  4. Ich kann nichts mehr installieren / updaten
80 Beiträge 6 Kommentatoren 13.9k Aufrufe 5 Beobachtet
    @reindeer-web
    Hast du dein System auf Stand?
    Wenn es sauber ist:
    sudo apt update
    sudo apt install --reinstall nodejs
    reindeer-webR
    reindeer-webR
    reindeer-web
    #71
    Habe es ausgeführt und dies war die Ausgabe:
    root@iobroker:/opt/iobroker# sudo apt update
    Get:1 http://deb.debian.org/debian bullseye InRelease [116 kB]
    Get:2 http://security.debian.org/debian-security bullseye-security InRelease [48,4 kB]
    Get:3 http://deb.debian.org/debian bullseye-updates InRelease [44,1 kB]
    Get:4 https://deb.nodesource.com/node_16.x bullseye InRelease [4.586 B]
    Get:5 http://security.debian.org/debian-security bullseye-security/main amd64 Packages [180 kB]
    Get:6 http://deb.debian.org/debian bullseye/main amd64 Packages [8.182 kB]
    Get:7 https://deb.nodesource.com/node_16.x bullseye/main amd64 Packages [775 B]
    Get:8 http://deb.debian.org/debian bullseye-updates/main amd64 Packages [2.596 B]
    Fetched 8.578 kB in 5s (1.793 kB/s)
    Reading package lists... Done
    All packages are up to date.
    root@iobroker:/opt/iobroker# sudo apt install --reinstall nodejs
    0 upgraded, 0 newly installed, 1 reinstalled, 0 to remove and 0 not upgraded.
    Need to get 27,1 MB of archives.
    After this operation, 0 B of additional disk space will be used.
    Get:1 https://deb.nodesource.com/node_16.x bullseye/main amd64 nodejs amd64 16.17.0-deb-1nodesource1 [27,1 MB]
    Fetched 27,1 MB in 4s (6.749 kB/s)
    debconf: unable to initialize frontend: Dialog
    debconf: (No usable dialog-like program is installed, so the dialog based frontend cannot be used. at /usr/share/perl5/Debconf/FrontEnd/Dialog.pm line 78, <> line 1.)
    debconf: falling back to frontend: Readline
    (Reading database ... 30393 files and directories currently installed.)
    Preparing to unpack .../nodejs_16.17.0-deb-1nodesource1_amd64.deb ...
    Unpacking nodejs (16.17.0-deb-1nodesource1) over (16.17.0-deb-1nodesource1) ...
    Setting up nodejs (16.17.0-deb-1nodesource1) ...
    iobroker läuft jetzt wieder
    • reindeer-webR reindeer-web
      J
      J
      Jan1
      #72
      @reindeer-web
      warum kommt man eigentlich immer auf die Idee, wenn man schon als root user unterwegs ist, in sudo zu verwenden?
      • J Jan1
        @reindeer-web
        Thomas BraunT
        Thomas BraunT
        Most Active Developer
        #73
        @jan1
        Die Frage ist eher, warum man auf die Idee kommt unnötigerweise überhaupt mit dem root herumzuhampeln.
        Dann passieren so krumme Dinge wie hier gesehen nämlich nochmal so schnell.
        reindeer-webR 1 Antwort Letzte Antwort
          @jan1
          reindeer-webR
          reindeer-webR
          reindeer-web
          #74
          Wie gesagt, ich hatte mich über die console von portainer eingeloggt.
          Und wie kann ich mich z.B. mit putty und einem Benutzer einloggen?
          Bin mir im Unklaren wegen ip-Adresse, port usw.
            Thomas BraunT
            Thomas BraunT
            #75
            @reindeer-web sagte in Ich kann nichts mehr installieren / updaten:
            In dem man sich einen User anlegt und diesen verwendet. Müsste auch in Containern gehen. Ich setze die Kübel allerdings nicht ein.
            Mußte mal in die Anleitung schauen.
              reindeer-webR
              reindeer-webR
              reindeer-web
              #76
              Wobei ich jetzt immer noch vor dem anfänglichen Problem stehe, dass ich keinen Adapter mehr installieren kann und
              mit dem Befehl
              npm ls | grep -E 'github|ERR'
              ja viele 'extraneous' ausgegeben werden. Soll ich die mit
              cd /opt/iobroker && npm prune
              bereinigen?
              Thomas BraunT GlasfaserG 2 Antworten Letzte Antwort
                mit dem Befehl
                bereinigen?
                Thomas BraunT
                Thomas BraunT
                #77
                @reindeer-web
                Kannst du machen, das hört sich aber eher danach an:
                https://forum.iobroker.net/topic/57337/fehler-25-bei-adapter-install-update-mit-npm8
                  mit dem Befehl
                  bereinigen?
                  GlasfaserG
                  GlasfaserG
                  #78
                  Nimm das neue Image 7 , dann ein Backup fertig ,!
                  -----                             Docker-Image                             -----
                  -----                    image:               v6.0.0
                  denn du hast 6.0 , im neuen ist schon NodeJS16 drin und wird auch schon beim erstellen Tagesaktuell auf das aktuelle Nodejs16 upgraded.
                  Und wer weiß was du sonst nach nebenbei rumgeschraubt hast .
                  • GlasfaserG Glasfaser
                    -----                    image:               v6.0.0
                    reindeer-webR
                    reindeer-webR
                    reindeer-web
                    #79
                    @glasfaser
                    Vielen Dank an alle, die mir hier weitergeholfen haben.
                    Habe einen neuen docker mit v7 installiert und dann das backup eingepielt.
                    Dauert natürlich etwas, bis alle Adapter wieder geladen sind, aber dann hat alles funktioniert außer der Visualierung. Die ließ sich weder installieren noch starten.
                    Habe dann auf der Konsole mit
                    npm i iobroker.vis@1.4.6
                    eine ältere Version installiert, die sich dann auch updaten und wieder starten ließ.
                      @glasfaser
                      GlasfaserG
                      GlasfaserG
                      #80
                      @reindeer-web
                      Schön das du meinen Vorschlag gefolgt bist .
                      Das mit VIS ist bekannt und auch mit WS
                      https://forum.iobroker.net/topic/57443/gelöst-docker-updates-verschwinden-immer-wieder/39
                      und nebenbei
                      vermeide Befehle mit npm
                      nutze
                      iobroker install vis@1.4.6
                      84.1k
