  3. Off Topic
  4. Grafana
  5. Grafana Installation - Fehler grafana-rpi:armhf
    6.8k
Geplant Angeheftet Gesperrt Verschoben Grafana
91 Beiträge 5 Kommentatoren 12.2k Aufrufe 4 Beobachtet
  • H heli-wolf
    Sorry, dachte nicht das ich nur diesen Befehl eingeben muss.
    iobroker@iobroker:~ $ apt --fix-broken install
    E: Could not open lock file /var/lib/dpkg/lock-frontend - open (13: Permission denied)
    E: Unable to acquire the dpkg frontend lock (/var/lib/dpkg/lock-frontend), are you root?
    bringt aber wieder einen Fehler.
    @heli-wolf sagte in Grafana Installation - Fehler grafana-rpi:armhf:
    versuch es mal wie alle apt Befehle mit sudo davor
    H 1 Antwort Letzte Antwort
      heli-wolf
      Vielen Dank, jetzt hat er zumindest die Installation fortgeführt.
      iobroker@iobroker:~ $ sudo apt install grafana
      Reading package lists... Done
      The following NEW packages will be installed:
        grafana
      0 upgraded, 1 newly installed, 0 to remove and 14 not upgraded.
      Need to get 76.8 MB of archives.
      After this operation, 271 MB of additional disk space will be used.
      Get:1 https://packages.grafana.com/oss/deb stable/main arm64 grafana arm64 9.1.4 [76.8 MB]
      Fetched 76.8 MB in 29s (2,660 kB/s)
      Selecting previously unselected package grafana.
      (Reading database ... 54954 files and directories currently installed.)
      Preparing to unpack .../grafana_9.1.4_arm64.deb ...
      Unpacking grafana (9.1.4) ...
      dpkg: error processing archive /var/cache/apt/archives/grafana_9.1.4_arm64.deb (--unpack):
       trying to overwrite '/usr/lib/systemd/system/grafana-server.service', which is also in package grafana-rpi:armhf 9.1.4
      dpkg-deb: error: paste subprocess was killed by signal (Broken pipe)
      Errors were encountered while processing:
      E: Sub-process /usr/bin/dpkg returned an error code (1)
      iobroker@iobroker:~ $ sudo /bin/systemctl enable grafana-server
      [sudo] password for iobroker:
      Synchronizing state of grafana-server.service with SysV service script with /lib/systemd/systemd-sysv-install.
      Executing: /lib/systemd/systemd-sysv-install enable grafana-server
      Created symlink /etc/systemd/system/multi-user.target.wants/grafana-server.service → /lib/systemd/system/grafana-server.service.
      iobroker@iobroker:~ $ sudo /bin/systemctl start grafana-server
      Aber in den folgenden Zeilen besteht ein weiteres Problem:
      • H heli-wolf
          grafana
        @heli-wolf ich hab das mal nach OffTopic verschoben.
        Grafana ist kein Bestandteil von ioBroker.
        ich denke du hast einen Pi?
        was willst du dann mit einem 64Bit PC paket?
          heli-wolf
          @homoran said in Grafana Installation - Fehler grafana-rpi:armhf:
          Bearbeiten
          das habe ich nicht ausgewählt.
          Wie kann ich das ändern?
          HomoranH DJMarc75D 2 Antworten Letzte Antwort
          • H heli-wolf
            Bearbeiten
            @heli-wolf sorry, mein Fehler!
            arm ist nicht amd :-(
            alles gut
            ab hier jann ich nicht mehr helfen, nutze Grafana nicht
            • H heli-wolf
              Bearbeiten
              DJMarc75D Offline
              DJMarc75D Offline
              DJMarc75
              @heli-wolf
              Wie bist Du denn da prinzipiell am Start ?
              uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
              Lehrling seit 1975 !!!
              • DJMarc75D DJMarc75
                @heli-wolf
                heli-wolf
                @djmarc75 said in Grafana Installation - Fehler grafana-rpi:armhf:
                iobroker@iobroker:~ $ sudo ln -s /usr/bin/node /usr/bin/nodejs
                iobroker@iobroker:~ $ uname -m && type -P nodejs node npm && nodejs -v && node -v && npm -v && iob -v && whoami && groups && pwd && sudo apt update &> /dev/null && sudo apt update && apt policy nodejs
                aarch64
                /usr/bin/nodejs
                /usr/bin/node
                /usr/bin/npm
                v16.17.0
                v16.17.0
                8.15.0
                4.0.23
                iobroker
                iobroker adm tty dialout cdrom sudo audio video plugdev games users input render netdev bluetooth gpio i2c spi
                /home/iobroker
                Hit:1 http://deb.debian.org/debian bullseye InRelease
                Hit:2 http://deb.debian.org/debian bullseye-updates InRelease
                Hit:3 http://security.debian.org/debian-security bullseye-security InRelease
                Hit:4 http://archive.raspberrypi.org/debian bullseye InRelease
                Hit:5 https://packages.grafana.com/oss/deb stable InRelease
                Hit:6 https://deb.nodesource.com/node_16.x bullseye InRelease
                Hit:7 https://repos.influxdata.com/debian bullseye InRelease
                14 packages can be upgraded. Run 'apt list --upgradable' to see them.
                W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:2
                W: Target Packages (main/binary-arm64/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                W: Target Packages (main/binary-armhf/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                W: Target Packages (main/binary-all/Packages) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                W: Target Translations (main/i18n/Translation-en_GB) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                W: Target Translations (main/i18n/Translation-en) is configured multiple times in /etc/apt/sources.list.d/grafana.list:1 and /etc/apt/sources.list.d/grafana.list:3
                nodejs:
                  Installed: 16.17.0-deb-1nodesource1
                  Candidate: 16.17.0-deb-1nodesource1
                  Version table:
                 *** 16.17.0-deb-1nodesource1 500
                        500 https://deb.nodesource.com/node_16.x bullseye/main arm64 Packages
                     12.22.12~dfsg-1~deb11u1 500
                        500 http://security.debian.org/debian-security bullseye-security/main arm64 Packages
                     12.22.5~dfsg-2~11u1 500
                        500 http://deb.debian.org/debian bullseye/main arm64 Packages
                • H heli-wolf
                  aarch64
                  /usr/bin/nodejs
                  /usr/bin/node
                  /usr/bin/npm
                  v16.17.0
                  v16.17.0
                  8.15.0
                  4.0.23
                  iobroker
                  /home/iobroker
                  nodejs:
                    Version table:
                  DJMarc75D Offline
                  DJMarc75D Offline
                  DJMarc75
                  und immernoch nicht
                  sudo apt upgrade
                  ausgeführt
                    und immernoch nicht
                    sudo apt upgrade
                    ausgeführt
                    heli-wolf
                    @djmarc75
                    Doch hatte ich schon ausgeführt.
                    iobroker@iobroker:~ $ sudo apt upgrade
                    Calculating upgrade... Done
                    The following packages will be upgraded:
                      base-files curl dpkg dpkg-dev libcurl3-gnutls libcurl4 libdpkg-perl
                      libpam-systemd libsystemd0 publicsuffix raspi-config systemd systemd-sysv
                      systemd-timesyncd
                    14 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
                    Need to get 12.5 MB of archives.
                    After this operation, 5,120 B disk space will be freed.
                    Do you want to continue? [Y/n] y
                    Get:1 http://deb.debian.org/debian bullseye/main arm64 base-files arm64 11.1+deb11u5 [70.1 kB]
                    Get:2 http://deb.debian.org/debian bullseye/main arm64 dpkg arm64 1.20.12 [2,521 kB]
                    Get:3 http://archive.raspberrypi.org/debian bullseye/main arm64 raspi-config all 20220907 [31.7 kB]
                    Get:4 http://deb.debian.org/debian bullseye/main arm64 systemd-sysv arm64 247.3-7+deb11u1 [113 kB]
                    Get:5 http://deb.debian.org/debian bullseye/main arm64 libpam-systemd arm64 247.3-7+deb11u1 [274 kB]
                    Get:6 http://deb.debian.org/debian bullseye/main arm64 systemd-timesyncd arm64 247.3-7+deb11u1 [130 kB]
                    Get:7 http://deb.debian.org/debian bullseye/main arm64 systemd arm64 247.3-7+deb11u1 [4,153 kB]
                    Get:8 http://deb.debian.org/debian bullseye/main arm64 libsystemd0 arm64 247.3-7+deb11u1 [354 kB]
                    Get:9 http://deb.debian.org/debian bullseye/main arm64 curl arm64 7.74.0-1.3+deb11u3 [264 kB]
                    Get:10 http://deb.debian.org/debian bullseye/main arm64 libcurl4 arm64 7.74.0-1.3+deb11u3 [324 kB]
                    Get:11 http://deb.debian.org/debian bullseye/main arm64 dpkg-dev all 1.20.12 [2,312 kB]
                    Get:12 http://deb.debian.org/debian bullseye/main arm64 libdpkg-perl all 1.20.12 [1,551 kB]
                    Get:13 http://deb.debian.org/debian bullseye/main arm64 libcurl3-gnutls arm64 7.74.0-1.3+deb11u3 [321 kB]
                    Get:14 http://deb.debian.org/debian bullseye/main arm64 publicsuffix all 20220811.1734-0+deb11u1 [127 kB]
                    Fetched 12.5 MB in 5s (2,691 kB/s)
                    Reading changelogs... Done
                    Preparing to unpack .../base-files_11.1+deb11u5_arm64.deb ...
                    Unpacking base-files (11.1+deb11u5) over (11.1+deb11u4) ...
                    Setting up base-files (11.1+deb11u5) ...
                    Installing new version of config file /etc/debian_version ...
                    Preparing to unpack .../dpkg_1.20.12_arm64.deb ...
                    Unpacking dpkg (1.20.12) over (1.20.11) ...
                    Setting up dpkg (1.20.12) ...
                    Preparing to unpack .../systemd-sysv_247.3-7+deb11u1_arm64.deb ...
                    Unpacking systemd-sysv (247.3-7+deb11u1) over (247.3-7) ...
                    Preparing to unpack .../libpam-systemd_247.3-7+deb11u1_arm64.deb ...
                    Unpacking libpam-systemd:arm64 (247.3-7+deb11u1) over (247.3-7) ...
                    Preparing to unpack .../systemd-timesyncd_247.3-7+deb11u1_arm64.deb ...
                    Unpacking systemd-timesyncd (247.3-7+deb11u1) over (247.3-7) ...
                    Preparing to unpack .../systemd_247.3-7+deb11u1_arm64.deb ...
                    Unpacking systemd (247.3-7+deb11u1) over (247.3-7) ...
                    Preparing to unpack .../libsystemd0_247.3-7+deb11u1_arm64.deb ...
                    Unpacking libsystemd0:arm64 (247.3-7+deb11u1) over (247.3-7) ...
                    Setting up libsystemd0:arm64 (247.3-7+deb11u1) ...
                    Preparing to unpack .../0-curl_7.74.0-1.3+deb11u3_arm64.deb ...
                    Unpacking curl (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
                    Preparing to unpack .../1-libcurl4_7.74.0-1.3+deb11u3_arm64.deb ...
                    Unpacking libcurl4:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
                    Preparing to unpack .../2-dpkg-dev_1.20.12_all.deb ...
                    Unpacking dpkg-dev (1.20.12) over (1.20.11) ...
                    Preparing to unpack .../3-libdpkg-perl_1.20.12_all.deb ...
                    Unpacking libdpkg-perl (1.20.12) over (1.20.11) ...
                    Preparing to unpack .../4-libcurl3-gnutls_7.74.0-1.3+deb11u3_arm64.deb ...
                    Unpacking libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) over (7.74.0-1.3+deb11u2) ...
                    Preparing to unpack .../5-publicsuffix_20220811.1734-0+deb11u1_all.deb ...
                    Unpacking publicsuffix (20220811.1734-0+deb11u1) over (20211207.1025-0+deb11u1) ...
                    Preparing to unpack .../6-raspi-config_20220907_all.deb ...
                    Unpacking raspi-config (20220907) over (20220901) ...
                    Setting up libcurl3-gnutls:arm64 (7.74.0-1.3+deb11u3) ...
                    Setting up systemd (247.3-7+deb11u1) ...
                    Setting up systemd-timesyncd (247.3-7+deb11u1) ...
                    Setting up libdpkg-perl (1.20.12) ...
                    Setting up libcurl4:arm64 (7.74.0-1.3+deb11u3) ...
                    Setting up curl (7.74.0-1.3+deb11u3) ...
                    Setting up raspi-config (20220907) ...
                    Setting up publicsuffix (20220811.1734-0+deb11u1) ...
                    Setting up systemd-sysv (247.3-7+deb11u1) ...
                    Setting up dpkg-dev (1.20.12) ...
                    Setting up libpam-systemd:arm64 (247.3-7+deb11u1) ...
                    Processing triggers for man-db (2.9.4-2) ...
                    Processing triggers for dbus (1.12.20-2) ...
                    Processing triggers for libc-bin (2.31-13+rpt2+rpi1+deb11u4) ...
                    • H heli-wolf
                      @djmarc75
                        systemd-timesyncd
                      DJMarc75D Offline
                      DJMarc75D Offline
                      DJMarc75
                      @heli-wolf nochmal:
                        @heli-wolf nochmal:
                        heli-wolf
                        ln: failed to create symbolic link '/usr/bin/nodejs': File exists
                        aarch64
                        /usr/bin/nodejs
                        /usr/bin/node
                        /usr/bin/npm
                        v16.17.0
                        v16.17.0
                        8.15.0
                        4.0.23
                        iobroker
                        /home/iobroker
                        Hit:1 http://security.debian.org/debian-security bullseye-security InRelease
                        Hit:2 http://deb.debian.org/debian bullseye InRelease
                        Hit:3 http://deb.debian.org/debian bullseye-updates InRelease
                        Hit:5 https://deb.nodesource.com/node_16.x bullseye InRelease
                        Hit:6 https://packages.grafana.com/oss/deb stable InRelease
                        All packages are up to date.
                        nodejs:
                          Version table:
                        • DJMarc75D Offline
                          DJMarc75D Offline
                          DJMarc75
                          @heli-wolf
                          puh, da weiss ich auch nicht weiter.
                          Vielleicht kann da mal @thomas-braun drauf schauen wenn er Zeit und Muße hat.
                            @heli-wolf
                            heli-wolf
                            @djmarc75
                            wie kann ich eine Datei umbenennen bzw. Löschen.
                            mit dem Befehl
                            rm grafana_9.1.4_arm64.deb
                            lässt er es nicht zu.
                            ebenfalls funktioniert das Umbenennen mit MV auch nicht.
                            • H heli-wolf
                              @djmarc75
                              mit dem Befehl
                              DJMarc75D Offline
                              DJMarc75D Offline
                              DJMarc75
                              Was hast Du da vor ??
                                heli-wolf
                                @djmarc75
                                ich habe jetzt die Grafanainstallation entfernt und neu installiert und dabei die richtigen Dateien installiert.
                                aber leider hat er die alte Version der grafana_9.1.4_arm64.deb noch im Archiv und das stößt bei der Installation auf Probleme.
                                  grafana
                                0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
                                Need to get 0 B/76.8 MB of archives.
                                dpkg: error processing archive /var/cache/apt/archives/grafana_9.1.4_arm64.deb (  --unpack):
                                Jetzt wollte ich die besagte Datei löschen um so die Installation ohne Konflikt vornehmen zu können.
                                • H heli-wolf
                                  @djmarc75
                                    grafana
                                  ohne Konflikt
                                  da ist kein Konflikt
                                  da hast du wohl etwas am Paketmanager vorbei kaputt gespielt
                                  Broken pipe
                                    ohne Konflikt
                                    Broken pipe
                                    heli-wolf
                                    wie kann man den Rohrbruch beseitigen?
                                    • H heli-wolf
                                      keine Ahnung.
                                      Aber vielleicht kann @thomas-braun da helfen, wenn er Zeit hat
                                      • Thomas BraunT Online
                                        Bin gerade am Handy. Schau später mit großem Monitor mal rein. Aber da sind falsche list-Dateien und falsche Pakete installiert, wenn ich das richtig sehe.
                                          heli-wolf
                                          Vielen Dank !!!
