  3. Off Topic
  4. Grafana
  5. Grafana Installation - Fehler grafana-rpi:armhf
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 5 Kommentatoren 12.2k Aufrufe 4 Beobachtet
  • H heli-wolf
    @djmarc75
    Doch hatte ich schon ausgeführt.
    iobroker@iobroker:~ $ sudo apt upgrade
    Reading package lists... Done
    Calculating upgrade... Done
    The following packages will be upgraded:
      base-files curl dpkg dpkg-dev libcurl3-gnutls libcurl4 libdpkg-perl
      libpam-systemd libsystemd0 publicsuffix raspi-config systemd systemd-sysv
      systemd-timesyncd
    14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
    Need to get 12.5 MB of archives.
    After this operation, 5,120 B disk space will be freed.
    Do you want to continue? [Y/n] y
    Get:1 http://deb.debian.org/debian bullseye/main arm64 base-files arm64 11.1+deb11u5 [70.1 kB]
    Get:2 http://deb.debian.org/debian bullseye/main arm64 dpkg arm64 1.20.12 [2,521 kB]
    Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-config all 20220907 [31.7 kB]
    Get:4 http://deb.debian.org/debian bullseye/main arm64 systemd-sysv arm64 247.3-7+deb11u1 [113 kB]
    Get:5 http://deb.debian.org/debian bullseye/main arm64 libpam-systemd arm64 247.3-7+deb11u1 [274 kB]
    Get:6 http://deb.debian.org/debian bullseye/main arm64 systemd-timesyncd arm64 247.3-7+deb11u1 [130 kB]
    Get:7 http://deb.debian.org/debian bullseye/main arm64 systemd arm64 247.3-7+deb11u1 [4,153 kB]
    Get:8 http://deb.debian.org/debian bullseye/main arm64 libsystemd0 arm64 247.3-7+deb11u1 [354 kB]
    Get:9 http://deb.debian.org/debian bullseye/main arm64 curl arm64 7.74.0-1.3+deb11u3 [264 kB]
    Get:10 http://deb.debian.org/debian bullseye/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u3 [324 kB]
    Get:11 http://deb.debian.org/debian bullseye/main arm64 dpkg-dev all 1.20.12 [2,312 kB]
    Get:12 http://deb.debian.org/debian bullseye/main arm64 libdpkg-perl all 1.20.12 [1,551 kB]
    Get:13 http://deb.debian.org/debian bullseye/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u3 [321 kB]
    Get:14 http://deb.debian.org/debian bullseye/main arm64 publicsuffix all 20220811.1734-0+deb11u1 [127 kB]
    Fetched 12.5 MB in 5s (2,691 kB/s)
    Reading changelogs... Done
    (Reading database ... 54954 files and directories currently installed.)
    Preparing to unpack .../base-files_11.1+deb11u5_arm64.deb ...
    Unpacking base-files (11.1+deb11u5) over (11.1+deb11u4) ...
    Setting up base-files (11.1+deb11u5) ...
    Installing new version of config file /etc/debian_version ...
    Preparing to unpack .../dpkg_1.20.12_arm64.deb ...
    Unpacking dpkg (1.20.12) over (1.20.11) ...
    Setting up dpkg (1.20.12) ...
    Preparing to unpack .../systemd-sysv_247.3-7+deb11u1_arm64.deb ...
    Unpacking systemd-sysv (247.3-7+deb11u1) over (247.3-7) ...
    Preparing to unpack .../libpam-systemd_247.3-7+deb11u1_arm64.deb ...
    Unpacking libpam-systemd:arm64 (247.3-7+deb11u1) over (247.3-7) ...
    Preparing to unpack .../systemd-timesyncd_247.3-7+deb11u1_arm64.deb ...
    Unpacking systemd-timesyncd (247.3-7+deb11u1) over (247.3-7) ...
    Preparing to unpack .../systemd_247.3-7+deb11u1_arm64.deb ...
    Unpacking systemd (247.3-7+deb11u1) over (247.3-7) ...
    Preparing to unpack .../libsystemd0_247.3-7+deb11u1_arm64.deb ...
    Unpacking libsystemd0:arm64 (247.3-7+deb11u1) over (247.3-7) ...
    Setting up libsystemd0:arm64 (247.3-7+deb11u1) ...
    Preparing to unpack .../0-curl_7.74.0-1.3+deb11u3_arm64.deb ...
    Unpacking curl (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
    Preparing to unpack .../1-libcurl4_7.74.0-1.3+deb11u3_arm64.deb ...
    Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
    Preparing to unpack .../2-dpkg-dev_1.20.12_all.deb ...
    Unpacking dpkg-dev (1.20.12) over (1.20.11) ...
    Preparing to unpack .../3-libdpkg-perl_1.20.12_all.deb ...
    Unpacking libdpkg-perl (1.20.12) over (1.20.11) ...
    Preparing to unpack .../4-libcurl3-gnutls_7.74.0-1.3+deb11u3_arm64.deb ...
    Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
    Preparing to unpack .../5-publicsuffix_20220811.1734-0+deb11u1_all.deb ...
    Unpacking publicsuffix (20220811.1734-0+deb11u1) over (20211207.1025-0+deb11u1) ...
    Preparing to unpack .../6-raspi-config_20220907_all.deb ...
    Unpacking raspi-config (20220907) over (20220901) ...
    Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) ...
    Setting up systemd (247.3-7+deb11u1) ...
    Setting up systemd-timesyncd (247.3-7+deb11u1) ...
    Setting up libdpkg-perl (1.20.12) ...
    Setting up libcurl4:arm64 (7.74.0-1.3+deb11u3) ...
    Setting up curl (7.74.0-1.3+deb11u3) ...
    Setting up raspi-config (20220907) ...
    Setting up publicsuffix (20220811.1734-0+deb11u1) ...
    Setting up systemd-sysv (247.3-7+deb11u1) ...
    Setting up dpkg-dev (1.20.12) ...
    Setting up libpam-systemd:arm64 (247.3-7+deb11u1) ...
    Processing triggers for man-db (2.9.4-2) ...
    Processing triggers for dbus (1.12.20-2) ...
    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
    DJMarc75D Offline
    DJMarc75D Offline
    DJMarc75
    @heli-wolf nochmal:
    uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
    Lehrling seit 1975 !!!
    H 1 Antwort Letzte Antwort
    • DJMarc75D DJMarc75
      @heli-wolf nochmal:
      heli-wolf
      @djmarc75 said in Grafana Installation - Fehler grafana-rpi:armhf:
      iobroker@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
      iobroker@iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
      aarch64
      /usr/bin/nodejs
      /usr/bin/node
      /usr/bin/npm
      v16.17.0
      v16.17.0
      8.15.0
      4.0.23
      iobroker
      iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
      /home/iobroker
      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
      Hit:2 http://deb.debian.org/debian bullseye InRelease
      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
      Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
      Hit:6 https://packages.grafana.com/oss/deb stable InRelease
      Hit:7 https://repos.influxdata.com/debian bullseye InRelease
      All packages are up to date.
      W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
      W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
      nodejs:
        Installed: 16.17.0-deb-1nodesource1
        Candidate: 16.17.0-deb-1nodesource1
        Version table:
       *** 16.17.0-deb-1nodesource1 500
              500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
           12.22.12~dfsg-1~deb11u1 500
              500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
           12.22.5~dfsg-2~11u1 500
              500 http://deb.debian.org/debian bullseye/main arm64 Packages
      • DJMarc75D Offline
        DJMarc75D Offline
        DJMarc75
        @heli-wolf
        puh, da weiss ich auch nicht weiter.
        Vielleicht kann da mal @thomas-braun drauf schauen wenn er Zeit und Muße hat.
          @heli-wolf
          heli-wolf
          @djmarc75
          wie kann ich eine Datei umbenennen bzw. Löschen.
          mit dem Befehl
          rm grafana_9.1.4_arm64.deb
          lässt er es nicht zu.
          ebenfalls funktioniert das Umbenennen mit MV auch nicht.
          • H heli-wolf
            @djmarc75
            mit dem Befehl
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
            Was hast Du da vor ??
              heli-wolf
              @djmarc75
              ich habe jetzt die Grafanainstallation entfernt und neu installiert und dabei die richtigen Dateien installiert.
              aber leider hat er die alte Version der grafana_9.1.4_arm64.deb noch im Archiv und das stößt bei der Installation auf Probleme.
              iobroker@iobroker:~ $ sudo apt install grafana
              The following NEW packages will be installed:
                grafana
              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
              Need to get 0 B/76.8 MB of archives.
              After this operation, 271 MB of additional disk space will be used.
              Preparing to unpack .../grafana_9.1.4_arm64.deb ...
              Unpacking grafana (9.1.4) ...
              dpkg: error processing archive /var/cache/apt/archives/grafana_9.1.4_arm64.deb (  --unpack):
               trying to overwrite '/usr/lib/systemd/system/grafana-server.service', which is                                       also in package grafana-rpi:armhf 9.1.4
              dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
              Errors were encountered while processing:
              E: Sub-process /usr/bin/dpkg returned an error code (1)
              Jetzt wollte ich die besagte Datei löschen um so die Installation ohne Konflikt vornehmen zu können.
              • H heli-wolf
                @djmarc75
                  grafana
                ohne Konflikt
                da ist kein Konflikt
                da hast du wohl etwas am Paketmanager vorbei kaputt gespielt
                Broken pipe
                  ohne Konflikt
                  Broken pipe
                  heli-wolf
                  wie kann man den Rohrbruch beseitigen?
                  • H heli-wolf
                    keine Ahnung.
                    Aber vielleicht kann @thomas-braun da helfen, wenn er Zeit hat
                    • Thomas BraunT Online
                      Bin gerade am Handy. Schau später mit großem Monitor mal rein. Aber da sind falsche list-Dateien und falsche Pakete installiert, wenn ich das richtig sehe.
                        heli-wolf
                        Vielen Dank !!!
                        • H heli-wolf
                          @djmarc75
                            grafana
                          Wo kommt die denn her? Hast du die etwa am Paketmanager vorbei in das System geschraubt?
                          Die mehrfach vorhandenen Einträge/Zeilen in der
                          löschen.
                          Da sollte nur
                          deb [signed-by=/usr/share/keyrings/grafana.gpg] https://packages.grafana.com/oss/deb stable main
                          drin stehen.
                          Dann
                          sudo apt purge grafana-rpi
                          sudo apt update
                          apt policy grafana*
                            löschen.
                            Da sollte nur
                            drin stehen.
                            Dann
                            sudo apt update
                            apt policy grafana*
                            heli-wolf
                            @thomas-braun said in Grafana Installation - Fehler grafana-rpi:armhf:
                            apt policy grafana*
                            iobroker@iobroker:~ $ sudo apt purge grafana-rpi
                            The following packages were automatically installed and are no longer required:
                              libbrotli1:armhf libexpat1:armhf libfontconfig1:armhf libfreetype6:armhf
                              libpng16-16:armhf libuuid1:armhf zlib1g:armhf
                            Use 'sudo apt autoremove' to remove them.
                            The following packages will be REMOVED:
                              grafana-rpi:armhf*
                            0 upgraded, 0 newly installed, 1 to remove and 0 not upgraded.
                            After this operation, 258 MB disk space will be freed.
                            Removing grafana-rpi:armhf (9.1.4) ...
                            (Reading database ... 47955 files and directories currently installed.)
                            Purging configuration files for grafana-rpi:armhf (9.1.4) ...
                            dpkg: warning: while removing grafana-rpi:armhf, directory '/etc/grafana' not empty so not removed
                            dpkg: warning: while removing grafana-rpi:armhf, directory '/usr/lib/systemd/system' not empty so not removed
                            iobroker@iobroker:~ $ sudo apt update
                            Hit:1 http://deb.debian.org/debian bullseye InRelease
                            Hit:2 http://security.debian.org/debian-security bullseye-security InRelease
                            Hit:3 http://archive.raspberrypi.org/debian bullseye InRelease
                            Hit:4 http://deb.debian.org/debian bullseye-updates InRelease
                            Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                            Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                            iobroker@iobroker:~ $ apt policy grafana*
                            N: Unable to locate package grafana_9.1.4_armhf.deb
                            N: Unable to locate package grafana-rpi_7.5.0_armhf.deb
                            N: Unable to locate package grafana-rpi_9.1.4_armhf.deb
                            sollten die Fehler jetzt behoben sein?
                            kann ich die Installation mit
                            jetzt wieder starten?
                            • H heli-wolf
                              apt policy grafana*
                                grafana-rpi:armhf*
                              heli-wolf
                              @heli-wolf
                              löschen.
                              Wie lösche ich diese Dateien.
                              Über Filezilla habe ich keine Berechtigung Dateien zu löschen.
                              • H heli-wolf
                                apt policy grafana*
                                  grafana-rpi:armhf*
                                Nein, da hast du ganz schon rumgeaast...
                                Da ist einiges schief.
                                löschen.
                                Da sollte nur
                                drin stehen.
                                • H heli-wolf
                                  @heli-wolf
                                  löschen.
                                  Nicht die Datei löschen, die doppelten Zeilen darin.
                                  Geht mit einem Editor, nano z. B.
                                  sudo nano /etc/apt/sources.list.d/grafana.list
                                    heli-wolf
                                    Die Grafana.list habe ich mit einem Editor angesehen und sieht folgend aus:
                                    deb https://packages.grafana.com/oss/deb stable main
                                    2 davon habe ich gelöscht.
                                    • H heli-wolf
                                      @heli-wolf
                                      sudo apt update
                                        @heli-wolf
                                        sudo apt update
                                        heli-wolf
                                        sudo apt update
                                        Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                                        Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                                        • H heli-wolf
                                          sudo apt update
                                          @heli-wolf
                                          apt policy grafana*
