  4. on -> scriptEnabled -> Error im log
javascript
19 Beiträge 3 Kommentatoren 565 Aufrufe 2 Beobachtet
  • bahnuhrB bahnuhr
    @glasfaser
    Guten Morgen.
    Beim Stop von Instanz kamen zahlreiche o.g. log Fehler.
    Bei Start von javascript Instanz kam dies:
    avascript.0
    2022-09-15 07:49:07.222	error	notice
    javascript.0
    2022-09-15 07:49:07.221	error	npm notice npm notice New minor version of npm available! 8.15.0 -> 8.19.2 npm notice Changelog: <https://github.com/npm/cli/releases/tag/v8.19.2> npm notice Run `npm install -g npm@8.19.2` to update! npm
    javascript.0
    2022-09-15 07:49:07.218	info	found 0 vulnerabilities
    javascript.0
    2022-09-15 07:49:07.216	info	16 packages are looking for funding run `npm fund` for details
    javascript.0
    2022-09-15 07:49:07.210	info	added 234 packages, changed 1 package, and audited 236 packages in 36s
    javascript.0
    2022-09-15 07:48:44.190	error	npm WARN deprecated request@2.88.2: request has been deprecated, see https://github.com/request/request/issues/3142
    javascript.0
    2022-09-15 07:48:43.600	error	WARN deprecated uuid@3.4.0: Please upgrade to version 7 or higher. Older versions may use Math.random() in certain circumstances, which is known to be problematic. See https://v8.dev/blog/math-random for details.
    javascript.0
    2022-09-15 07:48:43.597	error	npm
    javascript.0
    2022-09-15 07:48:42.763	error	WARN deprecated node-inspect@2.0.0: This module is part of Node.js core and does not need to be installed separately. It is now unmaintained.
    javascript.0
    2022-09-15 07:48:42.758	error
    javascript.0
    2022-09-15 07:48:42.753	error	npm
    javascript.0
    2022-09-15 07:48:41.953	error	WARN deprecated har-validator@5.1.5: this library is no longer supported
    javascript.0
    2022-09-15 07:48:41.950	error	npm
    Nachdem alles geladen war die o.g. Script ausprobiert:
    Also Script beendet, im log kommt:
    javascript.0
    2022-09-15 07:51:36.951	info	script.js.Scripte.test9: hier
    javascript.0
    2022-09-15 07:51:36.922	error	Error by canceling scheduled job "<Anonymous Job 79 2022-09-15T05:50:00.155Z>"
    javascript.0
    2022-09-15 07:51:36.922	error	Error by canceling scheduled job "<Anonymous Job 78 2022-09-15T05:50:00.154Z>"
    javascript.0
    2022-09-15 07:51:36.918	info	Stop script script.js.Scripte.Sonstige.Yamaha
    Script gestartet:
    javascript.0
    2022-09-15 07:52:14.191	info	script.js.Scripte.Sonstige.Yamaha: registered 6 subscriptions, 2 schedules, 0 messages, 0 logs and 0 file subscriptions
    javascript.0
    2022-09-15 07:52:14.160	info	Start javascript script.js.Scripte.Sonstige.Yamaha
    javascript.0
    2022-09-15 07:52:14.032	info	script.js.Scripte.test9: hier
    Fazit : Fehler ist noch da.
    Wie gesagt, früher lief dies.
    Ist seit einem der letzten Updates so.
    Bin überall auf stable.
    GlasfaserG Offline
    GlasfaserG Offline
    @bahnuhr sagte in on -> scriptEnabled -> Error im log:
    2022-09-15 07:49:07.221 error npm notice npm notice New minor version of npm available! 8.15.0 -> 8.19.2 npm notice Changelog: https://github.com/npm/cli/releases/tag/v8.19.2 npm notice Run npm install -g npm@8.19.2 to update! npm
    Und hier die Finger von lassen , nicht machen !!!
    • GlasfaserG Glasfaser
      bahnuhrB Online
      bahnuhrB Online
      bahnuhr
      @glasfaser sagte in on -> scriptEnabled -> Error im log:
      ok
      Danke.
        Warum hat der mir das issue eingefügt ?
        Kam automatisch.
        Du hast einige Module im JS eingetragen , die nicht mehr richtig laufen ..
        Zu schedule :
        Suche mal im JS bei der Lupe/Suchfunktion alle Skripte mit "schedule" und schalte die aus ,
        bzw. eventuell alle Scripte ausschalten
        und nur mit deimem Test Skript etwas ausführen .
        bahnuhrB Online
        bahnuhrB Online
        bahnuhr
        @glasfaser
        Bei jedem Script was ich ausschalte kommt:
        Vielleicht wäre es ja auch ne Idee den javascript instanz neu zu installieren, was meinst du ?
        Danke.
          Kam automatisch.
          Zu schedule :
          GlasfaserG Offline
          GlasfaserG Offline
          Zu schedule :
          Mein Hintergrund dazu war , eventuell läuft da ein Ghost Script mit einem Schedule.
          Deshalb die Suche nach den Schedule Skripte .
          Also alle Skripte aus , dann die JS instanz neustarten , dann deine Testskript nur starten ,
          was ist dann !?
          Erstmal nur eine Fehlersuche würde ich sagen ... wie oben angegeben !
          PS: Hast du auch mal dein System , mal neu gestartet !?
            Zu schedule :
            was ist dann !?
            bahnuhrB Online
            bahnuhrB Online
            bahnuhr
            mach ich
            Danke.
            • bahnuhrB bahnuhr
              mach ich
              GlasfaserG Offline
              GlasfaserG Offline
              @bahnuhr
              Ich habe hier noch etwas gefunden ...
              Eventuell ein zusammenhang !?
              https://github.com/ioBroker/ioBroker.javascript/issues/1102
                @bahnuhr
                bahnuhrB Online
                bahnuhrB Online
                bahnuhr
                Ja, sieht vergleichbar aus.
                Das riecht nach einem neuen bug !?
                Danke.
                • bahnuhrB Online
                  bahnuhrB Online
                  bahnuhr
                  alle scripte aus.
                  Dann proxmox komplett mit iob vm neu gestartet.
                  Als alles wieder da war; nur die beiden Scripte (Test9 und Yamaha) aktiviert .
                  kein Fehler bei script an.
                  Und dann Script aus.
                  Und siehe da; -> auch kein Fehler ! Yuhuu!
                  Also offenstichtlich doch kein bug
                  Fazit:
                  Habe wieder alle Scripte laufen.
                  @Glasfaser
                  Danke dir für den Austausch.
                  Danke.
                  • bahnuhrB bahnuhr
                    alle scripte aus.
                    Fazit:
                    @Glasfaser
                    GlasfaserG Offline
                    GlasfaserG Offline
                    Ich würde es trotzdem beobachten .
                    Deshalb meine Vermutung ein Ghost Skript / Schedule.
                    Hast du denn jetzt mal überprüft und deine Skripte danach durchsucht !?
                      bahnuhrB Online
                      bahnuhrB Online
                      bahnuhr
                      Ja hab ich.
                      Hatte alle deaktiviert und dann immer 10-20 aktiviert.
                      Script laufen lassen. keine Fehler.
                      Und dann wieder 10-20 aktiviert, Scirpt laufen lassen. Bis ich fertig war.
                      Nun sind alle aktiviert und log zeigt keine Fehler beim laufen lassen des Scriptes.
                      Keine Ahnung wo dies auf einmal herkam.
                      Danke.
                      • bahnuhrB bahnuhr
                        Ja hab ich.
                        GlasfaserG Offline
                        GlasfaserG Offline
                        Ja ... auch OK.
                        Aber ich meinte ...
                        eventuell in einen Script ein schedule der nicht richtig erstellt wurde , was dir so nicht erstmal auffällt .
                        Deshalb sollteste du in der JS Suchfunktion alle Scripte mit "schedule" Anzeigen lassen/durchsuchen.
                        Aber wenn es jetzt wieder geht , dann ist es ja gut.
