTwlFPEN
                        /opt/iobroker/node_modules/@node-red/.editor-api-Xk7v1FU7
                        /opt/iobroker/node_modules/@node-red/.editor-client-FpqhSpDH
                        /opt/iobroker/node_modules/@node-red/.nodes-oC2yqxJN
                        /opt/iobroker/node_modules/@node-red/.registry-ccnbcuRd
                        /opt/iobroker/node_modules/@node-red/.runtime-1jQRdxlO
                        /opt/iobroker/node_modules/@node-red/.util-sbKUIGKV
                        /opt/iobroker/node_modules/memorystore/node_modules/.yallist-dQCRuaxJ
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.accepts-OXiUlc3Q
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.bytes-1xgHDNBN
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.body-parser-UqURhhX1
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.cookie-tK2ONQ1o
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.depd-C51S9yJW
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.destroy-qlf2lv5l
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.http-errors-Za9l7C18
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.inherits-TuGh0LXN
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.mime-types-PeP4UgEO
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.mime-db-kRSHCEJi
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.ms-eKzAxOLx
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.negotiator-cgjfl5da
                        /opt/iobroker/node_modules/iobroker.web/node_modules/.on-finished-xF1T4SnU
                        Was müsste ich jetzt tun...?
                        Node Red läuft auch nicht da immer diesr Fehler kommt.
                        warn	node:internal/modules/cjs/loader:959 throw err; ^ Error: Cannot find module 'jsonfile/utils' Require stack: - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/node-red/red.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15) at Function.Module._load (node:internal/modules/cjs/loader:804:27) at Module.require (node:internal/modules/cjs/loader:1028:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js:3:23) at Module._compile (node:internal/modules/cjs/loader:1126:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) at Module.load (node:internal/modules/cjs/loader:1004:32) at Function.Module._load (node:internal/modules/cjs/loader:839:12) at Module.require (node:internal/modules/cjs/loader:1028:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/node-red/red.js' ] }
                        node-red.0
                        2022-10-03 21:21:29.034	info	node-red exited with 1
                        node-red.0
                        2022-10-03 21:21:29.030	warn	node:internal/modules/cjs/loader:959 throw err; ^ Error: Cannot find module 'jsonfile/utils' Require stack: - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js - /opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js - /opt/iobroker/node_modules/node-red/red.js at Function.Module._resolveFilename (node:internal/modules/cjs/loader:956:15) at Function.Module._load (node:internal/modules/cjs/loader:804:27) at Module.require (node:internal/modules/cjs/loader:1028:19) at require (node:internal/modules/cjs/helpers:102:18) at Object.<anonymous> (/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js:3:23) at Module._compile (node:internal/modules/cjs/loader:1126:14) at Object.Module._extensions..js (node:internal/modules/cjs/loader:1180:10) at Module.load (node:internal/modules/cjs/loader:1004:32) at Function.Module._load (node:internal/modules/cjs/loader:839:12) at Module.require (node:internal/modules/cjs/loader:1028:19) { code: 'MODULE_NOT_FOUND', requireStack: [ '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/output-json.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/json/index.js', '/opt/iobroker/node_modules/node-red/node_modules/fs-extra/lib/index.js', '/opt/iobroker/node_modules/node-red/red.js' ] }
                        • NWHN NWH
                          NPM 8.15.0
                          Node 16.17.1
                          node-red.0
                          node-red.0
                          Thomas BraunT
                          Thomas BraunT
                          #164
                          @nwh sagte in Untersuchung: code 25 fehlerlösung:
                          Dich als user und nicht als root einloggen.
                            NWHN
                            NWHN
                            NWH
                            #165
                            @thomas-braun ich mache das über die Konsole vom Docker auf der Synology.
                            Wüsste gar nicht wie das anders ginge.
                            • NWHN NWH
                              Thomas BraunT
                              Thomas BraunT
                              #166
                              @nwh
                              Bei Docker bin ich eh raus. Keinen Bock auf den Kram.
                                @nwh
                                NWHN
                                NWHN
                                NWH
                                #167
                                @thomas-braun na dann....
                                • NWHN NWH
                                  Thomas BraunT
                                  Thomas BraunT
                                  #168
                                  @nwh
                                  Lösch die Verzeichnisse.
                                    @nwh
                                    NWHN
                                    NWHN
                                    NWH
                                    #169
                                    @thomas-braun tjo das kann ich nicht, da ich mich damit nicht auskenne. Leider.
                                    Hilft es was wenn ich NodeRed lösche? in der IOB Oberfläche.
                                    • NWHN NWH
                                      Thomas BraunT
                                      Thomas BraunT
                                      #170
                                      @nwh
                                      Wir schauen jetzt erstmal etwas herum.
                                      cd /opt/iobroker/
                                      npm ls body-parser
                                        @nwh
                                        cd /opt/iobroker/
                                        npm ls body-parser
                                        NWHN
                                        NWHN
                                        NWH
                                        #171
                                        npm ls body-parser
                                        root@iobroker:/opt/iobroker# npm ls body-parser
                                        sudo: Hostname iobroker kann nicht aufgelöst werden: Zu diesem Hostnamen gehört keine Adresse
                                        iobroker.inst@2.0.3 /opt/iobroker
                                        ├─┬ iobroker.admin@6.2.22
                                        │ ├── body-parser@1.20.0
                                        │ └─┬ express@4.18.1
                                        │   └── body-parser@1.20.0 deduped
                                        ├─┬ iobroker.node-red@4.0.0 invalid: "3.3.1" from the root project
                                        │ └─┬ node-red@3.0.2
                                        │   ├─┬ @node-red/editor-api@3.0.2
                                        │   │ └── body-parser@1.20.0 deduped
                                        │   └─┬ @node-red/nodes@3.0.2
                                        └─┬ iobroker.web@4.3.0
                                        • NWHN NWH
                                          npm ls body-parser
                                          Thomas BraunT
                                          Thomas BraunT
                                          #172
                                          @nwh
                                          npm ls destroy
                                          83.9k
