  3. Off Topic
  4. Grafana
  5. Grafana Installation - Fehler grafana-rpi:armhf
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 5 Kommentatoren 12.2k Aufrufe 4 Beobachtet
    @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
    bringt aber wieder einen Fehler.
    versuch es mal wie alle apt Befehle mit sudo davor
    heli-wolf
    Vielen Dank, jetzt hat er zumindest die Installation fortgeführt.
    iobroker@iobroker:~ $ sudo apt install grafana
    Reading package lists... Done
    The following NEW packages will be installed:
      grafana
    0 upgraded, 1 newly installed, 0 to remove and 14 not upgraded.
    Need to get 76.8 MB of archives.
    After this operation, 271 MB of additional disk space will be used.
    Get:1 https://packages.grafana.com/oss/deb stable/main arm64 grafana arm64 9.1.4 [76.8 MB]
    Fetched 76.8 MB in 29s (2,660 kB/s)
    Selecting previously unselected package grafana.
    (Reading database ... 54954 files and directories currently installed.)
    Preparing to unpack .../grafana_9.1.4_arm64.deb ...
    Unpacking grafana (9.1.4) ...
    dpkg: error processing archive /var/cache/apt/archives/grafana_9.1.4_arm64.deb (--unpack):
     trying to overwrite '/usr/lib/systemd/system/grafana-server.service', which is also in package grafana-rpi:armhf 9.1.4
    dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
    Errors were encountered while processing:
    E: Sub-process /usr/bin/dpkg returned an error code (1)
    iobroker@iobroker:~ $ sudo /bin/systemctl enable grafana-server
    [sudo] password for iobroker:
    Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
    Executing: /lib/systemd/systemd-sysv-install enable grafana-server
    Created symlink /etc/systemd/system/multi-user.target.wants/grafana-server.service → /lib/systemd/system/grafana-server.service.
    iobroker@iobroker:~ $ sudo /bin/systemctl start grafana-server
    Aber in den folgenden Zeilen besteht ein weiteres Problem:
    • H heli-wolf
        grafana
      @heli-wolf ich hab das mal nach OffTopic verschoben.
      Grafana ist kein Bestandteil von ioBroker.
      ich denke du hast einen Pi?
      was willst du dann mit einem 64Bit PC paket?
      H 1 Antwort Letzte Antwort
        heli-wolf
        @homoran said in Grafana Installation - Fehler grafana-rpi:armhf:
        Bearbeiten
        das habe ich nicht ausgewählt.
        Wie kann ich das ändern?
        HomoranH DJMarc75D 2 Antworten Letzte Antwort
        • H heli-wolf
          Bearbeiten
          @heli-wolf sorry, mein Fehler!
          arm ist nicht amd :-(
          alles gut
          ab hier jann ich nicht mehr helfen, nutze Grafana nicht
          • H heli-wolf
            Bearbeiten
            DJMarc75D Offline
            DJMarc75D Offline
            DJMarc75
            @heli-wolf
            Wie bist Du denn da prinzipiell am Start ?
            uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
            Lehrling seit 1975 !!!
            • DJMarc75D DJMarc75
              @heli-wolf
              heli-wolf
              @djmarc75 said in Grafana Installation - Fehler grafana-rpi:armhf:
              iobroker@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
              iobroker@iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              aarch64
              /usr/bin/nodejs
              /usr/bin/node
              /usr/bin/npm
              v16.17.0
              v16.17.0
              8.15.0
              4.0.23
              iobroker
              iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
              /home/iobroker
              Hit:1 http://deb.debian.org/debian bullseye InRelease
              Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
              Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
              Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
              Hit:5 https://packages.grafana.com/oss/deb stable InRelease
              Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
              Hit:7 https://repos.influxdata.com/debian bullseye InRelease
              14 packages can be upgraded. Run 'apt list --upgradable' to see them.
              W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
              W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
              W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
              W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
              W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
              W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
              W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
              W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
              W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
              W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
              nodejs:
                Installed: 16.17.0-deb-1nodesource1
                Candidate: 16.17.0-deb-1nodesource1
                Version table:
               *** 16.17.0-deb-1nodesource1 500
                      500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                   12.22.12~dfsg-1~deb11u1 500
                      500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                   12.22.5~dfsg-2~11u1 500
                      500 http://deb.debian.org/debian bullseye/main arm64 Packages
              • H heli-wolf
                aarch64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.17.0
                v16.17.0
                8.15.0
                4.0.23
                iobroker
                /home/iobroker
                nodejs:
                  Version table:
                DJMarc75D Offline
                DJMarc75D Offline
                DJMarc75
                und immernoch nicht
                sudo apt upgrade
                ausgeführt
                  und immernoch nicht
                  sudo apt upgrade
                  ausgeführt
                  heli-wolf
                  @djmarc75
                  Doch hatte ich schon ausgeführt.
                  iobroker@iobroker:~ $ sudo apt upgrade
                  Calculating upgrade... Done
                  The following packages will be upgraded:
                    base-files curl dpkg dpkg-dev libcurl3-gnutls libcurl4 libdpkg-perl
                    libpam-systemd libsystemd0 publicsuffix raspi-config systemd systemd-sysv
                    systemd-timesyncd
                  14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                  Need to get 12.5 MB of archives.
                  After this operation, 5,120 B disk space will be freed.
                  Do you want to continue? [Y/n] y
                  Get:1 http://deb.debian.org/debian bullseye/main arm64 base-files arm64 11.1+deb11u5 [70.1 kB]
                  Get:2 http://deb.debian.org/debian bullseye/main arm64 dpkg arm64 1.20.12 [2,521 kB]
                  Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-config all 20220907 [31.7 kB]
                  Get:4 http://deb.debian.org/debian bullseye/main arm64 systemd-sysv arm64 247.3-7+deb11u1 [113 kB]
                  Get:5 http://deb.debian.org/debian bullseye/main arm64 libpam-systemd arm64 247.3-7+deb11u1 [274 kB]
                  Get:6 http://deb.debian.org/debian bullseye/main arm64 systemd-timesyncd arm64 247.3-7+deb11u1 [130 kB]
                  Get:7 http://deb.debian.org/debian bullseye/main arm64 systemd arm64 247.3-7+deb11u1 [4,153 kB]
                  Get:8 http://deb.debian.org/debian bullseye/main arm64 libsystemd0 arm64 247.3-7+deb11u1 [354 kB]
                  Get:9 http://deb.debian.org/debian bullseye/main arm64 curl arm64 7.74.0-1.3+deb11u3 [264 kB]
                  Get:10 http://deb.debian.org/debian bullseye/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u3 [324 kB]
                  Get:11 http://deb.debian.org/debian bullseye/main arm64 dpkg-dev all 1.20.12 [2,312 kB]
                  Get:12 http://deb.debian.org/debian bullseye/main arm64 libdpkg-perl all 1.20.12 [1,551 kB]
                  Get:13 http://deb.debian.org/debian bullseye/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u3 [321 kB]
                  Get:14 http://deb.debian.org/debian bullseye/main arm64 publicsuffix all 20220811.1734-0+deb11u1 [127 kB]
                  Fetched 12.5 MB in 5s (2,691 kB/s)
                  Reading changelogs... Done
                  Preparing to unpack .../base-files_11.1+deb11u5_arm64.deb ...
                  Unpacking base-files (11.1+deb11u5) over (11.1+deb11u4) ...
                  Setting up base-files (11.1+deb11u5) ...
                  Installing new version of config file /etc/debian_version ...
                  Preparing to unpack .../dpkg_1.20.12_arm64.deb ...
                  Unpacking dpkg (1.20.12) over (1.20.11) ...
                  Setting up dpkg (1.20.12) ...
                  Preparing to unpack .../systemd-sysv_247.3-7+deb11u1_arm64.deb ...
                  Unpacking systemd-sysv (247.3-7+deb11u1) over (247.3-7) ...
                  Preparing to unpack .../libpam-systemd_247.3-7+deb11u1_arm64.deb ...
                  Unpacking libpam-systemd:arm64 (247.3-7+deb11u1) over (247.3-7) ...
                  Preparing to unpack .../systemd-timesyncd_247.3-7+deb11u1_arm64.deb ...
                  Unpacking systemd-timesyncd (247.3-7+deb11u1) over (247.3-7) ...
                  Preparing to unpack .../systemd_247.3-7+deb11u1_arm64.deb ...
                  Unpacking systemd (247.3-7+deb11u1) over (247.3-7) ...
                  Preparing to unpack .../libsystemd0_247.3-7+deb11u1_arm64.deb ...
                  Unpacking libsystemd0:arm64 (247.3-7+deb11u1) over (247.3-7) ...
                  Setting up libsystemd0:arm64 (247.3-7+deb11u1) ...
                  Preparing to unpack .../0-curl_7.74.0-1.3+deb11u3_arm64.deb ...
                  Unpacking curl (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
                  Preparing to unpack .../1-libcurl4_7.74.0-1.3+deb11u3_arm64.deb ...
                  Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
                  Preparing to unpack .../2-dpkg-dev_1.20.12_all.deb ...
                  Unpacking dpkg-dev (1.20.12) over (1.20.11) ...
                  Preparing to unpack .../3-libdpkg-perl_1.20.12_all.deb ...
                  Unpacking libdpkg-perl (1.20.12) over (1.20.11) ...
                  Preparing to unpack .../4-libcurl3-gnutls_7.74.0-1.3+deb11u3_arm64.deb ...
                  Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
                  Preparing to unpack .../5-publicsuffix_20220811.1734-0+deb11u1_all.deb ...
                  Unpacking publicsuffix (20220811.1734-0+deb11u1) over (20211207.1025-0+deb11u1) ...
                  Preparing to unpack .../6-raspi-config_20220907_all.deb ...
                  Unpacking raspi-config (20220907) over (20220901) ...
                  Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) ...
                  Setting up systemd (247.3-7+deb11u1) ...
                  Setting up systemd-timesyncd (247.3-7+deb11u1) ...
                  Setting up libdpkg-perl (1.20.12) ...
                  Setting up libcurl4:arm64 (7.74.0-1.3+deb11u3) ...
                  Setting up curl (7.74.0-1.3+deb11u3) ...
                  Setting up raspi-config (20220907) ...
                  Setting up publicsuffix (20220811.1734-0+deb11u1) ...
                  Setting up systemd-sysv (247.3-7+deb11u1) ...
                  Setting up dpkg-dev (1.20.12) ...
                  Setting up libpam-systemd:arm64 (247.3-7+deb11u1) ...
                  Processing triggers for man-db (2.9.4-2) ...
                  Processing triggers for dbus (1.12.20-2) ...
                  Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
                  • H heli-wolf
                    @djmarc75
                      systemd-timesyncd
                    DJMarc75D Offline
                    DJMarc75D Offline
                    DJMarc75
                    @heli-wolf nochmal:
                      @heli-wolf nochmal:
                      heli-wolf
                      ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                      aarch64
                      /usr/bin/nodejs
                      /usr/bin/node
                      /usr/bin/npm
                      v16.17.0
                      v16.17.0
                      8.15.0
                      4.0.23
                      iobroker
                      /home/iobroker
                      Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                      Hit:2 http://deb.debian.org/debian bullseye InRelease
                      Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                      Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                      Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                      All packages are up to date.
                      nodejs:
                        Version table:
                      • DJMarc75D Offline
                        DJMarc75D Offline
                        DJMarc75
                        @heli-wolf
                        puh, da weiss ich auch nicht weiter.
                        Vielleicht kann da mal @thomas-braun drauf schauen wenn er Zeit und Muße hat.
                          @heli-wolf
                          heli-wolf
                          @djmarc75
                          wie kann ich eine Datei umbenennen bzw. Löschen.
                          mit dem Befehl
                          rm grafana_9.1.4_arm64.deb
                          lässt er es nicht zu.
                          ebenfalls funktioniert das Umbenennen mit MV auch nicht.
                          • H heli-wolf
                            @djmarc75
                            mit dem Befehl
                            DJMarc75D Offline
                            DJMarc75D Offline
                            DJMarc75
                            Was hast Du da vor ??
                              heli-wolf
                              @djmarc75
                              ich habe jetzt die Grafanainstallation entfernt und neu installiert und dabei die richtigen Dateien installiert.
                              aber leider hat er die alte Version der grafana_9.1.4_arm64.deb noch im Archiv und das stößt bei der Installation auf Probleme.
                                grafana
                              0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                              Need to get 0 B/76.8 MB of archives.
                              dpkg: error processing archive /var/cache/apt/archives/grafana_9.1.4_arm64.deb (  --unpack):
                              Jetzt wollte ich die besagte Datei löschen um so die Installation ohne Konflikt vornehmen zu können.
                              • H heli-wolf
                                @djmarc75
                                  grafana
                                ohne Konflikt
                                da ist kein Konflikt
                                da hast du wohl etwas am Paketmanager vorbei kaputt gespielt
                                Broken pipe
                                  ohne Konflikt
                                  Broken pipe
                                  heli-wolf
                                  wie kann man den Rohrbruch beseitigen?
                                  • H heli-wolf
                                    keine Ahnung.
                                    Aber vielleicht kann @thomas-braun da helfen, wenn er Zeit hat
                                    • Thomas BraunT Online
                                      Bin gerade am Handy. Schau später mit großem Monitor mal rein. Aber da sind falsche list-Dateien und falsche Pakete installiert, wenn ich das richtig sehe.
                                        heli-wolf
                                        Vielen Dank !!!
                                        • H heli-wolf
                                          @djmarc75
                                            grafana
                                          Wo kommt die denn her? Hast du die etwa am Paketmanager vorbei in das System geschraubt?
                                          Die mehrfach vorhandenen Einträge/Zeilen in der
                                          löschen.
                                          Da sollte nur
                                          deb [signed-by=/usr/share/keyrings/grafana.gpg] https://packages.grafana.com/oss/deb stable main
                                          drin stehen.
                                          Dann
                                          sudo apt purge grafana-rpi
                                          sudo apt update
                                          apt policy grafana*
